  3. gw.process -- how often this should be run?
5 Posts 4 Posters 2.7k Views 2 Watching
  • NuubiN
    NuubiN
    Nuubi
    [http://www.mysensors.org/download/sensor_api_15] 'Nodes that expects incoming messages, such as an actuator or repeating nodes, must check for new messages frequently'.
    Any idea how often gw.process() should be called to not miss any messages?
    • TheoLT
      TheoLT
      TheoL
      I'm not sure. But the messages might be buffered. I always use the gw.wait(); in my main loop, because it delays the loop but keeps checking for messages while it's executing the delay.
      • NuubiN
        NuubiN
        Nuubi
        How do you use gw.wait(ms) with the library version 1.4? [http://www.mysensors.org/download/sensor_api_14]
        Is it implemented at all in this version? Switching to 1.5 at this point (of miserable HW development) is not appealing at all:expressionless:
        • karl261K
          karl261K
          karl261
          Hi, just discovered the gw.wait() function. I suppose I should change
          for (int i=0; i <= 30000; i++){
          delay(1);
          for this?
          gw.wait(30000);
            Yes, you should ;)
