  3. Isue / Bug in message.getInt or getFloat/ payload dos not reinitialized completely?
9 Posts 2 Posters 4.0k Views 1 Watching
  • M Offline
    M Offline
    maxtox
    wrote on last edited by maxtox
    Hi, i think it is abug in message.getInt/ Get Float because... after couple of times from reading a int value it gets the rest of a float before ...
    example
    it reads allways a value 10 with getInt
    then a temp sensor sends a value 47.28
    after the getInt value gets 1028
    check here:
    i send to node 0/13 ALLWAYS "0" and after 10sec "-20.20"
    if i take get Float it gets FUNNY numbers like (see in the code):
    20.20 or 1.28 etc..
    im pwm
    im digital
    0;255;3;0;9;Message arrived on topic: DOino<>MQTT/0/13/1/0/3
    im pwm
    im digital
    0;255;3;0;9;Sending message on topic: DOino<>MQTT/0/58/1/0/0
    0;255;3;0;9;Message arrived on topic: DOino<>MQTT/0/58/1/0/0
    im pwm
    im digital
    im pwm
    im digital
    im pwm
    im digital
    im pwm
    im digital
    im pwm
    im digital
    node receives on child id
    always the number after the "." (in this case 28) gets as add to int value of 10...So it gets 1028
    could you please check! can send you my sketch if you like!
    Arduino Mega 2560 with iobroker.net (MQTT, node-red, etc..)
    • M Offline
      M Offline
      maxtox
      here anothe example (getFloat)
      i'm sending 1.1 and -20.20)
      geting sometimes right values but sometimes:
      im pwm
      im digital
      im pwm
      So somehow it doesnt see the "0" and writes something from the last value!
      • M Offline
        M Offline
        maxtox
        If i send 10 or 100 (so MANY ZERO's) with getFloat
        it gets COMPLETly CRAZY!
        10073.00
        im digital
        im pwm
        • hekH Offline
          hekH Offline
          Might be related to this:
          https://github.com/mysensors/Arduino/pull/317
          • M Offline
            M Offline
            maxtox
            checking!
            • M Offline
              M Offline
              maxtox
              same issue!!!!
              NO changes!
              • M Offline
                M Offline
                maxtox
                changed to the NEW ->>>MYTransport.cpp from Pull!
                sending -2 and 10 as float to arduino:
                im digital
                im digital
                0;255;3;0;9;Message arrived on topic: DOino<>MQTT/0/58/1/0/0 as Float!!!!!!!!!!
                im digital
                • M Offline
                  M Offline
                  maxtox
                  please tell us when is solved, because i have made a Sketch to use ALL of the sensors with MQTT! But with this issue NOBODY could yuse it...
                  Just a part of te code;
                    int childPin = message.sensor;
                    //  Serial.println(message.getBool());
                    //  Serial.println(message.sensor);
                    for (int i = 0; i<iomodus_count; i++) ////search All Sensor Variables and set them
                    { //MyMessage msg(i, iomodus[i].variableType);
                      while (iomodus[i].sensorType == S_UNUSED) { i++; }  //do not waste time to check UNUSED pins
                                                //********************************IF VAR1 = Temp OFFSET existst***************************************
                      if (message.type == V_VAR1)
                        if ((childPin == i) && (iomodus[i].sensorType == S_TEMP) && (iomodus[i].sensorVersion == "MAX31855"))
                          Temp_offset[i] = message.getFloat();
                        if ((childPin == i) && (iomodus[i].sensorType == S_TEMP) && (iomodus[i].sensorVersion == "NTC"))
                      //********************************IF VAR2 = LPF (Low Pass Filter existst***************************************
                      if (message.type == V_VAR2)
                        //***************Low Pass Filter**************
                        if ((childPin == i) && (iomodus[i].sensorType == S_TEMP) && (iomodus[i].sensorVersion == "MAX31855") && (message.getFloat() <= 1.0))
                          ktype_LPF_rate[i] = message.getFloat();
