  3. Send a string as a value
8 Posts 5 Posters 4.1k Views 2 Watching
  • M Offline
    M Offline
    Meister_Petz
    is there a way to send a string as the value of a message:
    I would like to do that:
    String test = String(sRead1) + "-" + String(sRead2)+ "-" + String(sRead3); // result: "20.5-1011-2.5"
    gw.send(msg1.set(test));
    I did not find a way to get "test" transformed (char, string,...) to get it sent. But interestingly this works:
    gw.send(msg1.set("20.5-1011-2.5"));
    so I think there should be a way to get "test" transformed in a format which can be sent.
    Anyone any ideas?
    Many Thanks!
    • hekH Offline
      hekH Offline
      You should avoid using String on embedded systems (thus we do not have any send for it).
      Have a look at strcpy.
      • M Offline
        M Offline
        Meister_Petz
        do you have an example? Many Thanks!
        • M Meister_Petz
          Anyone any ideas?
          Many Thanks!
          T Offline
          T Offline
          tekka
          @Meister_Petz you can always do something like this:
          char Output[13];
          String OutStr = String(sRead1) + "-" + String(sRead2) + "-" + String(sRead3);
          OutStr.toCharArray(Output,13);
          gw.send(msg.set(Output));
          but as @hek pointed out, try avoiding it where possible...
          • T tekka
            char Output[13];
            M Offline
            M Offline
            Meister_Petz
            @tekka
            Many Thanks!
            I'd like to avoid it, but I'm not a developer and so my programing skills are limited ;-)
            • F Offline
              F Offline
              fets
              @Meister_Petz, you could simply write :
              gw.send(msg.set(OutStr.c_str()));
              • A Offline
                A Offline
                AWI
                Or just use the character arrays with snprintf
                • M Offline
                  M Offline
                  Meister_Petz
                  many thanks! I know it's easy for you - unfortunately not for me. That's why I'm here. ;-)
