  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.6k Views 73 Watching
  • P
    P
    p0lar
    Yes I can reboot the node. trying to upload dallastemp to it.
    MySensors_20160102-104854.log
    tekkaT 1 Reply Last reply
    • P p0lar
      tekkaT
      tekkaT
      tekka
      @p0lar I do not see any DEBUG nor bootloader messages. Can you update the GW sketch with DEBUG enabled? Also, what bootloader did you flash?
      • P
        P
        p0lar
        Its turned on in MySensors.h and reuploaded
        MyConfig.h
        • P
          P
          p0lar
          But i dont see anything. UNO ethernet GW with SoftSPI enabled
          • P
            P
            p0lar
            Bootloader on the sensors is the one from your firmware directory. on the GW its the standard arduino one... do I need yours on the GW?
            • P p0lar
              tekkaT
              tekkaT
              tekka
              @p0lar No, GW should have normal (i.e. Arduino) bootloader. However, without DEBUG output it's gonna be hard to diagnose what's wrong - can you double-check your settings and re-upload the GW sketch just to be on the safe side.
              Also, I'd like to see the log during a manual reset (not remote reboot) of your node.
              • P
                P
                p0lar
                Thanks. Ill check that when I get back into town end of this week.
                  stebra
                  Hi @tekka,
                  tried now some evenings to change node-id / clear the eeprom. No luck. FW update works always. After reading the bootloader code I expected myscontroller to send a invalid fwrequestresponse packet with special crc for the bootloader commands. Never showed up in the log.
                  Myscontroller .282 on Win xp and msbootloader 1.1 on nano. 47uF on nrf. No transmission errors.
                  Any ideas where to look next ? Maybe .278 will do the trick ?
                  Thanks for your efforts ,
                  stebra
                  • S stebra
                    Hi @tekka,
                    stebra
                    tekkaT
                    tekkaT
                    tekka
                    @stebra please post the myscontroller log with gw DEBUG enabled that shows OTA update and ID reassign request.
                      stebra
                      MySensors_20160110-115615_stebra.log
                      hi tekka,
                      here is the log. Contains:
                      [2016-01-10 12:02:26.390 Info] INFO *** Logging START *** // stebra : succesful reboot of node 6 via myscontroller
                      [2016-01-10 12:02:59.000 Info] INFO *** Logging START *** // stebra : succesful FW update of node 6 via myscontroller
                      [2016-01-10 12:05:35.109 Info] INFO *** Logging START *** // stebra : ID reassign attempt of node 6 to node 12 via myscontroller
                      [2016-01-10 12:05:48.328 Info] INFO Send FW info to node 6: type=1E, version=1, blocks=0x0448, CRC=0xA87A // here the behaviour is unexpected for me
                      [2016-01-10 12:06:37.437 Info] INFO *** Logging START *** // stebra: Clear eeprom attempt on node 6
                      [2016-01-10 12:06:44.812 Info] INFO Send FW info to node 6: type=1E, version=1, blocks=0x0448, CRC=0xA87A // here the behaviour is unexpected for me
                      thank you for having a look..
                        stebra
                        and also a ss for another reassign attempt node 6--> 12.
                        FIRMWARE_CONFIG_REQUEST is not answered from myscontroller. therefore no reassign of node id.
                        • D
                          dakipro
                          wrote on last edited by dakipro
                          #338
                          Maybe I should open a new topic for this, but I cannot flash bootloader, I always get
                          Arduino: 1.6.7 (Windows 10), Board: "ATmega328 internal 8Mhz with MYSBootloader"
                          ***failed;
                          avrdude: verification error, first mismatch at byte 0x0000
                          0x3f != 0xff
                          Here is the verbose message
                          C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM4 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:i -Ulock:w:0xFF:m
                          avrdude: verifying ...
                          avrdude done.  Thank you.
                                   Programmer Type : STK500
                                   Hardware Version: 2
                                   Firmware Version: 1.18
                                   Topcard         : Unknown
                                   Vtarget         : 0.0 V
                                   Varef           : 0.0 V
                                   Oscillator      : Off
                                   SCK period      : 0.1 us
                          avrdude: erasing chip
                          avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex"
                          avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
                          avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
                          avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex contains 32722 bytes
                          Writing |  ***failed;
                          avrdude: verifying lock memory against 0xFF:
                          avrdude: load data lock data from input file 0xFF:
                                   0x3f != 0xff
                          I get same message with both 3.3v and 5v pro mini that is linked in the store.
                          I am using Funduino uno as a ips, and I can flash blink f.eks. using uno as isp, but I cannot flash bootloader. This is the step 6 from the instructions that is failing. Any ideas how to fix this? I would really like OTA as my network is slowly growing.
                          Thanks for any tips!
                          • D
                            dakipro
                            I think I have flashed MYSBootloader finaly, after ~6hours of trying and reading (persistent guy :) )
                            The instructions are for the older version I guess, right board should be copied from MYSController/bootloader/boards.txt, not from this topic post#75. Now I am trying to figure how to flash the sketch, but I guess that is explained somewhere on the topic
                            • D
                              dakipro
                              Just one more question, I didn't find it answered on the topic (maybe too tired), but:
                              I have existing network with ethernet gateway and some nodes, and all is working fine. To make it OTA update-able, I need to
                              1. i upload ethernet gateway to the Arduino Nano, then flash MYSBootloader on it,
                              2. upload some sketch (which?) on Arduino Mini nodes, and then flash MYSBootloader on it, and then I can program it OTA?
                              3. Or something else?
                              Or did I miss the point completely? :(
                              • P
                                P
                                p0lar
                                wrote on last edited by p0lar
                                #341
                                so from what I know.
                                you DONT need the MYSBootloader on the gateway. just normal arduino bootloader. you DO need the MYSBootloader on ALL the sensors you with to connect to your gateway.
                                Do the MYSBootloader first then use this tool to upload the firmware to your sensors OTA
                                • D dakipro
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @dakipro I use the settings mentioned in #75 in Atmel studio, however, AVRDUDE does not support the upper two bits of the lock fuse (therefore the error message 0xFF!=0x3F). Changing the lock bits to 0x3F should do the job.
                                  And yes, as @p0lar pointed out, only the nodes and not the gateway should have MYSBootloader.
                                  • P
                                    P
                                    p0lar
                                    HMM i cant build a DEBUG version of the ethernet gateway... even when I try to define it and print hello world it wont... weird.. any ideas?
                                    • D
                                      dakipro
                                      Aha, I get it now. Then I just flash MYSBootloader on the sensor, and attach the radio and it will automatically connect to the gateway (it has some sort of sketch/communication with MySensors built in)? And then I use the MYSController to upload my sketch as described?
                                      Or how do I upload a initial sketch if I cannot use arduino anymore?
                                      Btw, I love MYSController, i use it all the time in development as it shows all that is going on with the sensors, thank you very much for developing it!
                                      • P
                                        P
                                        p0lar
                                        #345
                                        correct. you build the .hex file in arduino studio or whatever and copy it to the MY gui firmware folder and edit the csv file and then reload.
                                        http://forum.mysensors.org/topic/1066/bootloader/8
                                        This should help
                                        • P
                                          P
                                          p0lar
                                          #346
