  3. Problem with ID_REQUEST
21 Posts 6 Posters 7.8k Views 3 Watching
  • T
    Tang
    The ack set to 1 was just a test. I tryed first with 0
    So no idea of my problem ... :S
    • T
      Tang
      I just tryed with new gateway and development branch and same result...
      I reverted back to 1.4.2 without problem. The sensor sends its ID_REQUEST, my controller sends the reply and startup is complete.
      I suppose there is something new in 1.5 that is not correct.
      SparkmanS 1 Reply Last reply
      • T Tang
        SparkmanS
        SparkmanS
        Sparkman
        @Tang Which controller are you using? I've added new nodes under 1.5 and it worked fine for me with the controller I have (HomeSeer).
        Al
        • SparkmanS Sparkman
          Al
          Tang
          wrote on last edited by Tang
          @Sparkman I'm using agocontrol. I'm developping mysensors module.
          The problem is my controller seems to have the good behaviour but the gateway does nothing.
          Like Hek said it's like the frame is lost during serial transfer, but I have doubt about it.
          A downgrade of my gateway to 1.4.2 version fixes the problem. My controller sends exactly the same frame (SENDING: 255;255;3;0;4;2)
          015-Aug-19 11:22:48.806905 [DEBUG]  => 09:22:48 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
          2015-Aug-19 11:22:48.808057 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:22:48.808084 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:48.808113 [DEBUG]  => 09:22:48 2015/08/19 RECEIVING: 255/255;INTERNAL;0;I_ID_REQUEST;
          2015-Aug-19 11:22:48.808276 [DEBUG] Free id found: 2
          2015-Aug-19 11:22:48.808354 [DEBUG]  => SENDING: 255;255;3;0;4;2
          2015-Aug-19 11:22:48.853276 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:22:48.853309 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:48.853338 [DEBUG]  => 09:22:48 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;send: 0-0-255-255 s=255,c=3,t=4,pt=0,l=1,st=fail:2
          2015-Aug-19 11:22:48.857694 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:22:48.857715 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:48.857745 [DEBUG]  => 09:22:48 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 2-2-0 s=255,c=0,t=17,pt=0,l=5:1.4.2
          2015-Aug-19 11:22:48.859906 [TRACE] Use protocol version found in current message
          2015-Aug-19 11:22:48.859925 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:48.859952 [DEBUG]  => 09:22:48 2015/08/19 RECEIVING: 2/255;PRESENTATION;0;S_ARDUINO_NODE;1.4.2
          2015-Aug-19 11:22:48.859976 [WARNING] PRESENTATION subtype '17' not supported (protocol v1.4)
          2015-Aug-19 11:22:48.864316 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:22:48.864336 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:48.864363 [DEBUG]  => 09:22:48 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1:0
          2015-Aug-19 11:22:48.864452 [TRACE] protocol found:
          2015-Aug-19 11:22:48.864480 [DEBUG]  => 09:22:48 2015/08/19 RECEIVING: 2/255;INTERNAL;0;I_CONFIG;0
          2015-Aug-19 11:22:48.864499 [WARNING] Error: no protocol version found for this message, drop it
          2015-Aug-19 11:22:50.814719 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:22:50.814794 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:50.814827 [DEBUG]  => 09:22:50 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 2-2-0 s=255,c=0,t=17,pt=0,l=5:1.4.2
          2015-Aug-19 11:22:50.816996 [TRACE] Use protocol version found in current message
          2015-Aug-19 11:22:50.817017 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:50.817044 [DEBUG]  => 09:22:50 2015/08/19 RECEIVING: 2/255;PRESENTATION;0;S_ARDUINO_NODE;1.4.2
          2015-Aug-19 11:22:50.817067 [WARNING] PRESENTATION subtype '17' not supported (protocol v1.4)
          2015-Aug-19 11:22:50.821411 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:22:50.821432 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:50.821460 [DEBUG]  => 09:22:50 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1:0
          2015-Aug-19 11:22:50.822611 [TRACE] protocol found:
          2015-Aug-19 11:22:50.822640 [DEBUG]  => 09:22:50 2015/08/19 RECEIVING: 2/255;INTERNAL;0;I_CONFIG;0
