  3. ๐Ÿ’ฌ My Slim 2AA Battery Node
arduinomysensorslow powerbatteryenclosurenrf24l01
27 Posts 17 Posters 13.1k Views 14 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/10/My-Slim-2AA-Battery-Node
    • CosmocatC
      CosmocatC
      Cosmocat
      Iยดve read about your battery node with great interest. Nice work! Do your nodes keep their meshing capability after you put them in sleep mode?
      • mfalkviddM
        If you mean a repeater node (https://www.mysensors.org/download/sensor_api_15#create-repeating-nodes ) the answer is no. The radio is shut off during sleep so it can not receive. For a repeater node you need a permanent power supply.
        • CosmocatC
          CosmocatC
          Cosmocat
          Thats what I suspected. Thanks for quick response.
          • carlekiC
            carlekiC
            carleki
            Hello :)
            In the BOM file there is C5 capacitor, but I can't figure out where it does stand on the board. Can you help please ?
            CosmocatC m26872M 2 Replies Last reply
            • carlekiC carleki
              Hello :)
              CosmocatC
              CosmocatC
              Cosmocat
              @carmelo42 Hi, I have not (yet) built a "Slim 2AA battery node" so I'm afraid I'm not the right guy to ask. Good luck though.
              • carlekiC carleki
                Hello :)
                m26872M
                m26872M
                m26872
                • carlekiC
                  carlekiC
                  carleki
                  wrote on last edited by carleki
                  thanks @m26872 :)
                  I have ordered smd capacitors for c5 ... but I think it will be good :)
                  Can you explain the role of the C5 cap ? I know that C4 is for decoupling for the radio, but C1, C2, C3 and C4 : I don't know !
                  Another little question :)
                  with my brand new atmega328p, I have burned the bootloader with an arduino uno with the "ArduinoISP" in it.
                  After that, I have sent the sketch with another arduino (with it's own atmega removed) and my brand new atmega like that :
                  https://www.arduino.cc/en/uploads/Tutorial/ArduinoUSBSerialSimple.png
                  Is it possible to put the sketch in the atmega directly on the slim2aabatterynode board ? With an FTDI serial device ?
                  m26872M 1 Reply Last reply
                  • loiphinL
                    loiphinL
                    loiphin
                    Keep in mind that if you are trying to use a DHT11 or DHT22 attached to the Slim 2AA, it only seems to work with 8 or 16MHz.. I couldn't get it to work with the ATmega328 running at 1MHz! It works fine with 8MHz internal oscillator :)
                    • carlekiC carleki
                      thanks @m26872 :)
                      m26872M
                      m26872M
                      m26872
                      @carmelo42 Sorry for a late reply. In short C2 is to reset the avr, C1 and C3 are to decouple the avr. And C4,C5 for the radio as you say. The caps are there as a recommendation, precaution, stability, etc, and all of them are not always necessary when it's supplied by battery.
                      And yes, the idea of the FTDI-6-pin-header and bootloader is to provide ability to load sketches the normal Auduino way with FTDI and Arduino IDE.
                      • JonnyDev13J
                        JonnyDev13J
                        JonnyDev13
                        • miljumeM
                          miljumeM
                          miljume
                          Hello, I have built a number of these sensor nodes and really like the generic design!
                          However I have run into trouble when trying to build a power meter with a photo sensor.
                          I am using the code from MySensors but also tried other sources but my problem is that the digital pin i am using (D3) dont drop enough for the sensor to treat it as digital 0 as it stays at 2.3 V with a 2 AA battery power attached
                          When trying the pulse sensor with external power it works perfect so it seems like D3 is floating which also is confirmed when I measure on D3 without the sensor attached. (approx 2.7V)
                          I have used this row in my sketch pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                          Any clues what I can try?
                          • miljumeM miljume
                            sundberg84S
                            sundberg84S
                            @miljume said in ๐Ÿ’ฌ My Slim 2AA Battery Node:
                            INPUT_PULLUP
                            What kind of sensor do you use? Some sensors have an analog and digital output. The Digital should return either 0V or VCC while the analog returns all analog values between 0V and VCC.
                            You could try an external pulldown resistor of 10k to ground if you think the pin is floating.
                            Another approach is to elaborate with a photoresistor only and to get a clean 0/1 use an transistor. If the voltage drops to low though for the pin to get a clear 1 (2.4v on 3.3v atmega) you might need a DC/DC step up booster.
                            miljumeM 1 Reply Last reply
                            • sundberg84S sundberg84
                              INPUT_PULLUP
                              miljumeM
                              miljumeM
                              miljume
                              @sundberg84 Thank you for your feedback! I used the design found here so the sensor is OK. I had also tried to use a pulldown resistor but it showed that I had used too low value. When I use 10k as you suggested it worked like a charm, thank you! What I dont understand is why I should need the pulldown resistor in the first place? Shouldn't it be possible to solve that in the software?
                              • miljumeM miljume
                                sundberg84S
                                sundberg84S
                                @miljume - I dont think you can solve a floating pin in the software. Im not that experienced with internal pullups either so someone else have to answer that. Good you have it working though!
                                • KoreshK
                                  KoreshK
                                  Koresh
                                  Internal pull-up resistors have 20-50k resistance. It may be not enough.
                                  • B
                                    B
                                    buxtronix
                                    For those looking to 3d print a case for this, if you cant find the right sized ducting, I designed one thats unobtrusive:
                                    https://www.thingiverse.com/thing:2418194
                                    • Aki1988A
                                      Aki1988A
                                      Aki1988
                                      wrote on last edited by Aki1988
                                      Hello, i made a few. is someone interested in these nodes in Germany? We switched to an other Home Automation (wife: you can't build something DIY in our house that is so important than a light switch ...) system and so those nodes were never used. All nodes come untested and most of them unflashed. It would be a shame if they would just lay around here. Shipping is on you, the nodes and other s no longer needed (mysensors) stuff is free. Nodes are in Germany, and i will send them via DHL. if you are interested write me a mail to aki1988 (at) me (dot) com - first come first serve.
                                      Edit: gone
                                      • J
                                        J
                                        Johove
                                        wrote on last edited by Johove
                                        I built a couple of these nodes last year, I used 8 MHz internal, fuses off, and a DTH22.
                                        This a node on a dometizc network, it measures temperatur and internal voltage every 6 minutes, then it deep sleep.
                                        I can confirm that these nodes last more that a year on 2 aa batteries.
                                        • G
                                          G
                                          GHoggan
                                          Hello, I placed an order through the openhardware.io website with Itead last night.
                                          They came back this morning with a ticket saying :
                                          Your gerber file: 571bf156249971713bb044ea.zip (Normalized Name:A100151928AN_A2AGLF002A.zip) in the order #100151928 is rejected.
                                          The reason is:
                                          The Gerber file doesn't have outline layer , please add it and re-upload the new file , thank you.
                                          Can you please assist as I don't really want to cancel my order.
                                          Thanks in advance
                                          Glenn
                                          With your input, this post could be even better ๐Ÿ’—
