  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 404.4k Views 39 Watching
    Mike Cayouette
    Hi
    Excellent build and exactly what I have been looking for. I just got my ESP-12 this week and I am about to build this. I just have one question, what is the "Inclusion mode" for? I tried to figure it out by look at the sketch and it's not quite clear.
    Thank you for everything you have done to get this to where it's at.
    Mike
    • M Mike Cayouette
      Hi
      Mike
      @Mike-Cayouette I copied the implementation from the Ethernet gateway.
      I thought it was meant as a function to allow clients to join the network within a certain timeframe after pressing the button.
      When looking at the code I'm not sure it does anything at all...
      Maybe @hek can shed some light on the issue?
      Daniel OliveiraD 1 Reply Last reply
        It doesn't do much on the gateway side. As @Yveaux says it allows you to have a physical button in the gateway to enable inclusion mode. After some (configurable) time it disables inclusion mode. The enabled/disabled status is sent to controller side. But no filtering of presentation messages occurs on the gateway.
        So it is really up to the controller to respect the inclusion mode status (whether or not to create new devices).
          @Yveaux
          Please PM me any updates needed on this:
          http://www.mysensors.org/build/esp8266_gateway
          • YveauxY Yveaux
            Daniel OliveiraD
            Daniel OliveiraD
            Daniel Oliveira
            Hi @Yveaux ,
            I finally received my NodeMCU (but from http://doit.am/) did you had to flash any firmware (like the NodeMCU one) in order to be able to use it from Arduino IDE or it is just flash the .ino and it's ready to go?
            Regards
            MySensors rules my home :)
            • Daniel OliveiraD Daniel Oliveira
              Hi @Yveaux ,
              Regards
              @Daniel-Oliveira by downloading from the Arduino ide you will overwrite any firmware already in the flash. No manual steps are required. Just connect and download from Arduino ide.
                Mike Cayouette
                Thank you for the quick response @Yveaux & @hek
                I started working on the gateway today but I seem to be having a problem. I already had IDE version 1.6.5 installed with the board manager enabled. I've been creating some sensors on some ESP-01 for a few weeks without a problem. I replaced the MySensors folder I had in my library folder with the most recent one. My old sketches still compile but when I try to compile the ESP8266Gateway sketch I get the following error.
                Esp8266Gateway.cpp.o: In function `incomingMessage(MyMessage const&)':
                Esp8266Gateway.cpp:(.text+0x74): undefined reference to `vsnprintf_P'
                Esp8266Gateway.cpp.o: In function `output(char const*, ...)':
                Esp8266Gateway.cpp:(.text+0xb6): undefined reference to `vsnprintf_P'
                MySensors/MyHwESP8266.cpp.o: In function `hw_writeConfig(int, unsigned char)':
                MyHwESP8266.cpp:(.text+0x138): undefined reference to `snprintf_P'
                MySensors/MyHwESP8266.cpp.o: In function `MyHwESP8266::MyHwESP8266()':
                MyHwESP8266.cpp:(.text+0x16f): undefined reference to `snprintf_P'
                MySensors/MyHwESP8266.cpp.o: In function `MyHwESP8266::debugPrint(bool, char const*, ...)':
                MyHwESP8266.cpp:(.text+0x19a): undefined reference to `vsnprintf_P'
                MyHwESP8266.cpp:(.text+0x1b3): undefined reference to `vsnprintf_P'
                collect2: error: ld returned 1 exit status
                Error compiling.
                All I changed in the ESP8266Gateway example sketch was the SSID and Password.
                Regards,
                Mike
                • M Mike Cayouette
                  Error compiling.
                  Regards,
                  Mike
                  Can you check the boardmanager which version of ESP Arduino you have installed?
                  Mine's like this:
                  upload-fbb1d613-848e-4c2d-8076-8eb684d07141
                  I use the 'stable' version, located at http://arduino.esp8266.com/stable/package_esp8266com_index.json
                  Maybe your installation is inclomplete; you could try removing & reinstalling Arduino for ESP.
                    Mike Cayouette
                    That was the problem, I was running an older version, I upgraded it and now it show's the same as your version.
                    Thanks again,
                    Mike
                    • J
                      J
                      jvandenbroek
                      Just wanted to say thank you! It works great after hooking it up on my breadboard, now I can finally include MySensors in my sensor network 8-)
                      • J jvandenbroek
                        @jvandenbroek Great to hear it's working fine! Have fun!
                        • G
                          G
                          gmccarthy
                          Great work. Just starting out with mysensors and looking forward to implementing this. Waiting for my hardware to arrive :)
                          • G gmccarthy
                            @gmccarthy said:
                            Great work.
                            Your icon suggests differently :laughing:
                            • G
                              G
                              gmccarthy
                              wrote on last edited by gmccarthy
                              #61
                              I'm having problems compiling this - I must be missing something but can't figured out what.
                              Error:
                              Esp8266Gateway.ino:77:25: fatal error: ESP8266WiFi.h: No such file or directory
                              I've downloaded the mysensor library and unzipped it.
                              My sketchbook location is: C:\Users\xxxxx\Documents\Arduino
                              Under C:\Users\xxxxx\Documents\Arduino\libraries\MySensors\examples\Esp8266Gateway
                              Ads
                              The esp8266gateway.ino file is present.
                              Update: Pffft....try selecting the generic ESP8266 module :)
                              • DrJeffD
                                DrJeffD
                                DrJeff
                                Built Mine :smiley: works great the only problem I had was uploading the code from a Mac OSX Mavericks so I opened a Win7 VM I keep for these type of problems and all is good. Thanks! @Yveaux :clap:
                                • DrJeffD DrJeff
                                  #63
                                  @DrJeff said:
                                  Built Mine
                                  Great to hear you got things running!
                                  @hek is also on Mac and he managed to download directly. Maybe you can discuss your issues with him so we can update the install instructions if something special is required for Mac.
                                  My Gateway has shrunk...!
                                  Sure did, and it's wireless now :laughing:
                                    @DrJeff
                                    I managed to upload on mac, but had to fiddle around before I got it working.
                                    Added this text after my experience.
                                    "This NodeMCU board normally can be flashed automatically and shouldn't need bootload/reset buttons to be pressed. If you see error, try changing baudrate from from 9600 to 57600. Still problems? Hold flash and press reset. Start upload in IDE while keeping flash-button pressed until upload starts."
                                    • DrJeffD
                                      DrJeffD
                                      DrJeff
                                      @hek Yes I tried those but it's probably the driver install it was acting a little finicky so it was quicker to flip over to the VM. :)
                                      • F
                                        F
                                        fleinze
                                        @DrJeff
                                        I remember that there was an error in the boardmanager-package for MacOS. You need to change the file-permissions to executable:
                                        sudo chmod +x ~/Library/Arduino15/packages/esp8266/tools/esptool/0.4.4/esptool
                                        • rvendrameR
                                          rvendrameR
                                          rvendrame
                                          wrote on last edited by rvendrame
                                          #67
                                          I followed the steps above, and I'm even able to upload sketches, however I only get this in serial monitor:
                                          Bad module maybe?
                                          EDIT: After choosing the right board (v.1.0) and applying the fix above from @fleinze, it seems it is working now...
                                          ESP8266 GW + mySensors 2.3.2
                                          Alexa / Google Home
