  3. st:fail sometimes and sometimes OK
24 Posts 5 Posters 8.6k Views 2 Watching
  • F Offline
    F Offline
    flopp
    wrote on last edited by flopp
    Controller:
    Domoticz, version 2.3867
    Sensor:
    Arduino Nano Clone, nRF24L01+(maybe clone) with one sensor BMP180, battery powered by a LiPo 300 mAh directly to Arduino, no step-down- PWR LED removed, regulator for RAW removed
    BMP180 and NRF is connected via a step-down, 3.3 volt
    Battery level right now is 4 volt
    Gateway:
    Arduino Pro Mini Clone, nRF24L01+(maybe clone). Powered by USB
    Serial gateway
    Sensor code, added Battery reading from Arduino VCC, not analog input
     * Version 1.0 - Henrik Ekblad
     * Pressure sensor example using BMP085 module
     * http://www.mysensors.org/build/pressure
    #include <Adafruit_BMP085.h>
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    #define BATT_CHILD 2
    const float ALTITUDE = 8; // <-- adapt this value to your own location's altitude.
    // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
    const unsigned long SLEEP_TIME = 60000;
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
    	STABLE = 0,			// "Stable Weather Pattern"
    	SUNNY = 1,			// "Slowly rising Good Weather", "Clear/Sunny "
    	CLOUDY = 2,			// "Slowly falling L-Pressure ", "Cloudy/Rain "
    	UNSTABLE = 3,		// "Quickly rising H-Press",     "Not Stable"
    	THUNDERSTORM = 4,	// "Quickly falling L-Press",    "Thunderstorm"
    	UNKNOWN = 5			// "Unknown (More Time needed)
    Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
    //int BATTERY_SENSE_PIN = A0;  // select the input pin for the battery sense point
    //int oldBatteryPcnt = 0;
    long result;
    float lastPressure = -1;
    float lastTemp = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
    // get kPa/h be dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    boolean metric;
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    MyMessage battMsg(BATT_CHILD, V_VOLTAGE);
       analogReference(INTERNAL1V1);
       analogReference(INTERNAL);
    	gw.begin();
    	gw.sendSketchInfo("Pressure Sensor", "1.1");
    	if (!bmp.begin())
    		Serial.println("Could not find a valid BMP085 sensor, check wiring!");
    		while (1) {}
    	// Register sensors to gw (they will be created as child devices)
    	gw.present(BARO_CHILD, S_BARO);
    	gw.present(TEMP_CHILD, S_TEMP);
      gw.present(BATT_CHILD, S_MULTIMETER);
       // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       // ((305400+100000)/100000)*1.1 = Vmax = 4.46 Volts
       // 4.46/1023 = Volts per bit = 0.0043591398
       //float batteryV  = sensorValue * 0.004359140;
       float batteryV  = sensorValue * 4.2 / 1023;
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
    	float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
    	float temperature = bmp.readTemperature();
    	if (!metric)
    		// Convert to fahrenheit
    		temperature = temperature * 9.0 / 5.0 + 32.0;
    	int forecast = sample(pressure);
    	Serial.print("Temperature = ");
    	Serial.print(temperature);
    	Serial.println(metric ? " *C" : " *F");
    	Serial.print("Pressure = ");
    	Serial.print(pressure);
    	Serial.println(" hPa");
    	Serial.print("Forecast = ");
    	if (temperature != lastTemp)
    		gw.send(tempMsg.set(temperature, 1));
    		lastTemp = temperature;
    	if (pressure != lastPressure)
    		gw.send(pressureMsg.set(pressure, 1));
    		lastPressure = pressure;
    	if (forecast != lastForecast)
    		gw.send(forecastMsg.set(weather[forecast]));
    		lastForecast = forecast;
      //if (oldBatteryPcnt != batteryPcnt) {
       // Power up radio after sleep
       //gw.sendBatteryLevel(batteryPcnt);
       readVcc();
       Serial.println(result/10);
       gw.send(battMsg.set(result/1000.000, 3));
    //   oldBatteryPcnt = batteryPcnt;
    	gw.sleep(SLEEP_TIME);
    float getLastPressureSamplesAverage()
    	float lastPressureSamplesAverage = 0;
    	for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
    		lastPressureSamplesAverage += lastPressureSamples[i];
    	lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
    	return lastPressureSamplesAverage;
    // Algorithm found here
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
    	// Calculate the average of the last n minutes.
