  3. Adapter for RFM69 on NRF24L01+ pinout-header
27 Posts 10 Posters 13.2k Views 9 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    @Sparkman : Super, thanks
      shabba
      @Sparkman Have you used them? Wonder what it involves. Soldering the RFM69 to the adaptor and plugging in the adaptor?
      SparkmanS 1 Reply Last reply
        @GertSanders said:
        Has anyone made or purchased an adapter to connect the RFM69 to a header with connections for nRF24L01+ ?
        Such a header uses the following Arduino pins:
        1: GND
        2: 3V3
        3: CE (pin 9)
        4: CSN (pin 10 or SS)
        5: SCK (pin 13)
        6: MOSI (pin 11)
        7: MISO (pin 12)
        8: IRQ (not used)
        The RFM69 will need an interrupt pin, most likely D2 (pin 3 on the atmega328p).
        Sounds like it might be good for retrofits. Ideally you'd pull out the NRF24L01+ and just plug-in the RFM69, and then everything would "just work" after a reboot. Unfortunately you might still have the interrupt wire to run to D2. Unless maybe that's the "unused" IRQ? To which pin on the Arduino does the IRQ socket already connect with? I would guess it's either D2 or D3. Most likely it's D2, in which case all is good. D9 wouldn't be needed anymore and could be freed up.
        • S shabba
          SparkmanS
          SparkmanS
          Sparkman
          I have ordered them, but I have not used them. It is just the circuit board, so you will need to add headers and solder the rfm module to it.
          Al
          • SparkmanS Sparkman
            Al
            shabba
            @Sparkman Do let us know how you get on with them. Tempted to change over to RFM69 and this sounds like a potential route. Thanks!
            • GertSandersG
              GertSandersG
              GertSanders
              I hope that the Serial gateway implementation on Raspberry PI also allows for a switch to RFM69. That all depends on how the IRQ pin needs te be treated.
              On my board I provided for a jumper to connect the IRQ pin of the NRF24 to pin 2 of the atmega328 ( the INT0 pin). The MySensors library requires connection of IRQ to pin 2. But that would only cover the sensor side, not my gateway side yet. So here is hoping that we will have a solution of the gateway side as well.
                shabba
                Hi folks - Anyone use a good adaptor? I want to change all my sensors to RFM69 but have lots of boards that are designed for NRF24L01+
                  https://www.openhardware.io/view/16/NRF2RFM69
                    shabba
                    @hek Thanks but I do I order it? Put a few on a 5x5cm board on itead? Is there a file I can upload?
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      I would also like to know this. If you look at the openhardware.io site there is a link to the projects github page. There it is mentioned that he added a panelized version but I don´t understand witch file I need to upload to dirtycbs to order that version
                        You need to .zip all "combined" files. Each one describes a layer. The ".txt" for drills, ".gts"for top soldermask, etc... Fabhouse need all of them in one .zip
                        Here is explained which files you need for your .zip (in the Ordering Section)
                        http://dirtypcbs.com/about.php
                          Hmm, wait a bit ordering... I'm discussing some issues with PCBWay about the panelized version @tbowmo uploaded yesterday.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            I've added a link to dirtypcb's on the project forum thread
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              I have ordered several adapters:
                              https://github.com/hallard/RFM12B-BreakOut
                              They are on oshpark.
                              Please check carefully which footprint you have:
                              • rfm12b /rfm69c(w) (the old rfm12 footprint)
                              • rfm69chw /rfm95* (lora footprint)
                              They are working fine @GertSanders on your nodes :-)
                              I have also ordered @tbowmo adapter, but have not tried it.
                              • alexsh1A alexsh1
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @alexsh1
                                How is the power consumption and the range with these modules ?
                                alexsh1A 1 Reply Last reply
                                • GertSandersG GertSanders
                                  @alexsh1
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @GertSanders The range is BY FAR better. I am getting a very stable signal in the corners where nrf24l01+ has never worked. No more voodoo dancing trying to make nrf24l01+ work!
                                  I have not measured the consumption yet as I would need a proper scope rather than using a multimeter. So I had to rely on this table:
                                  Consumption
                                  • D
                                    drock1985
                                    @alexsh1
                                    very nice work. So the NRF2RFM69; will it work with the RFM69CHW chip at all? The reason I ask is, I have a lot of slimnodes on battery as well that I would like to switch radios for some better range (and hopefully, less failures on my network).
                                    My Projects
                                    2 Door Chime Sensor
                                    Washing Machine Monitor
                                    • D drock1985
                                      @alexsh1
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @drock1985 You do not need "H" radios on the nodes. I have the gateway with RFM69HCW (lora footprint the same as RFM95*) and the node with RFM69CW (RFM12B footprint). The issue with "H" radio is that it consumes much more to transmit - 130mA (vs 45mA for a non-H radio). 16.5cm insulated wire works really nicely. I did not notice much difference to SMA antenna though It does look sleeker.
                                      The range on 433Mhz modules (one H and one non-H) is excellent. I'll to go outside to measure it. It covers the whole house without any dead zones.
                                      • alexsh1A
                                        alexsh1A
                                        alexsh1
                                        By the way, anyone knows if there is an adapter for nrf24l01+ SMD to RFM69?
                                        I am more interested in the lora footprint. I supposed this board (Flash Memory: 256Kb) on the kickstarter with RN2483 or RN2903 Module :)
                                        • D
                                          drock1985
                                          Thanks @alexsh1, that answers that.
                                          One other quick question. Other than ordering the PCB's from dirtypcb's; any other hardware for the board required? I know I will need wire for an antenna, but wasn't sure if there was any need for capacitors or resistors. I looked through the thread and found no parts list so i'm leaning towards no.
                                          Thanks again,
                                          My Projects
                                          2 Door Chime Sensor
                                          12.5k
