  3. [Tutorial] Raspberry Pi NRF24l01 direct connection
raspberry pinrf24l01
56 Posts 32 Posters 94.6k Views 24 Watching
  • Roberto BrunialtiR
    Roberto BrunialtiR
    Roberto Brunialti
    wrote on last edited by Roberto Brunialti
    #23
    Ok. It seems the gateway is working as i get the same final screen when I run it. But... does it has a verbose mode? How can I know If it is working? I tried with a test node, unfortunately it seems not working ... or simply it does'nt give any feedback...
      minscof
      wrote on last edited by minscof
      #24
      I used this gateway on a wheezy debian (RPI2) for several months and everything was ok. I upgraded my raspbian to jessie, and then the CPU load was always 100%. So I try to revert to wheezy, but i have now the same problem : CPU stays at 100 % .
      So there must be a system configuration somewhere to improve this gateway and prevent it to use all the CPU.
      Do you have an idea ?
      **Solved **: see this post
      • D
        davy39
        I'm trying to setup a direct connection between domoticz and /dev/ttyMySensorsGateway
        Waiting for my hardware (no NRF24l01 attached yet), I'm actually playing around with the software part.
        I did install Domoticz and MySensorsGateway on the Pi and I'm getting a /dev/ttyMySensorsGateway symlink at boot time.
        The problem is that I can't see it on domoticz interface when trying to choose a serial port on "Mysensors gateway USB" device : only /dev/ttyAMA0 ....
        Is that because no NRF24 is connected or there is a specific configuration to make /dev/ttyMySensorsGateway appearing as a serial port (chown, udev ....)
        Thanks for your help
        • fetsF
          fetsF
          fets
          Hi everybody,
          I'm new in mysensors world and I would like to use my pi2 with direct connection to nrf24l01.
          There is a new release of the arduino library but I can't find the raspberry one.
          Somebody knows if it exists and where to find it ?
          I also tried to find an example of using raspberry as mqtt gateway without success, any ideabut was not able to find an example
            You could probably run the old one.
            Ideally I would like to have the same code-base for RPi but someone needs to help implement the HW-implementation-class.
            • fetsF
              fetsF
              fets
              Thanks hek, i'll try to use old code but I didn't find anything about raspberry as mqtt client gateway.
              If I succeed, and if not too late, i'll try to implement the new library
                If you do want to help out, have a look at the gateway-refactoring-branch. Opening up for different protocols over there (where MQTT should be one of them).
                https://github.com/mysensors/Arduino/tree/gateway-refactoring
                • Fernando ArconadaF
                  Fernando ArconadaF
                  Fernando Arconada
                  hi everybody
                  @hek are you going to support Rpi + rf24 direct connection? I were playing with https://github.com/mysensors/Raspberry a bit and works (I opened a pair of tickets) but needs to be updated.
                  I also think that PiGateway should support MQTT I have created PiGatewayMQTT (It's just a prototype).
                  What will be the future of https://github.com/mysensors/Raspberry repo? abandoned in favor of any kind of gateway-refactoring-branch ?
                  thanks
                  • J
                    J
                    jelluz
                    wrote on last edited by jelluz
                    #31
                    (solved)
                    Hi. Thanks a lot for this implentation and the helpful posts here!
                    I've got the gateway working with a tmp75 temperature sensor on an arduino. The nrf24 is sitting on the raspberry directly (CE pin 22), as a controller i'm using PiMatic. It works very nicely!
                    There is one small problem however. The PiGatewaySerial will only work if i have called PiGateway before (and closed it again). With working I mean picking up radio transmissions from my sensor node. Everything else seems normal (/dev/ttyPiGatewaySerial and radio details printout).
                    The details of both configurations might give a clue:
                    pi@raspberrypi ~/mysensors_rpi $ sudo ./PiGateway
                    Starting Gateway...
