  3. Uploading SerialGateway WARNING
18 Posts 2 Posters 5.7k Views
  • W
    W
    Wijbe.Fryslan
    Hello, I'm trying to make a new SerialGateway, from scratch and the same on this webside. So far so good... But I think he's not working... (In Domoticz I see no versionnumber nor a sensor.)
    So I started checking the hardware, that's (lets hope) ok.
    Next step is checking the software, installing the newest version of ArduinoIDE (on Windows) and the latest release of MySensors, so far so good.
    When I try to check the SerialGateway-sketch there's the next warning:
    WARNING: Category '' in library UIPEthernet is not valid. setting to 'Uncategorized'
    Can I Upload the sketch?
    • sundberg84S
      sundberg84S
      Hi! Welcome!
      Here is a great tutorial from MySensors how to install the Arduino IDE and MySensors liberary! Start there and work your way forward. Maybe your library didnt install correctly?
      http://www.mysensors.org/about/arduino#installing-the-development-environment-on-your-computer
      • W
        W
        Wijbe.Fryslan
        @sunberg84 Thanks for your advice. All those steps already done some time ago...
        Think this is not a relevant answer by my question. ;)
        • sundberg84S
          sundberg84S
          Hi, then i missunderstood you.
          Have you tried to upload the sketch?
          • W
            W
            Wijbe.Fryslan
            Yep, with the same warning and zero results in Domoticz.
            • sundberg84S
              sundberg84S
              No "Upload finish" and nothing on the serial log - then the answer is: No you cant and I would think if you go back to my first post that your library didnt install correctly.
              • W
                W
                Wijbe.Fryslan
                Again, installing AerduinoIDE, then de latest realese of MySensors: same problem...
                • sundberg84S
                  sundberg84S
                  Sorry to hear - but the Warning really sounds like the Library UIPEthernet is something wrong with. Did you have this library before or installed on another directiory as well? It has not been updated for a year in MySensors Masterbranch.
                  When you open your arduino IDE do you see all the MySensors examples there (In example -> MySensors)? The your lib is installed.
                  W 2 Replies Last reply
                  • W
                    W
                    Wijbe.Fryslan
                    So mabey the download from MySensors isn't ok (UIPEthernet is a part of that).
                    Again downloaded and added but the same warning.
                    • sundberg84S
                      sundberg84S
                      @hek Has there been any change in 1.5 download lately? I cant remeber any other users having this problem.
                      • W
                        W
                        Wijbe.Fryslan
                        Now installing ArduinoIDE 1.6.5 (aug '15) and MySensors 1.5 (jan '15) there's no warning...
                        W 1 Reply Last reply
                        • W Wijbe.Fryslan
                          W
                          W
                          Wijbe.Fryslan
                          @Wijbe.Fryslan LOL, jan '15 has to be jan '15 (older version deleted...)
                          • sundberg84S
                            sundberg84S
                            Nice to hear @Wijbe-Fryslan! :)
                            • W
                              W
                              Wijbe.Fryslan
                              You think this is THE solution????
                              • sundberg84S
                                sundberg84S
                                Dont know, as long as it works for you...
                                • sundberg84S sundberg84
                                  W
                                  W
                                  Wijbe.Fryslan
                                  @sundberg84 The sketch UIPEthernet becomes to al my downloads from MySensors.
                                    W
                                    W
                                    Wijbe.Fryslan
                                    @sundberg84 said:
                                    ... When you open your arduino IDE do you see all the MySensors examples there (In example -> MySensors)? The your lib is installed....
                                    I think so. How manny are there, so I can check. ;)
                                    • W
                                      W
                                      Wijbe.Fryslan
                                      Playing with my Arduino IDE and mysensors download on my computer with Windows 7, I can make the following conclusion:
                                      Arduino-1.6.5-r2-windows works fine;
                                      Arduino-1.6.7-windows gives described UIPEthernet warning.
