  3. Node-RED
  4. nodered "injected" between domoticz and mysensors
Scheduled Pinned Locked Moved Node-RED
21 Posts 9 Posters 18.7k Views 6 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @bpair
    This is my first stab at node-red, so haven't decided the whole setup yet.. Just playing with it, and see what features it has, and what I can make out of it..
    I'm thinking about making a second nodetype as well, that can wrap a standard node-red msg.payload, into a mysensors serial api "datagram", where you can choose the node_id, message type etc. in dropdowns, when configuring that node.
    • G
      G
      gbfromhb
      wrote on last edited by gbfromhb
      @bpair
      "One thing to know about node-red is that it is single threaded. I don't think it is an issue with a small setup and with small node-red sketches but if you have a large number of messages you could start to see a delay in processing."
      This single thread will handle a trimenduse load, because of the way it is done. It receives a request, and then asynchronously processes this request, it then looks to see if any asynchronous promises have completed (callback). The only concern I have with this single thread is if you were doing CPU intensive calculations
      bpairB 1 Reply Last reply
      • G gbfromhb
        @bpair
        bpairB
        bpairB
        bpair
        @gbfromhb Good to know. Thanks!
        • D
          diggs
          This is also something I have started playing with. Having node-red in the system seems like a powerful way to move and connect information around the place between the mysensor system and all sorts of interfaces.
          It would be good to have an area where we could share the nodes and codes etc.
          What code do you use for parsing the serial data into its different parts?
          At the moment I have the mysensors serial gateway talking to domoticz directly (as standard) with the node-red serial node picking up serial data in parallel to then send off other places (influxdb, mqtt etc). At the moment I can grab the serial data, but no idea how to parse it out for useful sending on.
          • tbowmoT
            tbowmoT
            tbowmo
            ok, my stab at a couple of nodes for this, should be install-able with the following command
            npm install -g node-red-contrib-mysensors
            This will add two extra nodes, that can be used with mysensors serial GW API.
            • tbowmoT
              tbowmoT
              tbowmo
              a small example that I made, using my node-red-contrib-mysensors nodes (needs to be installed for this to work)
              This routes data from a mysensors GW, to both domoticz and pidome. It filters out node-id request, so they are not sent to pidome (domoticz is the one that hands out id's to mysensors nodes).
              I have a pulse counting arduino on my utility meter, this outputs strings as <watts>;<wh>\n, which I split into two different messages with a function, and dumps into mysensor serial protocol
              To connect with domoticz / pidome, the following pipes are made with socat
              socat PTY,link=/dev/ttyS80,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB20,mode=666,group=dialout,raw &
              socat PTY,link=/dev/ttyS81,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB21,mode=666,group=dialout,raw &
              socat PTY,link=/dev/ttyS82,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB22,mode=666,group=dialout,raw &
              It makes 3 virtual serial ports that I can use to attach pidome etc. to domoticz. I put it in /etc/rc.local
              domoticz is using /dev/ttyUSB20 as a mysensors serial GW.
              [{"id":"acfe3226.5301d","type":"serial-port","serialport":"/dev/ttyACM0","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":true},{"id":"66f437ac.990bc8","type":"serial-port","serialport":"/dev/ttyS81","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":true},{"id":"b5105521.4aefa8","type":"serial-port","serialport":"/dev/ttyS80","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":true},{"id":"821a7286.7de59","type":"serial-port","serialport":"/dev/ttyUSB0","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":true},{"id":"5b8bba4c.a47444","type":"serial in","name":"From Mysensors","serial":"821a7286.7de59","x":257,"y":196,"z":"67deb464.98214c","wires":[["1656727d.e9a98e","4755dfb8.b8aa2"]]},{"id":"47b5936e.b84a6c","type":"serial out","name":"To Mysensors","serial":"821a7286.7de59","x":1166,"y":305,"z":"67deb464.98214c","wires":[]},{"id":"602db35f.9fd24c","type":"serial in","name":"From Domoticz","serial":"b5105521.4aefa8","x":248,"y":348,"z":"67deb464.98214c","wires":[["47b5936e.b84a6c","f58d12f9.0a72f"]]},{"id":"4755dfb8.b8aa2","type":"serial out","name":"To