  3. [n00b]]Ethernet GW - without NF24
31 Posts 4 Posters 18.1k Views 3 Watching
  • A
    afick
    Helo,
    I want to build my "iHome" based only (for now) on 1 eth gw with directly connected sensors (like motion, light,smoke, temp, etc).
    How can i remove/turn off nf24 support and how can i use direct connectedd sensors on gw.
    I need only one exaple :)
      wrote on last edited by hek
      You can do it using this branch:
      https://github.com/mysensors/Arduino/tree/gateway-refactoring
      • A
        afick
        gr8 but do you have any documentation or help-docs for this or anything what can help me in setting up this?
          Currently no documentation for this branch but all the examples has been updated.
          You should be able to use any one of the examples and add:
          #define MY_GATEWAY_SERIAL
          and remove
          before the MySensors.h-include.
          • B
            B
            brix7be
            Hello Hek, Hello Everyone,
            I've actually one arduino uno and an ethernet shield Wizenet W5100 and for exemple a temp sensor DS18B20 directly connected to it.
            I can send to a serial terminal the temperature value. It's working properly :-).
            I would to know how I could simplify the code of the "Ethernet GW" Sketch for send the value of a sensor directly from the GW to Domoticz. (Without using an urduino dedicated to the sensor acquisition and without an RF module).
            Could you give me an exemple of the code or the command to send to domoticz?
            Or do you have a documentation link?
            Because the link you posted before is dead https://github.com/mysensors/Arduino/tree/gateway-refactoring.
            I've made many rescearch, and i don't find the protocol documentation to discuss with domoticz!
            I appreciate if you could help me to the right way :-).
            Awayting your answer, thanks very much in advance.
            PS: Sorry for my bad english...
              The code has been merged into development-branch now:
              • B
                B
                brix7be
                Thanks for your quickly answer.
                I'm sorry but I didn't found the code or information regarde my question into the repository you noticed.
                Could you please give me the complete link?
                Thanks you again.
                  We can't have all permutations of examples ready available...
                  So you'll have to put it together by combining:
                  https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayW5100/GatewayW5100.ino
                  and
                  https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/DallasTemperatureSensor/DallasTemperatureSensor.ino
                  You'd basically only have to copy the #defines from the gateway to the DallasTemp-sketch.
                  • B
                    B
                    brix7be
                    Hi Hek,
                    Sure, you can't realise every solutions or exemple for everyone :-).
                    So it's a good advice for me to begin my tests.
                    When i merge the both codes, i receive an error "sendSketchInfo was not declared in this scope"!
                    I've checked and normally all the librairies are available for the code.
                    (When i'm building the GatewayW5100 only it works) but not for the dallas.
                    Do you have an idea?
                    Gwen.
                      Just did a quick test calling sendSketchInfo in the gateway and it compiles fine for me.
                      • B
                        B
                        brix7be
                        hum, strange.
                        I continue to search a solution.
                        I'll give you a feed back ;-).
                        • B
                          B
                          brix7be
                          It doesn't work.
                          But i found the code of Bram81 http://forum.mysensors.org/topic/1591/how-to-add-a-sensor-to-the-serial-gateway/22
                          and I can compile it well.
                          And it calls the gw.sendSketchInfo("Soil_Moist_Sensor_grb", "1.15");
                          Do you have another tip?
                            remove "gw." from the call.
                            • B
                              B
                              brix7be
                              You are right, it blocks when i call sendSketchInfo directly (without to be an attribute of gw) !?!
                              • B
                                B
                                brix7be
                                wrote on last edited by brix7be
                                Here is the merged code
                                Thanks for the advices
                                // BELOW the gateway W5100 sketch
                                //#define MY_RADIO_NRF24
                                //#define MY_RADIO_RFM69 // I DONT WANT TO USE THE RADIO MODULE
                                #define MY_GATEWAY_W5100
                                //#define MY_W5100_SPI_EN 4
                                // radio on the same spi bus.
