  3. Help with combination DHT and Relay
10 Posts 4 Posters 5.0k Views 2 Watching
  • P
    P
    punter9
    Hey I am building up a useful mysensors network around my apartment and could use a helping hand. I have several single purpose setups going (relay, dht, moisture, etc) but I would really like to learn to roll them together. My first attempt is for a DHT and relay. I have combined the code but I am getting radio init error in the serial monitor. Could someone lend an eye to help me learn this? Thanks in advance!
    /** combo mysensors - DHT11/22 and Single Relay
     *   * The MySensors Arduino library handles the wireless radio link and protocol
     *  Humidity
     *   * REVISION HISTORY
     * Version 1.0 - Henrik EKblad
     * This sketch provides an example how to implement a humidity/temperature
     * sensor using DHT11/DHT-22
     * Relay
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to control physical relays.
     * This example will remember relay state after power failure.
     * http://www.mysensors.org/build/relay
     * INCLUSIONS
     * Humidity
     * Relay
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
     * DEFINE
     * Humidity
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
     * Relay
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
     * RADIO - I THINK
     * Relay
    MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
    //MyTransportRFM69 radio;
    // Message signing driver (none default)
    //MySigningNone signer;
    // Select AtMega328 hardware profile
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
     * Humidity
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
     * VOID SETUP
     * Humidity
    gw.begin();
      gw.sendSketchInfo("Humidity", "1.0");
     * Relay
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
     * VOID LOOP
     * Humidity
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
     * Relay
     * INCOMING MESSAGE RELAY ONLY
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    • BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @punter9
      a little advice...
      comments seem really helpful for beginners, but believe me you will look to lose as much of that as possible once you really learn this stuff.
      put what I did (untested) side-by-side with your code and look for the critical differences in the setup() function.
      #define CHILD_ID_RELAY 2
      #define RELAY_PIN 4
      //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
      MyHwATMega328 hw;
      DHT dht;
      float lastTemp;
      float lastHum;
        gw.sendSketchInfo("Combo", "1.0");
        gw.present(CHILD_ID_RELAY, S_LIGHT);
        pinMode(RELAY_PIN, OUTPUT);
        digitalWrite(RELAY_PIN, gw.loadState(1) ? RELAY_ON : RELAY_OFF);
          if (!metric)
          lastHum = humidity;
        if (message.type == V_LIGHT)
          digitalWrite(RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
          gw.saveState(1, message.getBool());
      @hek
      folks trying to extend that multi-relay sketch always seem to have issues. Perhaps a better executed extensible sketch is in order!
      hekH 1 Reply Last reply
      • P
        P
        punter9
        Thanks! right off the bat I am seeing this being added
        and this instead of each sketch called out this being in there
        will this still work with domoticz?
        • P punter9
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @punter9 said:
          this creates an instance of the MySensor class called "gw"
          this runs the "present" function of the MySensors class in the gw instance, which tells your controller to create an instance of the device on Domoticz
          this function sends the name of the sketch and its version number to Domoticz to the parent device. You can only have one name...
          recommend that you try it!
          • P
            P
            punter9
            ha! you are awesome. Thank you so much
              @punter9
              a little advice...
              #define RELAY_PIN 4
              MyHwATMega328 hw;
              DHT dht;
              float lastTemp;
              float lastHum;
                  if (!metric)
                  lastHum = humidity;
              @hek
              Yes, do you have an idea how this would be designed?
              TheoLT 1 Reply Last reply
              • P
                P
                punter9
                wrote on last edited by punter9
                okay got it working and both sensors have been found in domoticz. Only issue is relay doesn't turn on or off with control. But it has been found. I have it plugged into pin 4, checked that it worked by manually jumping the pins, and I can see the tx/rx light blink when I click the button in domoticz (but no relay click).
                  TheoLT
                  TheoLT
                  TheoL
                  @hek @punter9 What do you guys think the sketch should do? Just control one single relais? If you guys don't have the time I'm glad to help you. Just want to return the favour for all that you guys have done. I'm really happy with MySensors.
                  • P
                    P
                    punter9
                    Thanks for checking in @TheoL . My intent for this sketch was to learn how to combine sketches and make a useful project. Got that done and working! It would be cool if there was an easy way to help newbies like myself out doing this. I can tell you without this awesome forum I would have not figured out some pretty basic stuff! Thanks for all the help, this is an awesome site
                    • P punter9
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      what does the serial monitor show when you click the button in Domoticz?
