  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 76.6k Views 11 Watching
  • karl261K karl261
    Hi, I am using the mysensors-pimatic system and it works great. Now, I am using an optocoupler to simulate some buttons being pressend, and at the moment I am using the relay sketch for that. That works great, but it gives me on/off switches in pimatic. However, I only press the button momentarily. So I would need more a momentary button in pimatic. Something that does not switch but I still can press. So three questions:
    1. Is there a way to have an "ordinary" button in pimatic (not on/off)? Something I press only? This on/off switch works (everytime I switch on or off it simulates on button pressed on my optocoupler), but it is not really what I am looking for.
    2. Is there some code for a momentary button in mysensors? The relay code I am using works great. I adapted in a way that it swtiches the optocoupler on and 50ms later automatically off. Works great, but I was wondering if there was a more elegant way to do it.
    3. If there is no code for a momentary button for pimatic, where would I start looking if I'd want to contribute code?
    Cheers!
    Dheeraj
    @karl261 using ButtonsDevice as mentioned by Oitzu, you can achieve the point no. 1 . non off/on switch..
    upload-9622ca50-7f41-488d-b9db-64391bbf0479
          "id": "mode",
          "name": "TV Mode",
          "class": "ButtonsDevice",
          "buttons": [
              "id": "PVR",
             "text": "PVR"
              "id": "HTPC",
              "text": "HTPC"
              "id": "Chromecast",
              "text": "Chromecast"
              "id": "testing",
              "text": "RainBowCycle"
    for point no. 2 you can use pimatic IFTTT rules to control (*hidden * relay switch button) moreover you can switch off optocoupler after 50 ms using rules.
    1. if you have some special requirement you are welcome to contribute..
    • karl261K
      karl261K
      karl261
      Hi guys. Thanks for the replies. This seems to work. I created a button and made a rule "if button XY pressed then toggle AB". So I suppose I leave the relay device as is, just remove it from my pimatic page (out of sight) and move in the button instead. IS that right?
      Very cool indeed!
      • karl261K
        karl261K
        karl261
        Hi there, I have problem that appears recently. I hope somebody can point me in the right direction.
        I had my setup running for the past two weeks without any problems. No changes in hardware. Now the following happened:
        Suddenly out of nowhere pimatic stop transmitting/receiving. Just like this. No error message. Pimatic frontend working finde. But no data going out to or coming in from the serial gateway.
        I checked all logs: Nothing. I re-started pimatic: No success. All logs normal. I restarted the pi2: Nothing. All logs normal. I unplugged/replugged the arduino nano: Nothing. No success.
        Then I shutdown the pi2, I pulled the power cable, I put it back in and voila: Everything worked normally. Still nothing in any logs. Unfortunately, now about 24h later, the same issue.
        What is happening there? How can I debug that? I also tried resetting the usb:
        echo 0 > /sys/bus/usb/devices/1-1.5/authorized
        echo 1 > /sys/bus/usb/devices/1-1.5/authorized
        Nothing.
        What can I do? Why was it running perfectly for two weeks?
        I changed back to a super simple pimatic config with just one device, but still the same issues.
        What to do? Please advice!
        • OitzuO
          OitzuO
          Oitzu
          Hi there! Spontaneously i have no idea what could be going wrong, only chance is to narrow down the problem.
          Based on your writing i assume you are using the serial gateway to interface with the mysensors network?
          Did you try to enable the debug output in pimatic?
          You could try to stop pimatic, detach usb, attach usb and look directly with screen on the serial device what the gateway is doing.
          screen <device>
          • karl261K
            karl261K
            karl261
            This is the only thing I see in the screen
            Then nothing else. No signal recieved, even if I now my sensors are sending, but also, when I am sending something via pimatic, no send message.
            • OitzuO
              OitzuO
              Oitzu
              @karl261 maybe a defect nrf24 module? The serial connection to the nano seems to work and should normaly show received messages.
              Do you have any spare modules laying arround?
              • karl261K
                karl261K
                karl261
                @Oitzu that is possible. And also weird. It was working for three weeks without problem. Is there no way to get an error message from the nrf24? Why does it work after unplugging the pi? Why does it not help to reset the sub bus, which should power cycle the nano and the radio module?
