  3. My Slim 2AA Battery Node
498 Posts 71 Posters 598.6k Views 69 Watching
    @m26872 great idea indeed. You convinced me :)
    Did you think of monitoring the voltage as this type of nodes needs this or did you leave it also as an option for us ?
    m26872M
    m26872M
    m26872
    @ahmedadelhosni
    ... or here.
    • B
      B
      betonishard
      wrote on last edited by betonishard
      #75
      @m26872
      I received my panelized boards as well (guess 1.4). They look great!!.
      I do have a question about this. Maybe it was just some silly thinking. I was trying to program the arduino 328p-pu on a regular arduino uno board (default motion sketch). After I did this I hooked it up on to the board.
      However I am not receiving anything on the arduino serial monitor. I connected the arduino uno to your board. v to v, rx to rx, tx to tx, ground to ground and reset to reset. Am I just thinking to simple? Can someone please advise me to get this board up and running? I also soldered d13 additional to the nrf.
      I soldered all caps, however I did not solder the resistor, is that one mandatory?
      Many thanks and keep up the good work.
      m26872M 1 Reply Last reply
      • m26872M m26872
        @ahmedadelhosni
        ... or here.
        ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        @m26872 @AWI yeah you are right. Thanks a lot.
        I really consider buying the latest version. I think it is verified now to be working correctly.
        • B betonishard
          @m26872
          m26872M
          m26872M
          m26872
          @betonishard
          If you've got red boards it's v1.4 and should not need the D13 fix. And R1 and C2 are mandatory if you want the 6 pin serial Arduino interface to work.
          Did you read about the necessary bootloader and fuse settings in the first post? An Atmega328p setup as standard Arduino wont work, because of Internal clock, BOD, etc. Perhaps Arduino Uno as a bootloader is good for you.
          If you haven't any experience in bootloader and fuse settings, you should know that it can be a mess. A lot of things can go wrong. Nobody can walk you through it here. Look among all the existing toturials on the internet to find what is working for you and of course ask if you have any more specific questions.
          • ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            wrote on last edited by ahmedadelhosni
            #78
            I know I have many questions :) but how about inverting the nrf position by 180 degree so that it can be on top of the atmega and decrease that length. Would it fit in your design ?
            Can you do such board for those who are interested like me :) ?
              m26872M
              m26872M
              m26872
              wrote on last edited by m26872
              #79
              @ahmedadelhosni
              I think it's a good idea! And an easy mod, but it's not on priority list atm. Someone else would get a quick start from my already published kicad-files.
              The thought behind present design is that I didn't want anything to cover the antenna in any direction, but I doubt it would matter much in this suggested case. It'll be worse when it comes to the hight. Look at the photos. The nRF becomes too high for my enclosures if I use a socket, and the 328p with its socket is too high to fit under a nRF without its socket. The solution would be to remove the 328p socket and move the R and Cs to bottom side or somewhere else. And without a 328p socket, the 3x2 AVR ISP pins would become more important to keep. Otherwise the board could have been trimmed even more.
              ahmedadelhosniA 2 Replies Last reply
              • m26872M m26872
                @ahmedadelhosni
                ahmedadelhosniA
                ahmedadelhosniA
                ahmedadelhosni
                #80
                @m26872 I guess the nrf above the atmega won't cause problems or interference to the atmega due to rf signals. so that's fine.
                I measured the nrf and it will be 13 mm, so I thought it may fit as from the photos, I guess the max height can be 13 or 14. For me increasing the height is not a problem as I am still searching for cheap compact and not so long enclosure with maximum heigh 20 mm to use. I am searching for cheap products which are kept in that size of enclosure which I need but didn't find it yet :)
                I didn't use Kicad before and I guess there is no converters to eagle. Youtube time :)
                Can you please tell me the total length of the board + nrf ?
                  m26872M
                  m26872M
                  m26872
                  @ahmedadelhosni
                  It's 74mm with the angled Arduino pins and 69mm without.
                  • m26872M m26872
                    @ahmedadelhosni
                    ahmedadelhosniA
                    ahmedadelhosniA
                    ahmedadelhosni
                    @m26872 Thanks.
                    Hopefully this is my last question :)
                    Is V1.4 and 2.0 the same ? One is red in Eagle and the other in black in Kicad ?
                    If yes, could you please guide me to the eagle's project files ? Thanks.
                      @m26872 Thanks.
                      m26872M
                      m26872M
                      m26872
                      @ahmedadelhosni
                      Yes, v1.4 is Eagle. I'll upload it later today. But it's just a brd-file. And I think I had some broken sch-brd connections even in v1.2. One reason for the KiCad design was to improve this.
                      • m26872M m26872
                        @ahmedadelhosni
                        ahmedadelhosniA
                        ahmedadelhosniA
                        ahmedadelhosni
                        @m26872 hmm I see. So i will begin learning Kicad today. Thanks for your effort and support
                          m26872M
                          m26872M
                          m26872
                          @ahmedadelhosni
                          I uploaded the brd in the v1.4 post above just for completness.
                          Happy Kicading! Hope you'll enjoy. I liked it a lot better. There were a few nice youtube tutorials.
                          You're welcome.
                          • m26872M
                            m26872M
                            m26872
                            First Slim Node board donation from the DirtyPCB board share now sent. $12 to MySensors.org. Thanks to everyone that have ordered.
                            Later credit draw will be in probably linger a bit. DirtyPCB seems to be somewhat of a non-profit community with manual attendance to all share credits. I almost got banned in my attempts to get a reply from them. In order to show my appreciation for their great service, I plan to only request further credits in quantities of 50. If the board not's been shared in a year a so, of course I'll make an exception.
                              @m26872
                              Thanks for the kind donation to the MySensors project. We'll use it to develop new fun things for the community!
                              • AWIA
                                AWIA
                                AWI
                                I was out of radio's, only a few "smd" types left which I mounted on the board with some patchwork ;-)
                                upload-9bcfc8fe-4f7f-48ba-90dc-31443ed62f89
                                Now even more space left in the (small) housing.
                                upload-6b158358-0c6f-4983-89d4-16a13f9a87e9
                                upload-b3b5aa3b-3e76-4690-a05c-49df931a6df7
                                • dakkyD
                                  dakkyD
                                  dakky
                                  Could u show a screen for the lockbits too? I have never set them before and need some guidance :D thanks
                                  Dakky
                                  Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
                                  Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
                                  Software: MySensors 2.0development
                                  m26872M bjacobseB 2 Replies Last reply
                                  • dakkyD dakky
                                    Dakky
                                    m26872M
                                    m26872M
                                    m26872
                                    @dakky Done.
                                    • Cliff KarlssonC
                                      Cliff KarlssonC
                                      Cliff Karlsson
                                      Is this what you used to burn the bootloader?
                                      USB-programmer-AVRISP-mkII-mk2-clone-ATMEL-AVR-New
                                      • m26872M
                                        m26872M
                                        m26872
                                        I use this. Maybe not so expensive when I bought it 15 months ago, but still. I remember I was mad after I'd failed a lot with avrdude and cheaper tools (uno).
                                          martkrui
                                          Just received my boards from DirtyPCB :smile:
                                          Enough for 10x3=30 sensors... :scream: The boards look nice. I think I can even skip the R&C's if I use the internal VCC measuring method but I'll have to scan the thread for that.
