  3. Extending range of regular nRF24L01+
28 Posts 10 Posters 28.3k Views 8 Watching
  • Y Offline
    Y Offline
    I ran into this article: http://www.instructables.com/id/Enhanced-NRF24L01/?ALLSTEPS
    It shows how to improve range of a regular nRF24L01+ module by adding a simpel DIY dipole antenna to it:
    This guy uses an even simpler solution:
    https://youtu.be/NpMnauHeR7Y
    I haven't tried it myself, but it might come in handy for those of you experiencing range issues.
    • S Offline
      Hihi isnt this "other guy " @petewill ?
      http://forum.mysensors.org/topic/775/8-lamp-outlet-smart-plug-module/64#
      Y P 2 Replies Last reply
      • S sundberg84
        Y Offline
        Y Offline
        @sundberg84 Hehe, good finding :+1: Or he might have identical hands as 'the other guy' :metal:
        I ran into this video on Hackaday and thought
        it would be nice to share it with you guys... :sob:
        • N Offline
          N Offline
          That last comment on Hackaday was interesting: "There is another way to extend radio range, and you don’t need additional hardware, just some heavy error correction code. We implemented a LDPC (Low density parity check code) on a cortex m3 with a 2.4 Ghz ISM band chip in one of our projects, with very good results."
          Anyone try that?
          Y 1 Reply Last reply
          • N NeverDie
            Anyone try that?
            Y Offline
            Y Offline
            @NeverDie then you need to implement error recovery instead of detection only.
            Any errors corrupting the header of the nrf packet will not be recoverable anyhow (unless you continuously run it in some sort of sniffer mode, but you don't want that...)
            • N Offline
              N Offline
              Regarding the antenna mod, then, does it somehow increase efficiency and thereby increase the effective power of the transmission, or does it merely make it more directional?
              • N NeverDie
                Y Offline
                Y Offline
                @NeverDie poddibly both, and make it more sensitive when receiving.
                • T Offline
                  T Offline
                  tbowmo
                  The antenna will have a certain gain, depending on how it's made, this will be added in both directions (TX/RX). The better antenna you make, the better radio coverage you'll get.
                  One caveat to making them yourself, is that it has to match the impedance of the radio input, otherwise you'll get into troubles with standing waves that will "destroy" your transmitter / receiver.
                  • S sundberg84
                    P Offline
                    P Offline
                    petewill
                    Haha! Well, I've definitely been called worse things than "other guy"... :)
                    Cool, my video made it on to hackaday! I use this cheap hack all over my house with definite improvement. Like the site says, not the most "technically sound" but it definitely works for me.
                    N 1 Reply Last reply
                    • P petewill
                      N Offline
                      N Offline
                      Roughly how much improvement would you say? 2x the range, or more like or 50% or less improvement?
                      P 1 Reply Last reply
                      • N NeverDie
                        P Offline
                        P Offline
                        petewill
                        @NeverDie Hard to say really. I haven't done any sort of range testing other than placing nodes around my house. I had nodes that were maybe 50 ft and 6 walls away from the gateway that wouldn't communicate at all and when I put in the antenna they communicate every time. I usually suggest that if you're having issues you give this a try since it's easy, cheap and reversible if it doesn't work.
                        Maybe some day I'll get around to testing the range but for now I'm using all my spare time to make new sensors :)
                        • S Offline
                          ssrini2
                          petewill:
                          Do we need cat5? Will any cable do?
                          Also do i need to have this antenna at both the tx and rx? Thanks for your cool video! Will try it and report my observations. We've got concrete walls in India.. I am hoping the range is still alright
                          • S ssrini2
                            petewill:
                            P Offline
                            P Offline
                            petewill
                            @ssrini2 I have only used cat5/cat6 cable but other wire may work. The stuff I use is solid copper (not stranded). There are many different examples out there of what can help but I have always used the method from my video. I would do some experimenting to see what works best for you. With concrete walls you may find that you want to turn on the repeating functionality on some of your MySensors devices.
                            • S Offline
                              ssrini2
                              It worked quite well with solid copper wire across concrete. Much appreciated. Thanks. I am now trying to see if there is a smaller length that could suffice for my experiments. Any thoughts on that? Is there a smaller wavelength wire that could suffice? Anway I will post in this forum the lengths that worked for me. Cheers!
                              • S ssrini2
                                P Offline
                                P Offline
                                petewill
                                @ssrini2 There are specific lengths that will work. I used an antenna calculator to find the length I used. I can't remember where I found it but I think a quick google search should work.
                                  Hi guys, I tried the single wire mod but without any noticeable improvement: with a single wall in between I can't go more than 5 mt or I start getting NACK messages. I'll have to try the dipole or my radio modules are crap (as I always suspected)
                                    N Offline
                                    N Offline
                                    @gohan said in Extending range of regular nRF24L01+:
                                    Have you first checked your power source ?
                                    Did you put a capacitor big enough and as close as possible to the VCC/GND pins of the radio module ?
                                      Yes, I'm using both adapters with voltage regulator and caps or 3v from the mega 2560 plus 100uf cap. I suspect the modules because they were very cheap. I'm waiting for the PA to arrive and meanwhile I was just trying to play around with the ones I got.
                                        N Offline
                                        N Offline
                                        @gohan yes then it sounds like bad modules, that extra dollar for a lot of 10 modules often make a lot of difference in quality ;)
                                          The problem is being lucky enough to get working ones. Let's see with dipole if something changes.
                                          12.1k
