  3. Help with arrays and debouncing
11 Posts 4 Posters 5.6k Views 1 Watching
  • DammeD
    DammeD
    Damme
    Code Contributor
    wrote on last edited by Damme
    I am not by a computer now but :
    define NUMCHILDREN sizeof(children)
    children = 8 chars.. :) you cant define that like so. The compiler will try to do a size of before code is compiled.
    The correct way would be uint8_t numchildren = sizeof(children); as your first line of code.
    and note, dont have a habit of using INT as standard (2 bytes, -32,768 to 32,767)
    YveauxY petewillP 2 Replies Last reply
    • DammeD Damme
      @Damme no, that's not true....
      Children is an array of int. Sizeof(int) = 2, sizeof(children) = size of the whole structure = 8*sizeof(int) = 14
      I usually define a macro to get the number of elements in an array:
      #define ARRAY_SIZE(x) (sizeof(x)/sizeof(x[0]))
      Then use as:
      for(int I = 0; I < ARRAY_SIZE(children); ++I)
      DammeD petewillP 2 Replies Last reply
      • YveauxY Yveaux
        Then use as:
        DammeD
        DammeD
        Damme
        Code Contributor
        @Yveaux Hmm, you're right. I didsomething just the other day and realized that it was sizing the variable as a string, not the content of variable itself! and it was somthing like in this example.Hmm, too bad I didn't remenber correcly.. :)
        • YveauxY Yveaux
          Then use as:
          petewillP
          petewillP
          petewill
          Great, thanks. Just so I'm clear, I would just paste in the line of code above as is? I don't need to substitute x for anything else?
          I was also just thinking... Is there any problem with having multiple Bounce objects in the array like I did?
          Thanks again. I'll try this tonight when I get home.
          • DammeD Damme
            petewillP
            petewillP
            petewill
            Sorry forgot to respond to this before. What would you recommend I use instead, byte?
            • petewillP petewill
              uint8_t, which is effectively an unsigned char or byte.
              Bit more typing, but I prefer making things explicit.
              Also no discussion on the size if you ever decide to port your code to a different platform (regular int on ATMega is 8bit, Arduino defines it as 16bit, on 32bit intel x86 or e.g. Raspberry Pi it is 32bit and on 64bit intel x64 it is 64bit !!)
              • petewillP
                petewillP
                petewill
                Ok, making progress. I think I have more problems than just my code. I am using a Mega so I can get more inputs and apparently I don't have something wired quite right. My sensors are sending 10 times but then stop because they are not receiving an Ack. That will then cause my node to time out. It seems I don't have the radio wired correctly. Any idea which pin is wrong? The sends are working fine when going to Vera (at least until the timeout). Here is what I'm getting in the serial monitor:
                    Relaying message back to gateway.
                    Tx: fr=12,to=0,la=12,ne=0,ci=21,mt=1,ty=16,cr=235: 0
                    Ack: receive timeout
                    Natalie's Door: 0
                    Tx: fr=12,to=0,la=12,ne=0,ci=21,mt=1,ty=16,cr=140: 1
                    Natalie's Door: 1
                    Natalie's Door: 0
                    Open ping reading pipe: 12
                    Tx: fr=12,to=255,la=12,ne=255,ci=255,mt=4,ty=9,cr=85:
                    No relay nodes was found. Trying again in 10 seconds.
                • petewillP
                  petewillP
                  petewill
                  Probably should have done some more testing before posting. Just anxious to get this working before I have to go to bed...
                  I figured out the problem. I had to put a capacitor across my radio 3.3v and ground pins. I haven't had to do this with any of my pro mini sensors so I forgot that may be an issue. Anyway, after doing that I got an Ack: received OK message!
                  Hopefully my mistakes can help someone else avoid them...
                  • petewillP
                    petewillP
                    petewill
                    Ok, looks like I was wrong again. Turns out was a bad wire (or wires) connecting the radio to the Mega. Either that or the Mega has some bad connections. Anyway, I switched out the wires and all is working again (for now).
                    Z 1 Reply Last reply
                      Z
                      Z
                      Zeph
                      Loose wires are a bear to find at times - you do something (like adding a cap) and you think you fixed it. Then for no good reason the problem comes back. Been there.
