  3. Forum Banner on Screen
notificationscreengateway
31 Posts 12 Posters 15.1k Views 5 Watching
    mvader
    @Marik said:
    forum. I have also noticed that size of window affects if its shown or not, smaller window does not show it for me.
    yes what he shows is what i'm seeing.
    happens every time, on every machine no matter if you click the x or click here to activate them. keeps coming back no matter what
    • mfalkviddM
      The banner is shown on my ipad as well, but only in landscape mode (probably due to the browser width as suggested above)
        Ok, linked this thread over at NodeBB:
        https://community.nodebb.org/topic/6713/desktop-notifications-popup-problem
        • mfalkviddM
          Looks similar to this issue from 1 year ago https://github.com/psychobunny/nodebb-plugin-desktop-notifications/issues/14
            wrote on last edited by hek
            Yep saw it... looks like that they solved it once.. wonder why it would appear again.. What makes it even stranger is that only some people is experiencing it.
            Corrected a couple of js errors I saw here on this install today. But I doubt that would change anything regarding this issue.
            • E
              E
              emc2
              wrote on last edited by emc2
              For a dirty quick fix you can add the following custom filter in your adblock preferences (works on µBlock)
              forum.mysensors.org###header-menu > .visible-md-block.visible-lg-block.desktop-notification-permission
              • E emc2
                mvader
                @emc2 thanks! that worked
                • mfalkviddM
                  No news so far?
                    Can't help more than referring to this (we're using the latest version of the plugin(0.2.2)):
                    If we'll get an update I'll install it here.
                    • mfalkviddM
                      I'm so tired of clicking close tens of times per day so I figured out how to block this on a URL-based adblocker. (The uBlock suggestion is great, but only works on adblockers that can block using CSS.)
                      On Adblock Plus the following filter works:
                      ||forum.mysensors.org/templates/partials/nodebb-plugin-desktop-notifications/*
                      Will try to find a filter for iOS as well. The problem is even worse there because the banner hides several useful buttons ("WATCH" for example).
                      chiefC 1 Reply Last reply
                        chiefC
                        chiefC
                        chief
                        Thanks for the ABP filter, this banner bugging me for desktop notifications that I'll never enable was driving me absolutely nuts.
                        While using the filter works great, I would rather see the plugin go away as long as it ignores settings within Firefox to disable all desktop notification attempts. Only started seeing this about a month or so ago, very strange.
                        • rmtuckerR
                          rmtuckerR
                          rmtucker
                          I am stuck with this in firefox.
                          Its a nuisance!!!!
                            Weird,
                            What is your setting here:
                            • rmtuckerR
                              rmtuckerR
                              rmtucker
                              @hek
                              My settings as they have always been.
                                Ok, does it disappear if you choose "block" or "allow" for notifications?
                                rmtuckerR 1 Reply Last reply
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  @hek
                                  Makes no difference if i use either of those settings?
                                    Strange, I cannot reproduce in firefox here.
                                      rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      @hek
                                      This is a clean install of firefox as of 2 days ago.
                                      Had to rebuild my computer.
                                      Maybe that has some bearing on the problem.
                                      • L
                                        L
                                        LastSamurai
                                        I am having a similar popup in chrome (windows). I can close the popup (in the bottom right corner) but the "x" is invisible and I get the same popup again every time I use the forum. I don't want any desktop notifications ;)
                                          #31
                                          Understand it might be annoying.. We run the latest version of the notif-plugin mentioned above (0.3.1). So it seems they still have some issues. They had an issue (which is closed) that sound like the things you experience.
                                          I can't seem to find any related user setting in my account either.
                                          https://github.com/psychobunny/nodebb-plugin-desktop-notifications/issues/19
