  3. A very beginner needs help - MySensors and OpenHab !
43 Posts 7 Posters 34.1k Views 6 Watching
  • E
    E
    ewgor
    @TimO finally I managed to add the dht 11 too and it works fine. Can you please tell me what to change in the rule file to add more buttons (same as this one that works)? I tried to change some parts of the light address but it doesn't work.
    I would like to add a normal button too (not like a switch) with a door symbol like door open or close for my exit door and to change its status from blue to red when you push the button.
    Thank you for the help you gave me by now!
    All the best!
    • E
      E
      ewgor
      wrote on last edited by ewgor
      #27
      Hi All,
      Can anyone please tell me if I want to add a few more buttons (same as this one with relay with button actuator) what should i change in the Openhab rules and in the Arduino sketch too? can it be done as the relay actuator example ?
      i mean first relay is connected to pin 3 and the next relay to pin 3+1=4, pin 4+1=5 and so on and the buttons pins to be alocated in the same way? is there any way to do it like this but for the relay with button actuator example?
      In the Openhab rules i tried to modify as i said above some of the addresses of the commands on or off from here:
      sendCommand(Arduino, "101;1;1;0;2;1\n")
      except the last numbers which i understand are like 1 for ON and 0 for OFF but it didn't work.
      The last thing that i would like to add is related only to Openhab if ill get an answer or a suggestion to my ask here above is a normal button (not like a slider) to control an electrical strike through a relay so when pressed once door open for 5 seconds or more and than close again. I know that here are more to discuss because maybe the door its not gonna be psychically closed but the Openhab status could show that the door is closed but this can be solved with a magnetic contact (i think) that can be added so the Openhab rules should be made like so: if the magnetic contact is connected than the door is closed and locked, else the door is open / unlocked even the electrical strike is closed until the magnetic contact will be connected! or to close the electrical strike only after the magnetic contact is closed.
      OH too much talking, I know this is maybe too much for me but theoretical speaking I know how to make it and I think i know how to set up the connection but physically is impossible because of missing knowledge in programming Arduino or Openhab!
      Lets take it one by one: Can anyone help me with first part of my request, how to add a few more buttons same as the only one working now?
      Thanks all
      • E
        E
        ewgor
        People i see that this post was seen by more than 2k times but nobody is answering! How is this possible? Nobody knows how to do it or everybody enjoy watching a noob asking for help? Common people at least off topic let's say hi each other!
        hekH 1 Reply Last reply
        • E ewgor
          Hey @ewgor, tone it down a bit. You won't get any answers by acting aggressive.
          It could be as simple as no-one has the the answer and you got to find a solution yourself.
          E 1 Reply Last reply
            E
            E
            ewgor
            @hek thanks for the answer. At least now i know i'm not alone :). Anyhow as far as i've seen by now only @TimO was the only one who answered me and gave me some info. It is possible that non of the heros, admins or other kind of this forum members to have a suggestion for me?
            Sorry if i was aggressive again!
            Good help :)
            • T
              TimO
              Well, the short answer for this is yes. It depends on your sketch. The loop with pin+1 is just a short notation.
              I would suggest to start with the simple sketch with one button here: http://www.mysensors.org/build/binary
              Give the node a static id, change items, rules and sitemap in OH.
              You have to change V_TRIPPED to V_LIGHT:
              So the OH rule with V_LIGHT will match and the item state is changed, when the button is pressed.
              • E
                E
                ewgor
                Oh TimO i thought i'll never see you again here :) thanks for the answer.
                I'm using the RelayWithButtonActuator example on which i added the humidity and temperature part and its working well. I choose this example because in this way i can get in real time the light status in Openhab even the light is turned ON / OFF from physical button on the breadboard or from the Openhab button.
                The Openhab rules are already made with the V_LIGHT command not the V_TRIPPED.
                I cant figure out what to add in the Arduino sketch to add more relays and more buttons and to make it work in the setup or loop functions. Than, on the Openhab rules i tried to copy the only light rule i have right now and to change some of the numbers in the
                but its not working :(
                If i'll get at least 5 buttons and 5 relays working in this way it would be perfect.
