  3. Scrolling Text sensor node with new V_TEXT
51 Posts 17 Posters 36.0k Views 13 Watching
  • J Jager
    You can send messages as done here? http://forum.mysensors.org/topic/1957/lcd-clock-and-text-sensor-node-with-new-v_text
    AWIA
    AWIA
    AWI
    @Jager If your controller supports it you can. In Domoticz the text value is not pushed so you need to make a request for it.
    • HoffanH
      HoffanH
      Hoffan
      What am i missing, Because i get this when i try to compile it
      Arduino:1.6.5 (Mac OS X), Kort:"Arduino Nano, ATmega328"
      ScrollingText:55: error: 'V_TEXT' was not declared in this scope
      ScrollingText.ino: In function 'void setup()':
      ScrollingText:166: error: 'S_INFO' was not declared in this scope
      ScrollingText:170: error: 'V_TEXT' was not declared in this scope
      ScrollingText.ino: In function 'void loop()':
      ScrollingText:191: error: 'V_TEXT' was not declared in this scope
      ScrollingText.ino: In function 'void incomingMessage(const MyMessage&)':
      ScrollingText:210: error: 'V_TEXT' was not declared in this scope
      AWIA 1 Reply Last reply
      • HoffanH Hoffan
        AWIA
        AWIA
        AWI
        @Hoffan V_TEXT is still in the development branch...
        • HoffanH
          HoffanH
          Hoffan
          Okey, That can explain, Byt when i use the Dev Branch
          I get this Errors
          ScrollingText:52: error: 'MyTransportNRF24' does not name a type
          ScrollingText:53: error: 'MySensor' does not name a type
          ScrollingText:163: error: 'gw' was not declared in this scope
          ScrollingText:177: error: 'gw' was not declared in this scope
          • HoffanH Hoffan
            I get this Errors
            AWIA
            AWIA
            AWI
            @Hoffan you best read the instructions for the development branch. The syntax changed a little. I'm typing on a phone right now. Best to search yourself
              wrote on last edited by hek
              #24
              How to convert a sketch to 1.6 is described here (until it has been posted somewhere more sticky..) :
              https://docs.google.com/document/d/1NKq5uuNdnxF5jWnum7VT32mbKLjuvqlx2A5D1qQ-H3Q/edit#heading=h.t5sdmpn6jz2i
              Basically a few search/replace... The above sketch would look something like this (untested)
               PROJECT: MySensors / Scrolling Text display
               PROGRAMMER: AWI
               DATE: september 12, 2015/ last update: september 12, 2015
               FILE: AWI_scroll_MAX.ino
               LICENSE: Public domain
               Hardware: tbd ..Ceech - ATmega328p board w/ NRF24l01
                  and MySensors 1.5 ()
              Special:
                  Need to use MySensors development edition
              SUMMARY:
                  3 S_xx devices for scrolling text
                  - Displays a scrolling text from a "V_TEXT" variable
                  - additional dimmer sensor for controlling display brightness
                  - 'Alarm' switch. If "On", overrides the text display to display ALARM message
                  - You can also input messages from the Serial monitor (testing)
                  Uses excellent MD_MAX72XX library
               Remarks:
                  Fixed node-id
              // Use the MD_MAX72XX library to scroll text on the display with the use of the callback function
              // to control what is scrolled on the display text.
              // You need to set the used display in the library MD_MAX72XX.h
              // User can enter text on the serial monitor and this will display as a
              // Speed for the display is controlled by a pot on SPEED_IN analog in.
