  3. Scrolling Text sensor node with new V_TEXT
51 Posts 17 Posters 36.0k Views 13 Watching
  • P popunonkok
    Looks great. Is it posible (Or do you think it will be) to sen dynamic values to the display from Domoticz? Like the temperature or soil moist procentage.
    AWIA
    AWIA
    AWI
    @popunonkok it is very possible. In fact this is what I'm doing. You need to work on the controller side. For domoticz you can use a lua time script which sends new text every x time. For long messages you will need to script a fifo with multiple text messages.
    • GertSandersG
      GertSandersG
      GertSanders
      Is it possible to send text to the node without a request call from the node itself?
      The example is not clear on this point and the json example only sets the text value within Domoticz, right?
      AWIA 1 Reply Last reply
      • GertSandersG GertSanders
        AWIA
        AWIA
        AWI
        @GertSanders Domoticz does not "push" the Text value when changed. The published sketch "asks" periodically for the Text value. What I do now is create a Switch (S_BINARY/ light) with function "New text available". This switch triggers the polling sequence.
        • GertSandersG
          GertSandersG
          GertSanders
          @GizMoCuz : It would be nice to be able to define the text of the S_INFO sensor in de UI of Domoticz, instead of only via json. I'm not capable of programming that myself, but it would make the use of text easier. I already log all incoming SMS messages into my SMS connected sensor in V_TEXT and have it this way a nice view on what nodes are sending to my SMS passthrough node or what SMS messages are received into my MySensors network. I know Domoticz has it's own SMS interface, but my node is capable of switching on stuff based on directly received SMS commands, and with V_TEXT I can now follow what is happening without needing a serial connection to the node. I should be clear that I'm a big fan of Domoticz :-)
          • J
            J
            Jager
            You can send messages as done here? http://forum.mysensors.org/topic/1957/lcd-clock-and-text-sensor-node-with-new-v_text
            • J Jager
              AWIA
              AWIA
              AWI
              @Jager If your controller supports it you can. In Domoticz the text value is not pushed so you need to make a request for it.
              • HoffanH
                HoffanH
                Hoffan
                What am i missing, Because i get this when i try to compile it
                Arduino:1.6.5 (Mac OS X), Kort:"Arduino Nano, ATmega328"
                ScrollingText:55: error: 'V_TEXT' was not declared in this scope
                ScrollingText.ino: In function 'void setup()':
                ScrollingText:166: error: 'S_INFO' was not declared in this scope
                ScrollingText:170: error: 'V_TEXT' was not declared in this scope
                ScrollingText.ino: In function 'void loop()':
                ScrollingText:191: error: 'V_TEXT' was not declared in this scope
                ScrollingText.ino: In function 'void incomingMessage(const MyMessage&)':
                ScrollingText:210: error: 'V_TEXT' was not declared in this scope
                • HoffanH Hoffan
                  AWIA
                  AWIA
                  AWI
                  @Hoffan V_TEXT is still in the development branch...
                  • HoffanH
                    HoffanH
                    Hoffan
                    Okey, That can explain, Byt when i use the Dev Branch
                    I get this Errors
                    ScrollingText:52: error: 'MyTransportNRF24' does not name a type
                    ScrollingText:53: error: 'MySensor' does not name a type
                    ScrollingText:163: error: 'gw' was not declared in this scope
                    ScrollingText:177: error: 'gw' was not declared in this scope
                    • HoffanH Hoffan
                      I get this Errors
                      AWIA
                      AWIA
                      AWI
                      @Hoffan you best read the instructions for the development branch. The syntax changed a little. I'm typing on a phone right now. Best to search yourself
                        wrote on last edited by hek
                        #24
                        How to convert a sketch to 1.6 is described here (until it has been posted somewhere more sticky..) :
                        https://docs.google.com/document/d/1NKq5uuNdnxF5jWnum7VT32mbKLjuvqlx2A5D1qQ-H3Q/edit#heading=h.t5sdmpn6jz2i
                        Basically a few search/replace... The above sketch would look something like this (untested)
                         PROJECT: MySensors / Scrolling Text display
                         PROGRAMMER: AWI
                         DATE: september 12, 2015/ last update: september 12, 2015
                         FILE: AWI_scroll_MAX.ino
                         LICENSE: Public domain
                         Hardware: tbd ..Ceech - ATmega328p board w/ NRF24l01
                            and MySensors 1.5 ()
                        Special:
                            Need to use MySensors development edition
                        SUMMARY:
                            3 S_xx devices for scrolling text
                            - Displays a scrolling text from a "V_TEXT" variable
                            - additional dimmer sensor for controlling display brightness
                            - 'Alarm' switch. If "On", overrides the text display to display ALARM message
                            - You can also input messages from the Serial monitor (testing)
                            Uses excellent MD_MAX72XX library
                         Remarks:
                            Fixed node-id
                        // Use the MD_MAX72XX library to scroll text on the display with the use of the callback function
                        // to control what is scrolled on the display text.