                Looking for any answer.
                • E
                  E
                  ewgor
                  Hello? TimO? :) are you there?
                  • T
                    TimO
                    Well, there are many approaches and I would go the easiest (but not the most elegant) way.
                    Double everything for every additional button / relay. If that works for two/three buttons/relays use arrays (like in the relay example sketch).
                    #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                    #define RELAY_PIN2 5 ######## ADD THAT ######
                    #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
                    #define BUTTON_PIN2 6 ######## ADD THAT ######
                    #define CHILD_ID2 2 ######## ADD THAT ######
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    Bounce debouncer = Bounce();
                    Bounce debouncer2 = Bounce(); ######## ADD THAT ######
                    int oldValue=0;
                    int oldValue2=0; ######## ADD THAT ######
                    bool state;
                    bool state2; ######## ADD THAT ######
                    MyMessage msg2(CHILD_ID2,V_LIGHT); ######## ADD THAT ######
                      gw.sendSketchInfo("Relay & Button", "1.0");
                     // Setup the button
                      pinMode(BUTTON_PIN,INPUT);
                      pinMode(BUTTON_PIN2,INPUT); ######## ADD THAT ######
                      // Activate internal pull-up
                      digitalWrite(BUTTON_PIN2,HIGH); ######## ADD THAT ######
                      debouncer.attach(BUTTON_PIN);
                      debouncer2.attach(BUTTON_PIN2); ######## ADD THAT ######
                      debouncer.interval(5);
                      debounder2.interval(5);######## ADD THAT ######
                      gw.present(CHILD_ID, S_LIGHT);
                      gw.present(CHILD_ID2,S_LIGHT);######## ADD THAT ######
                      digitalWrite(RELAY_PIN2,RELAY_OFF); ######## ADD THAT ######
                      pinMode(RELAY_PIN, OUTPUT);
                      pinMode(RELAY_PIN2, OUTPUT); ######## ADD THAT ######
                      state = gw.loadState(CHILD_ID);
                      state2 = gw.loadState(CHILD_ID2); ######## ADD THAT ######
                      digitalWrite(RELAY_PIN2, state2?RELAY_ON:RELAY_OFF); ######## ADD THAT ######
                    *  Example on how to asynchronously check for new messages from gw
                      debouncer.update();
                      debounder2.update(); ######## ADD THAT ######
                      // Get the update value
                      int value = debouncer.read();
                      if (value != oldValue && value==0) {
                          gw.send(msg.set(state?false:true), true); // Send new state and request ack back
                      oldValue = value;
                    value = debouncer2.read(); ######## ADD THAT ######
                      if (value != oldValue2 && value==0) { ######## ADD THAT ######
                          gw.send(msg2.set(state?false:true), true); // Send new state and request ack back ######## ADD THAT ######
                      } ######## ADD THAT ######
                      oldValue2 = value; ######## ADD THAT ######
                      if (message.isAck()) {
                         // Change relay state
                         state = message.getBool();
                         if(message.sensor == 1) { ######## ADD THAT ######
                           // Store state in eeprom
                           gw.saveState(CHILD_ID, state);
                         } else if(message.sensor == 2) { ######## ADD THAT ######
                           digitalWrite(RELAY_PIN2, state?RELAY_ON:RELAY_OFF); ######## ADD THAT ######
                           // Store state in eeprom ######## ADD THAT ######
                           gw.saveState(CHILD_ID2, state); ######## ADD THAT ######
                    The code is not tested nor compiled, but I hope you'll get the idea of how to add a button and a relay.
                    Of course this could be done much more elegant with arrays, that could be your next step.
                    • E
                      E
                      ewgor
                      #35
                      Wow! thanks for your time to fill this sketch! appreciate that.
