  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 212.8k Views 36 Watching
  • mfalkviddM
    @den2k I think your best chance is to post in the Home Assistant category. I don't have any experience with Home Assistant unfortunately.
    • J jpbabou
      Hi
      something is missing..
      Is there a problem with the repository
      Tks a lot for your job!
      pi@domoticjp ~ $ sudo git clone https://github.com/mysensors/Raspberry.git
      Cloning into 'Raspberry'...
      remote: Counting objects: 273, done.
      remote: Compressing objects: 100% (3/3), done.
      remote: Total 273 (delta 0), reused 0 (delta 0), pack-reused 270
      Receiving objects: 100% (273/273), 215.00 KiB | 0 bytes/s, done.
      Resolving deltas: 100% (114/114), done.
      Checking connectivity... done.
      pi@domoticjp ~ $ cd Raspberry/librf24-bcm
      -bash: cd: Raspberry/librf24-bcm: No such file or directory
      @jpbabou said:
      Hi
      The guide has been updated to reflect the updated in the MySensors Raspberry repository now. Thanks @jpbabou !
      • D den2k
        weird. Permission Denied problem again.
        What is the USER : GROUP that is needed for this to work?
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        #47
        @den2k
        Hi!
        Have you added the user that runs homeassistant to the dialout group? This group is usually owner of serial ports.
        Check default group of serial port (change for your port below) after connecting it:
        pi@martin-pi:~ $ ls -l /dev/ttyUSB0
        crw-rw---- 1 root dialout 188, 0 dec 18 03:21 /dev/ttyUSB0
        Check groups that user pi is in:
        pi@martin-pi:~ $ groups pi
        pi : pi adm dialout cdrom sudo audio video plugdev games users input netdev spi i2c gpio
        If pi runs homeassistant, which should be the case, and is not in dialout, add pi to dialout:
        sudo adduser pi dialout
        Changing owner of a port will only work until you disconnect it. Default owner will be restored upon reconnect, if you haven't written a special udev rule.
        Edit:
        According to the readme in the mysensors raspberry repo (https://github.com/mysensors/Raspberry), the group of the device is tty. So you should probably use that, and not dialout. But you will know, when you check with ls -l.
          Note: This guide is only applicable to MySensors 1.x. For MySensors 2, use this guide.
          I noticed that a step-by-step procedure to connect the NRF24L01 to the GPIO pins and use the Raspberry as a Serial Gateway was listed in the document for MySensors 1.6.
          Since I have three gateways configured this way, and I need to set up 3 more for covering different offices around the world, and I had already written the instructions in Swedish for Datormagazin, I thought I'd help out.
          This is the first draft. Any feedback is welcome.
          INTRODUCTION
          The radio module NRF24L01+ is cheap and power efficient, but it is unable to communicate with regular wifi. The bridge between NRF24L01+ nodes and the "computer world" is called a Gateway. You can use other types of gateways, but connecting the NRF24L01+ module directly to the Raspberry Pi is a simple and cheap alternative.
          Wiring Things Up
          Connect the NRF20L01+ radio module to the Raspberry Pi like this:
          Raspberry Pi NRF24L01+ Color
          6 / GND GND Black
          1 / 3.3V DC VCC Red
          22 / GPIO25 CE Orange
          24 / GPIO 8 CSN/CS Yellow
          23 / GPIO11 / SPI_CLK SCK Green
          19 / GPIO10 / SPI_MOSI MOSI Blue
          21 / GPIO9 / SPI_MISO MISO Violet
          The IRQ pin on NRF24L01 is not currently used.
          For a comprehensive view of the Raspberry Pi pins, see http://pinout.xyz/
          You should also connect a decoupling capacitor to the radio. See this guide.
