  3. st:fail sometimes and sometimes OK
24 Posts 5 Posters 8.8k Views 2 Watching
  • sundberg84S sundberg84
    Hi!
    Do you have any caps on the radio(s)?
    F
    F
    flopp
    @sundberg84
    Yes, on both
    • F flopp
      I disconnected Serial gateway from Domoticz and it seems to work anyway, but not receive the data in Domoticz of course
      I aslo added delay(100) after each gw.send
      It seems that Gateway gets the data but not tells the sensor OK
      I also saw that there is an extra -0 at sensor data but not in gateway, BOLD below
      Gateway:
      0;0;3;0;9;read: 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.0
      2;1;1;0;0;21.0
      0;0;3;0;9;read: 2-2-0 s=0,c=1,t=4,pt=7,l=5,sg=0:1006.3
      2;0;1;0;4;1006.3
      2;0;1;0;4;1006.3
      0;0;3;0;9;read: 2-2-0 s=2,c=1,t=38,pt=7,l=5,sg=0:4.037
      2;2;1;0;38;4.037
      Sensor:
      Temperature = 21.00 *C
      Pressure = 1006.31 hPa
      Forecast = unknown
      send: 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:21.0
      send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=ok:1006.3
      403
      send: 2-2-0-0 s=2,c=1,t=38,pt=7,l=5,sg=0,st=fail:4.037
      Pressure = 1006.29 hPa
      Forecast = unknown
      send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=fail:1006.3
      403
      send: 2-2-0-0 s=2,c=1,t=38,pt=7,l=5,sg=0,st=ok:4.037
      F
      F
      flopp
      I saw that I had forgot to put the delay for TEMP, i add it and now it seems to be better
      • F flopp
        Controller:
        Domoticz, version 2.3867
        Sensor:
        Arduino Nano Clone, nRF24L01+(maybe clone) with one sensor BMP180, battery powered by a LiPo 300 mAh directly to Arduino, no step-down- PWR LED removed, regulator for RAW removed
        BMP180 and NRF is connected via a step-down, 3.3 volt
        Battery level right now is 4 volt
        Gateway:
        Arduino Pro Mini Clone, nRF24L01+(maybe clone). Powered by USB
        Serial gateway
        Sensor code, added Battery reading from Arduino VCC, not analog input
         * Version 1.0 - Henrik Ekblad
         * Pressure sensor example using BMP085 module
         * http://www.mysensors.org/build/pressure
        #include <Adafruit_BMP085.h>
        #define BARO_CHILD 0
        #define TEMP_CHILD 1
        #define BATT_CHILD 2
        const float ALTITUDE = 8; // <-- adapt this value to your own location's altitude.
        // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
        const unsigned long SLEEP_TIME = 60000;
        const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
        enum FORECAST
        	STABLE = 0,			// "Stable Weather Pattern"
        	SUNNY = 1,			// "Slowly rising Good Weather", "Clear/Sunny "
        	CLOUDY = 2,			// "Slowly falling L-Pressure ", "Cloudy/Rain "
        	UNSTABLE = 3,		// "Quickly rising H-Press",     "Not Stable"
        	THUNDERSTORM = 4,	// "Quickly falling L-Press",    "Thunderstorm"
        	UNKNOWN = 5			// "Unknown (More Time needed)
        Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
        //int BATTERY_SENSE_PIN = A0;  // select the input pin for the battery sense point
        //int oldBatteryPcnt = 0;
        long result;
        float lastPressure = -1;
        float lastTemp = -1;
        int lastForecast = -1;
        const int LAST_SAMPLES_COUNT = 5;
        float lastPressureSamples[LAST_SAMPLES_COUNT];
        // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
        // get kPa/h be dividing hPa by 10
        #define CONVERSION_FACTOR (1.0/10.0)
        int minuteCount = 0;
        bool firstRound = true;
        // average value is used in forecast algorithm.
        float pressureAvg;
        // average after 2 hours is used as reference value for the next iteration.
