  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.1k Views 73 Watching
  • P
    P
    p0lar
    Thanks. Ill check that when I get back into town end of this week.
      stebra
      Hi @tekka,
      tried now some evenings to change node-id / clear the eeprom. No luck. FW update works always. After reading the bootloader code I expected myscontroller to send a invalid fwrequestresponse packet with special crc for the bootloader commands. Never showed up in the log.
      Myscontroller .282 on Win xp and msbootloader 1.1 on nano. 47uF on nrf. No transmission errors.
      Any ideas where to look next ? Maybe .278 will do the trick ?
      Thanks for your efforts ,
      stebra
      tekkaT 1 Reply Last reply
      • S stebra
        Hi @tekka,
        stebra
        tekkaT
        tekkaT
        tekka
        @stebra please post the myscontroller log with gw DEBUG enabled that shows OTA update and ID reassign request.
          stebra
          MySensors_20160110-115615_stebra.log
          hi tekka,
          here is the log. Contains:
          [2016-01-10 12:02:26.390 Info] INFO *** Logging START *** // stebra : succesful reboot of node 6 via myscontroller
          [2016-01-10 12:02:59.000 Info] INFO *** Logging START *** // stebra : succesful FW update of node 6 via myscontroller
          [2016-01-10 12:05:35.109 Info] INFO *** Logging START *** // stebra : ID reassign attempt of node 6 to node 12 via myscontroller
          [2016-01-10 12:05:48.328 Info] INFO Send FW info to node 6: type=1E, version=1, blocks=0x0448, CRC=0xA87A // here the behaviour is unexpected for me
          [2016-01-10 12:06:37.437 Info] INFO *** Logging START *** // stebra: Clear eeprom attempt on node 6
          [2016-01-10 12:06:44.812 Info] INFO Send FW info to node 6: type=1E, version=1, blocks=0x0448, CRC=0xA87A // here the behaviour is unexpected for me
          thank you for having a look..
            stebra
            and also a ss for another reassign attempt node 6--> 12.
            FIRMWARE_CONFIG_REQUEST is not answered from myscontroller. therefore no reassign of node id.
            • D
              dakipro
              wrote on last edited by dakipro
              #338
              Maybe I should open a new topic for this, but I cannot flash bootloader, I always get
              Arduino: 1.6.7 (Windows 10), Board: "ATmega328 internal 8Mhz with MYSBootloader"
              ***failed;
              avrdude: verification error, first mismatch at byte 0x0000
              0x3f != 0xff
              Here is the verbose message
              C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM4 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:i -Ulock:w:0xFF:m
              avrdude: verifying ...
              avrdude done.  Thank you.
                       Programmer Type : STK500
                       Hardware Version: 2
                       Firmware Version: 1.18
                       Topcard         : Unknown
                       Vtarget         : 0.0 V
                       Varef           : 0.0 V
                       Oscillator      : Off
                       SCK period      : 0.1 us
              avrdude: erasing chip
              avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex"
              avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
              avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
              avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex contains 32722 bytes
              Writing |  ***failed;
              avrdude: verifying lock memory against 0xFF:
              avrdude: load data lock data from input file 0xFF:
                       0x3f != 0xff
              I get same message with both 3.3v and 5v pro mini that is linked in the store.
              I am using Funduino uno as a ips, and I can flash blink f.eks. using uno as isp, but I cannot flash bootloader. This is the step 6 from the instructions that is failing. Any ideas how to fix this? I would really like OTA as my network is slowly growing.
              Thanks for any tips!
              • D
                dakipro
                I think I have flashed MYSBootloader finaly, after ~6hours of trying and reading (persistent guy :) )
                The instructions are for the older version I guess, right board should be copied from MYSController/bootloader/boards.txt, not from this topic post#75. Now I am trying to figure how to flash the sketch, but I guess that is explained somewhere on the topic
                • D
                  dakipro
                  Just one more question, I didn't find it answered on the topic (maybe too tired), but:
                  I have existing network with ethernet gateway and some nodes, and all is working fine. To make it OTA update-able, I need to
                  1. i upload ethernet gateway to the Arduino Nano, then flash MYSBootloader on it,
                  2. upload some sketch (which?) on Arduino Mini nodes, and then flash MYSBootloader on it, and then I can program it OTA?
                  3. Or something else?
                  Or did I miss the point completely? :(
                  • P
                    P
                    p0lar
                    wrote on last edited by p0lar
                    #341
                    so from what I know.
                    you DONT need the MYSBootloader on the gateway. just normal arduino bootloader. you DO need the MYSBootloader on ALL the sensors you with to connect to your gateway.
                    Do the MYSBootloader first then use this tool to upload the firmware to your sensors OTA
                    • D dakipro
                      tekkaT
                      tekkaT
                      tekka
                      @dakipro I use the settings mentioned in #75 in Atmel studio, however, AVRDUDE does not support the upper two bits of the lock fuse (therefore the error message 0xFF!=0x3F). Changing the lock bits to 0x3F should do the job.