              #include <MD_MAX72xx.h>                     // multipurpose library for MAX72xx diaplay driver  https://parola.codeplex.com/
              #include <MySensor.h>                       // Mysensor network
              #include <Time.h>                           //http://playground.arduino.cc/Code/Time
              #define USE_POT_CONTROL 0                   // enable Scroll speed  potentiometer
              #define PRINT_CALLBACK  0
              // Macro to simplify serial print
              #define PRINT(s, v) { Serial.print(F(s)); Serial.print(v); }
              // Define the number of devices we have in the chain and the hardware interface
              // need to be adapted to your setup
              const int MAX_DEVICES = 8 ;                 // number of 8x8 displays
              const int CLK_PIN = 7 ;                     // SPI like clock
              const int DATA_PIN = 8 ;                    // SPI like data
              const int CS_PIN = 6 ;                      // SPI like select
              // Parola is able to use SPI hardware interface, not testted in combination with MySensors
              // MD_MAX72XX mx = MD_MAX72XX(CS_PIN, MAX_DEVICES);
              // now use Arbitrary pins
              MD_MAX72XX mx = MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES); // instantiate one display chain
              // Scrolling parameters, you can attach normal potentiometer to A5, Vcc, Gnd
              #if USE_POT_CONTROL
              const int SPEED_IN = A5 ;
              const int SCROLL_DELAY = 20 ;               // in milliseconds
              #endif // USE_POT_CONTROL
              const int CHAR_SPACING = 1 ;                // pixels between characters
              // MySensors constants & variables
              const byte nodeId = 51 ;                    // MySensors fixed node id
              const byte messageCHILD = 8 ;               // Text from ControllerLCD
              const byte brightnessChild = 9 ;            // Brightness of display
              const byte alarmChild = 10 ;                // Display Alarm text (overrides normal text)
              boolean timeReceived = false ;              // Flag to indicate time received
              // Display constants & variables
              byte textBrightness = 1 ;                   // brightness of display (between 0 - MAX_INTENSITY (0xF)
              byte textOnOff = true ;                     // textOnOff = ! shutdown
              boolean textAlarm = false ;                 // Alarm (switch S_BINARY)
              // Global message buffers shared by MySensors and Scrolling functions
              const int BUF_SIZE = 25 ;                   // max payload for MySensors(NRF24l01)
              char curMessage[BUF_SIZE];                  // current displayed message
              char newMessage[BUF_SIZE];                  // next message to be displayed if available
              bool newMessageAvailable = false ;          // new message available flag
              uint16_t    scrollDelay;                    // in milliseconds
              // *** Definition and initialisation
              // define the MySensor network (1.5)
              // Initialize messages for sensor network
              MyMessage textMsg(messageCHILD, V_TEXT);    // message for Sending Text to Controller
              /* MD_MAX72XX functions: can be found in the documentation for the library,
               * no need to customtize callback & scroll routines (unless you want to...)
              uint8_t scrollDataSource(uint8_t dev, MD_MAX72XX::transformType_t t)
              // Callback function for data that is required for scrolling into the display
                static char       *p = curMessage;
                static uint8_t    state = 0;
                static uint8_t    curLen, showLen;
                static uint8_t    cBuf[8];
                uint8_t colData;
                // finite state machine to control what we do on the callback
                switch(state)
                  case 0: // Load the next character from the font table
                    showLen = mx.getChar(*p++, sizeof(cBuf)/sizeof(cBuf[0]), cBuf);
                    curLen = 0;
                    state++;
                    // if we reached end of message, reset the message pointer
                    if (*p == '\0')
                      p = curMessage;         // reset the pointer to start of message
                      if (newMessageAvailable)    // there is a new message waiting
                        strcpy(curMessage, newMessage);   // copy it in
                        newMessageAvailable = false;
                    // !! deliberately fall through to next state to start displaying
                  case 1: // display the next part of the character
                    colData = cBuf[curLen++];
                    if (curLen == showLen)                // end of character insert interchar space
                      showLen = CHAR_SPACING;
                      curLen = 0;
                      state = 2;
                  case 2: // display inter-character spacing (blank column)
                    colData = 0;
                    curLen++;
                      state = 0;
                  default:
                    state = 0;
                return(colData);
              // Callback (not used here)
              void scrollDataSink(uint8_t dev, MD_MAX72XX::transformType_t t, uint8_t col){
              // Callback function for data that is being scrolled off the display
              #if PRINT_CALLBACK
                  Serial.print("\n cb ");
                  Serial.print(dev);
                  Serial.print(' ');
                  Serial.print(t);
                  Serial.print(' ');
                  Serial.println(col);
              // non-blocking text display to be used in loop (call frequently)
              void scrollText(void){
                  static uint32_t prevTime = 0;
                  if (millis()-prevTime >= scrollDelay){                  // Is it time to scroll the text?