        float pressureAvg2;
        float dP_dt;
        boolean metric;
        MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
        MyMessage battMsg(BATT_CHILD, V_VOLTAGE);
           analogReference(INTERNAL1V1);
           analogReference(INTERNAL);
        	gw.begin();
        	gw.sendSketchInfo("Pressure Sensor", "1.1");
        	if (!bmp.begin())
        		Serial.println("Could not find a valid BMP085 sensor, check wiring!");
        		while (1) {}
        	// Register sensors to gw (they will be created as child devices)
        	gw.present(BARO_CHILD, S_BARO);
        	gw.present(TEMP_CHILD, S_TEMP);
          gw.present(BATT_CHILD, S_MULTIMETER);
           // get the battery Voltage
           #ifdef DEBUG
           Serial.println(sensorValue);
           // ((305400+100000)/100000)*1.1 = Vmax = 4.46 Volts
           // 4.46/1023 = Volts per bit = 0.0043591398
           //float batteryV  = sensorValue * 0.004359140;
           float batteryV  = sensorValue * 4.2 / 1023;
           #ifdef DEBUG
           Serial.print(batteryV);
           Serial.println(" V");
           Serial.print(batteryPcnt);
           Serial.println(" %");
        	float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
        	float temperature = bmp.readTemperature();
        	if (!metric)
        		// Convert to fahrenheit
        		temperature = temperature * 9.0 / 5.0 + 32.0;
        	int forecast = sample(pressure);
        	Serial.print("Temperature = ");
        	Serial.print(temperature);
        	Serial.println(metric ? " *C" : " *F");
        	Serial.print("Pressure = ");
        	Serial.print(pressure);
        	Serial.println(" hPa");
        	Serial.print("Forecast = ");
        	if (temperature != lastTemp)
        		gw.send(tempMsg.set(temperature, 1));
        		lastTemp = temperature;
        	if (pressure != lastPressure)
        		gw.send(pressureMsg.set(pressure, 1));
        		lastPressure = pressure;
        	if (forecast != lastForecast)
        		gw.send(forecastMsg.set(weather[forecast]));
        		lastForecast = forecast;
          //if (oldBatteryPcnt != batteryPcnt) {
           // Power up radio after sleep
           //gw.sendBatteryLevel(batteryPcnt);
           readVcc();
           Serial.println(result/10);
           gw.send(battMsg.set(result/1000.000, 3));
        //   oldBatteryPcnt = batteryPcnt;
        	gw.sleep(SLEEP_TIME);
        float getLastPressureSamplesAverage()
        	float lastPressureSamplesAverage = 0;
        	for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
        		lastPressureSamplesAverage += lastPressureSamples[i];
        	lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
        	return lastPressureSamplesAverage;
        // Algorithm found here
        // Pressure in hPa -->  forecast done by calculating kPa/h
        int sample(float pressure)
        	// Calculate the average of the last n minutes.
        	int index = minuteCount % LAST_SAMPLES_COUNT;
        	lastPressureSamples[index] = pressure;
        	minuteCount++;
        	if (minuteCount > 185)
        		minuteCount = 6;
        	if (minuteCount == 5)
        		pressureAvg = getLastPressureSamplesAverage();
        	else if (minuteCount == 35)
        		float lastPressureAvg = getLastPressureSamplesAverage();
        		float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
        			dP_dt = change * 2; // note this is for t = 0.5hour
        			dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
        	else if (minuteCount == 65)
        			dP_dt = change; //note this is for t = 1 hour
        			dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
        	else if (minuteCount == 95)
        			dP_dt = change / 1.5; // note this is for t = 1.5 hour
        			dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
        	else if (minuteCount == 125)
        		pressureAvg2 = lastPressureAvg; // store for later use.
