  3. ESP8266 gateway and sensor node not talking - noobie
megadht11esp8266
37 Posts 6 Posters 21.5k Views 4 Watching
    What does the gateway log say when you restart the sensor?
    • pwatt01P
      pwatt01P
      pwatt01
      Nothing. Or no change at least. The shots above are still the only messages that I am getting, apart from the ESP8266 rebooting by itself occasionaly, and the sensor node tends to repeat itself as new readings come in
        Mersing
        I've setup a ESP8266 Gateway with RF24 Radio.
        I've got a RF24 Node with DS18B20.
        I'ved used Esp8266Gateway.ino / DallasTemperatureSensor.ino out of the box.
        Everything is working fine. Node and GW are communicating.
        I'm now trying to run this setup with RF69. I'm facing the same issue as described in the initial post.
        Pin mapping
        RF69 <-> ESP8266
        DIO0 <-> GPIO4
        SCK <-> GPIO14
        MOSI <-> GPIO13
        MISO <-> GPIO12
        CS <-> GPIO15
        From RFM69.h
        define RF69_SPI_CS               SS
        #elif defined(ARDUINO_ARCH_ESP8266)
          // TODO !! Untested code! Entering unknown territory...
          #define RF69_IRQ_PIN          4
          #define RF69_IRQ_NUM          0
        By default, from RFM69.h, RF69_IRQ_PIN is 2.
        However to properly boot GPIO15 must be LOW and GPIO2 must be HIGH.
        Connecting IRQ to GPIO2, RF69 pull its IRQ to LOW, making GPIO2 LOW and ESP8266 not booting.
        Then I'll use GPIO4.
        I'm using the same config file for GW and Node (e.g same NWETWORKID, ENCRYPTKEY, FREQUENCY).
        On the Node Side : DallasTemperatureSensor.ino
        #define isRFM69HW true // Enable High Power
        MyTransportRFM69 transport( RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, isRFM69HW, RF69_IRQ_NUM );
        MySensor gw( transport );
        gw.begin( NULL, 8 );
        On the GW Side : Esp8266Gateway.ino
        MyTransportRFM69 transport(RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, isRFM69HW, RF69_IRQ_NUM);
        OUTPUT
        GW Side
        ESP8266 MySensors Gateway
        Connecting to WRT54G
        .......Connected!
        IP: 192.168.1.25
        Node
        send: 8-8-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=fail:1.5
        send: 8-8-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
        sensor started, id=8, parent=0, distance=1
        send: 8-8-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=fail:Temperature Sensor
        send: 8-8-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.1
        send: 8-8-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
        send: 8-8-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:21.5
        find parent
        send: 8-8-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
        No more log output from the Gateway.
        Any clue ?
          Mersing
          I received addition log on the GW:
          .......Connected!
          IP: 192.168.1.25
          0;0;3;0;9;Inclusion started by button.
          0;0;3;0;5;1
          0;0;3;0;5;0
          "Inclusion started by button." are coming randomly (not triggered by node reboot ).
            Guys, would be great if you used the development branch instead.
            Really need more testers of that code... also and any fixes for ESP8266/RF69 would be done in the dev-branch.
              Mersing
              I'm now testing with 1.6, on GW and Node.
              I'm trying to get familiar with the 1.6 changes.
              On the node how can I setup the NODE ID ? ( it seems that gw.begin( NULL, 5) can't be used anymore).
              On the Node side, I'm using DallasTemperatureSensor.ino.
              Should I add presentation() call from Setup () ?
              void setup()   {
                sensors.begin();
                presentation();
              I've setup the communication with RF24, as a first test.
              From the GW
              0;0;3;0;9;read: 5-5-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
              0;0;3;0;9;read: 5-5-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
              0;0;3;0;9;read: 5-5-0 s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature Senso
              0;0;3;0;9;read: 5-5-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
              0;0;3;0;9;read: 5-5-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
              0;0;3;0;9;read: 5-5-0 s=0,c=1,t=0,pt=7,l=5,sg=0:23.6
              0;0;3;0;9;read: 5-5-0 s=0,c=1,t=0,pt=7,l=5,sg=0:23.7
              Everything is working fine. (Seems the Node ID is coming from previous 1.5 upload, I've setup it to 5)
              I've then replaced the radio by RF69 ones.