          COMPILING THE GATEWAY
          Login to your Raspberry Pi (using SSH or open a terminal on the graphical console) and run these commands:
          git clone https://github.com/TMRh20/RF24.git
          cd RF24
          make all && sudo make install
          cd ..
          cd Raspberry
          If you get the following error:
          pi@raspberrypi ~/RF24 $ make all && sudo make install
          g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c RF24.cpp
          gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c bcm2835.c
          bcm2835.c: In function ‘bcm2835_init’:
          bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
          You've probably run into the problem discussed in this thread. People have had luck with different solutions. The simplest is to make the following change to ~/Raspberry/librf24-bcm/Makefile
          #IOBASE := $(shell cat /proc/iomem | grep bcm2708_vcio | cut -f 1 -d "-")
          IOBASE := 3F000000
          VERIFY THE GATEWAY
          Run sudo /usr/local/sbin/PiGatewaySerial. The output should look like this:
          pi@raspberrypi ~/Raspberry $ sudo /usr/local/sbin/PiGatewaySerial
          Starting PiGatewaySerial...
          Protocol version - 1.4
          Created PTY '/dev/pts/1'
          Gateway tty: /dev/ttyMySensorsGateway
          ================ SPI Configuration ================
          CSN Pin          = CE0 (PI Hardware Driven)
          CE Pin           = Custom GPIO25
          Clock Speed      = 8 Mhz
          ================ NRF Configuration ================
          STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
          RX_ADDR_P0-1     = 0xe7e7e7e7e7 0xc2c2c2c2c2
          RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
          TX_ADDR          = 0xe7e7e7e7e7
          RX_PW_P0-6       = 0x00 0x00 0x20 0x00 0x00 0x00
          EN_AA            = 0x3b
          EN_RXADDR        = 0x07
          RF_CH            = 0x4c
          RF_SETUP         = 0x23
          CONFIG           = 0x0e
          DYNPD/FEATURE    = 0x3f 0x06
          Data Rate        = 250KBPS
          Model            = nRF24L01+
          CRC Length       = 16 bits
          PA Power         = PA_LOW
          If the NRF24L01+ isn't correctly wired, the following error will be shown
          pi@raspberrypi ~ $ sudo /usr/local/sbin/PiGatewaySerial
          Created PTY '/dev/pts/2'
          check wires
          If this happens, double-check your wiring and correct any problems. Press Ctrl+Z and type
          sudo killall PiGatewaySerial
          to get rid of the non-functioning Gateway. Then run sudo /usr/local/sbin/PiGatewaySerial again
          If all is well, exit PiGatewaySerial by pressing Ctrl+C. Then run
          sudo /etc/init.d/PiGatewaySerial start
          to start the gateway as a background process. Verify that it started correctly by running
          sudo cat /dev/ttyMySensorsGateway
          You should see the message "Gateway startup complete". Exit by typing Ctrl+C.
          MAKE THE GATEWAY AUTOSTART
          To make sure the Gateway is started when your Raspberry Pi boots up, run the following command:
          sudo make enable-gwserial
          Enable the gateway for use with Domoticz
          Domoticz (and maybe other home automation systems) has trouble reading from the default path created by PiGatewaySerial. You might need to run the following command:
          sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
          And change /etc/rc.local from this
          exit 0
          to this
          exit 0
          OTHER NOTES
          • The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required. If you use an external power source gnd must be connected to the Raspberry Pi's gnd.
          • Connecting the NRF24L01+ directly to your Raspberry Pi will prevent you from using the Raspberry Pi's gpio ports for other things, like a Z-wave board.
          • A user experienced slow data transfer compared to USB-to-Serial(ttl)<-->MySensors Gateway connection, especially on OTA firmware update. If you think this will cause a problem for you, an ethernet gateway might be a better alternative.