Domoticz","serial":"b5105521.4aefa8","x":1164,"y":213,"z":"67deb464.98214c","wires":[]},{"id":"1656727d.e9a98e","type":"mysdecenc","name":"","x":560,"y":157,"z":"67deb464.98214c","wires":[["5dbdeccd.a24214"]]},{"id":"3094c378.cf6b3c","type":"debug","name":"","active":true,"console":"false","complete":"true","x":1033,"y":468,"z":"67deb464.98214c","wires":[]},{"id":"5dbdeccd.a24214","type":"function","name":"Filter ID requests","func":"if (msg.messageType != 3 &\n    msg.subType != 3) {\n    return msg;\n}","outputs":1,"noerr":0,"x":738,"y":157,"z":"67deb464.98214c","wires":[["2ce8f789.d31708"]]},{"id":"293de58.fd6c21a","type":"serial in","name":"From PiDome","serial":"66f437ac.990bc8","x":246,"y":266,"z":"67deb464.98214c","wires":[["47b5936e.b84a6c","4755dfb8.b8aa2"]]},{"id":"f58d12f9.0a72f","type":"serial out","name":"To PiDome","serial":"66f437ac.990bc8","x":1162,"y":386,"z":"67deb464.98214c","wires":[]},{"id":"2ce8f789.d31708","type":"mysdecenc","name":"","x":915,"y":156,"z":"67deb464.98214c","wires":[["f58d12f9.0a72f"]]},{"id":"ff3ea1e4.00c16","type":"serial in","name":"Meter input","serial":"acfe3226.5301d","x":229,"y":475,"z":"67deb464.98214c","wires":[["3c7fe6d9.c3801a"]]},{"id":"3c7fe6d9.c3801a","type":"function","name":"Split meter data","func":"var pl = msg.payload.split(';');\n\nmsg1 = {payload : parseFloat(pl[0])*1000};\nmsg2 = {payload : parseFloat(pl[1])/1000};\nreturn [msg1, msg2];","outputs":"2","noerr":0,"x":427,"y":475,"z":"67deb464.98214c","wires":[["e1a7231a.1e58e"],["b06687e3.4f9978"]]},{"id":"e1a7231a.1e58e","type":"mysencap","name":"V_WATT node 99","nodeid":"99","childid":"1","subtype":"17","x":642,"y":445,"z":"67deb464.98214c","wires":[["ede87fe8.12178"]]},{"id":"b06687e3.4f9978","type":"mysencap","name":"V_KWM node 99","nodeid":"99","childid":"2","subtype":"18","x":640,"y":488,"z":"67deb464.98214c","wires":[["ede87fe8.12178"]]},{"id":"ede87fe8.12178","type":"mysdecenc","name":"","x":868,"y":468,"z":"67deb464.98214c","wires":[["3094c378.cf6b3c","4755dfb8.b8aa2","f58d12f9.0a72f"]]}]```
              • tbowmoT
                tbowmoT
                tbowmo
                one word of caution, using the above scenario..
                You need to have something picking up the "serial port data" in the other end of the socat pipes, otherwise nodered clog up, and start to use 100% cpu. I discovered that the "hard way".
                As long as the socat pipe is emptied, node-red is running happily :)
                • tbowmoT
                  tbowmoT
                  tbowmo
                  just updated the plugin to node-red, so it now can send presentation messages as well (and internal messages, if you want), when using the "mysencap" node.
                  The presentation message is sent 1 second after a flow is deployed, or when node-red is started..
                  • JohnJ
                    JohnJ
                    John
                    This looks really cool! What is PiDome's role in this picture?
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @John
                      It would just be a proof of concept. However I haven't succeeded in bringing in Pidome, as it relies on USB device descriptors for the serial port, and so I can't choose the socat pipe from nodered.
                      One could use it for testing new sensor types, mock them up in nodered and inject messages to the controller (pidome, domoticz etc)
                      • JohnJ
                        JohnJ
                        John
                        Yep, that's correct, to make sure the correct interface is loaded (serial/hid/etc..). If you would get it to trigger udev with a serial description it should catch it.
                        Nonetheless in about a week or two, three i think the fixed udev triggered mechanism will be supplemented with an user selectable list of available ports as i'm quite interested in this mockup.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          just made a small update, so it now can create a more full presentation round, to another controller, with both sketch name, and version strings..
                          Use the following to update your plugin..
                          npm update node-red-contrib-mysensors
                          • tbowmoT tbowmo
                            bpairB
                            bpairB
                            bpair
                            @tbowmo Thanks for the update. I hope to try using socat as a way to test different controllers easily. I am frustrated with the controller options and I feel like as my project progresses being able to easily change controllers might be very desirable. This architecture makes that possible.
                            I have a function in my node-red flow that enriches the messages from MySensors. I realize this begins to do what a controller might do, but I need a simple way to translate "Node:20, Child:1" to "Tank 1 - Water Temperature" so that I can publish that to a database or dweet.io or easily display in a graph. I might know what a graph of Node:20:Child1=25.6 means but nobody else will.
