  3. st:fail sometimes and sometimes OK
24 Posts 5 Posters 8.8k Views 2 Watching
  • dakkyD
    dakkyD
    dakky
    did you change the caps? I had massive problem with 4,7nF Caps at my gateway: random fails when transmitting. I now use 100nF and 4,7nF at the gateway and it works like a charm
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
    F 1 Reply Last reply
    • dakkyD dakky
      F
      F
      flopp
      I have not solder them there, will do now.
      I saw some fails again :pensive: after it worked for 10-15 minutes without any fail
      I think you mean uF not nF? Guide says uF.
      • dakkyD
        dakkyD
        dakky
        of course u're right. was a little brainf*ck ;)
        soldering or not does not change anything as long as the parts are fixed.
        • F
          F
          flopp
          I know but I just put the cap pin in a hole of the dupont cable.
          • rvendrameR
            rvendrameR
            rvendrame
            Once I had similar problems, a 4.7nF cap and gw.wait(100) after each transmit did the trick for me... Hope it helps somehow.
            ESP8266 GW + mySensors 2.3.2
            Alexa / Google Home
            F M 2 Replies Last reply
            • rvendrameR rvendrame
              F
              F
              flopp
              @rvendrame
              Where did you put ge.wait, sensor code or gateway code?
              • rvendrameR
                rvendrameR
                rvendrame
                @flopp said:
                @rvendrame
                Sensor. And capacitors on both.
                Alexa / Google Home
                  @flopp said:
                  @rvendrame
                  F
                  F
                  flopp
                  sorry for asking so much :smile:
                  after each gw.send?
                  rvendrameR 1 Reply Last reply
                  • F flopp
                    after each gw.send?
                    rvendrameR
                    rvendrameR
                    rvendrame
                    after each gw.send?
                    Yes
                    Alexa / Google Home
                      after each gw.send?
                      Yes
                      F
                      F
                      flopp
                      @rvendrame said:
                      after each gw.send?
                      Yes
                      • F
                        F
                        flopp
                        It have now been running for 35 minutes without any error, 100uF on both NRF. Delay(100); after each gw.send. Will try later to remove that and see it the problem was the caps.
                        Thanks everyone 👊
                        • F
                          F
                          flopp
                          During I wrote above reply it reported 3 fails!!!
                          I hope that was just a glitch and will let it run without any changes
                          • sundberg84S
                            sundberg84S
                            What do you power the nodes with? Since it seems to work better with caps on, there might be something to your power or wiring you can do to make it better.
                            • sundberg84S sundberg84
                              F
                              F
                              flopp
                              I wrote it in first post, no hard feelings
                              sensor, lipo batt
                              gateway, usb from PC
                              • sundberg84S
                                sundberg84S
                                Sorry m8. My thought was that depending how you run power and ground in your ciriut it can disturb the radio. For example i had a 5v arduino with a 5v relay and if i didn run the ground through the arduino but instead direct to ground the radio got to many spikes and i got really much st:fails.
                                  F
                                  F
                                  flopp
                                  @sundberg84
                                  no worries, I done it my self my times.
                                  Right now I think the problem was a loose cap or bad/small cap. Before I used a 4.7uF, no I have one 100uF on each NRF.
                                  • sundberg84S
                                    sundberg84S
                                    Yea, thats kind of interesting... i have 25+ nodes and everyone except the gateway runs on 4.7 only and it works great... but if that works for you im glad!
                                      Marcell Kovacs
                                      I also got to this solution when experienced the same 'st:fail' issue. The arduino's delay wont help, because it wont receive anything from radio during the delay.
                                      As i got mutch less or no error with ack = false, I thing its linked to receiving some ACK packets. I have no deeper information or debugging possibilities at the moment.
