  3. (SOLVED) Programming problem: error: 'incomingMessage' was not declared in this scope
3 Posts 2 Posters 4.7k Views
  • O Offline
    O Offline
    Ole Theill Sørensen
    wrote on last edited by Ole Theill Sørensen
    I am trying to mix and match two sketches..
    One is the RealTimeClockDisplaySensor example and one is a sketch I found on HomeSeer forum.
    Both compiles without any problems.
    But when I use this sketch:
    * Version 1.0 - Henrik Ekblad
    * Example sketch showing how to request time from controller which is stored in RTC module
    * The time and temperature (DS3231/DS3232) is shown on an attached Crystal LCD display
    * Wiring (radio wiring on www.mysensors.org)
    * Arduino   RTC-Module     I2C Display
    * GND       GND            GND
    * +5V       VCC            VCC
    * A4        SDA            SDA
    * A5        SCL            SCL
    * http://www.mysensors.org/build/display
    #include <Time.h>
    #include <DS3232RTC.h>  // A  DS3231/DS3232 library
    //Standard
           #define RELAY_1                            4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
           #define NUMBER_OF_RELAYS                2 // Total number of attached relays
           #define RELAY_ON                        0  // GPIO value to write to turn on attached relay
           #define RELAY_OFF                        1 // GPIO value to write to turn off attached relay
    // Other Stuff
    //        Bounce debouncer = Bounce();
           int numSensors=                            0;
    boolean timeReceived = false;
    unsigned long lastUpdate=0, lastRequest=0;
    // Initialize display. Google the correct settings for your display.
    // The follwoing setting should work for the recommended display in the MySensors "shop".
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
               gw.begin(incomingMessage, AUTO, false);
     gw.sendSketchInfo("Oles relay", "1.0");
     // Request latest time from controller at startup
    //  gw.requestTime(receiveTime);
     //Present relays to gateway
     for (int sensor=1; sensor <=NUMBER_OF_RELAYS;sensor++) {
         gw.present(sensor, S_LIGHT);
     // initialize the lcd for 16 chars 2 lines and turn on backlight
     lcd.begin(16,2);
    //void receiveTime(unsigned long controllerTime) {
    // // Ok, set incoming time
    //  Serial.print("Time value received: ");
    //  Serial.println(controllerTime);
    //  RTC.set(controllerTime); // this sets the RTC to the time from controller - which we do want periodically
    //  timeReceived = true;
           if (message.isAck()) {
            } else if (message.type==V_LIGHT) {
                 state = message.getBool();
                // Change relay state
               lcd.home();
               lcd.print(message.sensor);
               lcd.print(" , ");
               lcd.print(state);
               //Send the msg
               gw.send(msg.setSensor(message.sensor).set(state), true);
                Serial.println(state);
                //Handle LED's on change
                ledControl(message.sensor);
    void updateDisplay(){
     // Print date and time
     lcd.home();
    //  lcd.print(" ");
    //  lcd.print(tmYearToCalendar(tm.Year)-2000);
     lcd.print("gammel ");
     // Go to next line and print temperature
     lcd.setCursor ( 0, 1 );
     lcd.print("tekst");
    //  lcd.print(RTC.temperature()/4);
    //  lcd.print("C");
    void printDigits(int digits){
     if(digits < 10)
       lcd.print('0');
     lcd.print(digits);
    I get the following error message:
    C:\Users\Owner\(...)\Oles_nye_display2.ino: In function 'void setup()':
    Oles_nye_display2:70: error: 'incomingMessage' was not declared in this scope
    C:\Users\Owner\(...)\Oles_nye_display2.ino: At global scope:
    Oles_nye_display2:95: error: expected declaration before '}' token
    exit status 1
    I am new to c++ and sketches, is there a simple fix to this problem?
    Using Win7, Arduino 1.6.7
    Right now it is a proof of concpt.. My end goal is to have my display change based on change of "fake" relays... So if the gateway tells me to turn on child1, my display writes "Window open"
    • B Offline
      B Offline
      BartE
      @Ole-Theill-Sørensen on commenting out function void receiveTime(
      you missed one } character at the end i think you have to add // in front of that line as well
      • O Offline
        O Offline
        Ole Theill Sørensen
        Thank you, that was it...
        There are other issues with the code I see now.. But I will persue them tonight..