              Below the changes in GatewayESP8266.ino
              #define MY_RADIO_RFM69
              #define MY_RF69_IRQ_PIN 4
              Node ouput
              Starting...
              send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=fail:1.6.0-beta
              send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
              send: 5-5-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=fail:Temperature Sensor
              send: 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.1
              sensor started, id=5, parent=0, distance=1
              find parent
              send: 5-5-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
              send: 5-5-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
              send: 5-5-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:22.5
              send: 5-5-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:22.6
              GW Output
              0;0;3;0;9;Starting...
              scandone
              f 0, ....scandone
              .add 0
              aid 7
              pm open phy_2,type:2 0 0
              cnt
              connected with WRT54G, channel 6
              dhcp client start...
              .ip:192.168.1.25,mask:255.255.255.0,gw:192.168.1.1
              .IP: 192.168.1.25
              sl
              f -240, ....scandone
              usl
              sul 7 0
              reconnect
              rm 0
              pm close 7 0 0/3399505
              f 0, ....scandone
              .add 0
              aid 7
              cnt
              ..ip:192.168.1.25,mask:255.255.255.0,gw:192.168.1.1
              .Connected!
              IP: 192.168.1.25
              Nothing more on the GW side.
              Any idea ? Where (lib) can I start troubleshooting ?
              Regards.
                Set static id with:
                #define MY_NODE_ID xx
                My guess is something goes wrong here:
                https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/drivers/RFM69/RFM69.cpp#L47
                  Mersing
                  I had a look at RFM69.cpp, bool RFM69::initialize function.
                  It a bit far away from my current skill to debug.
                  I've tried to display registers to check if they have been properly initialized.
                    Serial.println( "bool RFM69::initialize" );
                    Serial.println( "Read Registers" );
                    Serial.print( "RegOpMode Read 0x01 : " );
                    Serial.println( readReg( 0x01) );
                    Serial.print( "RegDataModul Read 0x02 : " );
                    Serial.println( readReg( 0x02) );
                    Serial.print( "RegVersion Read 0x10 : " );
                    Serial.println( readReg( 0x10) );
                    Serial.print( "RegRssiValue Read 0x24) : " );
                    Serial.println( readReg( 0x24) );
                    Serial.println( "" );
                  Output is
                  Read Registers
                  RegOpMode Read 0x01 : 4
                  RegDataModul Read 0x02 : 0
                  RegVersion Read 0x10 : 36
                  RegRssiValue Read 0x24) : 56
                  scandone
                  f 0, ....scandone
                  .add 0
                  aid 7
                  cnt
                  Seems the registers are OK. However I can't go a step further.
                  I'm please to help for testing any new enhancement.
                  Regards,
                  Mersing.
                    Hmm... I should really order a few RFM69 radios myself.
                    I only have a couple of Moteions. Doesn't help much if I would help out debugging ESP8266 with RFM69.
                      Mersing
                      You could maybe hack / re-use the radio from the Motino :smiley:
                        Na... just have to wait for the china slow boat. Should be here before christmas :zzz:
                        • F
                          F
                          Fabien
                          I have same bug : http://forum.mysensors.org/topic/2538/esp8266-and-rfm69w-loop-reboot
                            Are you getting the same error in dev branch?
                            • F
                              F
                              Fabien
                              With the last git developpement it works. except when a node start presentation, gateway reboot. And sometimes it reboots randomless.
                              node is a sensebender with MySensors 1.6 and gateway with 1.6 too.
