Adapter for RFM69 on NRF24L01+ pinout-header
Has anyone made or purchased an adapter to connect the RFM69 to a header with connections for nRF24L01+ ?
Such a header uses the following Arduino pins:
1: GND
2: 3V3
3: CE (pin 9)
4: CSN (pin 10 or SS)
5: SCK (pin 13)
6: MOSI (pin 11)
7: MISO (pin 12)
8: IRQ (not used)The RFM69 will need an interrupt pin, most likely D2 (pin 3 on the atmega328p).
1: GND
2: 3V3
3: CE (pin 9)
5: SCK (pin 13)
6: MOSI (pin 11)
7: MISO (pin 12)
@GertSanders There are these: https://oshpark.com/shared_projects/TKNcHTRl
Al -
@Sparkman : Super, thanks
1: GND
2: 3V3
3: CE (pin 9)
5: SCK (pin 13)
6: MOSI (pin 11)
7: MISO (pin 12)
Sounds like it might be good for retrofits. Ideally you'd pull out the NRF24L01+ and just plug-in the RFM69, and then everything would "just work" after a reboot. Unfortunately you might still have the interrupt wire to run to D2. Unless maybe that's the "unused" IRQ? To which pin on the Arduino does the IRQ socket already connect with? I would guess it's either D2 or D3. Most likely it's D2, in which case all is good. D9 wouldn't be needed anymore and could be freed up.
@Sparkman Have you used them? Wonder what it involves. Soldering the RFM69 to the adaptor and plugging in the adaptor?
I hope that the Serial gateway implementation on Raspberry PI also allows for a switch to RFM69. That all depends on how the IRQ pin needs te be treated.
On my board I provided for a jumper to connect the IRQ pin of the NRF24 to pin 2 of the atmega328 ( the INT0 pin). The MySensors library requires connection of IRQ to pin 2. But that would only cover the sensor side, not my gateway side yet. So here is hoping that we will have a solution of the gateway side as well.
I would also like to know this. If you look at the openhardware.io site there is a link to the projects github page. There it is mentioned that he added a panelized version but I don´t understand witch file I need to upload to dirtycbs to order that version
You need to .zip all "combined" files. Each one describes a layer. The ".txt" for drills, ".gts"for top soldermask, etc... Fabhouse need all of them in one .zip
Here is explained which files you need for your .zip (in the Ordering Section)
http://dirtypcbs.com/about.php -
I have ordered several adapters:
https://github.com/hallard/RFM12B-BreakOut
They are on oshpark.
Please check carefully which footprint you have:
- rfm12b /rfm69c(w) (the old rfm12 footprint)
- rfm69chw /rfm95* (lora footprint)
They are working fine @GertSanders on your nodes :-)
I have also ordered @tbowmo adapter, but have not tried it. -
I have also ordered @tbowmo adapter, but have not tried it.How is the power consumption and the range with these modules ?
@GertSanders The range is BY FAR better. I am getting a very stable signal in the corners where nrf24l01+ has never worked. No more voodoo dancing trying to make nrf24l01+ work!
I have not measured the consumption yet as I would need a proper scope rather than using a multimeter. So I had to rely on this table:
very nice work. So the NRF2RFM69; will it work with the RFM69CHW chip at all? The reason I ask is, I have a lot of slimnodes on battery as well that I would like to switch radios for some better range (and hopefully, less failures on my network).
@drock1985 You do not need "H" radios on the nodes. I have the gateway with RFM69HCW (lora footprint the same as RFM95*) and the node with RFM69CW (RFM12B footprint). The issue with "H" radio is that it consumes much more to transmit - 130mA (vs 45mA for a non-H radio). 16.5cm insulated wire works really nicely. I did not notice much difference to SMA antenna though It does look sleeker.
The range on 433Mhz modules (one H and one non-H) is excellent. I'll to go outside to measure it. It covers the whole house without any dead zones.
