  2. Announcements
  3. MySensors 1.5.2 Released
35 Posts 6 Posters 17.4k Views 4 Watching
  • korttomaK
    korttomaK
    korttoma
    How can I do the following on this Library version?
    #define MY_NODE_ID 12
    #define RF24_CE_PIN		4
    #define RF24_CS_PIN		10
    #define RF24_PA_LEVEL	RF24_PA_MAX
    MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL);
    MySensor (transport);
    {             gw.begin(NULL, MY_NODE_ID);
    Cant seem to wrap my head around this. btw, I'm using Codebender.
    • Tomas
    • AnticimexA
      AnticimexA
      Anticimex
      There is no difference in how you write your sketch in 1.5.2 compared to 1.5.1. So I am not sure I understand your question.
      • korttomaK
        korttomaK
        korttoma
        Whell a sketch used to compile just fine using 1.5 but now I get:
        In file included from (sketch file) MultiTemp.ino:39:
        (personal library file) MySensors/MySensor.h:158:70: error: unknown type name 'MyHwDriver'
        (sketch file) MultiTemp.ino:71:10: error: redefinition of 'transport' with a different type: 'MySensor' vs 'MyTransportNRF24'
        MySensor(transport);
        (sketch file) MultiTemp.ino:69:18: note: previous definition is here
        • Tomas
        • AnticimexA
          AnticimexA
          Anticimex
          If you skipped on 1.5.1 and went from 1.5 to 1.5.2 I think @hek needs to fill you (and me) in on what changes has been made.
          • korttomaK
            korttomaK
            korttoma
            Btw, I just upload the MySensor folder from the library as a .zip to codebender. Do I need anything outside this folder?
            • Tomas
            • AnticimexA
              AnticimexA
              Anticimex
              I don't think so. Perhaps it helps to re-download the image. Which link did you use? The zip link to 1.5.2 is here.
                Github is the best place. I have a vague memory of routing problems fixed in 1.5.1.
                https://github.com/mysensors/Arduino/releases
                • korttomaK
                  korttomaK
                  korttoma
                  Tried to get the Lib again but it does not seem to be any different:
                  Trying to compile the sketch (coodiebender.something/sketch:213307) unchanged results in this:
                  In file included from (sketch file) MultiTemp.ino:35:
                  (sketch file) MultiTemp.ino:63:10: error: no matching constructor for initialization of 'MySensor'
                  MySensor gw(transport);
                  So I remove the "gw" but it stil complains:
                  (sketch file) MultiTemp.ino:63:11: error: redefinition of 'transport' with a different type: 'MySensor' vs 'MyTransportNRF24'
                  I'm just not doing it right that is all, but how should it be done?
                  • Tomas
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    Have you looked at one of the existing examples as a reference? For example the DallasTemperatureSensor.ino
                    • korttomaK
                      korttomaK
                      korttoma
                      The examples do not include a transport definition
                      • Tomas
                      • korttomaK
                        korttomaK
                        korttoma
                        Is there "SOMETHING" missing like this??
                        MySensor gw(transport, SOMETHING);
                        candidate constructor not viable: requires 2 arguments, but 1 was provided
                        How do I define "MyHwDriver"??
                        • Tomas
                        hekH 1 Reply Last reply
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          Have a look at this example
                          • korttomaK
                            korttomaK
                            korttoma
                            Thanks for the example @Anticimex now I know how but it is stil not working when using codebender.
                            (sketch file) MultiTemp.ino:66:1: error: unknown type name 'MyHwATMega328'
                            MyHwATMega328 hw; // Select AtMega328 hardware profile
                            I tested now with Arduino IDE 1.6.5 and my sketch compiles just fine.
                            • Tomas
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              Sorry, I am not very familiar with codebender. It looks to me that the library you try to build with is very out if date if it lacks those hw definitions. I don't know how the library ends up at codebender. Perhaps @hek has some communication with them to support it.
                              • carlierdC
                                carlierdC
                                carlierd
                                I tried to compile with 1.5.2 and got these errors:
                                /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::sendRoute(MyMessage&)':
                                /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:27:25: error: '_doSign' was not declared in this scope
                                 #define DO_SIGN(node) (~_doSign[node>>3]&(1<<(node%8)))
                                /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:356:6: note: in expansion of macro 'DO_SIGN'
                                  if (DO_SIGN(message.destination) && message.sender == nc.nodeId && !mGetAck(message) && mGetLength(message) &&
                                /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::process()':
                                /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:28:25: error: '_doSign' was not declared in this scope
                                 #define SET_SIGN(node) (_doSign[node>>3]&=~(1<<(node%8)))
                                /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:670:6: note: in expansion of macro 'SET_SIGN'
                                      SET_SIGN(msg.sender);
                                /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:29:27: error: '_doSign' was not declared in this scope
                                 #define CLEAR_SIGN(node) (_doSign[node>>3]|=(1<<(node%8)))
                                /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:673:6: note: in expansion of macro 'CLEAR_SIGN'
                                      CLEAR_SIGN(msg.sender);
                                /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:682:40: note: in expansion of macro 'DO_SIGN'
                                      if (signer.requestSignatures() && DO_SIGN(msg.sender))
                                Erreur lors de la compilation.
                                No compilation issue with 1.5. And everything is working perfectly.
                                David.
                                AnticimexA 1 Reply Last reply
                                  @Anticimex
                                  Yes, I'll have to update the codebender library manually.
                                  korttomaK 1 Reply Last reply
                                  • carlierdC carlierd
                                    David.
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @carlierd I found a problem there. I have to make a new release. Sorry for the inconvenience!
                                    carlierdC 1 Reply Last reply
                                    • AnticimexA Anticimex
                                      carlierdC
                                      carlierdC
                                      carlierd
                                      @Anticimex No problem !! Thanks for the support :)
                                        @Anticimex
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        @hek said:
                                        @Anticimex
                                        I have uploaded 1.5.2 library as a Personal Library in codebender. I have not had any trouble doing this before. Just tried 1.5.3 but I get the same error.
                                        • Tomas
                                        • korttomaK korttoma
                                          Weird it finds the MySensors constructor, it has a default value (MyHwDriver) but doesn't use it. Darn compilers.