          As always, I stand on the shoulders of giants. Related posts:
          • http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
          • http://forum.mysensors.org/topic/1974/domoticz-as-controller-and-a-gateway-for-mysensor-nodes-running-on-a-raspberry-pi-2
          TROUBLESHOOTING
          If you get this error
          pi@Domoticz3:~/Raspberry$ sudo /etc/init.d/PiGatewaySerial start
          [....] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.serviceFailed to start PiGatewaySerial.service: Unit PiGatewaySerial.service failed to load: No such file or directory.
           failed!
          or this error
          sudo: /usr/local/sbin/PiGatewaySerial: command not found
          you have probably forgotten to run sudo make install. Read the instructions again, and follow them this time :-) User @sineverba reported that a reboot of the Pi after running make install helped.
          Scala
          @mfalkvidd Hi there and thanks for a great and super detailed step-by-step tutorial.
          I've got mine running in no time with your instructions, but after a couple of minutes I've got the following error:
          2015-12-30 20:51:30.356 Error: MySensors: Unhandled sensor (sub-type=32), please report with log!
          2015-12-30 20:52:01.390 Error: Serial Port closed!... Error: End of file
          2015-12-30 20:52:02.315 MySensors: retrying in 30 seconds...
          2015-12-30 20:52:31.319 MySensors: Using serial port: /dev/ttyUSB20
          2015-12-30 20:52:31.320 Error: MySensors: Error opening serial port!
          2015-12-30 20:52:32.321 MySensors: retrying in 30 seconds...
          2015-12-30 20:53:01.324 MySensors: Using serial port: /dev/ttyUSB20
          I also attached a partial screen capture showing that it was working before 8-)
          Any idea on why is this happening and how to solve it?
          Southern regards and happy new year to all!
          ronnyandreR 1 Reply Last reply
          • mfalkviddM
            You are using a sensor type that your version of Domoticz doesn't support. What type os sensor is it? Which version of Domoticz are you using? Upgrading Domoticz might solve the problem (if the newer version supports this sub-type).
            • Sander TeunissenS
              Sander TeunissenS
              Sander Teunissen
              When I try to run the init.d script:
              I get the following error:
               failed!
              No such file or directory.... Obviously a missing folder or file, but I am not savvy enough to debug this.... Any help appreciated..
              • Sander TeunissenS Sander Teunissen
                 failed!
                @Sander-Teunissen my guess is that you forgot the sudo make install part of the installation instructions.
                • Sander TeunissenS
                  Sander TeunissenS
                  Sander Teunissen
                  @mfalkvidd Yesterday I stopped trying and shutdown the Pi. This morning I tried the same again and it works !!
                  Pretty sure I haven't done anything else.
                  Thanks anyway.
                  Sander
                  • MrRikkieM
                    MrRikkieM
                    MrRikkie
                    wrote on last edited by MrRikkie
                    #53
                    Hello, If followed the instruction and everything seemed to work without any problem.
                    However when I enter the command : sudo cat /dev/ttyMySensorsGateway
                    I get the message : cat: /dev/ttyMySensorsGateway: No such file or directory
                    Does anybody have any idea how to solve this ?
                    mfalkviddM ronnyandreR 2 Replies Last reply
                    • MrRikkieM MrRikkie
                      @MrRikkie what output did you get when you ran sudo /etc/init.d/PiGatewaySerial start ?
                      • MrRikkieM
                        MrRikkieM
                        MrRikkie
                        No output and no error message. Just a new command line.
                        pi@raspberrypi ~ $ sudo /etc/init.d/PiGatewaySerial start
                        pi@raspberrypi ~ $
                        • Sander TeunissenS
                          Sander TeunissenS
                          Sander Teunissen
                          When I
                          ls -l ttyMySensorsGateway
                          I get
                          lrwxrwxrwx 1 root root 10 Jan  3 20:21 ttyMySensorsGateway -> /dev/pts/0
                          It's all root. This results in all kinds of acessability issues. I followed all instructions exactly. Anyone any ideas how to change this ?
                          Sander.
                          martinhjelmareM mfalkviddM 2 Replies Last reply
                            When I
                            I get
                            Sander.