        			dP_dt = change / 2; // note this is for t = 2 hour
        			dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
        	else if (minuteCount == 155)
        			dP_dt = change / 2.5; // note this is for t = 2.5 hour
        			dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
        	else if (minuteCount == 185)
        			dP_dt = change / 3; // note this is for t = 3 hour
        			dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
        		pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
        	int forecast = UNKNOWN;
        		forecast = UNKNOWN;
        	else if (dP_dt < (-0.25))
        		forecast = THUNDERSTORM;
        	else if (dP_dt > 0.25)
        		forecast = UNSTABLE;
        		forecast = CLOUDY;
        		forecast = SUNNY;
        	else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
        		forecast = STABLE;
        		forecast = UNKNOWN;
        	// uncomment when debugging
        	//Serial.print(F("Forecast at minute "));
        	//Serial.print(minuteCount);
        	//Serial.print(F(" dP/dt = "));
        	//Serial.print(dP_dt);
        	//Serial.print(F("kPa/h --> "));
        	return forecast;
        long readVcc() {
          ADCSRA |= _BV(ADSC); // Convert
          result = ADCL;
          result |= ADCH<<8;
          result = 1126400L / result; // Back-calculate AVcc in mV
          return result;
        Sensor output:
        **Temperature = 20.90 C
        Pressure = 1005.88 hPa
        Forecast = stable
        send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=fail:1005.9
        403
        Pressure = 1005.90 hPa
        Forecast = stable
        403
        Pressure = 1005.81 hPa
        Forecast = stable
        send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=fail:1005.8
        403
        find parent
        send: 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
        read: 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
        parent=0, d=1
        Pressure = 1005.92 hPa
        Forecast = stable
        send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=ok:1005.9
        403
        Temperature = 21.20 *C
        Pressure = 1005.95 hPa
        Forecast = stable
        send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=ok:1006.0
        403
        Pressure = 1005.96 hPa
        Forecast = stable
        403
        Pressure = 1005.93 hPa
        Forecast = stable
        403
        Temperature = 21.20 C
        Pressure = 1006.01 hPa
        Forecast = stable
        403
        Pressure = 1005.89 hPa
        Forecast = stable
        403
        Gateway code, without any change from original sketch
         * LEDs (OPTIONAL):
        #define NO_PORTB_PINCHANGES
        #include <MySigningNone.h>
        #include <MyTransportRFM69.h>
        #include <MyTransportNRF24.h>
        #include <MyHwATMega328.h>
        #include <MyParserSerial.h>
        #include <stdarg.h>
        #include <PinChangeInt.h>
        #include "GatewayUtil.h"
        //MyTransportRFM69 transport;
        //MySigningNone signer;
        //MySigningAtsha204 signer;
        // Hardware profile
        MyHwATMega328 hw;
        #ifdef WITH_LEDS_BLINKING
        MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
        char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
        int inputPos = 0;
        boolean commandComplete = false;  // whether the string is complete
        void parseAndSend(char *commandBuffer);
        void output(const char *fmt, ... ) {
           va_list args;
           va_start (args, fmt );
           va_end (args);
           Serial.print(serialBuffer);
          // Add interrupt for inclusion button to pin
          PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
          // Send startup log message on serial
          serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
          checkInclusionFinished();
          if (commandComplete) {
            // A command wass issued from serial interface
            // We will now try to send it to the actuator
            parseAndSend(gw, inputString);
            inputPos = 0;
          SerialEvent occurs whenever a new data comes in the
         hardware serial RX.  This routine is run between each
         time loop() runs, so using delay inside loop can delay
         response.  Multiple bytes of data may be available.
        void serialEvent() {
          while (Serial.available()) {
            // get the new byte:
            char inChar = (char)Serial.read();
            // if the incoming character is a newline, set a flag
            // so the main loop can do something about it:
            if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
              if (inChar == '\n') {
                inputString[inputPos] = 0;
                commandComplete = true;
                // add it to the inputString:
                inputString[inputPos] = inChar;
                inputPos++;
                inputPos = 0;
        Output from Gateway not possible since it is in use by Domoticz. Of course I can disconnect it for test but I don't think Sensor will work correctly without a controller.
        Domoticz log:
        2016-01-05 14:06:15.639 (Test_First) General/Voltage (Voltage_strom)
        2016-01-05 14:08:26.481 (Test_First) General/Voltage (Voltage_strom)
        2016-01-05 14:09:32.184 (Test_First) General/Voltage (Voltage_strom)
        Missing minute 7
        Questions:
        1. Any ideas what this can be or is this normal?
        2. Why do it suddenly says Find parent, is it because it fails for both data that sensor should send? I have seen that if one fails it doesn't say Find parent.
