  3. My Slim 2AA Battery Node
498 Posts 71 Posters 599.1k Views 69 Watching
  • dakkyD
    dakkyD
    dakky
    do u add these photos and comments to openhardware.io ? they are quite helpful
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
    • m26872M m26872
      Humidity Sensor example
      http://forum.mysensors.org/topic/3049/slim-node-si7021-sensor-example
      (This post used to contain a not yet finished design by mistake. The link above now shows the correct finished project.)
      AWIA
      AWIA
      AWI
      @m26872 I don't use any I2C pull-ups. All my Si7021/ SHT21 (GY-21) boards include the SDA/SCL pull-ups (and LDO voltage regulator/ level conversion).
      m26872M rsachocR 2 Replies Last reply
      • AWIA AWI
        m26872M
        m26872M
        m26872
        wrote on last edited by m26872
        #120
        @AWI
        Oops, it makes me worried that I completely forgot that this project was in some test stage. Ldo and everything should probably be bypassed, but I wanted to test it first. Post edited. Thanks for noticing!
        And sorry for everyone else if this caused any trouble.
        (It also makes me a little worried about that I have too many ongoing projects right now. :confounded: )
        • AWIA AWI
          rsachocR
          rsachocR
          rsachoc
          @m26872 said:
          @AWI
          Apologies again, so that I understand it, does that mean when adding the mentioned temp sensor nodes I need additional parts?
          m26872M 1 Reply Last reply
          • rsachocR rsachoc
            @m26872 said:
            @AWI
            m26872M
            m26872M
            m26872
            @rsachoc My mistake and my apology. Unfortunatly I can't even finish and share the resluts from that humidity sensor in a while since I'm leaving for a few weeks holiday.
            Anyway
            @riataman Shows a mod of the GY-21 board in this post. He also link to a board without the LDO and level converter. In any case you wont need the two 4k7 pull-up in my pictures above, only if use the bare chip.
            • ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              What about using a hall effect sensor to detect magnet ?
              I have a door sensor using the same contact sensor, but I also have a hall effect sensor and I hope to test it soon. It is very small compared to the contact sensor.
                sensorchecker
                Hello m26872,
                your project is great, and i will order tomorrow a set of PCBs.
                I've done a breadboard setup with the SI7021 according to your schematic and your sketch, which works flawlessly.
                (ATmega328P / SI7021 / NRF24L01 / 2xAA Battery / your 1Mhz bootloader / your Fuse Settings)
                Unfortunately I do not get the current consumption below 2mA.
                What to do to get the power consumption below 10uA and to increase the battery life on a couple of years ?
                Any help is appreciated...
                AWIA 1 Reply Last reply
                • S sensorchecker
                  Hello m26872,
                  AWIA
                  AWIA
                  AWI
                  @sensorchecker A power consumption of 2mA is way out of range. Is your sensor entering sleep? Or an ftdi adapter still connected?
                  • A
                    arnoldg
                    can i run it on 5V without any problem.
                    For the RF433 interface i need 5V so i would like to make one that is powerd by an usb charger.
                      sensorchecker
                      @AWI
                      No FTDI Adapter, no LED and nothing else is connected.
                      I build the node like the schematic in the first post.
                      When i start the sensor node, power consumption is about 16mA.
                      After a few seconds (4-5sec) the current goes down to 2mA
                      Can you please tell me, how to find out, that the node is in sleep mode
                      I have really no idea how to fix that.. but i have to, because i ordered the PCBs today!
                      Thanks for your help
                      • S sensorchecker
                        @AWI
                        m26872M
                        m26872M
                        m26872
                        #128
                        @sensorchecker I think you should start with a simple example like the "reed switch sensor" and by looking at the other sketches you should be able to add some debug prints yourself. You only need a high ohm resitor 1M-10M and two pieces of wire to simulate a button or switch.
                        • A arnoldg
                          m26872M
                          m26872M
                          m26872
                          @arnoldg The nRf24L01+ is rated like 1.9-3.7V. So 5V will probably kill it.
                          • A
                            arnoldg
                            Oke, that's tru i didn't think of that.
                            but when i use a 5v - 3v power suply in between it could work.
                              sensorchecker
                              @m26872
                              I have already tested the "reed switch sensor" and it works fine for me- but with a power consumption of 2mA ...:-(
                              Is it possible that i have a problem with the bootloader or the fuses ?
                              How can i check that ?
                              Usually i use USBASP and avrdude for programming the processors on breadboards.
                              Is it also possible to do the whole programming with the arduino IDE ?
                              • S sensorchecker
                                @m26872
                                ahmedadelhosniA
                                ahmedadelhosniA
                                ahmedadelhosni
                                @sensorchecker did you try changing your nrf ?
                                • BartEB
                                  BartEB
                                  BartE
                                  @sensorchecker and @m26872 changing the NRF module did work for me as well.
                                  I was struggling a lot getting the power consumption down using all the trick and tips as described on the mysensors forum but nothing worked for by battery powered nodes (i have a couple these ).
                                  I was not able to bring the power consumption down below 2.4 mA (with the NFR mounted) finally i just, for an differnt experiment, i took a "fresh"NRF and just for the fun i measured the current and it was down to 0.05 mA for no reason. They came from the same batch.
                                  My theory now is that i broke the first radio module during programming of the node, although the FTDI serial module is in 3.3v mode it still measures around 4.5 volt. So the voltage might has damaged my NRF radio a bit (it still communicates).
                                    sensorchecker
                                    @ahmedadelhosni and @BartE and @m26872 you made my day...!
                                    Changing the NRF module was the solution, now my power consumption is about 8uA.
                                    Now waiting for the PCBs and parts to build 10- 15 nodes
                                    Thank you so much for your help
                                    • F
                                      F
                                      flopp
                                      There is no crystal?
                                      I haven't used Atmega328P as standalone but I have read that you need a crystal.
                                      • F flopp
                                        m26872M
                                        m26872M
                                        m26872
                                        #136
                                        @flopp There's an internal 8MHz xtal in the uC. Infact often default set to be used by factory "fuse" settings. It's not as ambient condition stable and accurate as an external crystal, but quite good enough for our application.
                                        F 1 Reply Last reply
                                        • m26872M m26872
                                          F
                                          F
                                          flopp
                                          @m26872 thanks
