  3. Sound Sensor
Sound Sensor
32 Posts 8 Posters 38.0k Views 2 Watching
  • epierreE
    epierreE
    epierre
    HEllo,
    I've based myself on a cookbook recipie, but it appears two issue:
    • each analogread brings 1023
    • the runningAverage keeps on increasing, never decreasing
      My sensor has only analog output (see sensor
      Here is the sketch:
    SoundSensor2
    Has anyne an idea of the analog value always the same first and then from the formulae above ?
    z-wave - Vera -> Domoticz
    • epierreE epierre
      HEllo,
        Here is the sketch:
      SoundSensor2
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @epierre
      you are maxing out the voltage on the analog pin.
      did you turn the potentiometer all the way down and check the input?
      try to debug the sensor with a basic sketch first, turning the pot while you look at the serial monitor. You may have to add a resistor... Then once you have it working, try your MySensors sketch.
      int inputPin = 3;  //check this
        Serial.begin(9600);
        pinMode(inputPin, INPUT);
        Serial.print(analogRead(inputPin));
      • epierreE
        epierreE
        epierre
        In fact it is a digital on-off output, playing with the potentimeter I saw that... so useless for my project...
        • epierreE epierre
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          Your sketch is looking for an analog input, yes?
          Your sensor is analog, or digital?
          • epierreE
            epierreE
            epierre
            digital... sadly...
            • epierreE epierre
              digital... sadly...
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @epierre
              We can still make it work, tripping when you have a loud noise
              • epierreE
                epierreE
                epierre
                yes the only way, as a door contact... nut not to measure noise pollution...
                • wmylionelW
                  wmylionelW
                  wmylionel
                  Not sure what happened to the links in the mysensor store but here is the link to the sound sensor you need, make sure it is the one that has 4 pins, with analog output as an option.
                  http://www.ebay.com/itm/1pc-New-Analog-Sound-Sensor-Board-Microphone-MIC-Controller-For-Arduino/300951969384?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D24143%26meid%3D8558634634764594554%26pid%3D100005%26prg%3D10240%26rk%3D2%26rkt%3D6%26sd%3D251565637147&rt=nc
                  epierreE 1 Reply Last reply
                  • wmylionelW wmylionel
                    epierreE
                    epierreE
                    epierre
                    @wmylionel yes I know this is my fault, I tried to order from one vendor rather to have several parcel, and lacking experience I did not check about this... nor about the wrong China Exports logo... experience come to a price...
                    • epierreE epierre
                      What do you mean by this?
                      • YveauxY Yveaux
                        epierreE
                        epierreE
                        epierre
                        @Yveaux the CE marking but C touching the E, without space... it is not Conformité Européenne but China Export... no warranty to comply in European space... be aware...
                        see wikipedia
                        Anyway, do you know a way to solder something to have access to something analog on it ?
                        • epierreE epierre
                          see wikipedia
                          @epierre Hard to say without a schematic... Seems to be something like this: http://yourduino.com/sunshop/images/products/SoundSensorDiagYW-700.jpg
                          You can try to connect to the analog input of the comparator (pin 3 of LM393) and see if it brings anything, but only if your module is similar ofcourse...
                          • YveauxY Yveaux
                            epierreE
                            epierreE
                            epierre
                            @Yveaux Hello I'm trying to compile a sketch using TIMSK, but to use it on an atm 128, I would need either timex8 or timex128 which only comes through an avrlib.
                            This is where I am lost, I have an avrlib on my disk, should I replace it with the full one ? how can I manage that ?
                            thanks,
                            • epierreE epierre
                              thanks,
                              @epierre I have very little time, but sharing the sketch might help to make your problem clear...
                              • YveauxY Yveaux
                                epierreE
                                epierreE
                                epierre
                                @Yveaux thanks, here it is:
                                avr_splmeter_02b.zip
                                http://davidegironi.blogspot.fr/2014/02/a-simple-sound-pressure-level-meter-spl.html
                                • epierreE epierre
                                  @epierre Had a quick look at the code. Seems the TIMSK stuff is just for timing the ADC samples at regular interval; the TIMER1_OVF_vect sets a flag (audioget_takesample) which is scanned for in the audioget_getsamples() function.
                                  Exactly the same behavior you can get by waiting using delay() or delayMicroseconds(), and then get the sample.
                                  That's probably easier then getting the raw timer stuff going.
                                  • epierreE
                                    epierreE
                                    epierre
                                    Since @hek is interrested, I'm revivind this post with several microphone available out there, in fact impossible to know if these use real electet ones...
                                    @BulldogLowell I've seen you've participated here http://forum.arduino.cc/index.php?topic=208520.15 but do you think this was the good solution ? if you go through http://davidegironi.blogspot.fr/2014/02/a-simple-sound-pressure-level-meter-spl.html the questions is open...
                                    Moshe LivneM 2 Replies Last reply
                                      wrote on last edited by hek
                                      Hmm.. not super easy to calculate an actual sound "pollution" value or do dB calculations using this I guess.
                                      Hmm.. Adafruit using a sample window in their example.
                                      https://learn.adafruit.com/adafruit-microphone-amplifier-breakout/measuring-sound-levels
                                        How does this differ from yours @epierre ?
                                        http://www.ebay.com/itm/Sound-Detection-Sensor-Module-Voice-Sensor-Intelligent-Vehicle-LM386-Audio-Power-/261598751181?pt=LH_DefaultDomain_0&hash=item3ce88029cd
                                        Seems to be two chips on it..
                                        • epierreE epierre
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @epierre I have ordered almost any kind of sound sensor on aliexpress for my washing machine sensor (at first I thought to get the beeps). They were all really bad.... I went the vibration way, but if I had to start all over again I think I would get https://www.sparkfun.com/products/9964