                      //********************************IF V_STATUS or V_LIGHT existst***************************************
                      if (message.type == V_STATUS)
                        if ((childPin == i) && (iomodus[i].sensorType == S_BINARY) && (iomodus[i].sensorVersion == "RELAY"))
                          if (relstate[i] != message.getBool())
                            digitalWrite(i, message.getBool() ? RELAY_ON : RELAY_OFF);
                            relstate[i] = message.getBool();
                            // Store state in eeprom
                            saveState(i, message.getBool());
                      //********************************IF V_PERCENTAGE or V_DIMMER existst***************************************
                      if ((message.type == V_PERCENTAGE) && (message.getInt() <= 100) && (message.getInt() != last_int_value[i]))
                        //***************PWM Rate 0 to 100 (%)**************
                        if ((childPin == i) && (iomodus[i].sensorVersion == "PWM")&& (i<=13))
                            pinMode(i, OUTPUT);
                            analogWrite(i, message.getInt()*2.25); // Set Value 0-255
                            last_int_value[i] = value;
                        //http://www.instructables.com/id/Analog-Output-Convert-PWM-to-Voltage/
                        if ((childPin == i) && (iomodus[i].sensorVersion == "PWM_5V") && (i >= 54) && (i >= 69))
                            pinMode(i, OUTPUT);
                            analogWrite(i, message.getInt()*2.55); // Set Value 0-255
                  HERE is the problem!!!!
                  message.getInt()
                  we can not use this function, if i use later in the void loop this:
                  				send(msg.setSensor(i).set(tempNTC, 2), 0);
                  because parts of this value float tempNTC are attached to the integer value above!
                  so it would be very cool if you could solve this issue!
                  Thank you!
                  • M Offline
                    M Offline
                    maxtox
                    Update...
                    to find the BUG maybe it will help:
                    I noticed that after a float value publisching, the "Dirt" is only staying until the next value:
                    here is ok
                    0;255;3;0;9;Message arrived on topic: DOino<>MQTT/0/11/1/1/15
                    0;255;3;0;9;Sending message on topic: DOino<>MQTT/0/11/1/1/15
                    message
                    1.00
                    here comes the float:
                    0;255;3;0;9;Message arrived on topic: DOino<>MQTT/0/58/1/1/0
                    0;255;3;0;9;Sending message on topic: DOino<>MQTT/0/58/1/1/0
                    message
                    40.84
                    here comes the DIRT (8 should be ZERO:
                    0;255;3;0;9;Message arrived on topic: DOino<>MQTT/0/8/1/1/2
                    0;255;3;0;9;Sending message on topic: DOino<>MQTT/0/8/1/1/2
                    message
                    0.84
                    here is the DIRT gone:
                    0;255;3;0;9;Message arrived on topic: DOino<>MQTT/0/10/1/1/77
                    0;255;3;0;9;Sending message on topic: DOino<>MQTT/0/10/1/1/77
                    message
                    0.00
                    0;255;3;0;9;Message arrived on topic: DOino<>MQTT/0/11/1/1/77
                    0;255;3;0;9;Sending message on topic: DOino<>MQTT/0/11/1/1/77
                    message
                    but funy is, that the MQTT Server does NOT get any dirt :
                    mqtt-0	2016-01-03 09:38:33	info	Send to client [mqtt_fd810ccf.027ef] "mqtt/0/DOino<>MQTT/0/8/1/1/2": 0
                    mqtt-0	2016-01-03 09:38:33	info	Send to client [DOino_1] "DOino<>MQTT/0/8/1/1/2": 0
                    from this float:
                    mqtt-0	2016-01-03 09:38:33	info	Client [DOino_1] _publishes "mqtt.0.DOino<>MQTT.0.58.1.1.0"(number): 40.84
                    mqtt-0	2016-01-03 09:38:33	info	Send to client [mqtt_fd810ccf.027ef] "mqtt/0/DOino<>MQTT/0/58/1/1/0": 40.84
                    mqtt-0	2016-01-03 09:38:33	info	Send to client [DOino_1] "DOino<>MQTT/0/58/1/1/0": 40.84```