          2015-Aug-19 11:22:50.822660 [WARNING] Error: no protocol version found for this message, drop it
          2015-Aug-19 11:22:52.827945 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:22:52.828028 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:52.828060 [DEBUG]  => 09:22:52 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 2-2-0 s=255,c=3,t=11,pt=0,l=18:Temperature Sensor
          2015-Aug-19 11:22:52.830376 [TRACE] protocol found:
          2015-Aug-19 11:22:52.830412 [DEBUG]  => 09:22:52 2015/08/19 RECEIVING: 2/255;INTERNAL;0;I_SKETCH_NAME;Temperature Sensor
          2015-Aug-19 11:22:52.830433 [WARNING] Error: no protocol version found for this message, drop it
          2015-Aug-19 11:22:52.834780 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:22:52.834802 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:52.834830 [DEBUG]  => 09:22:52 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3:1.0
          2015-Aug-19 11:22:52.837054 [TRACE] protocol found:
          2015-Aug-19 11:22:52.837086 [DEBUG]  => 09:22:52 2015/08/19 RECEIVING: 2/255;INTERNAL;0;I_SKETCH_VERSION;1.0
          2015-Aug-19 11:22:52.837115 [WARNING] Error: no protocol version found for this message, drop it
          2015-Aug-19 11:22:52.840755 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:22:52.840783 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:52.840811 [DEBUG]  => 09:22:52 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 2-2-0 s=0,c=0,t=6,pt=0,l=0:
          2015-Aug-19 11:22:52.841915 [TRACE] protocol found:
          2015-Aug-19 11:22:52.841945 [DEBUG]  => 09:22:52 2015/08/19 RECEIVING: 2/0;PRESENTATION;0;S_TEMP;
          2015-Aug-19 11:22:52.841965 [WARNING] Error: no protocol version found for this message, drop it
          2015-Aug-19 11:22:53.729763 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:22:53.729837 [TRACE] protocol found: 1.4.2
          2015-Aug-19 11:22:53.729869 [DEBUG]  => 09:22:53 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 2-2-0 s=0,c=1,t=0,pt=7,l=5:26.9
          2015-Aug-19 11:22:53.731027 [TRACE] protocol found:
          2015-Aug-19 11:22:53.731058 [DEBUG]  => 09:22:53 2015/08/19 RECEIVING: 2/0;SET;0;V_TEMP;26.9
          While I have it on 1.5
          2015-Aug-19 11:17:24.437051 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:17:24.437124 [TRACE] protocol found: 1.5
          2015-Aug-19 11:17:24.437157 [DEBUG]  => 09:17:24 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
          2015-Aug-19 11:17:24.437250 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:17:24.437269 [TRACE] protocol found: 1.5
          2015-Aug-19 11:17:24.437298 [DEBUG]  => 09:17:24 2015/08/19 RECEIVING: 255/255;INTERNAL;0;I_ID_REQUEST;
          2015-Aug-19 11:17:24.437464 [DEBUG] Free id found: 2
          2015-Aug-19 11:17:24.437540 [DEBUG]  => SENDING: 255;255;3;0;4;2
          2015-Aug-19 11:17:26.448202 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:17:26.448284 [TRACE] protocol found: 1.5
          2015-Aug-19 11:17:26.448316 [DEBUG]  => 09:17:26 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
          2015-Aug-19 11:17:26.449473 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:17:26.449494 [TRACE] protocol found: 1.5
          2015-Aug-19 11:17:26.449524 [DEBUG]  => 09:17:26 2015/08/19 RECEIVING: 255/255;INTERNAL;0;I_ID_REQUEST;
          2015-Aug-19 11:17:26.449689 [DEBUG] Free id found: 2
          2015-Aug-19 11:17:26.449765 [DEBUG]  => SENDING: 255;255;3;0;4;2
          2015-Aug-19 11:17:28.455924 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:17:28.456006 [TRACE] protocol found: 1.5
          2015-Aug-19 11:17:28.456039 [DEBUG]  => 09:17:28 2015/08/19 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
          2015-Aug-19 11:17:28.457196 [TRACE] Use protocol version of gateway (gateway or broadcast message)
          2015-Aug-19 11:17:28.457217 [TRACE] protocol found: 1.5
          2015-Aug-19 11:17:28.457245 [DEBUG]  => 09:17:28 2015/08/19 RECEIVING: 255/255;INTERNAL;0;I_ID_REQUEST;
          2015-Aug-19 11:17:28.457409 [DEBUG] Free id found: 2
          2015-Aug-19 11:17:28.457485 [DEBUG]  => SENDING: 255;255;3;0;4;2
          As you can see on sample above, on 1.4.2 the id is requested only once ("Free id found...")and all other mysensors stuff is normal while on 1.5 the sensor always requesting an id.
