  3. ESP8266 gateway and sensor node not talking - noobie
megadht11esp8266
37 Posts 6 Posters 21.5k Views 4 Watching
    Mersing
    I had a look at RFM69.cpp, bool RFM69::initialize function.
    It a bit far away from my current skill to debug.
    I've tried to display registers to check if they have been properly initialized.
      Serial.println( "bool RFM69::initialize" );
      Serial.println( "Read Registers" );
      Serial.print( "RegOpMode Read 0x01 : " );
      Serial.println( readReg( 0x01) );
      Serial.print( "RegDataModul Read 0x02 : " );
      Serial.println( readReg( 0x02) );
      Serial.print( "RegVersion Read 0x10 : " );
      Serial.println( readReg( 0x10) );
      Serial.print( "RegRssiValue Read 0x24) : " );
      Serial.println( readReg( 0x24) );
      Serial.println( "" );
    Output is
    0;0;3;0;9;Starting...
    Read Registers
    RegOpMode Read 0x01 : 4
    RegDataModul Read 0x02 : 0
    RegVersion Read 0x10 : 36
    RegRssiValue Read 0x24) : 56
    scandone
    f 0, ....scandone
    .add 0
    aid 7
    pm open phy_2,type:2 0 0
    cnt
    Seems the registers are OK. However I can't go a step further.
    I'm please to help for testing any new enhancement.
    Regards,
    Mersing.
      Hmm... I should really order a few RFM69 radios myself.
      I only have a couple of Moteions. Doesn't help much if I would help out debugging ESP8266 with RFM69.
        Mersing
        You could maybe hack / re-use the radio from the Motino :smiley:
          Na... just have to wait for the china slow boat. Should be here before christmas :zzz:
          • F
            F
            Fabien
            I have same bug : http://forum.mysensors.org/topic/2538/esp8266-and-rfm69w-loop-reboot
              Are you getting the same error in dev branch?
              • F
                F
                Fabien
                With the last git developpement it works. except when a node start presentation, gateway reboot. And sometimes it reboots randomless.
                node is a sensebender with MySensors 1.6 and gateway with 1.6 too.
                Important : You have to define MY_RF69_IRQ_NUM = MY_RF26_IRQ_PIN on ESP8266
                #define MY_RADIO_RFM69
                #define MY_RF69_IRQ_PIN 15
                #define MY_RF69_SPI_CS 2
                #define MY_RF69_IRQ_NUM 15
                Result is
                connected with PandoraBox_1BB657, channel 1
                dhcp client start...
                .ip:192.168.2.165,mask:255.255.255.0,gw:192.168.2.1
                .IP: 192.168.2.165
                0;0;3;0;9;Init complete, id=0, parent=0, distance=0
                chg_B:-120
                Soft WDT reset
                ctx: cont
                sp: 3ffef9a0 end: 3ffefc60 offset: 01b0
                >>>stack>>>
                3ffefb50:  00000001 3ffefd00 3ffeff68 00000001
                3ffefb60:  00000024 3ffefd00 3ffeff68 402022f2
                3ffefb70:  3ffe8496 00000000 3ffefd00 40202378
                3ffefb80:  3ffe8496 00000000 3ffefd00 40202563
                3ffefb90:  3ffefd1e 00000001 3ffefd00 40202a43
                3ffefba0:  3fffdc20 00000000 3ffeec28 3ffefcd8
                3ffefbb0:  3fffdc20 3ffefd1d 3ffefd00 40202e0c
                3ffefbc0:  40209c8d 00000000 3ffeec28 40203ed1
                3ffefbd0:  00000000 00000002 3ffefe58 402039d0
                3ffefbe0:  00000000 3ffefd00 3ffeff68 40202338
                3ffefbf0:  40101500 402059d6 3ffeff50 3ffefc20
                3ffefc00:  3ffefc10 00000004 3ffefcf9 40202358
                3ffefc10:  3fffdc20 00000000 00000000 3ffeec30
                3ffefc20:  3fffdc20 00000000 3ffeec28 3ffeec30
                3ffefc30:  3fffdc20 00000000 3ffeec28 40203aee
                3ffefc40:  00000000 00000000 3ffeec28 402041a0
                3ffefc50:  00000000 00000000 3ffeec40 40100114
                <<<stack<<<
                �!�L�<1���0;0;3;0;9;Starting gateway (RRNGE-, 1.6.0-beta)
                0;0;3;0;9;Radio init successful.
                scandone
                state: 0 -> 2 (b0)
                .state: 2 -> 3 (0)
                state: 3 -> 5 (10)
                add 0
                aid 3
                cnt
                chg_B:-60
                .IP: 192.168.2.165
                chg_B:-120
                0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.6
                0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:51
                0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.4
                And something strange, I only recieve Humidity one time. (sensebender defaut sketch with FORCE_TRANSMIT_INTERVAL 0 )
                • F
                  F
                  Fabien
                  wrote on last edited by Fabien
                  @hek you are right it works fine with
                  #define TIME_OUT 500
                  in https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/drivers/RFM69/RFM69.cpp#L47
                  0�~?�4�!�{�OAa�0;0;3;0;9;Starting gateway (RRNGE-, 1.6.0-beta)
                  scandone
                  state: 0 -> 2 (b0)
                  .state: 2 -> 3 (0)
                  state: 3 -> 5 (10)
                  add 0
                  aid 3
                  cnt
                  chg_B:-60
                  .IP: 192.168.2.165
                  chg_B:-120
                  0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.8
                  0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:54
                  0;0;3;0;9;read: 1-1-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
                  0;0;3;0;9;read: 1-1-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFFFF0300
                  0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=17,sg=0:Sensebender Micro
                  0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.4
                  0;0;3;0;9;read: 1-1-0 s=2,c=0,t=7,pt=0,l=0,sg=0:
                  0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.7
                  0;0;3;0;9;read: 1-1-0 s=2,c=1,t=1,pt=2,l=2,sg=0:50
                  0;0;3;0;9;Client 0 connected
                  0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:24.5
                  I don't try with other timeout values.