        3. Why does it send Pressure when the code say, IF new is same as last don't send.
        EDIT: added more Sensor output
        EDIT2: distance between sensor and gateway is 1 meter
        EDIT3: add question 3
        EDIT4: Gateway as Pro Mini
        F
        F
        flopp
        wrote on last edited by flopp
        @flopp said:
        Questions:
        3.Why does it send Pressure when the code say, IF new is same as last don't send.
        I read the code again, and I have not change this part of the code
        Pressure is a float so it will get decimals when it reads from BMP.
        This will almost every time send data because there are two decimals which will change.
        I changed it to INT instead of FLOAT and now I get value without decimals and it will not send data every loop, if it not changes of course
        • dakkyD
          dakkyD
          dakky
          did you change the caps? I had massive problem with 4,7nF Caps at my gateway: random fails when transmitting. I now use 100nF and 4,7nF at the gateway and it works like a charm
          Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
          Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
          Software: MySensors 2.0development
          F 1 Reply Last reply
          • dakkyD dakky
            F
            F
            flopp
            I have not solder them there, will do now.
            I saw some fails again :pensive: after it worked for 10-15 minutes without any fail
            I think you mean uF not nF? Guide says uF.
            • dakkyD
              dakkyD
              dakky
              of course u're right. was a little brainf*ck ;)
              soldering or not does not change anything as long as the parts are fixed.
              • F
                F
                flopp
                I know but I just put the cap pin in a hole of the dupont cable.
                • rvendrameR
                  rvendrameR
                  rvendrame
                  Once I had similar problems, a 4.7nF cap and gw.wait(100) after each transmit did the trick for me... Hope it helps somehow.
                  ESP8266 GW + mySensors 2.3.2
                  Alexa / Google Home
                  F M 2 Replies Last reply
                  • rvendrameR rvendrame
                    F
                    F
                    flopp
                    @rvendrame
                    Where did you put ge.wait, sensor code or gateway code?
                    • rvendrameR
                      rvendrameR
                      rvendrame
                      @flopp said:
                      @rvendrame
                      Sensor. And capacitors on both.
                      Alexa / Google Home
                        @flopp said:
                        @rvendrame
                        F
                        F
                        flopp
                        sorry for asking so much :smile:
                        after each gw.send?
                        rvendrameR 1 Reply Last reply
                        • F flopp
                          after each gw.send?
                          rvendrameR
                          rvendrameR
                          rvendrame
                          after each gw.send?
                          Yes
                          Alexa / Google Home
                            after each gw.send?
                            Yes
                            F
                            F
                            flopp
                            @rvendrame said:
                            after each gw.send?
                            Yes
                            • F
                              F
                              flopp
                              It have now been running for 35 minutes without any error, 100uF on both NRF. Delay(100); after each gw.send. Will try later to remove that and see it the problem was the caps.
                              Thanks everyone 👊
                              • F
                                F
                                flopp
                                During I wrote above reply it reported 3 fails!!!
                                I hope that was just a glitch and will let it run without any changes
                                • sundberg84S
                                  sundberg84S
                                  What do you power the nodes with? Since it seems to work better with caps on, there might be something to your power or wiring you can do to make it better.
                                    F
                                    F
                                    flopp
                                    I wrote it in first post, no hard feelings
                                    sensor, lipo batt
                                    gateway, usb from PC
                                    • sundberg84S
                                      sundberg84S
                                      Sorry m8. My thought was that depending how you run power and ground in your ciriut it can disturb the radio. For example i had a 5v arduino with a 5v relay and if i didn run the ground through the arduino but instead direct to ground the radio got to many spikes and i got really much st:fails.
                                        F
                                        F
                                        flopp
                                        @sundberg84
                                        no worries, I done it my self my times.
                                        Right now I think the problem was a loose cap or bad/small cap. Before I used a 4.7uF, no I have one 100uF on each NRF.
                                        • sundberg84S
                                          sundberg84S
                                          Yea, thats kind of interesting... i have 25+ nodes and everyone except the gateway runs on 4.7 only and it works great... but if that works for you im glad!
