  3. change pin 12 assignment
21 Posts 5 Posters 7.4k Views 3 Watching
  • S Offline
    s3bb0
    wrote on last edited by s3bb0
    hello,
    i use a pro mini and the nrf24+.
    my pin12 is broken, so i want to set it to pin5, but i can´t find the pin assignment for this.
    i found in nrf24_con.h:
    but initial it should be 12, so i´m confused.
    can anybody help me please?
    • E Offline
      E Offline
      ericvdb
      Pin 16 is analog pin 2. Analog pins can also be used as digital pins.
      A0 = 14
      A1 = 15
      A2 = 16
      A3 = 17
      A4 = 18
      A5 = 19
      And btw, are you asking this for a gateway device or a sensor device?
      • S Offline
        s3bb0
        thank you verry much,
        i´m asking for a sensordevice.
        im already using other sensor devices with pin12 (default-sketches).
        now i was searching for a code where is pin 12 assigned, but i couldn´t find it.
        do you know where pin 12 is assigned?
        • S Offline
          Sparkman
          wrote on last edited by Sparkman
          By default SOFTSPI is disabled. Edit your MyConfig.h file to enable SOFTSPI and the pin assignments: https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyConfig.h#L123
          Al
          • S Offline
            s3bb0
            thank you, but where is the original pin 12 assignment ?
            i don´t want to use softspi, just change the default pin12 to pin 5
            S 1 Reply Last reply
            • S s3bb0
              Sparkman
              @s3bb0 Pin 12 is the MISO pin which from what I understand, hard-coded in the inner workings of the Atmel chip and Arduino libraries, not the MySensors libraries, so you may have to use SOFTSPI to get this working. @hek, can you confirm?
              Al
              • S Offline
                s3bb0
                in pins_arduino.h i found the pin 12 but changeing it brings no result.
                thanks @Sparkman ok but if i try this to comment that part in, i get a error on compiling:
                Arduino: 1.6.4 (Mac OS X), Platine: "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
                Verwende die Bibliothek SPI im Ordner: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI
                Verwende die Bibliothek MySensors im Ordner: /Users/..../Documents/Arduino/libraries/MySensors (legacy)
                /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -Wextra -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10604 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI -I/Users//Documents/Arduino/libraries/MySensors /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build3964050026628109026.tmp/final_AnalogSoilMoistSensor.cpp -o /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build3964050026628109026.tmp/final_AnalogSoilMoistSensor.cpp.o
                In file included from /Users/
                /Documents/Arduino/libraries/MySensors/MyTransportNRF24.h:26:0,
                from /Users//Documents/Arduino/libraries/MySensors/MySensor.h:28,
                from final_AnalogSoilMoistSensor.ino:2:
                /Users/
                /Documents/Arduino/libraries/MySensors/utility/RF24.h:20:23: fatal error: DigitalIO.h: No such file or directory
                #include <DigitalIO.h>
                compilation terminated.
                Fehler beim Kompilieren.
                • S s3bb0
                  /Users/
                  Sparkman
                  @s3bb0 Are you using the 1.5 libraries or 1.4?
                  • S Offline
                    s3bb0
                    first 1.4 but now i tried 1.5.
                    • A Offline
                      A Offline
                      Anticimex
                      SOFTSPI is a software implementation of the SPI protocol which permits the use of any digital IO for use in the SPI bus.
                      If you are not using SOFTSPI, you use HW accelerated SPI, and that means you are bound to the specific pins on the MCU that has this capability. You cannot choose which pin to use in this case.
                      • S Offline
                        s3bb0
                        ah ok, now i understand this :)
                        ok, how can i use softspi and deaktivate the HWSPI ?
                        as a said , commenting in the line for softspi results in an error
                        • E Offline
                          E Offline
                          ericvdb
                          in RF24_config.h change
                            //#define SOFTSPI   // Requires library from https://github.com/greiman/DigitalIO
                          to
                          And put DgitalIO into Documents/Arduino (download from the link provided)
                          • S Offline
                            Sparkman
                            DigitialIO is included with the MySensors libraries and should not need to be downloaded separately. @hek and @Anticimex, it looks like there are two places to uncomment the #define SOFTSPI line: RF24_config.h and MyConfig.h. Can you confirm where this should be done or does it not matter? @s3bb0 did you delete all of the 1.4 files before copying in the 1.5 ones and then restart the IDE?