    	int index = minuteCount % LAST_SAMPLES_COUNT;
    	lastPressureSamples[index] = pressure;
    	minuteCount++;
    	if (minuteCount > 185)
    		minuteCount = 6;
    	if (minuteCount == 5)
    		pressureAvg = getLastPressureSamplesAverage();
    	else if (minuteCount == 35)
    		float lastPressureAvg = getLastPressureSamplesAverage();
    		float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
    			dP_dt = change * 2; // note this is for t = 0.5hour
    			dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
    	else if (minuteCount == 65)
    			dP_dt = change; //note this is for t = 1 hour
    			dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
    	else if (minuteCount == 95)
    			dP_dt = change / 1.5; // note this is for t = 1.5 hour
    			dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
    	else if (minuteCount == 125)
    		pressureAvg2 = lastPressureAvg; // store for later use.
    			dP_dt = change / 2; // note this is for t = 2 hour
    			dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
    	else if (minuteCount == 155)
    			dP_dt = change / 2.5; // note this is for t = 2.5 hour
    			dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
    	else if (minuteCount == 185)
    			dP_dt = change / 3; // note this is for t = 3 hour
    			dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
    		pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
    	int forecast = UNKNOWN;
    		forecast = UNKNOWN;
    	else if (dP_dt < (-0.25))
    		forecast = THUNDERSTORM;
    	else if (dP_dt > 0.25)
    		forecast = UNSTABLE;
    		forecast = CLOUDY;
    		forecast = SUNNY;
    	else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
    		forecast = STABLE;
    		forecast = UNKNOWN;
    	// uncomment when debugging
    	//Serial.print(F("Forecast at minute "));
    	//Serial.print(minuteCount);
    	//Serial.print(F(" dP/dt = "));
    	//Serial.print(dP_dt);
    	//Serial.print(F("kPa/h --> "));
    	return forecast;
    long readVcc() {
      ADCSRA |= _BV(ADSC); // Convert
      result = ADCL;
      result |= ADCH<<8;
      result = 1126400L / result; // Back-calculate AVcc in mV
      return result;
    Sensor output:
    **Temperature = 20.90 C
    Pressure = 1005.88 hPa
    Forecast = stable
    send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=fail:1005.9
    403
    send: 2-2-0-0 s=2,c=1,t=38,pt=7,l=5,sg=0,st=fail:4.037
    Pressure = 1005.90 hPa
    Forecast = stable
    403
    Pressure = 1005.81 hPa
    Forecast = stable
    send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=fail:1005.8
    403
    find parent
    send: 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    read: 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    parent=0, d=1
    Pressure = 1005.92 hPa
    Forecast = stable
    send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=ok:1005.9
    403
    send: 2-2-0-0 s=2,c=1,t=38,pt=7,l=5,sg=0,st=ok:4.037
    Temperature = 21.20 *C
    Pressure = 1005.95 hPa
    Forecast = stable
    send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=ok:1006.0
    403
    Pressure = 1005.96 hPa
    Forecast = stable
    403
    Pressure = 1005.93 hPa
    Forecast = stable
    403
    Temperature = 21.20 C
    Pressure = 1006.01 hPa
    Forecast = stable
    403
    Pressure = 1005.89 hPa
    Forecast = stable
    403
    Gateway code, without any change from original sketch
     * LEDs (OPTIONAL):
    #define NO_PORTB_PINCHANGES
    #include <MySigningNone.h>
    #include <MyTransportRFM69.h>
    #include <MyTransportNRF24.h>
    #include <MyHwATMega328.h>
    #include <MyParserSerial.h>
    #include <stdarg.h>
    #include <PinChangeInt.h>
    #include "GatewayUtil.h"
    //MyTransportRFM69 transport;
    //MySigningNone signer;
    //MySigningAtsha204 signer;
    // Hardware profile
    MyHwATMega328 hw;
    #ifdef WITH_LEDS_BLINKING
    MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
    char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
    int inputPos = 0;
    boolean commandComplete = false;  // whether the string is complete
    void parseAndSend(char *commandBuffer);
    void output(const char *fmt, ... ) {
       va_list args;
       va_start (args, fmt );
       va_end (args);
       Serial.print(serialBuffer);
      // Add interrupt for inclusion button to pin
      PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
      // Send startup log message on serial
      serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
      checkInclusionFinished();
      if (commandComplete) {
        // A command wass issued from serial interface
        // We will now try to send it to the actuator
        parseAndSend(gw, inputString);
        inputPos = 0;
      SerialEvent occurs whenever a new data comes in the
     hardware serial RX.  This routine is run between each
     time loop() runs, so using delay inside loop can delay
     response.  Multiple bytes of data may be available.