                      I tried your sketch and after cleaning some small mistakes i got these errors and i don't know how to lose them.
                      this is how the sketch looks:
                      #define RELAY_PIN2 5 //######## ADD THAT ######
                      #define BUTTON_PIN2 6 //######## ADD THAT ######
                      #define CHILD_ID2 2 //######## ADD THAT ######
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      Bounce debouncer2 = Bounce(); //######## ADD THAT ######
                      int oldValue=0;
                      int oldValue2=0; //######## ADD THAT ######
                      bool state;
                      bool state2; //######## ADD THAT ######
                      MyMessage msg2(CHILD_ID2,V_LIGHT); //######## ADD THAT ######
                       // Setup the button
                        pinMode(BUTTON_PIN2,INPUT); //######## ADD THAT ######
                        digitalWrite(BUTTON_PIN2,HIGH); //######## ADD THAT ######
                        debouncer2.attach(BUTTON_PIN2); //######## ADD THAT ######
                        debouncer2.interval(5);//######## ADD THAT ######
                        gw.present(CHILD_ID2, S_LIGHT);//######## ADD THAT ######
                        digitalWrite(RELAY_PIN2, RELAY_OFF); //######## ADD THAT ######
                        pinMode(RELAY_PIN2, OUTPUT); //######## ADD THAT ######
                        state2 = gw.loadState(CHILD_ID2); //######## ADD THAT ######
                        digitalWrite(RELAY_PIN2, state2?RELAY_ON:RELAY_OFF); //######## ADD THAT ######
                        debouncer.update();
                        debouncer2.update(); //######## ADD THAT ######
                        oldValue = value;
                        if (value2 != oldValue && value==0) {
                        oldValue2 = value;
                           if(message.sensor == 1) { //######## ADD THAT ######
                           } else if(message.sensor == 2) { //######## ADD THAT ######
                             digitalWrite(RELAY_PIN2, state?RELAY_ON:RELAY_OFF); //######## ADD THAT ######
                             gw.saveState(CHILD_ID2, state); //######## ADD THAT ######
                      and those are the errors:
                      sketch_sep09a.ino:81:3: error: expected unqualified-id before 'if'
                      sketch_sep09a.ino:84:3: error: 'oldValue2' does not name a type
                      sketch_sep09a.ino:85:1: error: expected declaration before '}' token
                      Error compiling.
                      About the OH rules i made them like this:
                      rule "Light"
                              when
                                      Item lightBar02 received command
                              then
                                     if(receivedCommand == ON) {
                              if(receivedCommand == OFF) {
                                 sendCommand(Arduino, "101;1;1;0;2;0\n")
                      end
                      what do you think? do i still need to modify something?
                      Thank you a lot!:pray:
                      • T
                        TimO
                        There is a copy & paste error. Remove the bracket after "oldValue = value;" :)
                        The OH rule looks good.
                        • T TimO
                          E
                          E
                          ewgor
                          @TimO still doesnt want to compile :(
                          this is the last error:
                          sketch_sep10b.ino:81:3: error: expected unqualified-id before 'if'
                          Error compiling.
                          • TheoLT
                            TheoLT
                            TheoL
                            wrote on last edited by TheoL
                            #38
                            You have a closing bracelet ({) too much that's ending your loop() method. I corrected it and added a comment so you can see what's been causing the problem.
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            int oldValue=0;
                            bool state;
                             // Setup the button
                              debouncer.update();
                              oldValue = value;
                            // }  <---- remove this bracelet it's closing the loop() method. Then your compiler sees an if statement that's not in a method, which is not allowed
                              oldValue2 = value;
                            Good luck with it.
                            b.t.w. I have no knowledge of openHab.
                            • TheoLT TheoL
                              #define RELAY_ON 1
                              #define RELAY_OFF 0
                              int oldValue=0;
                              bool state;
                               // Setup the button
                                debouncer.update();
                                oldValue = value;
                                oldValue2 = value;
                              Good luck with it.
                              E
                              E
                              ewgor
                              @TheoL thanks man, I'll try it right now, thanks again.
                              • E
                                E
                                ewgor
                                #40
                                Guys, i tried this sketch above and now it can be uploaded but its not working well.
                                The system reacts like this: the first button ( old one) turns the led on / off on the breadboard but its not refreshing the OH button on the webpage and i get some i get some WARN on the server like this:
                                2015-09-11 19:02:29.052 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                oes not exist.