                    ================ SPI Configuration ================
                    CSN Pin          = CE0 (PI Hardware Driven)
                    CE Pin           = Custom GPIO25
                    Clock Speed      = 8 Mhz
                    ================ NRF Configuration ================
                    STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                    RX_ADDR_P0-1     = 0xa8a8e1fc00 0xa8a8e1fc00
                    RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                    TX_ADDR          = 0xe7e7e7e7e7
                    RX_PW_P0-6       = 0x20 0x20 0x20 0x00 0x00 0x00
                    EN_AA            = 0x3b
                    EN_RXADDR        = 0x06
                    RF_CH            = 0x4c
                    RF_SETUP         = 0x23
                    CONFIG           = 0x0e
                    DYNPD/FEATURE    = 0x3f 0x06
                    Data Rate        = 250KBPS
                    Model            = nRF24L01+
                    CRC Length       = 16 bits
                    PA Power         = PA_LOW
                    [CALLBACK]0;0;3;0;14;Gateway startup complete.
                    read: 4-4-0 s=0,c=1,t=0,pt=7,l=5:22.9
                    [CALLBACK]4;0;1;0;0;22.9
                    after closing PiGateway and opening PiGatewaySerial i get this:
                    pi@raspberrypi ~/mysensors_rpi $ sudo ./PiGatewaySerial
                    Starting PiGatewaySerial...
                    Protocol version - 1.4
                    Created PTY '/dev/pts/3'
                    Gateway tty: /dev/ttyMySensorsGateway
                    CE Pin           = Custom GPIO22
                    Clock Speed      = 8 Mhz
                    EN_AA            = 0x3b
                    EN_RXADDR        = 0x06
                    RF_CH            = 0x4c
                    RF_SETUP         = 0x23
                    CONFIG           = 0x0e
                    Data Rate        = 250KBPS
                    Model            = nRF24L01+
                    PA Power         = PA_LOW
                    read: 4-4-0 s=0,c=1,t=0,pt=7,l=5:22.8
                    Notice how the CE pins of both SPI configurations are different!
                    I'm at the point that i want to daemonize the gateway. Which in fact i did, but the same problem persists. Before i hack the startup script to first run and close PiGateway before PiGatewaySerial, i was hoping that someone has an idea what i'm doing wrong.
                    Thanks in advance!
                    solved!
                    I have two RPIs (a Pi 2 B and a Pi B+), which both worked with the pyRF24 lib of TMRh20, so when i had a look in the source of the radio initialization of PiGatewaySerial and found this:
                    #ifdef __PI_BPLUS
                    	gw = new MyGateway(RPI_BPLUS_GPIO_J8_15, RPI_BPLUS_GPIO_J8_24, BCM2835_SPI_SPEED_8MHZ, 1);
                    	gw = new MyGateway(RPI_V2_GPIO_P1_22, BCM2835_SPI_CS0, BCM2835_SPI_SPEED_8MHZ, 1);
                    When i changed it to:
                    #ifdef __PI_BPLUS
                    and recompiled the gateways,it all started to work. After powerup everything runs :).
                    The Rpi that is connected now is the Pi 2 B. So i guess either i have my nrf25 wired differently then defined in this lib, or the precompiler was thinking i have a B+ connected. Or both.
                    I will find out when i get this also working on my B+.
                    J 1 Reply Last reply
                    • E
                      E
                      ericvdb
                      Hi all,
                      I just followed the guide in the 1ste post, but i'm not able to compile this correctly.
                      Here's the output:
                      g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=arm        v6zk -D BCM2835_PERI_BASE=0x -c RF24.cpp
                      gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=arm        v6zk -D BCM2835_PERI_BASE=0x -c bcm2835.c
                      bcm2835.c: In function ‘bcm2835_init’:
                      bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
                      bcm2835.c:1208:28: error: invalid suffix "x" on integer constant
                      bcm2835.c:1209:28: error: invalid suffix "x" on integer constant
                      bcm2835.c:1210:28: error: invalid suffix "x" on integer constant
                      bcm2835.c:1211:28: error: invalid suffix "x" on integer constant
                      bcm2835.c:1212:28: error: invalid suffix "x" on integer constant
                      bcm2835.c:1213:28: error: invalid suffix "x" on integer constant
                      bcm2835.c:1214:28: error: invalid suffix "x" on integer constant
                      bcm2835.c:1228:83: error: invalid suffix "x" on integer constant
                      bcm2835.c:1232:81: error: invalid suffix "x" on integer constant
                      bcm2835.c:1236:81: error: invalid suffix "x" on integer constant
                      bcm2835.c:1239:83: error: invalid suffix "x" on integer constant
                      bcm2835.c:1242:83: error: invalid suffix "x" on integer constant
                      bcm2835.c:1246:83: error: invalid suffix "x" on integer constant
                      bcm2835.c:1249:83: error: invalid suffix "x" on integer constant
                      bcm2835.c:1253:79: error: invalid suffix "x" on integer constant
                      Makefile:52: recept voor doel 'bcm2835.o' is mislukt
                      make: *** [bcm2835.o] Fout 1
                      g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -Ilibrf24-bcm/
                      g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -Ilibrf24-bcm/
                      g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -Ilibrf24-bcm/
                      g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -Ilibrf24-bcm/
                      g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -Ilibrf24-bcm/
                      g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=ar        mv6zk -I. -Ilibrf24-bcm/ -lrf24-bcm
                      /usr/bin/ld: cannot find -lrf24-bcm
                      collect2: ld returned 1 exit status
                      Makefile:60: recept voor doel 'PiGateway' is mislukt
                      make: *** [PiGateway] Fout 1
                      Done!