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @Sander-Teunissen
                            Try writing a udev rule to set owner of the device (ttyMysensorsGateway) at boot. If you don't need to use the link you could write a rule that names the pts device to the same name every boot, I think. At least for usb devices this works. Haven't tried it in this particular case.
                              When I
                              I get
                              Sander.
                              @Sander-Teunissen said:
                              When I
                              I get
                              The permissions for a soft link are not used (and if they were, any user would be allowed to do anything since everything is rwx). The permissions for the target is used instead. So it is the result of
                              ls -l /dev/pts/0
                              you need to worry about.
                              • ahmedadelhosniA
                                ahmedadelhosniA
                                ahmedadelhosni
                                Hello @mfalkvidd , I read the topic again but I am a bit confused. Normally we have a sketch on the Arduino board to enable signing for example or implement our desired code. I don't understand how to edit this before compiling ?
                                • mfalkviddM
                                  Sorry @ahmedadelhosni, I haven't tried to compile the Raspberry gateway for signing. @Anticimex will probably chide me for that, and rightly so :)
                                  It should just be a matter of modifying MyConfig.h to enable signing, as per the instructions in http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors but maybe the MySensor files in the Raspberry repo haven't been updated with the signing features.
                                  • AnticimexA
                                    AnticimexA
                                    Anticimex
                                    The signing backends are updated for multi arch support thanks to @tbowmo and his SAMD gateway project, but they still assume Arduino compatible api:s for io, so if the raspberry repo/port provide that, it should work. If not, it should just be a matter of adding support for the raspberry spi:s for setting pin direction and states and (if sw backend is to be used) provide a random number generator. The code is C/C++ and hw independent in other aspects.
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      If anyone would like to add support for rPi to the signing backends, I suggest using a Linux generic approach using sysfs to handle io. Same for rng (using an appropriate device node, rpi has a hw rng that should be used).
                                      If the design is Linux generic and uses proper design to abstract raspberry board specifics, it opens up for reuse by any hw that uses a Linux kernel :)
                                      • haydukeH
                                        haydukeH
                                        hayduke
                                        I've been struggling with this setup for a few weeks now. I've resisted posting to try and figure it out, but I'm not making any progress. When I first setup the rpi with the nrf24 directly connected, everything worked great. I was running a node with temp and motion pretty reliably. I had some difficulty getting the relay node to work, but I got that working eventually as well, but not reliably. While trying to resolve this, I started getting these errors (log from Domoticz):
                                        2016-02-19 10:43:36.007 MySensors: Using serial port: /dev/ttyUSB20
                                        2016-02-19 10:43:36.008 Error: MySensors: Error opening serial port!
                                        2016-02-19 10:43:37.008 MySensors: retrying in 30 seconds...
                                        I see the post above about this being related to using sensors not supported. Since it started with the relay node, I took that out of the setup, but I'm still getting the error.
                                        I've rebuilt the entire rpi, mysensors, and domoticz, but I can't get it to work reliably. If I start the gateway manually via a putty session, it will work for a few minutes, but then it stops and goes back to the command prompt in putty and I can see the log in Domoticz start showing the above errors.
                                        I have setup the gateway to start automatically, but it doesn't seem to restart correctly after a reboot.
                                        I suspect I have a version mismatch in my code somewhere, but I can't seem to find it. My last effort was to remove all code from my computer and start over, ie reinstall Arduino and a fresh download of MySensors code (v1.5).
                                        I've also tried changing the permissions on the tty devices, but that didn't seem to help either.
                                        I was real excited about this project when I first read about it. When I finally got some parts in, I had some quick success that kept me motivated, but my enthusiasm is waning a bit with my total lack of progress on this issue. :(
                                        Thanks in advance for any help.
                                        • mfalkviddM
                                          #64
                                          Which capacitor(s) are you using?
                                          Do you use a power amplified version of the nrf24l01+ or the regular version?
                                          What is the output of /usr/local/sbin/PiGatewaySerial until the gateway stops working?
                                          haydukeH 1 Reply Last reply
