  3. ESP8266 gateway and sensor node not talking - noobie
megadht11esp8266
37 Posts 6 Posters 21.5k Views 4 Watching
    Guys, would be great if you used the development branch instead.
    Really need more testers of that code... also and any fixes for ESP8266/RF69 would be done in the dev-branch.
      Mersing
      I'm now testing with 1.6, on GW and Node.
      I'm trying to get familiar with the 1.6 changes.
      On the node how can I setup the NODE ID ? ( it seems that gw.begin( NULL, 5) can't be used anymore).
      On the Node side, I'm using DallasTemperatureSensor.ino.
      Should I add presentation() call from Setup () ?
      void setup()   {
        sensors.begin();
        presentation();
      I've setup the communication with RF24, as a first test.
      From the GW
      0;0;3;0;9;read: 5-5-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
      0;0;3;0;9;read: 5-5-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
      0;0;3;0;9;read: 5-5-0 s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature Senso
      0;0;3;0;9;read: 5-5-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
      0;0;3;0;9;read: 5-5-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
      0;0;3;0;9;read: 5-5-0 s=0,c=1,t=0,pt=7,l=5,sg=0:23.6
      0;0;3;0;9;read: 5-5-0 s=0,c=1,t=0,pt=7,l=5,sg=0:23.7
      Everything is working fine. (Seems the Node ID is coming from previous 1.5 upload, I've setup it to 5)
      I've then replaced the radio by RF69 ones.
      Below the changes in GatewayESP8266.ino
      #define MY_RADIO_RFM69
      #define MY_RF69_IRQ_PIN 4
      Node ouput
      Starting...
      send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=fail:1.6.0-beta
      send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
      send: 5-5-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=fail:Temperature Sensor
      send: 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.1
      sensor started, id=5, parent=0, distance=1
      find parent
      send: 5-5-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
      send: 5-5-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
      send: 5-5-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:22.5
      send: 5-5-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:22.6
      GW Output
      0;0;3;0;9;Starting...
      scandone
      f 0, ....scandone
      .add 0
      aid 7
      pm open phy_2,type:2 0 0
      cnt
      connected with WRT54G, channel 6
      dhcp client start...
      .ip:192.168.1.25,mask:255.255.255.0,gw:192.168.1.1
      .IP: 192.168.1.25
      ESP8266 MySensors Gateway
      Connecting to WRT54G
      sl
      f -240, ....scandone
      usl
      sul 7 0
      reconnect
      rm 0
      pm close 7 0 0/3399505
      f 0, ....scandone
      .add 0
      aid 7
      cnt
      ..ip:192.168.1.25,mask:255.255.255.0,gw:192.168.1.1
      .Connected!
      IP: 192.168.1.25
      Nothing more on the GW side.
      Any idea ? Where (lib) can I start troubleshooting ?
      Regards.
        Set static id with:
        #define MY_NODE_ID xx
        My guess is something goes wrong here:
        https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/drivers/RFM69/RFM69.cpp#L47
          Mersing
          I had a look at RFM69.cpp, bool RFM69::initialize function.
          It a bit far away from my current skill to debug.
          I've tried to display registers to check if they have been properly initialized.
            Serial.println( "bool RFM69::initialize" );
            Serial.println( "Read Registers" );
            Serial.print( "RegOpMode Read 0x01 : " );
            Serial.println( readReg( 0x01) );
            Serial.print( "RegDataModul Read 0x02 : " );
            Serial.println( readReg( 0x02) );
            Serial.print( "RegVersion Read 0x10 : " );
            Serial.println( readReg( 0x10) );
            Serial.print( "RegRssiValue Read 0x24) : " );
            Serial.println( readReg( 0x24) );
            Serial.println( "" );
          Output is
          Read Registers
          RegOpMode Read 0x01 : 4
          RegDataModul Read 0x02 : 0
          RegVersion Read 0x10 : 36
          RegRssiValue Read 0x24) : 56
          scandone
          f 0, ....scandone
          .add 0
          aid 7
          cnt
          Seems the registers are OK. However I can't go a step further.
          I'm please to help for testing any new enhancement.
          Regards,
          Mersing.
            Hmm... I should really order a few RFM69 radios myself.
            I only have a couple of Moteions. Doesn't help much if I would help out debugging ESP8266 with RFM69.
              Mersing
              You could maybe hack / re-use the radio from the Motino :smiley:
                Na... just have to wait for the china slow boat. Should be here before christmas :zzz:
                • F
                  F
                  Fabien
                  I have same bug : http://forum.mysensors.org/topic/2538/esp8266-and-rfm69w-loop-reboot
                    Are you getting the same error in dev branch?
                    • F
                      F
                      Fabien
                      With the last git developpement it works. except when a node start presentation, gateway reboot. And sometimes it reboots randomless.
                      node is a sensebender with MySensors 1.6 and gateway with 1.6 too.
