  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 403.3k Views 39 Watching
    You can set static ip in the dev-branch.
    Even better :+1:
    • YveauxY Yveaux
      @mkeyno did you change anything to the gateway code, and which version of MySensors are you running?
      I've ported the gateway code to ESP8266. That doesn't mean any sensor code will also automatically run on an ESP.
      Packaged with MySensors are a lot of libraries that will not compile on ESP, so if you try to use one (pinchange int or timers) it will likely fail to compile.
      mkeyno
      @Yveaux no buddy I used the last update of your repository, my question is , are you aware that your esp8266 sample sketch call library that wont work with esp architecture? I've compare last update with previous library and I've find the for couple of header file following code has been added
      #ifdef AVR
      #include <avr/interrupt.h>
      #error MsTimer2 library only works on AVR architecture
      and I was wondering why your sample sketch call such file into the compiling
      • D
        D_dude
        wrote on last edited by D_dude
        #180
        Hi @Yveaux
        could you please assist in the error.
        ESP8266 MySensors Gateway
        Connecting to HoUsEoFcLoWnS
        scandone
        f 0, scandone
        .add 0
        aid 5
        pm open phy_2,type:2 0 0
        cnt
        connected with HoUsEoFcLoWnS, channel 11
        dhcp client start...
        .ip:192.168.0.23,mask:255.255.255.0,gw:192.168.0.1
        .Connected!
        IP: 192.168.0.23
         ets Jan  8 2013,rst cause:4, boot mode:(3,7)
        wdt reset
        tail 0
        chksum 0x42
        csum 0x42
        ~ld
        The gateway just keeps looping and connecting.
        I'm using a NodeMCU with a NRF ( both from ebay),
        Using the Regular library, and default sketch with SSID/pass updated.
        i tried checking the error "rst cause:4, boot mode:(3,7)" but wasn't able to find something.
        I even tried to power it using a USB cellphone charger, but i was unable to telnet so that rules out the power issue
        Thanks in advance
        • D
          D_dude
          update,
          the error changed to "rst cause:4, boot mode:(3,6)" once i added a capacitor.
          • D D_dude
            Hi @Yveaux
            scandone
            f 0, scandone
            .add 0
            aid 5
            cnt
            .Connected!
            IP: 192.168.0.23
            wdt reset
            tail 0
            chksum 0x42
            csum 0x42
            ~ld
            Thanks in advance
            @D_dude said:
            These ESP's seem to walk in mysterious ways...
            A lot of people have them, running without any issues (including myself and hek) and some people can't seem to get them to run stable.
            On the net, a lot of stability/reset issues are are claimed to have a relation to power supply.
            There are a lot of assumptions in this sentence ;-)
            What current rating is the cellphone charger? I'd advise one with at least 1amps, and a stable output.
            Not being able to telnet to the gateway can have more issues then just the ESP crashing...
            D 1 Reply Last reply
            • YveauxY Yveaux
              D_dude
              #183
              @Yveaux
              Thank you for the response.
              As for the cell phone charger, I'm using a tablet charger Specifically original HP stream 7 charger, and it is able to provide more that 1amp. I Will try to use other charger/power supply to see if that helps.
              PS: I reloaded the gateway sketch and the error went back to boot mode (3,7) even with cap present.
              • D D_dude
                @Yveaux
                @D_dude I searched the net for a description of reset causes and boot modes but failed to find one.
                I have no clue of what they mean.
                • YveauxY Yveaux
                  D_dude
                  @Yveaux
                  thank you for your assistance. I will try adding some debug in the code on the weekend to see what exactly is not running and possibly causing crash.
                  • mfalkviddM
                    I got a suggestion here to erase the flash before flashing. Haven't tried it yet, but it might help you @D_dude
                    D 2 Replies Last reply
                      D_dude
                      @mfalkvidd
                      Thank you, i will try this and post results.
                        D_dude
                        @mfalkvidd
                        tried erasing the flash using the method suggested but doesn't seem to be working for me. same result.