                            Al
                            A 1 Reply Last reply
                            • S Sparkman
                              Al
                              A Offline
                              A Offline
                              Anticimex
                              @Sparkman sorry, I have only used hw SPI. So I am not very familiar with the settings for soft SPI.
                              • H Offline
                                H Offline
                                You should only need to uncomment it in MyConfig.h
                                • S Offline
                                  s3bb0
                                  i tried to change it in MyConfig.h and installed 1.5 and even 1.4 again but still errors....
                                  var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/PinIO.cpp.o: In function PinIO::begin(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/PinIO.cpp:43: multiple definition of PinIO::begin(unsigned char)'
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/PinIO.cpp.o:/Users/..../Documents/Arduino/libraries/MySensors/PinIO.cpp:43: first defined here
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/PinIO.cpp.o: In function PinIO::begin(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/PinIO.cpp:43: multiple definition of PinIO::PinIO(unsigned char)'
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/PinIO.cpp.o: In function PinIO::begin(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/PinIO.cpp:43: multiple definition of PinIO::config(bool, bool)'
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In function SoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition of SoftI2cMaster::read(unsigned char)'
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/SoftI2cMaster.cpp.o:/Users/..../Documents/Arduino/libraries/MySensors/SoftI2cMaster.cpp:160: first defined here
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In function SoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition of SoftI2cMaster::start()'
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/SoftI2cMaster.cpp.o:/Users/..../Documents/Arduino/libraries/MySensors/SoftI2cMaster.h:136: first defined here
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In function SoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition of SoftI2cMaster::stop()'
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In function SoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition of SoftI2cMaster::write(unsigned char)'
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In function SoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition of I2cMasterBase::transferContinue(void*, unsigned int, unsigned char)'
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In function SoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition of I2cMasterBase::transfer(unsigned char, void*, unsigned int, unsigned char)'
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In function SoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition of SoftI2cMaster::begin(unsigned char, unsigned char)'
                                  /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp/MySensors/utility/SoftI2cMaster.cpp.o: In function SoftI2cMaster::read(unsigned char)': /Users/..../Documents/Arduino/libraries/MySensors/utility/SoftI2cMaster.cpp:160: multiple definition of SoftI2cMaster::SoftI2cMaster(unsigned char, unsigned char)'
                                  collect2: error: ld returned 1 exit status
                                  • S s3bb0
                                    Sparkman
                                    @s3bb0 Looks like you may have multiple copies of the libraries or both 1.4 an 1.5 installed at the same time. Make sure you delete all the libraries before installing the new ones.
                                    Al
                                    • S Offline
                                      s3bb0
                                      • A Offline
                                        A Offline
                                        Anticimex
                                        You probably need to purge your temp folder as well. The Arduino IDE is stupid and might believe it can re-use old build artifacts. (/var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build4313290786347724905.tmp)
                                        • S Offline
                                          s3bb0
                                          thank you all, but its still the problem.
                                          i deleted everything, even the temporary files.
                                          i installed everything (arduinoIDE + mysensors 1.5). everythin works until i comment the softSPI in.
                                          then it reports: the DigitalIO.h error-.
                                          Arduino: 1.6.5 (Mac OS X), Platine: "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
                                          Verwende die Bibliothek MySensors im Ordner: /Users/-------/ArduinoNEW/libraries/MySensors (legacy)
                                          /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -Wextra -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10605 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI -I/Users/----/ArduinoNEW/libraries/MySensors /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build8452403048590699508.tmp/LightSensor.cpp -o /var/folders/ts/_xf3xpf1769419gyjrkmv7yc0000gn/T/build8452403048590699508.tmp/LightSensor.cpp.o
                                          In file included from /Users/-----/ArduinoNEW/libraries/MySensors/MyTransportNRF24.h:26:0,
                                          from /Users/----/ArduinoNEW/libraries/MySensors/MySensor.h:28,
                                          from LightSensor.ino:30:
                                          /Users/----/ArduinoNEW/libraries/MySensors/utility/RF24.h:20:23: fatal error: DigitalIO.h: No such file or directory
                                          then i checked /Users/----/ArduinoNEW/libraries/ AND
                                          /Users/----/ArduinoNEW/libraries/DigitalIO/
                                          for the DigitalIO.h ==> IN BOTH EXISTS DigitalIO.h because i copied it for testing.
                                          that is so strange ... :(
                                          12.1k