                      Important : You have to define MY_RF69_IRQ_NUM = MY_RF26_IRQ_PIN on ESP8266
                      #define MY_RF69_IRQ_PIN 15
                      #define MY_RF69_SPI_CS 2
                      #define MY_RF69_IRQ_NUM 15
                      Result is
                      connected with PandoraBox_1BB657, channel 1
                      .ip:192.168.2.165,mask:255.255.255.0,gw:192.168.2.1
                      .IP: 192.168.2.165
                      0;0;3;0;9;Init complete, id=0, parent=0, distance=0
                      chg_B:-120
                      Soft WDT reset
                      ctx: cont
                      sp: 3ffef9a0 end: 3ffefc60 offset: 01b0
                      >>>stack>>>
                      3ffefb50:  00000001 3ffefd00 3ffeff68 00000001
                      3ffefb60:  00000024 3ffefd00 3ffeff68 402022f2
                      3ffefb70:  3ffe8496 00000000 3ffefd00 40202378
                      3ffefb80:  3ffe8496 00000000 3ffefd00 40202563
                      3ffefb90:  3ffefd1e 00000001 3ffefd00 40202a43
                      3ffefba0:  3fffdc20 00000000 3ffeec28 3ffefcd8
                      3ffefbb0:  3fffdc20 3ffefd1d 3ffefd00 40202e0c
                      3ffefbc0:  40209c8d 00000000 3ffeec28 40203ed1
                      3ffefbd0:  00000000 00000002 3ffefe58 402039d0
                      3ffefbe0:  00000000 3ffefd00 3ffeff68 40202338
                      3ffefbf0:  40101500 402059d6 3ffeff50 3ffefc20
                      3ffefc00:  3ffefc10 00000004 3ffefcf9 40202358
                      3ffefc10:  3fffdc20 00000000 00000000 3ffeec30
                      3ffefc20:  3fffdc20 00000000 3ffeec28 3ffeec30
                      3ffefc30:  3fffdc20 00000000 3ffeec28 40203aee
                      3ffefc40:  00000000 00000000 3ffeec28 402041a0
                      3ffefc50:  00000000 00000000 3ffeec40 40100114
                      <<<stack<<<
                      �!�L�<1���0;0;3;0;9;Starting gateway (RRNGE-, 1.6.0-beta)
                      0;0;3;0;9;Radio init successful.
                      scandone
                      state: 0 -> 2 (b0)
                      .state: 2 -> 3 (0)
                      state: 3 -> 5 (10)
                      add 0
                      aid 3
                      cnt
                      chg_B:-60
                      .IP: 192.168.2.165
                      chg_B:-120
                      0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.6
                      0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:51
                      0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.4
                      And something strange, I only recieve Humidity one time. (sensebender defaut sketch with FORCE_TRANSMIT_INTERVAL 0 )
                      • F
                        F
                        Fabien
                        wrote on last edited by Fabien
                        @hek you are right it works fine with
                        #define TIME_OUT 500
                        in https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/drivers/RFM69/RFM69.cpp#L47
                        0�~?�4�!�{�OAa�0;0;3;0;9;Starting gateway (RRNGE-, 1.6.0-beta)
                        scandone
                        state: 0 -> 2 (b0)
                        .state: 2 -> 3 (0)
                        state: 3 -> 5 (10)
                        add 0
                        aid 3
                        cnt
                        chg_B:-60
                        .IP: 192.168.2.165
                        chg_B:-120
                        0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.8
                        0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:54
                        0;0;3;0;9;read: 1-1-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
                        0;0;3;0;9;read: 1-1-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF0300
                        0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=17,sg=0:Sensebender Micro
                        0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.4
                        0;0;3;0;9;read: 1-1-0 s=2,c=0,t=7,pt=0,l=0,sg=0:
                        0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.7
                        0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:50
                        0;0;3;0;9;Client 0 connected
                        0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.5
                        I don't try with other timeout values.
                          Ok, great. We need to increase timeout then.
                          • F
                            F
                            Fabien
                            @hek Yes and perhaps a feature to set MY_RF69_IRQ_NUM = MY_RF26_IRQ_PIN when using ESP8266. Do You want to test other timeout values ? Is it critical ?
                              @Fabien said:
                              MY_RF26_IRQ_PIN
                              I cannot find this defined anywhere...
                              • F
                                F
                                Fabien
                                sorry MY_RF69_IRQ_PIN ...
                                • F
                                  F
                                  Fabien
                                  Work with 51ms timeout with my config. I set 60ms to be "secure"
                                    #23
                                    Better add a yield() call in those blocking wait loops.
                                    When quiclkly looking over the code of the RF69 driver, the RFM69::initialize call could in theory block for 1.5 sec...
                                    That's a watchdog reset waiting to happen!
                                      Yep,
                                      https://github.com/mysensors/Arduino/pull/287
                                        Yep,
                                        @hek :+1:
                                          Mersing
                                          This is working great !
                                          Tx for this !