                I have some nrf24 around, but the installation is in a remote place which I can only access from time to time. That's why I installed mysensors and piratical in the first place. To remote control some things. So three weeks before I can try another radio. I hoped I could reset the system somehow to be able to use my system in the meantime...
                OitzuO 1 Reply Last reply
                • karl261K karl261
                  OitzuO
                  OitzuO
                  Oitzu
                  Well i can only guess whats the problem or whats the reason to it.
                  A faulty device can fail at the first day or just after 3 weeks.
                  The mysensors libs will check at start time the communication with the nrf24 module. If the communication don't work it will give out a "check wires" instead of the "Gateway startup complete.".
                  Maybe the difference between the full power cycle and the nano power cycle is the duration of the power cycle?
                  I can guess that the full power cycle left the nrf24 module for a longer time without power?
                  A longer power down of the nano would result in more time for the caps to discharge?
                  • karl261K
                    karl261K
                    karl261
                    wrote on last edited by karl261
                    #64
                    @Oitzu thanks a lot for your help. I appreciate it.
                    Some more observations:
                    • If I reboot the pi, I get
                    in the screen session.
                    • However, if I do
                    echo '1-1.5' > /sys/bus/usb/drivers/usb/unbind
                    echo '1-1.5' > /sys/bus/usb/drivers/usb/bind
                    which should power cycle the usb device I do not see anything in the screen session. Which means that the arduino nano was not power cycled.
                    However I do see that something happened in the log file:
                    Nov 12 17:31:40 raspberrypi kernel: [  300.831131] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
                    Nov 12 17:31:40 raspberrypi kernel: [  300.839881] ftdi_sio 1-1.5:1.0: device disconnected
                    Nov 12 17:31:46 raspberrypi kernel: [  306.271337] ftdi_sio 1-1.5:1.0: FTDI USB Serial Device converter detected
                    Nov 12 17:31:46 raspberrypi kernel: [  306.278553] usb 1-1.5: Detected FT232RL
                    Nov 12 17:31:46 raspberrypi kernel: [  306.283631] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB0
                    So, what does it mean? I don't understand. Maybe there is something wrong with the pi's USB hub? Which is only reset when I pull the plug? But then the wifi should also not work, because it is sitting on the same USB hub.
                    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
                        |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
                            |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
                            |__ Port 4: Dev 4, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
                            |__ Port 5: Dev 5, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
                    I really don't like that there is no error message nowhere...
                    Is there any other place I could ask for help?
                    • karl261K
                      karl261K
                      karl261
                      Ok, so I found a way to reset the usb bus using hub-ctrl.c. There is interesting information here:
                      https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=93463
                      https://github.com/codazoda/hub-ctrl.c
                      https://www.raspberrypi.org/forums/viewtopic.php?t=71044&p=513908
                      http://raspberrypi.stackexchange.com/questions/27903/usb-power-cycling-problem
                      So, in my case I can issue the command
                      ./hub-ctrl -h 0 -P 5 -p 0 ; sleep 3; ./hub-ctrl  -h 0 -P 5 -p 1
                      and it does indeed reset the right port, because if I open now the screen sessoin I get the usual
                      BUT: Still the thing is not sending receiving anything. WHY?
                      • OitzuO
                        OitzuO
                        Oitzu
                        Tried to extend the sleep between power down and up?
                        • karl261K
                          karl261K
                          karl261
                          Yes, I also tried with 30 seconds. Longer?
                          • OitzuO
                            OitzuO
                            Oitzu
                            Well.. i think you can't lose anything. :D
                            Will be hard to debug after that without access to the actual hardware.
                            • karl261K
                              karl261K
                              karl261
                              So, I made some modifications to the Serial Gateway sketch so it includes
                              radio.printDetails();
                              I see that it is looping though the loop function, but I actually see NO ouput from this function. What does this mean? That there is actually no radio connected? Wouldn't it say something like "no radio" or so?
