  3. Soil Tensiometer Sensor Network
arduinomysensor 1.4nrf24l01+pa+lna
39 Posts 12 Posters 28.1k Views 3 Watching
    Not sure what you mean.
    • epierreE
      epierreE
      epierre
      @neverdie 2'' and 4'' are pretty close in depth (unless you put them horizontally, not vertically).
      in international units that makes 5, 10 and 20cm depths, my sensor is already 8 cm in height.
      z-wave - Vera -> Domoticz
      • epierreE epierre
        #30
        At present, I'm undoubtedly using a different sensor than you are, and I mounted it horizontally at the depth indicated, not vertically, if that's what you're doing. At the time I installed it, my goal for each sensor was just to measure soil moisture at a given depth, not across depths.
        • epierreE
          epierreE
          epierre
          @NeverDie have you gone to use the EvapoTranspiration calculus such as described below (example in the second part after the theory)
          http://www.konza.ksu.edu/weather/ReferenceET.PDF
          • epierreE epierre
            I haven't. It would be a great help if there were a free library that worked with generic weather station gear. It would seem that Davis has a non-free library that works with their particular weather station gear, but aside from that, I don't know of much else.
            • Lawrence HelmL
              Lawrence HelmL
              Lawrence Helm
              Also looking at soil moisture probes, either https://www.tindie.com/products/miceuz/i2c-soil-moisture-sensor/ which is based on the chirp one. Just need to seal the sides, or otherwise http://www.aliexpress.com/store/product/Soil-temperature-and-humidity-sensors-SHT10/1773013_32356151782.html
              Is anyone using the SHT ones ? (hopefully no pun intended) :)
              • epierreE
                epierreE
                epierre
                @Lawrence-Helm sht10 are expensive and are sensible to humidity, they are thus not made to stay in the ground or water.
                the soil humidity need to reach the captor but this one is not meant to support being in a too high humidity environment.
                Otherwise they are good ones
                • Lawrence HelmL
                  Lawrence HelmL
                  Lawrence Helm
                  @epierre the SHT10 that I put a link to has the following statements:
                  • Can be completely submerged.
                  and
                  • Usage:The probe can be directly embedded in the soil
                  Also the following link: http://www.adafruit.com/products/1298
                  Are your thoughts still the same, before I bite the bullet :)
                  • A
                    ahhk
                    read the description:
                    "but it's always best to avoid long-term (over 1 hour at a time) submersion, if you need something that can be submerged for over an hour you may want to find a different sensor. "
                    • epierreE
                      epierreE
                      epierre
                      @Lawrence-Helm I've got a collection of them and looked at their assembly, clearly don't trust the ill traducted or too much over-selling descriptions when you put electronic in a very humid environment
                      • H
                        H
                        haro
                        @epierre Hi...it is ameasing your work!! :D
                        I am wondering about Mq-135. We have troubles with reading differents gases.
                        From the datasheet we read the slopes
                        Gas X" X0" "Rs/R0 "Rs/R0 pendiente (log y- log y0)/(log x-log x0)"
                        Air 200 10 3.6 3.6 0.00000
                        co 200 10 1.3 2.9 -0.26783
                        nh4 200 10 0.79 2.7 -0.41024
                        c02 200 10 0.8 2.4 -0.36673
                        3/4/ 200 10 0.72 1.9 -0.32391
                        1/4/ 200 10 0.64 1.5 -0.28432
                        +- 200 10 0.59 1.4 -0.28845
                        these data are in the next worksheet https://docs.google.com/spreadsheets/d/18Z6XyxwXVsWdMIk9vbUuCucaLJDdmR0QUFSTYG79ftw/edit?usp=sharing
                        ¿may you share with us your code for this sensor in order to see your slopes and Rs/R0 values taken from the curve?
                        ¿do you know the meaning of the name go gases with 3/4 or 1/4 or +- ?
                        thank you in advance
                        • nervusvagusN
                          nervusvagusN
                          nervusvagus
                          wrote on last edited by nervusvagus
                          #39
                          following this thread loosely.
                          I have the following sensors and they seem to be accurate to some degree:
                          http://www.aliexpress.com/item/DFRobot-Capacitive-Analog-Soil-Moisture-Sensor-3-3-5-5V-Corrosion-Resistant-with-Gravity-3-Pin/32574020064.html?spm=2114.01010208.3.2.P99ddH&ws_ab_test=searchweb201556_0,searchweb201602_1_10037_10017_507_10033_10032_10040,searchweb201603_1&btsid=8d3b5e46-a069-441a-a1f7-491ae7e317e1
                          and they are much easier to work with Arduino compared to Watermark stuff. Anyone agree?
                          12.5k