                        // You need to set the used display in the library MD_MAX72XX.h
                        // User can enter text on the serial monitor and this will display as a
                        // Speed for the display is controlled by a pot on SPEED_IN analog in.
                        #include <MD_MAX72xx.h>                     // multipurpose library for MAX72xx diaplay driver  https://parola.codeplex.com/
                        #include <MySensor.h>                       // Mysensor network
                        #include <Time.h>                           //http://playground.arduino.cc/Code/Time
                        #define USE_POT_CONTROL 0                   // enable Scroll speed  potentiometer
                        #define PRINT_CALLBACK  0
                        // Macro to simplify serial print
                        #define PRINT(s, v) { Serial.print(F(s)); Serial.print(v); }
                        // Define the number of devices we have in the chain and the hardware interface
                        // need to be adapted to your setup
                        const int MAX_DEVICES = 8 ;                 // number of 8x8 displays
                        const int CLK_PIN = 7 ;                     // SPI like clock
                        const int DATA_PIN = 8 ;                    // SPI like data
                        const int CS_PIN = 6 ;                      // SPI like select
                        // Parola is able to use SPI hardware interface, not testted in combination with MySensors
                        // MD_MAX72XX mx = MD_MAX72XX(CS_PIN, MAX_DEVICES);
                        // now use Arbitrary pins
                        MD_MAX72XX mx = MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES); // instantiate one display chain
                        // Scrolling parameters, you can attach normal potentiometer to A5, Vcc, Gnd
                        #if USE_POT_CONTROL
                        const int SPEED_IN = A5 ;
                        const int SCROLL_DELAY = 20 ;               // in milliseconds
                        #endif // USE_POT_CONTROL
                        const int CHAR_SPACING = 1 ;                // pixels between characters
                        // MySensors constants & variables
                        const byte nodeId = 51 ;                    // MySensors fixed node id
                        const byte messageCHILD = 8 ;               // Text from ControllerLCD
                        const byte brightnessChild = 9 ;            // Brightness of display
                        const byte alarmChild = 10 ;                // Display Alarm text (overrides normal text)
                        boolean timeReceived = false ;              // Flag to indicate time received
                        // Display constants & variables
                        byte textBrightness = 1 ;                   // brightness of display (between 0 - MAX_INTENSITY (0xF)
                        byte textOnOff = true ;                     // textOnOff = ! shutdown
                        boolean textAlarm = false ;                 // Alarm (switch S_BINARY)
                        // Global message buffers shared by MySensors and Scrolling functions
                        const int BUF_SIZE = 25 ;                   // max payload for MySensors(NRF24l01)
                        char curMessage[BUF_SIZE];                  // current displayed message
                        char newMessage[BUF_SIZE];                  // next message to be displayed if available
                        bool newMessageAvailable = false ;          // new message available flag
                        uint16_t    scrollDelay;                    // in milliseconds
                        // *** Definition and initialisation
                        // define the MySensor network (1.5)
                        // Initialize messages for sensor network
                        MyMessage textMsg(messageCHILD, V_TEXT);    // message for Sending Text to Controller
                        /* MD_MAX72XX functions: can be found in the documentation for the library,
                         * no need to customtize callback & scroll routines (unless you want to...)