    void serialEvent() {
      while (Serial.available()) {
        // get the new byte:
        char inChar = (char)Serial.read();
        // if the incoming character is a newline, set a flag
        // so the main loop can do something about it:
        if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
          if (inChar == '\n') {
            inputString[inputPos] = 0;
            commandComplete = true;
            // add it to the inputString:
            inputString[inputPos] = inChar;
            inputPos++;
            inputPos = 0;
    Output from Gateway not possible since it is in use by Domoticz. Of course I can disconnect it for test but I don't think Sensor will work correctly without a controller.
    Domoticz log:
    2016-01-05 14:06:15.639 (Test_First) General/Voltage (Voltage_strom)
    2016-01-05 14:08:26.481 (Test_First) General/Voltage (Voltage_strom)
    2016-01-05 14:09:32.184 (Test_First) General/Voltage (Voltage_strom)
    Missing minute 7
    Questions:
    1. Any ideas what this can be or is this normal?
    2. Why do it suddenly says Find parent, is it because it fails for both data that sensor should send? I have seen that if one fails it doesn't say Find parent.
    3. Why does it send Pressure when the code say, IF new is same as last don't send.
    EDIT: added more Sensor output
    EDIT2: distance between sensor and gateway is 1 meter
    EDIT3: add question 3
    EDIT4: Gateway as Pro Mini
    F 1 Reply Last reply
    • F Offline
      F Offline
      flopp
      I disconnected Serial gateway from Domoticz and it seems to work anyway, but not receive the data in Domoticz of course
      I aslo added delay(100) after each gw.send
      It seems that Gateway gets the data but not tells the sensor OK
      I also saw that there is an extra -0 at sensor data but not in gateway, BOLD below
      Gateway:
      0;0;3;0;9;read: 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.0
      2;1;1;0;0;21.0
      0;0;3;0;9;read: 2-2-0 s=0,c=1,t=4,pt=7,l=5,sg=0:1006.3
      2;0;1;0;4;1006.3
      2;0;1;0;4;1006.3
      0;0;3;0;9;read: 2-2-0 s=2,c=1,t=38,pt=7,l=5,sg=0:4.037
      2;2;1;0;38;4.037
      Sensor:
      Temperature = 21.00 *C
      Pressure = 1006.31 hPa
      Forecast = unknown
      send: 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:21.0
      send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=ok:1006.3
      403
      Pressure = 1006.29 hPa
      Forecast = unknown
      send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=fail:1006.3
      403
      • S Offline
        Hi!
        Do you have any caps on the radio(s)?
        • S sundberg84
          Hi!