                      And yes, as @p0lar pointed out, only the nodes and not the gateway should have MYSBootloader.
                      • P
                        P
                        p0lar
                        HMM i cant build a DEBUG version of the ethernet gateway... even when I try to define it and print hello world it wont... weird.. any ideas?
                        • D
                          dakipro
                          Aha, I get it now. Then I just flash MYSBootloader on the sensor, and attach the radio and it will automatically connect to the gateway (it has some sort of sketch/communication with MySensors built in)? And then I use the MYSController to upload my sketch as described?
                          Or how do I upload a initial sketch if I cannot use arduino anymore?
                          Btw, I love MYSController, i use it all the time in development as it shows all that is going on with the sensors, thank you very much for developing it!
                          • P
                            P
                            p0lar
                            #345
                            correct. you build the .hex file in arduino studio or whatever and copy it to the MY gui firmware folder and edit the csv file and then reload.
                            http://forum.mysensors.org/topic/1066/bootloader/8
                            This should help
                            • P
                              P
                              p0lar
                              #346
                              • P
                                P
                                p0lar
                                I thinking I am build a DEBUG version of the GW code. but I dont think the logging is working in the app with my eth GW. am I mising something?
                                So. when I build a DEBUG version of the GW code I get this in the serial console hex size=29k so its bigger.
                                0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:71.6
                                1;1;1;0;0;71.6
                                0;0;3;0;9;read: 2-2-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                2;1;1;0;16;0
                                the NON DEBUG I get this. hex size = 26k
                                1;1;1;0;0;69.8
                                1;0;1;0;1;35.0
                                1;1;1;0;0;71.6
                                1;0;1;0;1;36.0
                                1;1;1;0;0;73.4
                                1;0;1;0;1;37.0
                                2;1;1;0;16;0
                                • P p0lar
                                  1;1;1;0;0;71.6
                                  2;1;1;0;16;0
                                  1;1;1;0;0;69.8
                                  1;0;1;0;1;35.0
                                  1;1;1;0;0;71.6
                                  1;0;1;0;1;36.0
                                  1;1;1;0;0;73.4
                                  1;0;1;0;1;37.0
                                  2;1;1;0;16;0
                                  tekkaT
                                  tekkaT
                                  tekka
                                  1;1;1;0;0;71.6
                                  2;1;1;0;16;0
                                  that looks good :)
                                  • P
                                    P
                                    p0lar
                                    #349
                                    Still nothing in the MySensors Debug tab... and only the NON debug info in the log files. maybe this is a ethernet GW issue? So I get debug info in the Arduino Serial monitor but no debug via TCP?
                                    [GENERAL]
                                    VERSION=0.1.2.282
                                    [COMMUNICATION]
                                    COM=COM1
                                    SPEED=4
                                    IP=10.1.1.200
                                    PORT=5003
                                    TCPACTIVE=1
                                    [STATUS]
                                    LOGGING=1
                                    DEBUGGING=1
                                    SENDMSG=1
                                    LOGPARSE=1
                                    AUTOFW=0
                                    AUTOID=1
                                    UTCTIME=0
                                    CLOSECONFIRM=0
                                    FILTERLOG=1
                                    SAVENODES=1
                                    METRICSYSTEM=0
                                      stebra
                                      @tekka : I tested the ID reassign by hardcoding the functionality in the serial gw sketch. Reboot node 6, wait for FW_CONFIG_REQUEST, answer with FW_CONFIG_RESPONSE.
                                      Works as expected & described in the MYSBootloader code. Please give me some hint why MYSController does not send the FW_CONFIG_RESPONSE packet with the bootloader commands after the reboot.
                                      I trigger the reassign via the node´s context menu in the gui, MYSBootloader Commands --> reassign ID. Anything wrong with that ?
                                      Maybe someone else has an idea what is happening/not happening ? @tekka could you find something in the log file?
                                      Thanks a lot...
                                        stebra
                                        Has anyone tested successfully reassigning the node-id with MYSBootloader 1.1 and MYSController 1.2.282 ? Would give me some new motivation to hear it's possible and has been done before. At the very moment I m at a dead end.
                                        If it is not working for you, I would also appreciate your feedback.
                                        • greglG
                                          greglG
                                          gregl
                                          @tekka
                                          Is the (dev branch) MQTTClientGateway supported by MYSController?
                                          I'm in the process of moving from Vera and Ethernet GW, to Openhab with MQTTClient gateway and would love to have the OTA functionality your bootloader and controller provides. I looked at this a while back, but ran out of time to play!
                                          So yeah.. Can MYSController talk with the MQTTClientGateway ( over Ethernet) ?
                                          Cheers,
                                          Greg