          The code is quite the same between 1.4.X and 1.5 protocol handling and there is absolutely no difference between ID_REQUEST on 1.4.X and 1.5. Both of functions are using the same code to send data to gateway.
          In view of those outputs, I don't know how to investigate more on my controller side... but good to know it works on other controller ;)
          Maybe somebody has a manual procedure using an external tool and tell me how to test it :p
            Weird, sure that id-response adds a newline?
            Does it work if you just hook up your gateway to the Arduino IDE Serial Monitor? And reply to the id-request over there (remember to turn on newline/carriage return).
            • T
              Tang
              I tryed with arduino IDE with "Both NL & CR" activated and the sensors received a new ID.
              Here is full output of gateway:
              0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
              255;255;3;0;3;
              0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=4,pt=0,l=1,st=fail:2
              0;0;3;0;9;read: 2-2-0 s=255,c=0,t=17,pt=0,l=3:1.5
              2;255;0;0;17;1.5
              0;0;3;0;9;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1:0
              2;255;3;0;6;0
              2;255;0;0;17;1.5
              2;255;3;0;6;0
              0;0;3;0;9;read: 2-2-0 s=255,c=3,t=11,pt=0,l=18:Temperature Sensor
              2;255;3;0;11;Temperature Sensor
              0;0;3;0;9;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3:1.1
              2;255;3;0;12;1.1
              0;0;3;0;9;read: 2-2-0 s=0,c=0,t=6,pt=0,l=0:
              2;0;0;0;6;
              0;0;3;0;9;read: 2-2-0 s=0,c=1,t=0,pt=7,l=5:26.2
              2;0;1;0;0;26.2
              I will try tomorrow to update my controller sending \n\r at end of command.
              Until now it seems my controller doesn't send it. Is it something new in 1.5 protocol to handle \n\r as end of command or it is a lack of my controller since the beginning?
                I cannot recall changing anything about how this is handled between 1.4->1.5.
                • T
                  Tang
                  Adding NL+CR to sent command fixed my problem.
                  Weird everything worked before 1.5. Anyway no problem now :D
                  Thank you for your help guys ;-)
                  bjacobseB 1 Reply Last reply
                  • T Tang
                    bjacobseB
                    bjacobseB
                    bjacobse
                    @Tang Does this means that you will update some code in Agocontrol?
                    I also uses Agocontrol and have upgraded mysensors to ver 1.5, and I'm not able to add new sensors
                    • bjacobseB bjacobse
                      Tang
                      @bjacobse yes i'm working on it
                      I just need to fix some stuff on actuator and it should be good
                      • T Tang
                        bjacobseB
                        bjacobseB
                        bjacobse
                        @Tang Perfect,
                        Let me know if I can do some testing/verification for you
                          @Tang Perfect,
                          Tang
                          @bjacobse said:
                          @Tang Perfect,
                          I commited my stuff. You can make a try and tell me all bugs you found ;-)
                          Please use irc now. Thx
                          • bjacobseB
                            bjacobseB
                            bjacobse
                            Thank you Tang, works perfekt now
