  3. OTA updates on Arduino Nano
23 Posts 5 Posters 13.6k Views 4 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @rvweert
    You need to reporgram the bootloader in your nano. To do this, you need a ISP programmer attached to the nano.
    Use either another arduino (clone) with ISP software loaded, to program the target, or buy an avr-dragon, etc. programming device
    • R
      R
      rvweert
      Hey thanks for the advice.
      I actually programmed the MYSbootloader with another Arduino (ISP). Now the programmed Arduino isn't responding anymore. It does work again if I restore the original bootloader. Should I perhaps change something in the fuse settings?
      Rene
      • OitzuO
        OitzuO
        Oitzu
        Rene
        The MYSbootloader doesn't support flashing over Serial! Connect a radio to the nano, make sure it works, and then flash. After the reset of the nano you should see firmware requests in myscontroller.
        • R
          R
          rvweert
          wrote on last edited by rvweert
          Hi and thanks again;-)
          Ok I've got the bootloader and sketch on the node. I also see it in my gateway using MYSController. However when I try to reboot it just starts sending a lot of messages but doesn't reboot. Neither do I seem able to update the firmware, any clue?
          I also added the line 'boolean process();' to the start of the loop.
          Rene
          tekkaT 1 Reply Last reply
          • OitzuO
            OitzuO
            Oitzu
            Rene
            Hi!
            I've seen this behavour before on a relay node.. could you reset the node and look what it sends right after the reset?
              mvader
              mine does this as well.
              It seems like (to me anyways)
              that when i had everything on 1.4 it worked well.
              but once i moved all my stuff over to the 1.5 lib, this stuff didn't play nice anymore.
              hoping that once @tekka releases the new app, it will solve some of those issues.
              • R rvweert
                Rene
                tekkaT
                tekkaT
                tekka
                Rene
                This is strange but not related to MYSbootloader since no fw config requests are received. The node seems to re-initiate over and over, but not reboot. Can you please upload the log file obtaind from MYScontroller to get some additional info. Are all your nodes updated with the same lib version?
                • M mvader
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  Didn't you mention in one of your posts that some nodes were having different lib versions?
                  • tekkaT tekka
                    mvader
                    wrote on last edited by mvader
                    I have everything on 1.5 stable now.
                    but i do notice that i have to constantly disconnect / connect in MYSController
                    I know that the controller and nodes still work, because lights (in my house) turn on and off. but no data is displayed in the controller screen.. i have to D/C
                    same with firmware update. they go so far and then stop.. i have to D/C
                    i have a nano with MYSBootloader acting as a 433 bridge and repeater, it does that (above screen shot) all the time. I'm using the 1.1 v of the bootloader.
                    it felt like things worked much better on 1.4 lib with the MYSController.
                    • M mvader
                      tekkaT
                      tekkaT
                      tekka
                      @mvader are you using serial or tcp/ip to connect the gw? can you post the myscontroller log (ideally with debug on) when those things happen?
                      • R
                        R
                        rvweert
                        Hi Tekka,
                        Please see here my log:
                        MySensors_20151109-085110.log
                        Also yes, all my nodes are running the same version from git.
                        Cheers,
                        Rene
                        • OitzuO
                          OitzuO
                          Oitzu
                          @rvweert: i see no bootloader involved. Could you try to add an wdt_reset(); at the beginning of the setup() routine?
                          • R
                            R
                            rvweert
                            Hi Oitzu,
                            Just tried that, same result...
                            • R
                              R
                              rvweert
                              No more news on this?;-)
                              • OitzuO
                                OitzuO
                                Oitzu
                                @rvweert out of ideas by simply looking at the logs.
                                Maybe @tekka knows anything.
                                Did you try to enable debug on the node and look at the nodes output?
                                • OitzuO Oitzu
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @rvweert I'll look into that in a little bit.
                                  • R rvweert
                                    Hi Tekka,
                                    Cheers,
                                    Rene
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @rvweert there is potentially an id conflict: was the node previously used as gateway? Anyhow, try clearing the eeprom with the ClearEepromConfig sketch and upload the log again.
                                    • R
                                      R
                                      rvweert
                                      Hey Tekka,
                                      Tried clearing both eeproms, still same problem. Actually tried two completely new nano's and same problem again...
                                      tekkaT 2 Replies Last reply
                                      • R rvweert
                                        Hey Tekka,
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @rvweert Looking at the logs, there is no bootloader involved (@Oitzu already confirmed this).
                                        This looks like a bad nRF chip and/or power issues (try with different a cap) since the msgs sent from the GW never reach the node.
                                        • R rvweert
                                          Hey Tekka,
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @rvweert MY_OTA_FIRMWARE_FEATURE enabled in MyConfig.h? This seems to be the cause of the restarting nodes. Try disabling this option unless you are using the sensebender board...