                      mx.transform(MD_MAX72XX::TSL);                      // scroll along - the callback will load all the data
                      prevTime = millis();                                // starting point for next time
              // sets the scroll delay (read from potentiometer if enabled)
              uint16_t getScrollDelay(void){
              #if USE_POT_CONTROL
                  uint16_t t = analogRead(SPEED_IN);
                  t = map(t, 0, 1023, 25, 250);
                  return(t);
                  return(SCROLL_DELAY);
              void setup(){
                  // set up the display first
                  mx.begin();                                             // initialize display chain
                  mx.setShiftDataInCallback(scrollDataSource);            // define function to get the scrolldata (returned as int8)
                  //mx.setShiftDataOutCallback(scrollDataSink);           // not used
                  mx.control(MD_MAX72XX::INTENSITY, 0x01);
              #if USE_POT_CONTROL                                         // initialize speed potentiometer if enabled
                  pinMode(SPEED_IN, INPUT);
                  scrollDelay = SCROLL_DELAY;
                  strcpy(curMessage, "I \x03 MySensors ");                // first message on display
                  newMessage[0] = '\0';                                   // new message initialized to empty
                  // Setup MySensors
                 //Serial in Sensor network = 115200
                  //Send the sensor node sketch version information to the gateway
                  sendSketchInfo("AWI Scroll MAX 51", "1.1");
                  present(messageCHILD, S_INFO, "Text line Scroll");   // new S_type 20150905 (not know by domoticz)
                  present(alarmChild, S_BINARY, "Alarm display");      // to display alarm text
                  present(brightnessChild, S_DIMMER, "Text brightness"); // new S_type 20150905 (not know by domoticz)
                  //send(textMsg.set("-"));                            // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
                  request(messageCHILD, V_TEXT, 0);                    // request value from controller
                  // Initializations
                  requestTime();                            // get the time from controller (handled by receiveTime)
              // loop only uses non-blocking functions
                  static unsigned long lastUpdate ;                       // Static hold the last update time
                  unsigned long now = millis();
                  scrollDelay = getScrollDelay();                         // update scroll delay from potentiometer
                  readSerial();
                  // Check for new conditions & ask for new information from controller every 10 seconds
                  if (now-lastUpdate > 10000){
                      if (textAlarm){                                     // if alarmstatus: override all text and set max intensity
                          strcpy(curMessage, "   ALARM   ");
                          mx.control(MD_MAX72XX::INTENSITY, MAX_INTENSITY);   // set current brightness
                          mx.control(MD_MAX72XX::SHUTDOWN, false) ;
                      } else {                                            // standard (non Alarm actions)
                          mx.control(MD_MAX72XX::INTENSITY, textBrightness);  // set current brightness
                          mx.control(MD_MAX72XX::SHUTDOWN, textOnOff) ;
                          request(messageCHILD, V_TEXT, 0);                // request new value from controller
                      lastUpdate = now;
                  scrollText();
                  setTime(controllerTime);                                // time from controller
                  timeReceived = true;
              // This is called when a message is received
                  Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
                  if (message.sensor == messageCHILD){
                      if (message.type==V_TEXT) {                     // Text content
                      strcpy(newMessage, message.getString());        // copy it in
                          newMessageAvailable = true ;
                  } else if (message.sensor == alarmChild) {
                      if (message.type==V_STATUS) {                   // True/ false content
                          textAlarm = message.getBool()?true:false ;  // set alarmflag
                          Serial.print("TextAlarm: ");
                          Serial.println(textAlarm);
                  } else if (message.sensor == brightnessChild){
                      if (message.type==V_PERCENTAGE) {               // Level 0..100  content
                          textBrightness = map(message.getInt(),0, 100, 0, MAX_INTENSITY ) ;  // map to brightnesslevel
                          Serial.print("TextBrightness: ");
                          Serial.println(textBrightness);
                      } else if (message.type==V_STATUS) {            // Display on/off
                          textOnOff = message.getBool()?false:true ;      // set shutdown/ !on/off
                          Serial.print("Text on/off: ");
                          Serial.println(textOnOff);
              // Testing purposes: input routine character buffer. Reads serial characters in buffer newMessage.
              // sets flag newMessageAvailable to true if completed
              void readSerial(void)
                static uint8_t    putIndex = 0;
                while (Serial.available())
                  newMessage[putIndex] = (char)Serial.read();
                  if ((newMessage[putIndex] == '\n') || (putIndex >= BUF_SIZE-3)) // end of message character or full buffer
                    // put in a message separator and end the string
                    newMessage[putIndex++] = ' ';
                    newMessage[putIndex] = '\0';
                    // restart the index for next filling spree and flag we have a message waiting
                    putIndex = 0;
                    newMessageAvailable = true;
                    // Just save the next char in next location
                    newMessage[putIndex++];
              • D
                dayve218
                ive spent a couple of hours on this, and i cant get it to work. any help?
                • D
                  dayve218
                  @AWI are you able to help me convrt this to1.6? i cant get it
                    Fixed a couple of thing in the sketch. Now it compiles on 1.6 but you have to install the MD_MAX72xx library which it uses.
                    • HoffanH
                      HoffanH
                      Hoffan
                      Where did you put the new sketch??
                      hekH 1 Reply Last reply
                      • HoffanH Hoffan
                        @Hoffan
                        I updated my post above.
                        • HoffanH
                          HoffanH
                          Hoffan
                          Okey... Strange because i test to compile that i Dev Branch and i get this error
                          Scrolltext.ino: In function 'void presentation()':
                          Scrolltext:205: error: too many arguments to function 'void requestTime()'
                          In file included from /Users/Hoffan/Documents/Arduino-development/libraries/MySensors/MySensor.h:205:0,
                          from Scrolltext.ino:34:
                          /Users/Hoffan/Documents/Arduino-development/libraries/MySensors/core/MySensorCore.cpp:234:6: note: declared here
                          void requestTime() {
                            Ok, how about now then..