                    Ok, great. We need to increase timeout then.
                    • F
                      F
                      Fabien
                      @hek Yes and perhaps a feature to set MY_RF69_IRQ_NUM = MY_RF26_IRQ_PIN when using ESP8266. Do You want to test other timeout values ? Is it critical ?
                        @Fabien said:
                        MY_RF26_IRQ_PIN
                        I cannot find this defined anywhere...
                        • F
                          F
                          Fabien
                          sorry MY_RF69_IRQ_PIN ...
                          • F
                            F
                            Fabien
                            Work with 51ms timeout with my config. I set 60ms to be "secure"
                              #23
                              Better add a yield() call in those blocking wait loops.
                              When quiclkly looking over the code of the RF69 driver, the RFM69::initialize call could in theory block for 1.5 sec...
                              That's a watchdog reset waiting to happen!
                                Yep,
                                https://github.com/mysensors/Arduino/pull/287
                                  Yep,
                                  @hek :+1:
                                    Mersing
                                    This is working great !
                                    Tx for this !
                                    • chrilleC
                                      chrilleC
                                      chrille
                                      I am seeing something similar with RFM69 (specifically RFM69CW) and ESP8266. I have build an ESP8266 gateway based on the GatewayESP8266 sketch and this is what I changed
                                      #define MY_GATEWAY_ESP8266
                                      #define MY_RF69_IRQ_PIN 4
                                      #define MY_RF69_SPI_CS 15
                                      #define MY_RF69_IRQ_NUM 4
                                      I build a sensor node with the DallasTemperatureSensor sketch on an Arduino Mini Pro and defined
                                      When I start up the gateway I see
                                      0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0-beta)
                                      ....scandone
                                      state: 0 -> 2 (b0)
                                      state: 2 -> 3 (0)
                                      state: 3 -> 5 (10)
                                      add 0
                                      aid 8
                                      cnt
                                      connected with AP, channel 1
                                      ip:62.x.x.x,mask:255.255.255.128,gw:62.x.x.x
                                      .IP: 62.x.x.x
                                      So far so good - I assume all the radio wiring is OK, since the radio init is successful
                                      On the sensor node I see
                                      Starting sensor (RRNNA-, 2.0.0-beta)
                                      find parent
                                      send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                                      find parent
                                      find parent
                                      Init complete, id=255, parent=255, distance=255
                                      As soon as the sensor node is started the ESP8266 crashes with a WDT reset
                                      Soft WDT reset
                                      ctx: cont
                                      sp: 3ffef370 end: 3ffef630 offset: 01b0
                                      >>>stack>>>
                                      3ffef520:  00000001 3ffef6d4 3ffef964 00000000
                                      3ffef530:  00000024 3ffef6d4 3ffef964 40202436
                                      3ffef540:  3ffe8432 00000000 3ffef6d4 402024bc
                                      3ffef550:  3ffe8432 00000000 3ffef6d4 402026a7
                                      3ffef560:  3ffef6f2 00000001 3ffef6d4 40202b87
                                      3ffef570:  3fffdae0 00000000 3ffee600 3ffef6ac
                                      3ffef580:  3fffdae0 3ffef6f1 3ffef6d4 40202cf4
                                      3ffef590:  3fff1210 00000000 3ffee600 402042b4
                                      3ffef5a0:  00000000 00000002 3ffef82c 40203d20
                                      3ffef5b0:  00000000 3ffef6d4 3ffef964 4020247c
                                      3ffef5c0:  401057ff 00000400 00000103 3ffef5f0
                                      3ffef5d0:  3ffef5e0 00000004 3ffef6cd 4020249c
                                      3ffef5e0:  3ffe8920 00000000 00000000 3ffee608
                                      3ffef5f0:  3fffdae0 00000000 3ffee600 3ffee608
                                      3ffef600:  3fffdae0 00000000 3ffee600 40203e6c
                                      3ffef610:  feefeffe feefeffe 3ffee600 402045b4
                                      3ffef620:  feefeffe feefeffe 3ffee610 40100114
                                      <<<stack<<<
                                      The libraries are 2.0 beta as from a few days ago. I consider the power to the ESP8266 to be OK, since I use the same for en NRF24 based gateway and also for several other ESP modules.
                                      From the thread I understand that known issues should be fixed in the current beta. Any ideas on how to move on?
                                      • chrilleC chrille
                                        ....scandone
                                        state: 0 -> 2 (b0)
                                        state: 2 -> 3 (0)
                                        state: 3 -> 5 (10)
                                        add 0
                                        aid 8
                                        cnt
                                        .IP: 62.x.x.x
                                        find parent
                                        find parent
                                        find parent
                                        Soft WDT reset
                                        ctx: cont
                                        >>>stack>>>
                                        <<<stack<<<
                                        @chrille Try adding the following line to your setup() function:
                                        ESP.wdtDisable();
                                        It should disable the (software) watchdog on ESP. See if it continues, or if it will now just hang.
                                        chrilleC 1 Reply Last reply
                                        • YveauxY Yveaux
                                          ESP.wdtDisable();
                                          chrilleC
                                          chrilleC
                                          chrille
                                          @Yveaux Just tried that. The change removed the watchdog message and the stack trace, but the module still reboots
                                          chrilleC YveauxY 2 Replies Last reply