                                Light Item: null Light: ON
                                2015-09-11 19:02:29.073 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                oes not exist.
                                2015-09-11 19:02:29.085 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                oes not exist.
                                2015-09-11 19:02:30.701 [INFO ] [runtime.busevents             ] - Arduino state
                                 updated to 0;0;3;0;9;read: 22-22-0 s=1,c=1,t=2,pt=2,l=2:0
                                0;0;3;0;9;send: 0-0-22-22 s=1,c=1,t=2,pt=2,l=2,st=fail:0
                                22;1;1;0;2;0
                                0;0;3;0;9;read: 22-22-0 s=2,c=1,t=2,pt=2,l=2:0
                                0;0;3;0;9;send: 0-0-22-22 s=2,c=1,t=2,pt=2,l=2,st=fail:0
                                22;2;1;0;2;0
                                22;2;1;0;2;0
                                0;0;3;0;9;send: 0-0-22-22 s=2,c=1,t=2,pt=2,l=2,st=ok:0
                                22;2;1;0;2;0
                                2015-09-11 19:02:30.719 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                oes not exist.
                                Light Item: null Light: OFF
                                2015-09-11 19:02:30.742 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                oes not exist.
                                2015-09-11 19:02:30.755 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                oes not exist.
                                2015-09-11 19:02:30.761 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                oes not exist.
                                I don't understand why i get so many things on the server pressing once on and once off!
                                The second button is completely dead, it doesn't do anything on the breadboard or on the web.
                                I think the Arduino sketch has some bugs somewhere even it can be compiled. Maybe something inside is wrong or maybe this is not the right way to multiply relays and buttons.
                                Please see bellow my OH settings.
                                Items:
                                String Arduino "Arduino" { serial="COM4@115200" }
                                Switch           lightBar01                          "Lumina dormitor"
                                Switch           lightBar02                          "Lumina hol"
                                Sitemap:
                                sitemap demo label="Acasa"
                                   Frame label="Lumini" {
                                            Switch item=lightBar01 label="Lumina dormitor"
                                			Switch item=lightBar02 label="Lumina hol"
                                Rules:
                                import org.openhab.core.library.types.*
                                import org.openhab.core.persistence.*
                                import org.openhab.model.script.actions.*
                                import org.joda.time.*
                                import java.util.*
                                import org.eclipse.xtext.xbase.lib.*
                                import org.openhab.core.items.*
                                var String ArduinoUpdate = ""
                                var String sketchName = ""
                                var int V_TEMP = 0
                                var int V_HUM = 1
                                var int V_LIGHT = 2
                                var int V_DIMMER = 3
                                var int V_PRESSURE = 4
                                var int V_FORECAST = 5
                                var int V_RAIN = 6
                                var int V_RAINRATE = 7
                                var int V_WIND = 8
                                var int V_GUST = 9
                                var int V_DIRECTION = 10
                                var int V_UV = 11
                                var int V_WEIGHT = 12
                                var int V_DISTANCE = 13
                                var int V_IMPEDANCE = 14
                                var int V_ARMED = 15
                                var int V_TRIPPED = 16
                                var int V_WATT = 17
                                var int V_KWH = 18
                                var int V_SCENE_ON = 19
                                var int V_SCENE_OFF = 20
                                var int V_HEATER = 21
                                var int V_HEATER_SW = 22
                                var int V_LIGHT_LEVEL = 23
                                var int V_VAR1 = 24
                                var int V_VAR2 = 25
                                var int V_VAR3 = 26
                                var int V_VAR4 = 27
                                var int V_VAR5 = 28
                                var int V_UP = 29
                                var int V_DOWN = 30
                                var int V_STOP = 31
                                var int V_IR_SEND = 32
                                var int V_IR_RECEIVE = 33
                                var int V_FLOW = 34
                                var int V_VOLUME = 35
                                var int V_LOCK_STATUS = 36
                                var int V_DUST_LEVEL = 37
                                var int V_VOLTAGE = 38
                                var int V_CURRENT = 39
                                var int msgPresentation = 0
                                var int msgSet = 1
                                var int msgReq = 2
                                var int msgInternal = 3
                                var int msgStream = 4
                                var int alarmArmor = 1
                                // Internal Commands
                                var int I_BATTERY_LEVEL = 0
                                var int I_TIME = 1
                                var int I_VERSION = 2
                                var int I_ID_REQUEST = 3
                                var int I_ID_RESPONSE = 4
                                var int I_INCLUSION_MODE = 5
                                var int I_CONFIG = 6