                        uint8_t scrollDataSource(uint8_t dev, MD_MAX72XX::transformType_t t)
                        // Callback function for data that is required for scrolling into the display
                          static char       *p = curMessage;
                          static uint8_t    state = 0;
                          static uint8_t    curLen, showLen;
                          static uint8_t    cBuf[8];
                          uint8_t colData;
                          // finite state machine to control what we do on the callback
                          switch(state)
                            case 0: // Load the next character from the font table
                              showLen = mx.getChar(*p++, sizeof(cBuf)/sizeof(cBuf[0]), cBuf);
                              curLen = 0;
                              state++;
                              // if we reached end of message, reset the message pointer
                              if (*p == '\0')
                                p = curMessage;         // reset the pointer to start of message
                                if (newMessageAvailable)    // there is a new message waiting
                                  strcpy(curMessage, newMessage);   // copy it in
                                  newMessageAvailable = false;
                              // !! deliberately fall through to next state to start displaying
                            case 1: // display the next part of the character
                              colData = cBuf[curLen++];
                              if (curLen == showLen)                // end of character insert interchar space
                                showLen = CHAR_SPACING;
                                curLen = 0;
                                state = 2;
                            case 2: // display inter-character spacing (blank column)
                              colData = 0;
                              curLen++;
                                state = 0;
                            default:
                              state = 0;
                          return(colData);
                        // Callback (not used here)
                        void scrollDataSink(uint8_t dev, MD_MAX72XX::transformType_t t, uint8_t col){
                        // Callback function for data that is being scrolled off the display
                        #if PRINT_CALLBACK
                            Serial.print("\n cb ");
                            Serial.print(dev);
                            Serial.print(' ');
                            Serial.print(t);
                            Serial.print(' ');
                            Serial.println(col);
                        // non-blocking text display to be used in loop (call frequently)
                        void scrollText(void){
                            static uint32_t prevTime = 0;
                            if (millis()-prevTime >= scrollDelay){                  // Is it time to scroll the text?
                                mx.transform(MD_MAX72XX::TSL);                      // scroll along - the callback will load all the data
                                prevTime = millis();                                // starting point for next time
                        // sets the scroll delay (read from potentiometer if enabled)
                        uint16_t getScrollDelay(void){
                        #if USE_POT_CONTROL
                            uint16_t t = analogRead(SPEED_IN);
                            t = map(t, 0, 1023, 25, 250);
                            return(t);
                            return(SCROLL_DELAY);
                        void setup(){
                            // set up the display first
                            mx.begin();                                             // initialize display chain
                            mx.setShiftDataInCallback(scrollDataSource);            // define function to get the scrolldata (returned as int8)
                            //mx.setShiftDataOutCallback(scrollDataSink);           // not used
                            mx.control(MD_MAX72XX::INTENSITY, 0x01);
                        #if USE_POT_CONTROL                                         // initialize speed potentiometer if enabled
                            pinMode(SPEED_IN, INPUT);
                            scrollDelay = SCROLL_DELAY;
                            strcpy(curMessage, "I \x03 MySensors ");                // first message on display
                            newMessage[0] = '\0';                                   // new message initialized to empty
                            // Setup MySensors
                           //Serial in Sensor network = 115200
                            //Send the sensor node sketch version information to the gateway
                            sendSketchInfo("AWI Scroll MAX 51", "1.1");
                            present(messageCHILD, S_INFO, "Text line Scroll");   // new S_type 20150905 (not know by domoticz)
                            present(alarmChild, S_BINARY, "Alarm display");      // to display alarm text
                            present(brightnessChild, S_DIMMER, "Text brightness"); // new S_type 20150905 (not know by domoticz)
                            //send(textMsg.set("-"));                            // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
                            request(messageCHILD, V_TEXT, 0);                    // request value from controller
                            // Initializations
                            requestTime();                            // get the time from controller (handled by receiveTime)
                        // loop only uses non-blocking functions
                            static unsigned long lastUpdate ;                       // Static hold the last update time
                            unsigned long now = millis();
                            scrollDelay = getScrollDelay();                         // update scroll delay from potentiometer
                            readSerial();
                            // Check for new conditions & ask for new information from controller every 10 seconds
