  3. Office plant monitoring
223 Posts 39 Posters 228.1k Views 42 Watching
  • L
    L
    Lars65
    I know that I am a pain in the *ss. But I have tried to change this code to accept more than one power pin.
    But I don't know how. I know how to mill a PCB, and lot of other stuff, but programming is not my cup of thee.
    I really need to try to study how.
    Bot for now, is it anybody who could help me?
    • mfalkviddM
      How much power do your sensors need? (How many sensors can use the same pin?)
      • mfalkviddM
        This is a VERY quick and dirty solution. I'm off to the movies now. Let me know if it works :-)
        https://codebender.cc/sketch:170297
        Edit: have updated the sketch
        • mfalkviddM
          @Lars65 Just a question before things get too crazy: Will you be running your node on battery power? If you will be using wall power you can just power all sensors continuously from Vcc and get rid of the code for turning on and off the sensors, and get rid of all the battery reporting code.
          D 1 Reply Last reply
          • L
            L
            Lars65
            Hi!
            At the moment do I only have three sensors, and I will be using them on the same arduino. Those will be powered by wall power.
            But I have ordered some more sensors, and some of them will be battery powered.
            Though both me and my wife often forget to water our plants, do I really like this.
            I use Domoticz, and it's easy to get a notification when it's time to water.
            You have been really helpfull. Tomorrow will I mill a new PCB, to test this code.
              damien
              wrote on last edited by damien
              Hi @mfalkvidd and thank you for your nice work and sketch.
              I just have one question about the power pin, I saw on datasheet that the adruino pro mini can handle 40mA max per powerpin. I Have four of these soil moisture sensors but cant find how much current they need... they use a LM393, and the datasheet say 0.4mA..
              Did you think than i coul plug all of them on the same powerpin or i need to use your second sketch ?
              Thanks in advance !
              • mfalkviddM
                @damien: I don't know, unfortunately. Maybe @Lars65 can do a measurement on his moisture sensors?
                  damien
                  @mfalkvidd Ok thanks for your reply, i will wait for @Lars65 to see if he has done the measurement, else i will do it by myself on mine when i receive them.
                  Thx
                  • L
                    L
                    Lars65
                    Hi Guys!
                    No I haven't made any measurements.
                    { 4, 0, 1, // This assumes 2 sensors per pin. First two sensors are powered through pin 4, using analog pins 0 and 1
                    **5, 2, 3, **// Second two sensors get power from pin 5 and are connected to analog pins 2 and 3
                    6, 4, 5 // Third set of sensors get power from pin 6 and are connected to analog pins 4 and 5
                    So I did change 4,0,1, to 4,0,. What I saw with this was that I use power pin 4, to the analog input A0. So now have I made it so A0, has powerpin 4, A1 has powerpin 5, and A2 has powerpin 6.
                    • mfalkviddM
                      #21
                      How did thinks go @Lars65 ?
                      I thought a bit more about this problem and I think I have come up with a pretty neat solution:
                      Throw away the chip on the moisture sensor and connect the "pitchfork" directly to the Arduino. Connect one prong to GND and one prong to an analog pin. No power pins are required.
                      https://codebender.cc/sketch:177182
                      The chip on the moisture sensor is basically a voltage divider. We get the same thing if we use the internal pull-up resistor on the Atmega processor.
                      EDIT: This means you can buy just the "pitchforks" really cheap: http://www.aliexpress.com/item/10pcs-Soil-Hygrometer-Detection-Module-Soil-Moisture-Sensor-Probes/2051713873.html
                      D Fat FlyF 2 Replies Last reply
                      • N
                        N
                        Nicklas Starkel
                        @mfalkvidd , I think there has been many discussions on how these sensors corrodes over time.
                        I can see that this node sleeps between the readings and thus reduces corrosion as it only is powered during reading.
                        However, some threads I've read suggests that you alternate the power, as well, between readings.
                        Something you might implement in the code?
                        Also, do you have an estimate on the duration usage on the batteries for one of your plants?
                        Cheers!
                        • mfalkviddM
                          #23
                          @Nicklas-Starkel If a measurement is taken once per hour, the sensor will only have power 0,008% of the time.
                          If corrosion still is a problem, and if the corrosion can be avoided by reversing polarity for every second measurement, I might add it. It would add complexity to the sketch though, and complexity is often the enemy of reliability.
                          Also, for people wanting to use multiple sensors on the same mcu, reversing polarity would cut the possible number of connected moisture sensors in half since it would require two analog pins per sensor.
                          My estimated battery time on 2xAA for a Mini Pro with removed power led and voltage regulator is 1-2 years.
                            damien
                            Hi @mfalkvidd and thank you very very much for your new version of the skecth for moisture sensors, its very clever ! i will test it as soon as possible
                            • mfalkviddM
                              @Nicklas-Starkel last weekend one of my sensors broke. Both pins were completely corroded and broke just where I connect the dupont wires. I think I will use hot glue to protect the connectors, but I have also added alternating power to my single-sensor sketch. I have this sketch running on three sensors now.
                              https://codebender.cc/sketch:158460
                              R Pierre PP 2 Replies Last reply
                                memheli
                                Newbie to controllers. I'd been looking at PanStamp for this project, and came across your post from Google. This would be my first project w/ micro controllers. How is this tied to the internet for reporting?
                                • mfalkviddM
                                  In MySensors lingo, the Arduino is called a sensor. The part that MySensors calls a controller runs on a "real" computer, and gets information from the sensors. The controller usually handles reporting. The documentation at http://www.mysensors.org/about/network can probably give you a good overview.
                                  • m26872M
                                    m26872M
                                    m26872
                                    Just some ideas to the corrosion issue (any photos?). If both pins were corroded, it may not be sufficient with polarity switching. Perhaps a simple active cathodic protection system could help. E.g. a +wire limited to a few uA and wrapped with some aluminium foil in the soil near the sensor?
                                    I haven't yet got to it, but the plant monitoring is on pretty high on my list.
                                    • m26872M m26872
                                      @m26872 said:
                                      (any photos?)
                                      m26872M 1 Reply Last reply
                                        R
                                        R
                                        rajbadri
                                        @mfalkvidd
                                        i am using your sketch for indoor plant monitoring but have modified the sleep time to one hour . the problem i am facing is that every alternate humidity reading i get is a 0
                                        like
                                        first reading ------ 67%
                                        second reading ----- 0%
                                        third reading ------65%
                                        fourth reading ------- 0%
                                        and likewise
                                        Please Guide
                                        • R rajbadri
                                          @mfalkvidd
                                          like
                                          and likewise
                                          Please Guide
                                          @rajbadri which pins are your sensor connected to?
                                          R 3 Replies Last reply
