  3. Need idea for turn off speakers when tv is off
7 Posts 6 Posters 2.9k Views 3 Watching
  • Tomasz PazioT
    Tomasz PazioT
    Tomasz Pazio
    I have some idea to turn off speakers connected to power when tv turn off.
    I was thinking about ping tv/reciever and when off than simple relay switch.. but... tv has no LAN and recieever do not support ping reply.
    Any idea how to make it happen? Power consumption monitoring?
    • m26872M
      m26872M
      m26872
      Maybe like this?
      • FotoFieberF
        FotoFieberF
        FotoFieber
        Idea 1: You could use a master / slave power strip... :)
        Idea 2: Do you turn of the tv with an IR remote? -> MySensors with IR Reciever
        Idea 3: Maybe you can sense the power state on one of the outputs of the TV? Analog Read?
        • R
          R
          riataman
          You can use a current transformer to detect when the TV is on, I'm doing something like that to detect when my air conditioner units are on.
          Something like this: http://openenergymonitor.org/emon/buildingblocks/how-to-build-an-arduino-energy-monitor
          But as they say, they already sell things to do what you want easily already.
          • tbowmoT
            tbowmoT
            tbowmo
            Depending on the TV manufacturer, there might be a serial port on it, where you could query the power status of the TV.
            I'm thinking about doing that part, with my LG plasma, which have a RS232 service port on the back (and LG is nice enough to actually describe the protocol in their user manual)
            • rvendrameR
              rvendrameR
              rvendrame
              I monitor my Samsung smartTV using the Vera's ping sensor plugin and it works very well.
              ESP8266 GW + mySensors 2.3.2
              Alexa / Google Home
              • Tomasz PazioT
                Tomasz PazioT
                Tomasz Pazio
                Ok solution is now live :)
                PowerNode from GreenWave with power monitoring.
                I'm monitoring power consumption on DVBT reciever. When it goes up from idle, tv and speakers turn on, when goes to idle consumption it turn off all :)