                              • OitzuO
                                OitzuO
                                Oitzu
                                https://github.com/mysensors/Arduino/blob/f9c8579bbdeaa50a0937287d4f7c14f794460540/libraries/MySensors/drivers/RF24/RF24.cpp#L455
                                Do you have MY_DEBUG_VERBOSE defined?
                                • karl261K
                                  karl261K
                                  karl261
                                  Good point. I had not, now I have. But still, there is absolutely 0 output from this. The only message I see is the "Gateway startup complete" stuff.
                                  fetsF 1 Reply Last reply
                                  • E
                                    E
                                    edautz
                                    wrote on last edited by edautz
                                    #72
                                    I use Pimatic for more than a year now and I am using the Mysensors plugin 0.8.21 for more than 4 weeks now.
                                    I use a serial gateway based on a arduino nano and a NRF24 radio.
                                    I have already several sensors running without troubles and it appear to be stable.
                                    What I see from your information is that the serial gateway is communicating, but seems to recieve nothing from your sensors.
                                    If you can see on the PI that your gateway is started up, then the PI is able to recieve the information.
                                    I debugged my serial gateway using the
                                    serial monitor in the Arduino ide. This is also the way to test your sensors. In the serial monitor you can see if they are connecting to the gateway and sending information.
                                    • B
                                      B
                                      BastienVH
                                      After using OpenHAB for quite some time, I've made the transition to Pimatic.
                                      I've got a pro mini 3V running on 2 AA batteries with a DS18B20-temp-sensor.
                                      I would like to be able to display the battery level but am having some trouble.
                                      I combined the temp and battery sensor into 1, but the battery status isn't being analyzed properly.
                                      When I restart the node it transmits a value of 12 and shortly after that a value of 0.
                                      Any ideas how to solve this?
                                      Is this related to pimatic and the format in which it receives battery data or is it simply a fault in my code?
                                      Thanks in advance!
                                      This is my code:
                                       * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                                       * http://www.mysensors.org/build/temp
                                      #include <OneWire.h>
                                      int numSensors=0;
                                      int node_id = 12;
                                      int oldBatteryPcnt = 0;
                                      boolean receivedConfig = false;
                                      boolean metric = true;
                                      MyMessage msg(0,V_TEMP);
                                        sensors.begin();
                                         analogReference(INTERNAL1V1);
                                         analogReference(INTERNAL);
                                       // Startup and initialize MySensors library. Set callback for incoming messages.
                                        gw.begin(NULL, node_id);
                                        gw.sendSketchInfo("Temperature Sensor met battery", "1.0");
                                           gw.present(i, S_TEMP);
                                         // get the battery Voltage
                                         #ifdef DEBUG
                                         Serial.println(sensorValue);
                                         #ifdef DEBUG
                                         Serial.print(batteryV);
                                         Serial.println(" V");
                                         Serial.print(batteryPcnt);
                                         Serial.println(" %");
                                           // Power up radio after sleep
                                           oldBatteryPcnt = batteryPcnt;}
                                        // Process incoming messages (like config from server)
                                        gw.sleep(conversionTime);
                                          float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                          #if COMPARE_TEMP == 1
                                            gw.send(msg.setSensor(i).set(temperature,1));
                                        gw.sleep(SLEEP_TIME);
                                      D 1 Reply Last reply
                                      • B BastienVH
                                        Thanks in advance!
                                        This is my code:
                                        int numSensors=0;
                                        int node_id = 12;
                                          sensors.begin();
                                           #ifdef DEBUG
                                           #ifdef DEBUG
                                        Dheeraj
                                        wrote on last edited by Dheeraj
                                        #74
                                        @BastienVH . check few things first.
                                        1. hardware wiring is correct and as per mysensor guide.
                                        2. what debug value "sensorValue" you are seeing on serial console if you debug your sensor node.
                                        3. check the debug log in pimatic
                                        B 1 Reply Last reply
                                        • D Dheeraj
                                          B
                                          B
                                          BastienVH
                                          @Dheeraj
                                          I feel so stupid now... I built this circuit on a breadboard and after fiddling around with it yesterday, I forgot to place the resistor for the battery in the right pin. It was now on a different row.
                                          Saw it and fixed it. Now I get a battery percentage in Pimatic!
                                          Thanks for your help!
