  3. Vera
  4. Sending Variables to a arduino switch
28 Posts 8 Posters 15.5k Views 6 Watching
  • P
    P
    patrick schaerer
    wrote on last edited by patrick schaerer
    I want to send variable 1 to a arduino switch, that is lightened with a LED. Variable 1 is the brightness of the led.
    I read several threads to that topic:
    http://forum.mysensors.org/topic/957/red-green-matrix-information-panel-with-real-time-clock
    http://code.mios.com/trac/mios_arduino-sensor/wiki/TipsAndTricks
    http://forum.mysensors.org/topic/80/getting-numbers-from-vera-to-a-sensor/6
    but they have syntax mysensors library doesn't recognise (mabe the changed with new versions)
    gw.getStatus(CHILD_ID, V_VAR1); for example
    In "TipsAndTricks" Case # 2 I'm not sure what radioId="4,255" is. Is that what is in vera altid?
    It would be great if someone could give a simple script to send a variable to a node and the code I should use in vera scene.
    TIA Patrick
    • mfalkviddM
      Which version of the MySensors library are you using?
      • P
        P
        patrick schaerer
        the one on codebender ... and I also tried 1.5
        and vera UI5
        • P
          P
          patrick schaerer
          I tried to write a node that sets the brightness of an attached LED with the value of V_VAR1
          I did this based on the Power Meter & Water Meter Sketch
          unfortunately it doesn't work :-( edit: it works now!
          here is the code:
          https://codebender.cc/sketch:221589
          • mfalkviddM
            What is the output on the serial port when you run it?
            What type of led are you using?
            Most leds cannot be controlled by voltage level (analogWrite), they need to be controlled by pwm.
            • P
              P
              patrick schaerer
              The LED is not the problem. AnalogWrite works perfect.
              Serial out is:
              Requesting VAR1
              LED Level 255
              connecting at 9600
               ,pt=0,l=23,sg=0,st=ok:LED brightness via VAR1
               send: 5-5-13-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:0.2
              send: 5-5-13-0 s=0,c=0,t=3,pt=0,l=0,sg=0,st=ok:
              Requesting VAR1 send: 5-5-13-0 s=0,c=2,t=24,pt=0,l=0,sg=0,st=ok: Requesting VAR1send: 5-5-13-0 s=0,c=2,t=24,pt=0,l=0,sg=0,st=ok:
              LED Level: 255
              read: 13-13-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
              LED Level: 255
              LED Level: 255
              LED Level: 255
              LED Level: 255
              LED Level: 255
              LED Level: 255
              IncomingMessage routine is never executed
              • sundberg84S
                sundberg84S
                Im having this issue as well with domoticz... sometimes i get a reply but its like that ack doesnt work somewhere. Im trying to figure this out but no luck so far. Was just about to post in Domoticz forum yesterday but didnt...
                Im trying to recieve a VAR1 for my rain sensor... sometimes it takes 10 tries and sometimes it never returns. I have the sensor just beside the gateway with no luck so my feeling is that there is an error in the code somewhere (Domoticz or Mysensors, dont know).
                So far I have not debugge my gateway (no logs) but in MYSController i get the request in but never see any reply out with the VAR1 value.
                • BartEB
                  BartEB
                  BartE
                  wrote on last edited by BartE
                  @patrick-schaerer the problem in your code snipped is the delay(1000).
                  This is a blocking call which blocks also your radio module from communicating. You have to use gw.wait(1000); i.s.o. delay. Now your plugin will receive data.
                  • P
                    P
                    patrick schaerer
                    ok Ill try that
                    • sundberg84S
                      sundberg84S
                      I don't have any delay in my code. Still same problem with var1 and domoticz.
                      • P
                        P
                        patrick schaerer
                        delay is not the problem ... i changed the code to gw.wait(1000)
                        Serial output is the same
                        • sundberg84S
                          sundberg84S
                          I wrote a code that only fetch time and the V_VAR1 - works every time.
                          MySensors 2.0b, Ethernet GW, Domoticz latest version:
                          #NOTE THAT CODE IS FOR MySensors > 1.6.0b version
                          #define MY_NODE_ID 7
                          #include <Time.h>
                          boolean timeReceived = false;
                          unsigned long lastUpdate=0, lastRequest=0;
                          #define CHILD_ID 1
                          boolean pcReceived = false;
                          unsigned long lastSend =0;
                          void presentation()  {
                            sendSketchInfo("Test to get V_VAR1", "1.0");
                            unsigned long now = millis();
                            // If no time has been received yet, request it every 5 second from controller
                            // When time has been received, request update every hour
                            if ((!timeReceived && (now-lastRequest) > (5UL*1000UL))
                              || (timeReceived && (now-lastRequest) > (60UL*1000UL*60UL))) {
                              requestTime();
                              lastRequest = now;
                              //Request V_VAR1 every 5 sec if not recieved.
