  3. Breakout boards - a plea for consistency!
5 Posts 4 Posters 2.5k Views 4 Watching
    MikeF
    I recently built a multi-sensor node, with 3 I2C breakout boards: HTU21D (temperature, humidity), BMP180 (barometric pressure), BH1750FVI (light level). These all had different pinouts (pins at bottom, left to right):
    HTU21D: Vcc > GND > SDA > SCL
    BMP180: 3.3V > SDA > SCL > GND > Vcc (3.6V - 6V)
    BH1750FVI: ADDR (connect to GND) > SDA > SCL > GND > Vcc
    For those of us using stripboard (rather than designed PCBs), it would be good to have a consistent standard! (Oh, and the Ceech board I use has Vcc > SDA > SCL > GND.)
      Try using the MySensors "standard".
      https://github.com/mysensors-kicad/documentation/raw/master/TheMYSXconnector.pdf
        MikeF
        I'm not sure I understand - I was talking about mounting these on a stripboard, where all the connections are different:
        TD22057T 1 Reply Last reply
        • M MikeF
          TD22057T
          TD22057T
          TD22057
          All of those came from different places so it's pretty unlikely anyone here can help...
          • mfalkviddM
            https://xkcd.com/927/
