  3. My Slim 2AA Battery Node
498 Posts 71 Posters 599.2k Views 69 Watching
  • dakkyD dakky
    Anyone want to share some photos with sensors assembled?
    Any experiences how long this node will last? I have one DHT11 and one BH1750 onboard and will wake up the node every 5-15 Minutes.
    Greetings
    Dakky
    rsachocR
    rsachocR
    rsachoc
    wrote on last edited by rsachoc
    #112
    Greetings
    Dakky
    I would like this too please! I'm trying to decide on which node to use as a motion sensor and temp/humidity sensor and would like to understand how I add a temp/humidty sensor to these and also the battery drain. And also, what temp/humidity sensors are we able to use with this node? I guess it ouputs max 3v, so does that mean the DHT11 and DHT22 are not able to be used here? Sorry for the newbie questions, I'm beginning to explore my options in relation to building my initial temp/humidity sensor and then a motion sensor.
    edit OK, so based on what m26872 said here (http://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor/5) I think that I can only use Si7021 or HTU21 sensors as this outputs around 3v? From reading the spec sheet of the DHT11 and 22 I see they need 3.7v, so I guess if I want to use those sensors I need this node (http://forum.mysensors.org/topic/486/my-2aa-battery-sensor)?
    m26872M 1 Reply Last reply
    • rsachocR rsachoc
      Greetings
      Dakky
      m26872M
      m26872M
      m26872
      @rsachoc Yep, you got it right.
      • dakkyD
        dakkyD
        dakky
        wrote on last edited by dakky
        #114
        Arghls no DHT11 with this node? Dammit. But a step up converter should do it?
        Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
        Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
        Software: MySensors 2.0development
        • m26872M
          m26872M
          m26872
          wrote on last edited by m26872
          #115
          Humidity Sensor example
          http://forum.mysensors.org/topic/3049/slim-node-si7021-sensor-example
          (This post used to contain a not yet finished design by mistake. The link above now shows the correct finished project.)
          AWIA 1 Reply Last reply
          • m26872M
            m26872M
            m26872
            #116
            Reed Switch example
            With external 10M pull-up to save battery. The plastic foam is used instead of a fixed mount, for easy disassemble, reflash, battery renewal etc.
            The Sketch
            // EgSlimReed2
            // By m26872, 2015-12-22
            // Interrupt driven binary switch for Slim Node with Reed switch and external pull-up (10Mohm)
            // Inspired by mysensors example:
            // https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/BinarySwitchSleepSensor/BinarySwitchSleepSensor.ino
            #include <Vcc.h>
            #define NODE_ID 5 //12 var senaste "reed-node"-id // 110    // Use static Node_ID  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
            #define SKETCH_NAME "EgSlimReed"
            #define SKETCH_VERSION "2.0 2015-12-22"
            #define SW_CHILD_ID 5
            #define SW_PIN 3
            #define BATTERY_REPORT_DAY 2   // Desired heartbeat interval when inactive. Maximum heartbeat/report interval is equal to this due to the dayCounter.
            #define BATTERY_REPORT_BY_IRT_CYCLE 10  // Adjust this according to usage frequency.
            #define ONE_DAY_SLEEP_TIME 86400000
            #define VCC_MIN 1.9
            #define VCC_MAX 3.3
            int dayCounter = 0;
            int irtCounter = 0;
            uint8_t value;
            uint8_t sentValue=2;
            bool interruptReturn=false;
            Vcc vcc;
            MyMessage msg(SW_CHILD_ID, V_TRIPPED);
              delay(100); // to settle power for radio
              gw.begin(NULL,NODE_ID);
              pinMode(SW_PIN, INPUT);
              digitalWrite(SW_PIN, LOW);    // Disable internal pull-ups
              gw.present(SW_CHILD_ID, S_DOOR);
              if (!interruptReturn) { // Woke up by timer (or first run)
            	dayCounter++;
            	if (dayCounter >= BATTERY_REPORT_DAY) {
            		  dayCounter = 0;
            		  sendBatteryReport();
              else {	// Woke up by pin change
            	  irtCounter++;
            	  gw.sleep(50);  	  // Short delay to allow switch to properly settle
            	  value = digitalRead(SW_PIN);
            	  if (value != sentValue) {
            		 sentValue = value;
            	  if (irtCounter>=BATTERY_REPORT_BY_IRT_CYCLE) {
            		irtCounter=0;
              // Sleep until something happens with the sensor,   or one sleep_time has passed since last awake.