                            • HoffanH
                              HoffanH
                              Hoffan
                              Now the compile is working...
                              Now i will test it in real :)
                              • Lawrence HelmL
                                Lawrence HelmL
                                Lawrence Helm
                                @Hoffan - how did you get on? Interested to know before I order some components :)
                                • HoffanH
                                  HoffanH
                                  Hoffan
                                  @Lawrence-Helm
                                  It didn't work all the way for me... And i didn't have the time to check whats wrong
                                  It thing its some thing withe the display settings
                                  • AWIA AWI
                                    Another experiment for the V_TEXT variable/ sensor. Including brightness & speed setting and special Alarm function.
                                    upload-3aa973f9-d6cf-41a5-8b59-2241311896b0
                                    A scrolling display to let the family now that the dog needs walking... nothing more than 1 nano, 8 (or whatever number) of displays with max7219 controller upload-f2290f64-a15d-48c9-8420-ab65e481a492 a radio and a few cables
                                    upload-4c163020-edac-4bc5-b3bf-50f1f3cccd24
                                    Total cost: €18 (with 8 displays)
                                    in Domoticz:
                                    upload-868a0c0c-a44d-480f-940c-e0378716ebd3
                                    Built around the very versatile "Parola" driver library
                                    (I will upload a video when I know how to .. ;-))
                                    https://www.youtube.com/watch?v=gCKTm427_Zc
                                     PROGRAMMER: AWI
                                    Special:
                                    SUMMARY:
                                     Remarks:
                                    	Fixed node-id
                                    #if USE_POT_CONTROL
                                    MyTransportNRF24 transport(9,10); 			// Sensoduino (8,7) Ceech board, 3.3v (7,8)  (pin default 9,10)
                                    MySensor gw(transport);
                                      uint8_t colData;
                                      switch(state)
                                          curLen = 0;
                                          state++;
                                          if (*p == '\0')
                                            curLen = 0;
                                            state = 2;
                                          colData = 0;
                                          curLen++;
                                            state = 0;
                                        default:
                                          state = 0;
                                      return(colData);
                                    #if PRINT_CALLBACK
                                    	Serial.print(dev);
                                    	Serial.print(' ');
                                    	Serial.print(t);
                                    	Serial.print(' ');
                                    #if USE_POT_CONTROL
                                    	return(t);
                                    void setup(){
                                    	// Setup MySensors
                                        gw.begin(incomingMessage, nodeId); 						// this node is 51 fixed
                                        gw.sendSketchInfo("AWI Scroll MAX 51", "1.1");
                                     	gw.present(messageCHILD, S_INFO, "Text line Scroll");	// new S_type 20150905 (not know by domoticz)
                                     	gw.present(alarmChild, S_BINARY, "Alarm display");		// to display alarm text
                                    	gw.present(brightnessChild, S_DIMMER, "Text brightness"); // new S_type 20150905 (not know by domoticz)
                                        //gw.send(textMsg.set("-"));							// initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
                                    	gw.request(messageCHILD, V_TEXT, 0); 					// request value from controller
                                    	// Initializations
                                        gw.requestTime(receiveTime);							// get the time from controller (handled by receiveTime)
                                    	readSerial();
                                    			gw.request(messageCHILD, V_TEXT, 0); 				// request new value from controller
                                    		lastUpdate = now;
                                    	scrollText();
                                          putIndex = 0;
                                    korttomaK
                                    korttomaK
                                    korttoma
                                    Hi @AWI do you stil have this setup in use? I tried to convert this to 2.0 and hock it up but there is something wrong with the order of the LED elements. They are somehow scrolling in the wrong direction. With part of the code handles this? Might be that I have the wrong library for the MD_MAX72XX where did you get the lib?
                                    • Tomas
                                    • korttomaK korttoma
                                      AWIA
                                      AWIA
                                      AWI
                                      Hi @korttoma I have it somewhere in the (large) pile of 'old and/or unfinished' projects :blush:
                                      What I remember is that there are difference between the MAX displays in orientation. Below a picture off mine..
                                      0_1480017878576_upload-bc9926a9-cff8-4d9d-b745-1e44384856c8
                                      You can change the display type in the MD_MAX72xx.h file of the library.
                                      From line #212 you can choose various display types (only select one). Have fun and let us know your progress..
                                      korttomaK 1 Reply Last reply
                                      • AWIA AWI
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        #37
                                        Thanks @AWI , the back of my displays are identical to yours and removing the LED element reviles the MAX7219EWG driver underneath.
                                        I will look in to the file you mentioned, maybe I can work something out.
                                        • Tomas
                                        • korttomaK
                                          korttomaK
                                          korttoma
                                          Chose the FC-16 from the .h file and now it is working! Thanks again @AWI
                                          • Tomas
                                          ? 1 Reply Last reply