                        Thanks for the tip though.
                        • mfalkviddM
                          Too bad. Thanks for posting your results.
                          • L
                            L
                            luisgcu
                            here is my ESP8266 wifi gateway installed in wifi repeater box, taking the advantage that its has a 5 volts power supply.
                            • L luisgcu
                              @luisgcu Nice housing!
                              Thanks for the pics!
                              • sowardS
                                sowardS
                                soward
                                I'd been using the ESP gateway for several weeks, but recently was having trouble adding a new sensor I am developing.
                                Since the copy of dev I built it with was now out of date, I went ahead and updated... still wasn't working right so while I had the serial link to it I checked and noticed it was crashing and cycling. It would work for hours, until I fired up my new node, then crash about immediately. A few dozen debug(PSTR())'s later, I found a cause.
                                In core/MySensorsCore.cpp the result of _msg.getConfig() is dereferenced in a comparison, and it's possible it could return NULL ( like when it's a new node ). I put a check around that and it's not crashing anymore. Which is more than what I can say for my new sensor node....
                                I have not tested this change with an AVR.
                                I submitted PR 264.
                                • mfalkviddM
                                  Great work @soward !
                                  • D
                                    D_dude
                                    on some basic debugging, seems like my sketch is crashing in setupGateway.
                                    infact even adding a print statement, it only prints first 3 chars.
                                    My question is setupGateway takes output as an arg, which in turn is a function, should there be some parameters for this function?
                                    also "Serial.print(serialBuffer);" does not print anything i added prints above and before and they don't show up either.
                                      va_end (args);
                                      Serial.print("A1");
                                      Serial.print("A2");
                                    any suggestions?
                                    • D D_dude
                                        va_end (args);
                                        Serial.print("A1");
                                        Serial.print("A2");
                                      any suggestions?
                                      #195
                                      @D_dude flush the serial output after each print.
                                      The ESP will output the serial data in the background while your programm continues and then it crashes.
                                      YhtY D 2 Replies Last reply
                                      • YveauxY Yveaux
                                        YhtY
                                        YhtY
                                        Yht
                                        I'm getting all the time this:
                                        Connecting to layla
                                        ......Connected!
                                        IP: 192.168.0.102
                                        Then it got stuck so I do reset and getting this in loop:
                                        Connecting to layla
                                        ..Connected!
                                        IP: 192.168.0.102
                                        0;0;3;0;9;radio init fail
                                        Soft WDT reset
                                        ctx: cont
                                        sp: 3ffefe70 end: 3fff00a0 offset: 01b0
                                        stack>>>
                                        3fff0020: 00000000 00000000 3ffeed74 40203665
                                        3fff0030: 0000007f 3ffef074 40205ba0 3ffef080
                                        3fff0040: 40202114 00000001 00000000 40205c10
                                        3fff0050: 6600a8c0 00ffffff 0100a8c0 3ffef074
                                        3fff0060: 3ffe84ac 3ffeee8c 3ffeefb0 4020256b
                                        3fff0070: 3ffe86b8 6600a8c0 00000000 00000000
                                        3fff0080: 3fffdc20 00000000 3ffef06d 40205bde
                                        3fff0090: 00000000 00000000 3ffef080 40100114
                                        <<<stack<<<
                                        ets Jan 8 2013,rst cause:2, boot mode:(3,6)
                                        tail 0
                                        chksum 0x42
                                        csum 0x42
                                        ~ld
                                        • YhtY Yht
                                          Connecting to layla
                                          ......Connected!
                                          IP: 192.168.0.102
                                          Connecting to layla
                                          ..Connected!
                                          IP: 192.168.0.102
                                          Soft WDT reset
                                          ctx: cont
                                          stack>>>
                                          <<<stack<<<
                                          tail 0
                                          chksum 0x42
                                          csum 0x42
                                          ~ld
                                          #197
                                          @Yht 0;0;3;0;9;radio init fail
                                          Means there's something wrong with your nRF communication. The WDT reset following this is normal.