                            I am new to json but am attempting to use that. Ideally node-red would allow for easily manage this mapping information via a web page and store it. I am setting this globally:
                            [{"id":"d5d724ec.cba8c","type":"subflow","name":"On Startup","in":[],"out":[{"x":454,"y":160,"wires":[{"id":"dcd80855.bc4688","port":0}]}]},{"id":"c7328a87.d34f28","type":"inject","name":"On Startup","topic":"server-startup","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"x":148,"y":160,"z":"d5d724ec.cba8c","wires":[["dcd80855.bc4688"]]},{"id":"dcd80855.bc4688","type":"function","name":"Save startup date","func":"msg.startupDate = msg.payload;\nmsg.payload = \"\";\nreturn msg;","outputs":1,"noerr":0,"x":318,"y":160,"z":"d5d724ec.cba8c","wires":[[]]},{"id":"302ddf01.cbf0b8","type":"subflow:d5d724ec.cba8c","name":"","x":127,"y":214,"z":"5791498e.8d6878","wires":[["841c3e7c.b41288"]]},{"id":"841c3e7c.b41288","type":"function","name":"SetGlobalVars","func":"node.log(\"Add sensorNodes to global context\");\n\nvar sNodes = [   \n        {nodeId:30, nodeLabel:\"Greenhouse\", \n            sensors:[\n                {childSensorId:1, childSensorLabel:\"Air\", sensorTypeLabel:\"Temperature\"},\n                {childSensorId:2, childSensorLabel:\"Air\", sensorTypeLabel:\"Humidity\"},\n                {childSensorId:130, childSensorLabel:\"AirBattery\", sensorTypeLabel:\"Voltage\"}\n            ] \n        }, \n        {nodeId:50, nodeLabel:\"Aquaponics\", \n            sensors:[\n                {childSensorId:0, childSensorLabel:\"Water\", sensorTypeLabel:\"Temperature\"},\n                {childSensorId:20, childSensorLabel:\"Air\", sensorTypeLabel:\"Humidity\"},\n                {childSensorId:21, childSensorLabel:\"Air\", sensorTypeLabel:\"Temperature\"},\n                {childSensorId:30, childSensorLabel:\"Light\", sensorTypeLabel:\"Lux\"}\n            ]\n        }\n    ];\n\ncontext.global.sensorNodes = sNodes;\n\n    \nmsg.payload = context.global.sensorNodes;\n\nreturn msg;","outputs":1,"noerr":0,"x":357,"y":213,"z":"5791498e.8d6878","wires":[[]]},{"id":"8ad9f121.3ea3b","type":"inject","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":127,"y":135,"z":"5791498e.8d6878","wires":[["841c3e7c.b41288"]]}]
                            and then using it:
                            [{"id":"d14e00ff.cc9f7","type":"function","name":"MySensorIdInfo","func":"var sensorNode = getByNodeId(context.global.sensorNodes, \"\"+msg.nodeId);\nif (sensorNode != null) {\n    console.log(\"NodeLabel = \" + sensorNode.nodeLabel);\n    msg.nodeLabel = sensorNode.nodeLabel;\n        \n    var childNode = getByChildId(sensorNode.sensors, \"\"+msg.childSensorId);\n    if (childNode != null) {\n        console.log(\"ChildNodeLabel = \" + childNode.childSensorLabel);\n        msg.childSensorLabel = childNode.childSensorLabel;\n        msg.sensorTypeLabel = childNode.sensorTypeLabel;\n    } else {\n        msg.childSensorLabel = msg.childSensorId;\n        msg.sensorTypeLabel = \"undefined\";\n    }\n} else {\n    node.error(\"No sensor match found in sensorNodes\");\n    msg.nodeLabel = msg.nodeId;\n    msg.childSensorLabel = msg.childSensorId;\n    msg.sensorTypeLabel = \"undefined\";   \n}\n\nif (msg.sensorTypeLabel == \"undefined\") {\n    return null;\n}\n\n//debug\nnode.log(\"nodeId = \" + msg.nodeId + \" :--: \" + \n\"nodeLabel = \" + msg.nodeLabel + \" :--: \" + \n\"childSensorId = \" + msg.childSensorId + \" :--: \" + \n\"childSensorLabel = \" + msg.childSensorLabel + \" :--: \" + \n\"sensorTypeLabel = \" + msg.sensorTypeLabel);\n\nreturn msg;\n\n//------- Helper Functions ----------//\n\nfunction getByNodeId(arr, value) {\n  for (var i=0, iLen=arr.length; i<iLen; i++) {\n    if (arr[i].nodeId == value) return arr[i];\n  }\n}\n\nfunction getByChildId(arr, value) {\n  for (var i=0, iLen=arr.length; i<iLen; i++) {\n    if (arr[i].childSensorId == value) return arr[i];\n  }\n}","outputs":1,"noerr":0,"x":614,"y":390,"z":"c3095d41.89f1e8","wires":[["6e57151f.370ffc","ae35a271.90c3b"]]}]
                            The one other piece I added was a response to the MetricOrImperial question. Maybe some of this is useful. Thanks for your work.
                            F 1 Reply Last reply
                            • bpairB bpair
                              and then using it:
                              F
                              F
                              Fabien
                              and then using it:
                              Thank you, it's very usefull !
                              • V
                                V
                                vickey
                                @tbowmo May you please share your node-red set up by exporting your setup as flow? If feasible for you