                      I'm using the 2015-05-05-raspbian-wheezy version complete with:
                      rpi-update
                      apt-get update
                      apt-get upgrade
                      Can anyone tell me what is going wrong.
                      Thx in advance.
                      • E
                        E
                        ericvdb
                        I got it working, and by adding ser2net in the mix, you have a MySensors raspberry pi ethernet gateway.
                        The trick is not to update the RPi, just use the latest image.
                        Does anyone know if it is possible to connect the status LEDs to the RPi?
                        • AndurilA
                          AndurilA
                          Anduril
                          Hi @ericvdb ,
                          could you please post your config for ser2net? I also tried to use my NRF24L01 connected to my RPi as ethernet gateway for MYSController, but all I got was an 'unable to bind port'.
                          • E
                            E
                            ericvdb
                            in /etc/ser2net.conf i used:
                            9003:raw:600:/dev/ttyMySensorsGateway
                            where 9003 is the tcp port your controller needs to connect to.
                            Remember, this allows only 1 connection, so if you want to play with multiple controllers, you can, however 1 at a time.
                            • AndurilA
                              AndurilA
                              Anduril
                              Don't see any difference to my old entry... but pasted yours and now it works. Thank you very much @ericvdb
                              • E
                                E
                                ericvdb
                                you're welcome ;)
                                • Vladut GrecuV Vladut Grecu
                                  [EDIT] - I uploaded a script in the next post that does everything I explained below
                                  I have installed MINImal raspBIAN which is a raspBIAN without a gui. So this should work for you guys.
                                  First of all you have to
                                  1. Undo your Overclock. If you have any. (SPI does not like Overclocked pi's)
                                  2. Enable SPI
                                  Details:
                                  On a normal raspbian image this can be done either on a fresh install (when you config your pi) or you can type in terminal sudo raspi-config
                                  From there you go into ADVANCED OPTIONS -> SPI
                                  On a minimal image you don't have the luxury of raspi-config. You have to manually activate it.
                                  (I already had it enabled but you can check)
                                  (If you don't have sudo installed on your image just run apt-get install sudo)
                                  sudo nano /etc/modprobe.d/raspi-blacklist.conf
                                  Make sure there IS a # before blacklist spi-bcm2708, so it looks like this…
                                  #blacklist spi-bcm2708
                                  If there is no line like that, you can add it. It won't do any harm.
                                  CTRL+O - Save
                                  ENTER - Confirm
                                  CTRL+X - Exit
                                  or
                                  CTRL+X - Exit
                                  y - I want to save the file
                                  ENTER - Confirm
                                  We have to edit now the config.txt.
                                  sudo nano /boot/config.txt
                                  add this to the end of the line
                                  dtparam=spi=on
                                  Save and exit.
                                  Reboot your pi.
                                  sudo reboot
                                  Enjoy using SPI. (Source)
                                  3.Downloading the files
                                  Details:
                                  You have 2 options. wget and git-clone. I'll start with:
                                  a. git-clone
                                  If you don't have git-clone you need to install the git tools. (Yes, git is related to github)
                                  sudo apt-get install git
                                  After you installed git you simply navigate to the folder that you wish to install the program and type:
                                  sudo git-clone https://github.com/mysensors/Raspberry.git
                                  This will download a zip, unarchive it and.. It does all the jobs for you.
                                  b. wget
                                  Some ppl are old-school and go the hard way or they just enjoy it done this way.
                                  Navigate to the folder that you wish to install the program and type:
                                  wget https://github.com/mysensors/Raspberry/archive/master.zip (this will download you the zip)
                                  Unzip the file
                                  If you don't have unzip installed just type
                                  sudo apt-get install unzip
                                  unzip master.zip -d /home/pi/Raspberry (you can specify any directory that you want instead of the /home/pi/Raspberry)
                                  4.Edit and compile what you downloaded
                                  In the Raspberry folder you have some files and some folders.
