  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 403.3k Views 39 Watching
  • YveauxY Yveaux
    @Mickey In principle the MQTT gateway should also run on the ESP8266, if you make the same changes to it as I did to the Ethernet gateway example (diff of the files should help a lot: https://www.diffchecker.com/eeo5ahzn).
    On the other hand, the pubsubclient (https://github.com/knolleary/pubsubclient) MQTT client implementation by knolleary is heavily tested and works fine on ESP8266 (I tested it myself).
    The ESP8266 has a lot more Flash & RAM available than an ATMega, so implementing MQTT should not be a problem.
    mkeyno
    @Yveaux
    hi
    there is problem for sensor library when we intend use the its examples as following
    In file included from \libraries\MySensors\MyGateway.cpp:13:0:
    \libraries\MySensors\utility/MsTimer2.h:7:2: error: #error MsTimer2 library only works on AVR architecture
    In file included from \libraries\MySensors\MyGateway.cpp:14:0:
    \libraries\MySensors\utility/PinChangeInt.h:103:19: fatal error: new.h: No such file or directory
    #include <new.h>
    compilation terminated.
    Error compiling.
    • M mkeyno
      @Yveaux
      hi
      #include <new.h>
      Error compiling.
      @mkeyno did you change anything to the gateway code, and which version of MySensors are you running?
      I've ported the gateway code to ESP8266. That doesn't mean any sensor code will also automatically run on an ESP.
      Packaged with MySensors are a lot of libraries that will not compile on ESP, so if you try to use one (pinchange int or timers) it will likely fail to compile.
      • AndurilA
        AndurilA
        Anduril
        @Yveaux SUCCES!!! Thank you very much, your way worked nearly perfect. ONly small change: "ß" is represented by hexcode DF, so using \eDF gives the correct wifi password for me.
        Now a last thing as bonus: how to setup a fixed ip and not using dhcp? My dhcp is not very usable as it reassigns all IPs on reboot (stupid firmware by Deutsche Telekom).
        • AndurilA Anduril
          @Anduril Great to hear you got it to work!
          Google'd a bit. Seems like Wifi.config requires 3 parameters:
              // static ip, gateway, netmask
              WiFi.config(IPAddress(192,168,1,100), IPAddress(192,168,1,1), IPAddress(255,255,255,0));
          Make sure to call it after WiFi.begin().
          Btw. ESP8266 Arduino port follows the Arduino WiFi library API.
            You can set static ip in the dev-branch.
              Even better :+1:
              • YveauxY Yveaux
                mkeyno
                @Yveaux no buddy I used the last update of your repository, my question is , are you aware that your esp8266 sample sketch call library that wont work with esp architecture? I've compare last update with previous library and I've find the for couple of header file following code has been added
                #ifdef AVR
                #include <avr/interrupt.h>
                and I was wondering why your sample sketch call such file into the compiling
                • D
                  D_dude
                  wrote on last edited by D_dude
                  #180
                  Hi @Yveaux
                  could you please assist in the error.
                  ESP8266 MySensors Gateway
                  Connecting to HoUsEoFcLoWnS
                  scandone
                  f 0, scandone
                  .add 0
                  aid 5
                  pm open phy_2,type:2 0 0
                  cnt
                  connected with HoUsEoFcLoWnS, channel 11
                  dhcp client start...
                  .ip:192.168.0.23,mask:255.255.255.0,gw:192.168.0.1
                  .Connected!
                  IP: 192.168.0.23
                   ets Jan  8 2013,rst cause:4, boot mode:(3,7)
                  wdt reset
                  tail 0
                  chksum 0x42
                  csum 0x42
                  ~ld
                  The gateway just keeps looping and connecting.
                  I'm using a NodeMCU with a NRF ( both from ebay),
                  Using the Regular library, and default sketch with SSID/pass updated.
                  i tried checking the error "rst cause:4, boot mode:(3,7)" but wasn't able to find something.
                  I even tried to power it using a USB cellphone charger, but i was unable to telnet so that rules out the power issue
                  Thanks in advance
                  • D
                    D_dude
                    update,
                    the error changed to "rst cause:4, boot mode:(3,6)" once i added a capacitor.
                    • D D_dude
                      Hi @Yveaux
                      scandone
                      f 0, scandone
                      .add 0
                      aid 5
                      cnt
                      .Connected!
                      IP: 192.168.0.23
                      wdt reset
                      tail 0
                      chksum 0x42
                      csum 0x42
                      ~ld
                      Thanks in advance
                      @D_dude said:
                      These ESP's seem to walk in mysterious ways...
                      A lot of people have them, running without any issues (including myself and hek) and some people can't seem to get them to run stable.
                      On the net, a lot of stability/reset issues are are claimed to have a relation to power supply.
                      There are a lot of assumptions in this sentence ;-)
                      What current rating is the cellphone charger? I'd advise one with at least 1amps, and a stable output.
                      Not being able to telnet to the gateway can have more issues then just the ESP crashing...
                      D 1 Reply Last reply
                      • YveauxY Yveaux
                        D_dude
                        #183
                        @Yveaux
                        Thank you for the response.
                        As for the cell phone charger, I'm using a tablet charger Specifically original HP stream 7 charger, and it is able to provide more that 1amp. I Will try to use other charger/power supply to see if that helps.
                        PS: I reloaded the gateway sketch and the error went back to boot mode (3,7) even with cap present.
                        • D D_dude
                          @Yveaux
                          @D_dude I searched the net for a description of reset causes and boot modes but failed to find one.
                          I have no clue of what they mean.
                          • YveauxY Yveaux
                            D_dude
                            @Yveaux
                            thank you for your assistance. I will try adding some debug in the code on the weekend to see what exactly is not running and possibly causing crash.
                            • mfalkviddM
                              I got a suggestion here to erase the flash before flashing. Haven't tried it yet, but it might help you @D_dude
                              D 2 Replies Last reply
                                D_dude
                                @mfalkvidd
                                Thank you, i will try this and post results.
                                  D_dude
                                  @mfalkvidd
                                  tried erasing the flash using the method suggested but doesn't seem to be working for me. same result.
                                  Thanks for the tip though.
                                  • mfalkviddM
                                    Too bad. Thanks for posting your results.
                                    • L
                                      L
                                      luisgcu
                                      here is my ESP8266 wifi gateway installed in wifi repeater box, taking the advantage that its has a 5 volts power supply.
                                      • L luisgcu
                                        @luisgcu Nice housing!
                                        Thanks for the pics!
                                        • sowardS
                                          sowardS
                                          soward
                                          I'd been using the ESP gateway for several weeks, but recently was having trouble adding a new sensor I am developing.
                                          Since the copy of dev I built it with was now out of date, I went ahead and updated... still wasn't working right so while I had the serial link to it I checked and noticed it was crashing and cycling. It would work for hours, until I fired up my new node, then crash about immediately. A few dozen debug(PSTR())'s later, I found a cause.
                                          In core/MySensorsCore.cpp the result of _msg.getConfig() is dereferenced in a comparison, and it's possible it could return NULL ( like when it's a new node ). I put a check around that and it's not crashing anymore. Which is more than what I can say for my new sensor node....
                                          I have not tested this change with an AVR.
                                          I submitted PR 264.