                            if (now-lastUpdate > 10000){
                                if (textAlarm){                                     // if alarmstatus: override all text and set max intensity
                                    strcpy(curMessage, "   ALARM   ");
                                    mx.control(MD_MAX72XX::INTENSITY, MAX_INTENSITY);   // set current brightness
                                    mx.control(MD_MAX72XX::SHUTDOWN, false) ;
                                } else {                                            // standard (non Alarm actions)
                                    mx.control(MD_MAX72XX::INTENSITY, textBrightness);  // set current brightness
                                    mx.control(MD_MAX72XX::SHUTDOWN, textOnOff) ;
                                    request(messageCHILD, V_TEXT, 0);                // request new value from controller
                                lastUpdate = now;
                            scrollText();
                            setTime(controllerTime);                                // time from controller
                            timeReceived = true;
                        // This is called when a message is received
                            Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
                            if (message.sensor == messageCHILD){
                                if (message.type==V_TEXT) {                     // Text content
                                strcpy(newMessage, message.getString());        // copy it in
                                    newMessageAvailable = true ;
                            } else if (message.sensor == alarmChild) {
                                if (message.type==V_STATUS) {                   // True/ false content
                                    textAlarm = message.getBool()?true:false ;  // set alarmflag
                                    Serial.print("TextAlarm: ");
                                    Serial.println(textAlarm);
                            } else if (message.sensor == brightnessChild){
                                if (message.type==V_PERCENTAGE) {               // Level 0..100  content
                                    textBrightness = map(message.getInt(),0, 100, 0, MAX_INTENSITY ) ;  // map to brightnesslevel
                                    Serial.print("TextBrightness: ");
                                    Serial.println(textBrightness);
                                } else if (message.type==V_STATUS) {            // Display on/off
                                    textOnOff = message.getBool()?false:true ;      // set shutdown/ !on/off
                                    Serial.print("Text on/off: ");
                                    Serial.println(textOnOff);
                        // Testing purposes: input routine character buffer. Reads serial characters in buffer newMessage.
                        // sets flag newMessageAvailable to true if completed
                        void readSerial(void)
                          static uint8_t    putIndex = 0;
                          while (Serial.available())
                            newMessage[putIndex] = (char)Serial.read();
                            if ((newMessage[putIndex] == '\n') || (putIndex >= BUF_SIZE-3)) // end of message character or full buffer
                              // put in a message separator and end the string
                              newMessage[putIndex++] = ' ';
                              newMessage[putIndex] = '\0';
                              // restart the index for next filling spree and flag we have a message waiting
                              putIndex = 0;
                              newMessageAvailable = true;
                              // Just save the next char in next location
                              newMessage[putIndex++];
                        • D
                          dayve218
                          ive spent a couple of hours on this, and i cant get it to work. any help?
                          • D
                            dayve218
                            @AWI are you able to help me convrt this to1.6? i cant get it
                              Fixed a couple of thing in the sketch. Now it compiles on 1.6 but you have to install the MD_MAX72xx library which it uses.
                              • HoffanH
                                HoffanH
                                Hoffan
                                Where did you put the new sketch??
                                hekH 1 Reply Last reply
                                • HoffanH Hoffan
                                  @Hoffan
                                  I updated my post above.
                                  • HoffanH
                                    HoffanH
                                    Hoffan
                                    Okey... Strange because i test to compile that i Dev Branch and i get this error
                                    Scrolltext.ino: In function 'void presentation()':
                                    Scrolltext:205: error: too many arguments to function 'void requestTime()'
                                    In file included from /Users/Hoffan/Documents/Arduino-development/libraries/MySensors/MySensor.h:205:0,
                                    from Scrolltext.ino:34:
                                    /Users/Hoffan/Documents/Arduino-development/libraries/MySensors/core/MySensorCore.cpp:234:6: note: declared here
                                    void requestTime() {
                                      Ok, how about now then..
                                      • HoffanH
                                        HoffanH
                                        Hoffan
                                        Now the compile is working...
                                        Now i will test it in real :)
                                        • Lawrence HelmL
                                          Lawrence HelmL
                                          Lawrence Helm
                                          @Hoffan - how did you get on? Interested to know before I order some components :)