                              if (!pcReceived && (now - lastSend > 5000)) {
                                request(CHILD_ID, V_VAR1);
                                lastSend=now;
                                return;
                              if (!pcReceived) {
                                return;
                            if (message.type==V_VAR1) {
                            Serial.print("Received last pulse count from gw:");
                            Serial.println(message.getULong());
                            pcReceived = true;
                          void receiveTime(unsigned long time) {
                            // Ok, set incoming time
                            setTime(time);
                            Serial.print("Got time, hour: ");
                            Serial.println(hour());
                            timeReceived = true;
                          Its not different from my Rain sensor code... where i have the same problem as above... so there must be something else blocking recieve function in that code or radiotraffic... Its nothing wrong with Domoticz and/or Gateway what i can see... its something wrong with the code in the sensor itself. To be continued...
                          • sundberg84S
                            sundberg84S
                            What is similar in our sketches that does not work is that we use pin 3. I have seen some post with relays that it worked if you move to pin 4. Don't know why but I will try this tonight. Worth a shot...
                            • BartEB
                              BartEB
                              BartE
                              @patrick-schaerer and @sundberg84
                              I've compiled your code and uploaded in my Arduino to debug your issue. What i noticed is that the sketch worked on my side, two remarks on the code snipped:
                              • why switching back to 9600 baud and not just setting your terminal to 115200 baud.
                              • line 83 contains an error i think the + should be removed so it becomes this line:
                              LED_Level = gwLEDLevel;
                              But this will not solve you original problem. What i also noticed is when you requesting data from a none exiting node you do not get any data but the following error in your Vera controller log file:
                              Open a terminal like putty -> new connection to your Vera's IP address login with username root and the WIFI password and give this command
                              tail -f /var/log/cmh/LuaUPnP.log
                              The error line you might see is this one (the second line is yellow marked)
                              50      01/17/16 15:07:28.915   luup_log:64: Arduino: Log: read: 50-50-0 s=255,c=3,t=12,pt=0,l=3,sg=0:0.2 <0x6011>
                              02      01/17/16 15:07:28.918   luup_log:64: Arduino: Incoming internal command '50;255;3;0;12;0.2' discarded for child: nil <0x6011>
                              So it might help to:
                              • start MySensors inclusion mode
                              • give a reset on your Arduino
                              • wait to see MySensors does find new nodes
                              • press stop inclusion
                              • wait until Vera is ready again
                              • press reload
                              • reset your Arduino again and make sure the MySensor node shows the corrent version information
                              • sundberg84S
                                sundberg84S
                                Tried my hypothesis above but same error. What made some different now was to add a second cap of 10uF to the radio... still nog good, but at least after some tries I now receive the V_VAR1.
                                • clio75C
                                  clio75C
                                  clio75
                                  @sundberg84
                                  Can your code be used on 1.5.1 ??
                                  I need to get Temp Values from Vera. to my PID controller
                                  • sundberg84S
                                    sundberg84S
                                    No - code is > 1.6b
                                    @clio75 I couldnt find out what my problem was... got tired of it and uploaded same sketch so complete new set of hardware... and now its working so my occlusion was bad hardware.
                                    • clio75C
                                      clio75C
                                      clio75
                                      @sundberg84
                                      Thanx for your reply,
                                      Do you know where I can find one example for getting variables from Vera ?
                                      I have tried searching, but can't seem to find any :(
                                      Thanx
                                      • sundberg84S
                                        sundberg84S
                                        In the library you can use timeawaresensor to recieve time
                                        https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/TimeAwareSensor
                                        The raingauge, WaterMeterPulseSensor and Power meter to recieve V_VAR1
                                        • P
                                          P
                                          patrick schaerer
                                          @BartE: Thank you for your corrections to the code. I changed that.
                                          Now the sketch works. All I did is to add a new repeaternode between the gateway and the receiving node. It was definetly a hardware problem (or the problem was solved in 1.5.3 update).
                                          The LED_Node_var sketch works!