                                //#if !defined(MY_W5100_SPI_EN)
                                //  #define MY_SOFTSPI
                                //  #define MY_SOFT_SPI_SCK_PIN 14
                                //  #define MY_SOFT_SPI_MISO_PIN 16
                                //  #define MY_SOFT_SPI_MOSI_PIN 15
                                //#endif
                                //#define MY_RF24_CE_PIN 5
                                //#define MY_RF24_CS_PIN 6
                                // Enable to UDP
                                //#define MY_USE_UDP
                                //#define MY_IP_ADDRESS 192,168,1,100   // If this is disabled, DHCP is used to retrieve address
                                //#define MY_PORT 5003
                                #define IP_PORT 5003        // The port you want to open
                                IPAddress myIp (192, 168, 1, 100);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
                                //#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
                                byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };  // DEAD BEEF FEED
                                // a R/W server on the port
                                EthernetServer server = EthernetServer(IP_PORT);
                                // handle to open connection
                                EthernetClient client = EthernetClient();
                                // Flash leds on rx/tx/err
                                //#define MY_LEDS_BLINKING_FEATURE
                                // Set blinking period
                                // Enable inclusion mode
                                //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                                #if defined(MY_USE_UDP)
                                  #include <EthernetUdp.h>
                                #include <Ethernet.h>
                                //Below the Dallas temp sketch
                                #include <OneWire.h>
                                int numSensors=0;
                                boolean receivedConfig = false;
                                boolean metric = true;
                                MyMessage msg(0,V_TEMP);
                                char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
                                int inputPos = 0;
                                bool sentReady = false;
                                void output(const char *fmt, ... ) {
                                   va_list args;
                                   va_start (args, fmt );
                                   va_end (args);
                                   Serial.print(serialBuffer);
                                   server.write(serialBuffer);
                                  // ////Prepare the ethernet connection
                                  Ethernet.begin(mac, myIp);
                                  sensors.begin();
                                     present(i, S_TEMP);
                                  sleep(conversionTime);
                                    float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                    #if COMPARE_TEMP == 1
                                  sleep(SLEEP_TIME);
                                  Looks like you added your own stuff..
                                  Should simply be
                                  #define MY_IP_ADDRESS 192, 168, 1, 100 // If this is disabled, DHCP is used to retrieve address
                                  And what the following doing here?
                                  And you include <SPI.h> and <MySensor.h> twice.
                                  • B
                                    B
                                    brix7be
                                    to be honnest, i don't know ...
                                    • B
                                      B
                                      brix7be
                                      With the #define MY_IP_ADDRESS i can't compile the projet.
                                      With the arduino command it works now, i can ping it on 192.168.1.100.
                                      But still nothing in domoticz.
                                      Am I on the right way?
                                      thanks again :-)
                                      // Enable to UDP
                                      byte ip[] = { 192, 168, 1, 100 };
                                      byte mac [] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
                                      int numSensors=0;
                                        Ethernet.begin(mac , ip);
                                        wait(1000);
                                        sensors.begin();
                                           present(i, S_TEMP);
                                        sleep(SLEEP_TIME);
                                        I don't understand.. why do you declare ip and mac like that? It most surely isn't picked up by the library. You're probably just getting an ip from your DHCP server.
                                        What compile error do you get when using the defines?
                                        • B
                                          B
                                          brix7be
                                          i've changed as before and it won't compile.
                                          The error is:
                                          no matching function for call to 'EthernetClass::begin(int, int, int, int, int, int, int, int, int, int)'
                                          No it takes the ip I put on the code before, cause the ping respond at this one.
                                          Thks
                                          // Enable to UDP
                                          //byte ip[] = { 192, 168, 1, 100 };
                                          //byte mac [] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
                                          int numSensors=0;
                                            Ethernet.begin(MY_MAC_ADDRESS , MY_IP_ADDRESS);
                                            wait(1000);
                                            sensors.begin();
                                               present(i, S_TEMP);
                                            sleep(SLEEP_TIME);