          F Offline
          F Offline
          flopp
          @sundberg84
          Yes, on both
          • F flopp
            Gateway:
            2;1;1;0;0;21.0
            2;0;1;0;4;1006.3
            2;0;1;0;4;1006.3
            2;2;1;0;38;4.037
            Sensor:
            Forecast = unknown
            403
            Forecast = unknown
            403
            F Offline
            F Offline
            flopp
            I saw that I had forgot to put the delay for TEMP, i add it and now it seems to be better
            • F flopp
              Controller:
              Sensor:
              Gateway:
              Serial gateway
              enum FORECAST
              long result;
              float pressureAvg;
              float pressureAvg2;
              float dP_dt;
              boolean metric;
              	gw.begin();
              	if (!bmp.begin())
              		while (1) {}
                 #ifdef DEBUG
                 #ifdef DEBUG
              	if (!metric)
                 readVcc();
              	minuteCount++;
              		minuteCount = 6;
              		forecast = UNKNOWN;
              		forecast = CLOUDY;
              		forecast = SUNNY;
              		forecast = STABLE;
              		forecast = UNKNOWN;
              	return forecast;
              long readVcc() {
                result = ADCL;
                result |= ADCH<<8;
                return result;
              Sensor output:
              Forecast = stable
              403
              Forecast = stable
              403
              Forecast = stable
              403
              find parent
              parent=0, d=1
              Forecast = stable
              403
              Forecast = stable
              403
              Forecast = stable
              403
              Forecast = stable
              403
              Forecast = stable
              403
              Forecast = stable
              403
               * LEDs (OPTIONAL):
              #include <stdarg.h>
              // Hardware profile
              MyHwATMega328 hw;
              int inputPos = 0;
                 va_list args;
                 va_end (args);
                  inputPos = 0;
                      inputPos++;
                      inputPos = 0;
              Domoticz log:
              Missing minute 7
              Questions:
              F Offline
              F Offline
              flopp
              @flopp said:
              Questions:
              3.Why does it send Pressure when the code say, IF new is same as last don't send.
              I read the code again, and I have not change this part of the code
              Pressure is a float so it will get decimals when it reads from BMP.
              This will almost every time send data because there are two decimals which will change.
              I changed it to INT instead of FLOAT and now I get value without decimals and it will not send data every loop, if it not changes of course
              • dakkyD Offline
                dakkyD Offline
                dakky
                did you change the caps? I had massive problem with 4,7nF Caps at my gateway: random fails when transmitting. I now use 100nF and 4,7nF at the gateway and it works like a charm
                Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
                Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
                Software: MySensors 2.0development
                • dakkyD dakky
                  F Offline
                  F Offline
                  flopp
                  I have not solder them there, will do now.
                  I saw some fails again :pensive: after it worked for 10-15 minutes without any fail
                  I think you mean uF not nF? Guide says uF.
                  • dakkyD Offline
                    dakkyD Offline
                    dakky
                    of course u're right. was a little brainf*ck ;)
                    soldering or not does not change anything as long as the parts are fixed.
                    • F Offline
                      F Offline
                      flopp
                      I know but I just put the cap pin in a hole of the dupont cable.
                      • R Offline
                        R Offline
                        rvendrame
                        Once I had similar problems, a 4.7nF cap and gw.wait(100) after each transmit did the trick for me... Hope it helps somehow.
                        ESP8266 GW + mySensors 2.3.2
                        Alexa / Google Home
                        F M 2 Replies Last reply
                        • R rvendrame
                          F Offline
                          F Offline
                          flopp
                          @rvendrame
                          Where did you put ge.wait, sensor code or gateway code?
                          • R Offline
                            R Offline
                            rvendrame
                            @flopp said:
                            @rvendrame
                            Sensor. And capacitors on both.
                            Alexa / Google Home
                            • R rvendrame
                              @flopp said:
                              @rvendrame
                              F Offline
                              F Offline
                              flopp
                              sorry for asking so much :smile:
                              after each gw.send?
                              R 1 Reply Last reply
                              • F flopp
                                after each gw.send?
                                R Offline
                                R Offline
                                rvendrame
                                after each gw.send?
                                Yes
                                Alexa / Google Home
                                • R rvendrame
                                  after each gw.send?
                                  Yes
                                  F Offline
                                  F Offline
                                  flopp
                                  @rvendrame said:
                                  after each gw.send?
                                  Yes
                                  • F Offline
                                    F Offline
                                    flopp
                                    It have now been running for 35 minutes without any error, 100uF on both NRF. Delay(100); after each gw.send. Will try later to remove that and see it the problem was the caps.
                                    Thanks everyone 👊
                                    • F Offline
                                      F Offline
                                      flopp
                                      During I wrote above reply it reported 3 fails!!!
                                      I hope that was just a glitch and will let it run without any changes
                                      • S Offline
                                        What do you power the nodes with? Since it seems to work better with caps on, there might be something to your power or wiring you can do to make it better.
                                        • S sundberg84
                                          F Offline
                                          F Offline
                                          flopp
                                          I wrote it in first post, no hard feelings
                                          sensor, lipo batt
                                          gateway, usb from PC
