  3. st:fail sometimes and sometimes OK
24 Posts 5 Posters 8.8k Views 2 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    @flopp said:
    @rvendrame
    Where did you put ge.wait, sensor code or gateway code?
    Sensor. And capacitors on both.
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    F 1 Reply Last reply
    • rvendrameR rvendrame
      @flopp said:
      @rvendrame
      F
      F
      flopp
      sorry for asking so much :smile:
      after each gw.send?
      rvendrameR 1 Reply Last reply
      • F flopp
        after each gw.send?
        rvendrameR
        rvendrameR
        rvendrame
        after each gw.send?
        Yes
        Alexa / Google Home
          after each gw.send?
          Yes
          F
          F
          flopp
          @rvendrame said:
          after each gw.send?
          Yes
          • F
            F
            flopp
            It have now been running for 35 minutes without any error, 100uF on both NRF. Delay(100); after each gw.send. Will try later to remove that and see it the problem was the caps.
            Thanks everyone 👊
            • F
              F
              flopp
              During I wrote above reply it reported 3 fails!!!
              I hope that was just a glitch and will let it run without any changes
              • sundberg84S
                sundberg84S
                What do you power the nodes with? Since it seems to work better with caps on, there might be something to your power or wiring you can do to make it better.
                • sundberg84S sundberg84
                  F
                  F
                  flopp
                  I wrote it in first post, no hard feelings
                  sensor, lipo batt
                  gateway, usb from PC
                  • sundberg84S
                    sundberg84S
                    Sorry m8. My thought was that depending how you run power and ground in your ciriut it can disturb the radio. For example i had a 5v arduino with a 5v relay and if i didn run the ground through the arduino but instead direct to ground the radio got to many spikes and i got really much st:fails.
                      F
                      F
                      flopp
                      @sundberg84
                      no worries, I done it my self my times.
                      Right now I think the problem was a loose cap or bad/small cap. Before I used a 4.7uF, no I have one 100uF on each NRF.
                      • sundberg84S
                        sundberg84S
                        Yea, thats kind of interesting... i have 25+ nodes and everyone except the gateway runs on 4.7 only and it works great... but if that works for you im glad!
                          Once I had similar problems, a 4.7nF cap and gw.wait(100) after each transmit did the trick for me... Hope it helps somehow.
                          Marcell Kovacs
                          I also got to this solution when experienced the same 'st:fail' issue. The arduino's delay wont help, because it wont receive anything from radio during the delay.
                          As i got mutch less or no error with ack = false, I thing its linked to receiving some ACK packets. I have no deeper information or debugging possibilities at the moment.
