  3. [example] GPS Sensor
gpsexample
18 Posts 8 Posters 17.2k Views 6 Watching
    Ok, my GPS sensor had been collecting dust in the drawer too long so I decided to create a MySensors example on how you could incorporate position data in a MySensors powered home automation setup.
    I've used the GY-NEO6MV2 module containing a Ublox GPS which communicates serially with the Arduino.
    So what should we use this for in a HA setup you might ask? Well the amount of use cases aren't exactly overwhelming but here are a few:
    1. Attach it to your robot lawn mower to get a notification when it has stuck somewhere.
    2. Build a gps tracked pet collar (preferably using the HW RF69 module for long range operation). Used for geo fencing the dog to get a notification when it runs away. Or why not use it while hunting?
    3. The GPS gives a very accurate (atomic) time information which can be used in the rest of your HA setup.
    The (new) message type sent to controller contains latitude, longitude and altitude information.
    Wiring it up is very simple:
    3v3 or 5V to VCC
    GND to GND
    A0 to TX
    You can of course change the A0 pin to something else in the code.
    And here comes the example code. Note that this code only runs on the development branch. Codebender does not host this branch yet so you'll have to build it locally on your computer in the IDE:
    https://codebender.cc/sketch:182035
    The module can be found here:
    http://www.ebay.com/itm/390647042336?rmvSB=true
    or
    http://www.aliexpress.com/item/2pcs-lot-GY-NEO6MV2-new-GPS-module-with-Flight-Control-Flight-Control-EEPROM-MWC-APM2-5/1811853522.html
    Output from Serial Monitor
    send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
    send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    sensor started, id=2, parent=0, distance=1
    Position: 55.722511;13.018091;12
    send: 2-2-0-0 s=1,c=1,t=49,pt=0,l=22,sg=0,st=ok:55.722511;13.018091;12
    GPS Time: 11/08/2015 22:59:11
    Position: 55.722527;13.018097;13
    send: 2-2-0-0 s=1,c=1,t=49,pt=0,l=22,sg=0,st=ok:55.722527;13.018097;13
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @hek whats up with that NORDIC board?
    RJ_Make
    hekH 1 Reply Last reply
    • RJ_MakeR RJ_Make
      @ServiceXp
      Ah.. it's a Nordic Uno shield I've had for a long time. It came with some dev-kit for the NRF-board. Use it sometimes when prototyping.
      • B
        B
        betonishard
        Nice example!!!
        What I was thinking of, is can it also be a part of the gateway (GPS gateway). In that way things such as(just an example could also be connected to mysensors):
        http://www.safewise.com/blog/10-wearable-safety-gps-devices-kids/
        • mrc-coreM
          mrc-coreM
          mrc-core
          hi. trying to use the code but i'm getting problems with this line "MyMessage msg(CHILD_ID_GPS, V_POSITION);"
          sketch_nov15a:68: error: 'V_POSITION' was not declared in this scope
          sketch_nov15a.ino: In function 'void present()':
          sketch_nov15a:93: error: 'sendSketchInfo' was not declared in this scope
          sketch_nov15a:96: error: 'S_GPS' was not declared in this scope
          sketch_nov15a.ino: In function 'void loop()':
          sketch_nov15a:125: error: 'send' was not declared in this scope
          Not getting this to work at all
            @mrc-core
            V_POSITION and S_GPS is only defined in the development branch.
            https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyMessage.h#L85
            • mfalkviddM
              Yes, V_POSITION is not present, not even in the MySensors development branch. Do you have some unpushed code @hek ?
                https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyMessage.h#L146
                • mfalkviddM
                  Thanks. I was pulling my own development branch instead of MySensor's :flushed: No wonder nothing had happened in a few days...
                  • mrc-coreM
                    mrc-coreM
                    mrc-core
                    had to insert in the code "MySensor gw;" and some "gw." at sendSketchInfo and present to stop the errors, flash the code to arduino nano but no info at monitor serie or at domoticz gateway can't seem to find the gps...
                    No understanding the new problem...
                      The new S_GPS/V_POSITION is only 7 days old.
                      I doubt @GizMoCuz has had time to implement support for it in Domoticz.
                      You should use the development branch like I mentioned above to make it compile out of the box.
                      • mrc-coreM
                        mrc-coreM
                        mrc-core
                        @hek said:
                        development branch
                        Thanks for the quick replay. Gona try the development branch. Once again thnaks
                          3v3 or 5V to VCC
                          GND to GND
                          A0 to TX
                          or
                          Pierre PP
                          Pierre PP
                          Pierre P
                          1. Build a gps tracked pet collar (preferably using the HW RF69 module for long range operation). Used for geo fencing the dog to get a notification when it runs away. Or why not use it while hunting?
                          I'm in. For the mower.
                          For the radio, the lower frequency the better. But, we need a new gateway no ?
                          Or there is a trick, like a repeater node with two radio of different frequency ?
                          No quote, no forum notification (else, the mail box ring every minutes !). Thanks, and have a very good MySensors day !
                          • D
                            drock1985
                            Hey @Pierre-P
                            Yeah, you would need a new gateway for each radio type.
                            My Projects
                            2 Door Chime Sensor
                            Washing Machine Monitor
                            • f.mathieuF
                              f.mathieuF
                              f.mathieu
                              Hi Guys,
                              new in this forum. really interresting project :-)
                              trid to follow your recommendations, but still have S_GPS error... do you have any developpment since the last message ?
                              i added the declared ligne in the MyMessage.h file, V_POSITION, but saw the S_GPS vairiable in the file.
                              what will need more ?
                              regards,
                              Franck
                                @f-mathieu
                                Use this version
                                https://github.com/mysensors/Arduino/archive/development.zip
                                • f.mathieuF
                                  f.mathieuF
                                  f.mathieu
                                  Thanks Hek for your fast answer. now i can compile it, but i have a radio init failed...
                                  any idea ?
                                  Pierre PP 1 Reply Last reply
                                  • f.mathieuF f.mathieu
                                    any idea ?
                                    Pierre PP
                                    Pierre PP
                                    Pierre P
                                    @drock1985 said:
                                    Hey @Pierre-P
                                    I found a new mysensors page ! here:
                                    https://www.mysensors.org/download/sensor_api_15#create-repeating-nodes
                                    Advanced initialization
                                    It's also possible to construct an instance with RFM69 radio driver and/or enable signing support. You can choose one of the following radio drivers:
                                    or
                                    MyTransportRFM69 transport(RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, isRFM69HW, RF69_IRQ_NUM);