              interruptReturn = gw.sleep(SW_PIN-2, CHANGE, ONE_DAY_SLEEP_TIME);
            void sendBatteryReport() {
            		  float p = vcc.Read_Perc(VCC_MIN, VCC_MAX, true);
            		  int batteryPcnt = static_cast<int>(p);
            • m26872M
              m26872M
              m26872
              Motion sensor example
              As already mentioned; more details to be found here.http://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor
              • dakkyD
                dakkyD
                dakky
                do u add these photos and comments to openhardware.io ? they are quite helpful
                • m26872M m26872
                  AWIA
                  AWIA
                  AWI
                  @m26872 I don't use any I2C pull-ups. All my Si7021/ SHT21 (GY-21) boards include the SDA/SCL pull-ups (and LDO voltage regulator/ level conversion).
                  m26872M rsachocR 2 Replies Last reply
                  • AWIA AWI
                    m26872M
                    m26872M
                    m26872
                    #120
                    @AWI
                    Oops, it makes me worried that I completely forgot that this project was in some test stage. Ldo and everything should probably be bypassed, but I wanted to test it first. Post edited. Thanks for noticing!
                    And sorry for everyone else if this caused any trouble.
                    (It also makes me a little worried about that I have too many ongoing projects right now. :confounded: )
                    • AWIA AWI
                      rsachocR
                      rsachocR
                      rsachoc
                      @m26872 said:
                      @AWI
                      Apologies again, so that I understand it, does that mean when adding the mentioned temp sensor nodes I need additional parts?
                      • rsachocR rsachoc
                        @m26872 said:
                        @AWI
                        m26872M
                        m26872M
                        m26872
                        @rsachoc My mistake and my apology. Unfortunatly I can't even finish and share the resluts from that humidity sensor in a while since I'm leaving for a few weeks holiday.
                        Anyway
                        @riataman Shows a mod of the GY-21 board in this post. He also link to a board without the LDO and level converter. In any case you wont need the two 4k7 pull-up in my pictures above, only if use the bare chip.
                        • ahmedadelhosniA
                          ahmedadelhosniA
                          ahmedadelhosni
                          What about using a hall effect sensor to detect magnet ?
                          I have a door sensor using the same contact sensor, but I also have a hall effect sensor and I hope to test it soon. It is very small compared to the contact sensor.
                            sensorchecker
                            Hello m26872,
                            your project is great, and i will order tomorrow a set of PCBs.
                            I've done a breadboard setup with the SI7021 according to your schematic and your sketch, which works flawlessly.
                            (ATmega328P / SI7021 / NRF24L01 / 2xAA Battery / your 1Mhz bootloader / your Fuse Settings)
                            Unfortunately I do not get the current consumption below 2mA.
                            What to do to get the power consumption below 10uA and to increase the battery life on a couple of years ?
                            Any help is appreciated...
                            • S sensorchecker
                              Hello m26872,
                              AWIA
                              AWIA
                              AWI
                              @sensorchecker A power consumption of 2mA is way out of range. Is your sensor entering sleep? Or an ftdi adapter still connected?
                              • A
                                arnoldg
                                can i run it on 5V without any problem.
                                For the RF433 interface i need 5V so i would like to make one that is powerd by an usb charger.
                                  sensorchecker
                                  @AWI
                                  No FTDI Adapter, no LED and nothing else is connected.
                                  I build the node like the schematic in the first post.
                                  When i start the sensor node, power consumption is about 16mA.
                                  After a few seconds (4-5sec) the current goes down to 2mA
                                  Can you please tell me, how to find out, that the node is in sleep mode
                                  I have really no idea how to fix that.. but i have to, because i ordered the PCBs today!
                                  Thanks for your help
                                  • S sensorchecker
                                    @AWI
                                    m26872M
                                    m26872M
                                    m26872
                                    #128
                                    @sensorchecker I think you should start with a simple example like the "reed switch sensor" and by looking at the other sketches you should be able to add some debug prints yourself. You only need a high ohm resitor 1M-10M and two pieces of wire to simulate a button or switch.
                                    • A arnoldg
                                      m26872M
                                      m26872M
                                      m26872
                                      @arnoldg The nRf24L01+ is rated like 1.9-3.7V. So 5V will probably kill it.
                                      • A
                                        arnoldg
                                        Oke, that's tru i didn't think of that.
                                        but when i use a 5v - 3v power suply in between it could work.
                                          sensorchecker
                                          @m26872
                                          I have already tested the "reed switch sensor" and it works fine for me- but with a power consumption of 2mA ...:-(
                                          Is it possible that i have a problem with the bootloader or the fuses ?
                                          How can i check that ?
                                          Usually i use USBASP and avrdude for programming the processors on breadboards.
                                          Is it also possible to do the whole programming with the arduino IDE ?