                                  The majority of ppl (including me) forget to complile the libs for the NRF24l01.
                                  This is the library provided by [TMRH20]{http://tmrh20.github.io} (He has some interesting stuff there including an audio library for NRF24l01.)
                                  Back to our stuff.
                                  Go to the Raspberry folder then into librf24-bcm.
                                  cd Raspberry/librf24-bcm/
                                  Type
                                  make
                                  Go back to the Raspberry folder
                                  cd ..
                                  Type
                                  make
                                  5.Connecting the NRF
                                  Mister TMRH20 tells us that we need to connect the NRF24l01 this way
                                  PIN		NRF24L01	RPI				RPi -P1 Connector
                                  1		GND			rpi-gnd			(25)
                                  2		VCC			rpi-3v3			(17)
                                  3		CE			rpi-gpio22		(15)
                                  4		CSN			rpi-gpio8		(24)
                                  5		SCK			rpi-sckl		(23)
                                  6		MOSI		rpi-mosi		(19)
                                  7		MISO		rpi-miso		(21)
                                  8		IRQ			Not Connected
                                  Connect everything like that except for the CE pin
                                  Run the PiGatewaySerial
                                  ./PiGatewaySerial
                                  It shoud prin something like this:
                                  Created PTY '/dev/pts/1'
                                  Clock Speed      = 8 Mhz
                                  RX_ADDR_P0-1     = 0xe7e7e7e7e7 0xc2c2c2c2c2
                                  RX_PW_P0-6       = 0x00 0x00 0x20 0x00 0x00 0x00
                                  EN_AA            = 0x3b
                                  EN_RXADDR        = 0x07
                                  RF_CH            = 0x10
                                  RF_SETUP         = 0x23
                                  CONFIG           = 0x0e
                                  Data Rate        = 250KBPS
                                  Model            = nRF24L01+
                                  PA Power         = PA_LOW
                                  Look at line 7 CE Pin = Custom GPIO25
                                  Connect the CE pin where it says you should.
                                  Here are some pictures with the GPIO connector on the rPi.
                                  https://www.google.ro/search?q=raspberry+pi+gpio&tbm=isch
                                  G
                                  G
                                  GrantsPi
                                  @Vladut-Grecu - Thanks very much for the tutorial!! After a bit of trial and error I was able to get the Pi reading my two nodes with very good reliability.
                                  I'm now trying to merge this RPi Direct Connection with the openHab With Serial Gateway that TimO was kind enough to post (http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway). I had openHab working well on the RPi using an Arduino nano serial gateway using that tutorial.
                                  Running PiGatewaySerial in a terminal window yields the proper readings from the Arduino nodes but when I try to have openHab recognize the serial port "/dev/ttyMySensorsGateway" instead of the "/dev/ttyUSB99@115200" used in the openHab tutorial I get messages from openHab saying it could not open serial port '/dev/ttyMySensorsGateway'...
                                  Just wondering if anyone else has tried to marry the two projects or has any suggestions. (Perhaps I should also post this in TimO's openHab thread...)
                                  • R
                                    R
                                    revoltec112
                                    upload-3f496795-4ae3-4ed2-b533-3f5e9fd6283e
                                    Hi I am a beginner
                                    If I have something that's ok , I plugged in humidity and temperature sensor , and for what I have in front of ./PiGatewaySerial enter sudo ? ,
                                    how to make the data visible in Domoticz please help
                                    • R
                                      R
                                      revoltec112
                                      whether in the / dev file must be named ttyMySensorsGeteway ? if so how it developed and what it should contain
                                      • Daniel OliveiraD
                                        Daniel OliveiraD
                                        Daniel Oliveira
                                        Hi @hek
                                        I know that a lot if going on regarding the MySensors 1.6 but I would like to know the plans for the repo mysensors/Raspberry?
                                        Is there any plans to keep developing it of merging it with the main libraries?
                                        I would like to be able to run the latest version on my Pi and I'm more than willing to help making it possible :)
                                        MySensors rules my home :)
                                          Hi @Daniel-Oliveira,
                                          I've talked with @Anticimex and @thozza about it... We think it would be best to move the RPi build file and any eventual support libs into the main MySensors repo to keep it in sync with the rest .
                                          Not sure if @thozza has begun working on some autoconf script or not (did you?). But I imagine he'd appreciate any help you can contribute with.
