  3. RFM69 problems
RFM69 problems
34 Posts 5 Posters 17.1k Views 2 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Thanks but I can't say that I understand, do I have to add a second "true" at the end?
    hekH 1 Reply Last reply
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      And should I just add "MyTransportRFM69 transport (RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, true, RF69_IRQ_NUM, true) ;"
      To the beginning of the sensor sketches to?
        @Cliff-Karlsson
        Sorry, missed the "true" argument you already had in your argument list.
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          Ok, but do I still need to add some RFM info to the sensor sketches?
          I really think that there should be some tutorial of everything that needs to be modified in the gateway and sensor sketches to be able to use the RFM69 radio
            Yes, default is that NRF radio gets initialized.
            • B
              B
              BenCranston
              @Cliff-Karlsson
              Here is what I did to get my RFM69HW's working (the high power variant):
              from MyConfig.h:
              *  RFM69 Driver Defaults
              #define RFM69_FREQUENCY     RF69_915MHZ
              #define RFM69_ENABLE_ENCRYPTION
              I had trouble with the #isRFM69HW define not working in the sketch for whatever reason, so I just went into MyTransportRFM69.h and modified the default of "false" to "true" like so:
              class MyTransportRFM69 : public MyTransport
              public:
                      MyTransportRFM69(uint8_t freqBand=RFM69_FREQUENCY, uint8_t networkId=RFM69_NETWORKID, uint8_t slaveSelectPin=RF69_SPI_CS, uint8_t interruptPin=RF69_IRQ_PIN, bool isRFM69HW=true, uint8_t interruptNum=RF69_IRQ_NUM);
              Then in my sketch, something like this:
              #define MY_RADIO_RFM69
                gw.sendSketchInfo(SN, SV);
                gw.present(BUTTON1, S_LIGHT);  // Top Button
                gw.process(); // tickle the MySensors framework
                check_buttons();  // update logical state from button changes
                update_mote();  //  Apply any gathered state changes to the actual hardware
              ... and bunch of other code not shown...
              There's likely a better way, but my brute force worked. I'd recommend that you start testing without the code signing turned on. It's easier to debug things not talking to the gateway with less features enabled as a start. Then add back in the message signing and you should be up and running. Once you've got your MyConfig.h all happy then it's really easy to use and replicate in your node sketches.
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                Thank, will try asap. Just a question, in your gateway did you only add "MyTransportRFM69 transport;" or did you also add the stuff from your sketch example like: #define MY_RADIO_RFM69 ?
                B 2 Replies Last reply
                  B
                  B
                  BenCranston
                  @Cliff-Karlsson The only things I really had to edit, was in MyConfig.h for the network ID, Frequency and encryption settings. In the sketch you just add the first line "#define MY_RADIO_RFM69" and the rest gets sorted out by the libraries. If you don't add the #define MY_RADIO_RFM69 it will default as @hek indicated to the NRF radio.
                    @Cliff-Karlsson
                    Note that @BenCranston is using the development branch.
                      B
                      B
                      BenCranston
                      @Cliff-Karlsson I just posted to Git my Serial gateway and a node. The code is still in flux, but it might help your endeavors. Find it here: https://github.com/TheCranston/MY-Sensors.git Caveat emptor... :) (first time posting anything via Github, so please excuse any conventions that I might have ignored - I'm learning)
                      @hek, good point. I just checked my Version.h and it says "1.5" which i thought was the latest master... humm... gotta check it over closely now.
                        I will do a couple of adjustments of the RF69 stuff tonight here on dev-branch.
                        Add a mis-wired check like we do for the RF24 driver. I also currently you have to do a
                        #define MY_IS_RFM69HW true
                        to activate the HW-version... this will be changed to
                        • Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          Ok, one more stupid question. If I want to try the developer branch do I just install the regular 1.5 zip amd then just overwrite them with the files from the developer branch on git?
                          • Cliff KarlssonC
                            Cliff KarlssonC
                            Cliff Karlsson
                            Ok, I think I have figured it out. But I am trying this sketch:
                             * LEDs (OPTIONAL):
                             * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
                            //#define MY_RADIO_NRF24
                            // Enable serial gateway
                            #define MY_GATEWAY_SERIAL
                            // Flash leds on rx/tx/err
                            // Set blinking period
                            // Enable inclusion mode
                            #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
                            #define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
                            #define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
                            But I am getting this error when trying to complie:
                            Arduino: 1.6.6 (Windows 7), Board: "Arduino Nano, ATmega328"
                            Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                            Warning: platform.txt from core 'Mysensors SAMD (32-bits ARM Cortex-M0+) Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                            Library can't use both 'src' and 'utility' folders.
                            Error compiling.
                              wrote on last edited by hek
                              Do like it says, turn on verbose output.
                              (you have to replace the old MySensors-folder under libraries with the new)
                              • Cliff KarlssonC
                                Cliff KarlssonC
                                Cliff Karlsson
                                Ok, I turned on the verbose output and this is what I got:
                                C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Cliff\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10606 -build-path "C:\Users\Cliff\AppData\Local\Temp\build8a702dc9de8b52c506f71d8c8aabed09.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Cliff\AppData\Local\Temp\arduino_8a702dc9de8b52c506f71d8c8aabed09\GatewaySerial.ino"
                                Error compiling.
                                I have removed arduino IDE and all mysensor libraries, I reinstalled the arduino IDE added/replaced the librarys with the Arduino-master, then replaced again with Arduino-development.
                                  You must have done something wrong setting it up (I'm also running 1.6.6).
                                  You should get the following error using the sketch you posted above:
                                  Users/hek/Documents/ArduinoGithub/libraries/MySensors/MySensor.h:195:3: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                                  • Cliff KarlssonC
                                    Cliff KarlssonC
                                    Cliff Karlsson
                                    Ok, after trying again I extracted Arduino-development to a separate folder in my sketchbook location witout replacing anything. I then got an error saying it could not find Mysensors.h so I copied it to the Gatewayserial folder and now it complies but gives me the error you specified hek. So how do I solve this? is not the gatewayserial sketch ready to complie as is?
                                      Oh, sorry I just copied part of the sketch above when I got the compile error.
                                      When compiling the whole file it works fine here.
                                      • Cliff KarlssonC
                                        Cliff KarlssonC
                                        Cliff Karlsson
                                        Ok so I should use the serialgateway sketch from the arduino master? I did not find any other serialgateway sketch in arduino development than the one I posten.
                                          No, you're using the right one.
                                          You must replace the WHOLE MySensors library folder. Not just copying the MySensors.h.