                              Important : You have to define MY_RF69_IRQ_NUM = MY_RF26_IRQ_PIN on ESP8266
                              #define MY_RF69_IRQ_PIN 15
                              #define MY_RF69_SPI_CS 2
                              #define MY_RF69_IRQ_NUM 15
                              Result is
                              connected with PandoraBox_1BB657, channel 1
                              .ip:192.168.2.165,mask:255.255.255.0,gw:192.168.2.1
                              .IP: 192.168.2.165
                              0;0;3;0;9;Init complete, id=0, parent=0, distance=0
                              chg_B:-120
                              Soft WDT reset
                              ctx: cont
                              sp: 3ffef9a0 end: 3ffefc60 offset: 01b0
                              >>>stack>>>
                              3ffefb50:  00000001 3ffefd00 3ffeff68 00000001
                              3ffefb60:  00000024 3ffefd00 3ffeff68 402022f2
                              3ffefb70:  3ffe8496 00000000 3ffefd00 40202378
                              3ffefb80:  3ffe8496 00000000 3ffefd00 40202563
                              3ffefb90:  3ffefd1e 00000001 3ffefd00 40202a43
                              3ffefba0:  3fffdc20 00000000 3ffeec28 3ffefcd8
                              3ffefbb0:  3fffdc20 3ffefd1d 3ffefd00 40202e0c
                              3ffefbc0:  40209c8d 00000000 3ffeec28 40203ed1
                              3ffefbd0:  00000000 00000002 3ffefe58 402039d0
                              3ffefbe0:  00000000 3ffefd00 3ffeff68 40202338
                              3ffefbf0:  40101500 402059d6 3ffeff50 3ffefc20
                              3ffefc00:  3ffefc10 00000004 3ffefcf9 40202358
                              3ffefc10:  3fffdc20 00000000 00000000 3ffeec30
                              3ffefc20:  3fffdc20 00000000 3ffeec28 3ffeec30
                              3ffefc30:  3fffdc20 00000000 3ffeec28 40203aee
                              3ffefc40:  00000000 00000000 3ffeec28 402041a0
                              3ffefc50:  00000000 00000000 3ffeec40 40100114
                              <<<stack<<<
                              �!�L�<1���0;0;3;0;9;Starting gateway (RRNGE-, 1.6.0-beta)
                              0;0;3;0;9;Radio init successful.
                              scandone
                              state: 0 -> 2 (b0)
                              .state: 2 -> 3 (0)
                              state: 3 -> 5 (10)
                              add 0
                              aid 3
                              cnt
                              chg_B:-60
                              .IP: 192.168.2.165
                              chg_B:-120
                              0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.6
                              0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:51
                              0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.4
                              And something strange, I only recieve Humidity one time. (sensebender defaut sketch with FORCE_TRANSMIT_INTERVAL 0 )
                              • F
                                F
                                Fabien
                                wrote on last edited by Fabien
                                @hek you are right it works fine with
                                #define TIME_OUT 500
                                in https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/drivers/RFM69/RFM69.cpp#L47
                                0�~?�4�!�{�OAa�0;0;3;0;9;Starting gateway (RRNGE-, 1.6.0-beta)
                                scandone
                                state: 0 -> 2 (b0)
                                .state: 2 -> 3 (0)
                                state: 3 -> 5 (10)
                                add 0
                                aid 3
                                cnt
                                chg_B:-60
                                .IP: 192.168.2.165
                                chg_B:-120
                                0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.8
                                0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:54
                                0;0;3;0;9;read: 1-1-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
                                0;0;3;0;9;read: 1-1-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF0300
                                0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=17,sg=0:Sensebender Micro
                                0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.4
                                0;0;3;0;9;read: 1-1-0 s=2,c=0,t=7,pt=0,l=0,sg=0:
                                0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.7
                                0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:50
                                0;0;3;0;9;Client 0 connected
                                0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.5
                                I don't try with other timeout values.
                                  Ok, great. We need to increase timeout then.
                                  • F
                                    F
                                    Fabien
                                    @hek Yes and perhaps a feature to set MY_RF69_IRQ_NUM = MY_RF26_IRQ_PIN when using ESP8266. Do You want to test other timeout values ? Is it critical ?
                                      @Fabien said:
                                      MY_RF26_IRQ_PIN
                                      I cannot find this defined anywhere...
                                      • F
                                        F
                                        Fabien
                                        sorry MY_RF69_IRQ_PIN ...
                                        • F
                                          F
                                          Fabien
                                          Work with 51ms timeout with my config. I set 60ms to be "secure"