                                var int I_FIND_PARENT = 7
                                var int I_FIND_PARENT_RESPONSE = 8
                                var int I_LOG_MESSAGE = 9
                                var int I_CHILDREN = 10
                                var int I_SKETCH_NAME = 11
                                var int I_SKETCH_VERSION = 12
                                var int I_REBOOT = 13
                                var int I_GATEWAY_READY = 14
                                // Mappings
                                var HashMap<String, String> sensorToItemsMap = newLinkedHashMap(
                                    "101;1;"            -> "lightBar01",    // looks good
                                    "lightBar01"       -> "101;1;",
                                	"101;2;"            -> "lightBar01",    // looks good
                                    "lightBar02"       -> "101;2;"
                                //receiving msg from mysensors gateway
                                rule "Arduino sends to Openhab"
                                    when
                                        Item Arduino received update
                                    then
                                        var String lineBuffer =  Arduino.state.toString.split("\n")
                                        for (String line : lineBuffer) {
                                            var String[] message = line.split(";")
                                            var Integer nodeId = new Integer(message.get(0))
                                            var Integer childId = new Integer(message.get(1))
                                            var Integer msgType = new Integer(message.get(2))
                                            var Integer ack = new Integer(message.get(3))
                                            var Integer subType = new Integer(message.get(4))
                                            var String msg = message.get(5)
                                            if(msgType == 1 ){
                                                if (subType == V_LIGHT){
                                                    var String state
                                                    var Integer statusInt = new Integer(message.get(5))
                                                    if(statusInt == 1) {
                                                        state = "ON"
                                                    else {
                                                        state = "OFF"
                                                    postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), state)
                                                    println ("Light Item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " Light: " + state )
                                				if (subType == V_TEMP){
                                                    postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), msg)
                                                    println ("Temp item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " temp: " + msg )
                                				if (subType == V_HUM){
                                                    println ("Hum item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " hum: " + msg )
                                            // Internal Command
                                            if(msgType == 3){
                                                if(subType == I_SKETCH_NAME){
                                                        println("Sketch name: " + msg )
                                                        sketchName=msg
                                                if(subType == I_SKETCH_VERSION){
                                                        println("Sketch version: " + msg )
                                                        postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), sketchName+" " +msg )
                                                        sketchName=""
                                end
                                rule "Light"
                                        when
                                                Item lightBar01 received command
                                        then
                                end
                                rule "Light"
                                        when
                                        then
                                end
                                Any suggestion will be kindly appreciated.
                                PS: I forgot to say that i added in the Arduino sketch the address of the node point:
                                #define NODE_ID 101
                                • E
                                  E
                                  ewgor
                                  #41
                                  Hey guys, i found the solution here array-relay-button-actuator but now the OH part comes 'couse this is different solution. How can i add CHILD_ ID's in this case to create more buttons in OH? i mean how to make difference between the two relays in OH?
                                  Can somebody please help me? This is what i was looking for.
                                  Thanks :scream:
                                  • E
                                    E
                                    ewgor
                                    I see, i need to search for help on another forum ...
                                    Many thanks to TimO who helped me a lot.
                                    • dexterbotD
                                      dexterbotD
                                      dexterbot
                                      Hello @ewgor, I follow you on another forum about this subject and are interested myself of this system. I found in the code you posted a small error - might this to be the problem.
                                      Please let me your email address - I would like to talk about this topic
                                      @ewgor said: Rules:
                                      "101;2;" -> "lightBar01", // <<<<<--------------------------HERE----------------:)
