  2. Announcements
  3. MySensors 1.5.2 Released
35 Posts 6 Posters 17.4k Views 4 Watching
  • korttomaK
    korttomaK
    korttoma
    Is there "SOMETHING" missing like this??
    MySensor gw(transport, SOMETHING);
    candidate constructor not viable: requires 2 arguments, but 1 was provided
    How do I define "MyHwDriver"??
    • Tomas
    hekH 1 Reply Last reply
    • AnticimexA
      AnticimexA
      Anticimex
      Have a look at this example
      • korttomaK
        korttomaK
        korttoma
        Thanks for the example @Anticimex now I know how but it is stil not working when using codebender.
        (personal library file) MySensors/MySensor.h:158:70: error: unknown type name 'MyHwDriver'
        (sketch file) MultiTemp.ino:66:1: error: unknown type name 'MyHwATMega328'
        MyHwATMega328 hw; // Select AtMega328 hardware profile
        I tested now with Arduino IDE 1.6.5 and my sketch compiles just fine.
        • Tomas
        • AnticimexA
          AnticimexA
          Anticimex
          Sorry, I am not very familiar with codebender. It looks to me that the library you try to build with is very out if date if it lacks those hw definitions. I don't know how the library ends up at codebender. Perhaps @hek has some communication with them to support it.
          • carlierdC
            carlierdC
            carlierd
            I tried to compile with 1.5.2 and got these errors:
            /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::sendRoute(MyMessage&)':
            /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:27:25: error: '_doSign' was not declared in this scope
             #define DO_SIGN(node) (~_doSign[node>>3]&(1<<(node%8)))
            /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:356:6: note: in expansion of macro 'DO_SIGN'
              if (DO_SIGN(message.destination) && message.sender == nc.nodeId && !mGetAck(message) && mGetLength(message) &&
            /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::process()':
            /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:28:25: error: '_doSign' was not declared in this scope
             #define SET_SIGN(node) (_doSign[node>>3]&=~(1<<(node%8)))
            /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:670:6: note: in expansion of macro 'SET_SIGN'
                  SET_SIGN(msg.sender);
            /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:29:27: error: '_doSign' was not declared in this scope
             #define CLEAR_SIGN(node) (_doSign[node>>3]|=(1<<(node%8)))
            /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:673:6: note: in expansion of macro 'CLEAR_SIGN'
                  CLEAR_SIGN(msg.sender);
            /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:682:40: note: in expansion of macro 'DO_SIGN'
                  if (signer.requestSignatures() && DO_SIGN(msg.sender))
            Erreur lors de la compilation.
            No compilation issue with 1.5. And everything is working perfectly.
            David.
            AnticimexA 1 Reply Last reply
              @Anticimex
              Yes, I'll have to update the codebender library manually.
              korttomaK 1 Reply Last reply
              • carlierdC carlierd
                David.
                AnticimexA
                AnticimexA
                Anticimex
                @carlierd I found a problem there. I have to make a new release. Sorry for the inconvenience!
                carlierdC 1 Reply Last reply
                • AnticimexA Anticimex
                  carlierdC
                  carlierdC
                  carlierd
                  @Anticimex No problem !! Thanks for the support :)
                    @Anticimex
                    korttomaK
                    korttomaK
                    korttoma
                    @hek said:
                    @Anticimex
                    I have uploaded 1.5.2 library as a Personal Library in codebender. I have not had any trouble doing this before. Just tried 1.5.3 but I get the same error.
                    • Tomas
                    • korttomaK korttoma
                      Weird it finds the MySensors constructor, it has a default value (MyHwDriver) but doesn't use it. Darn compilers.
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        And you have selected a atmega328-based target when you build?
                          korttomaK
                          korttomaK
                          korttoma
                          I take it you have managed to reproduce the situation or do you need some more information from me?
                          Yes, I have an "Arduino Pro Mini 5V 16MHz w/ ATmega328" selected when compiling.
                          • Tomas
                            No, I'm currently @work.
                              @korttoma
                              Updated codebender lib to 1.5.3 and it fails with the same error you got.
                              Seems like codebender doesn't define ARDUINO_ARCH_AVR for the Uno board... which is used to select the correct hw-driver here:
                              https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L47
                              I've tried to reach Vasilis over at codebender but I guess it's a bit late for a reply today.
                              • ferpandoF
                                ferpandoF
                                ferpando
                                I updated to 1.5.3 and I get 2 warnings just by opening arduino IDE
                                Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                                I'm using IDE 1.6.6
                                It was working before with MySensors 1.5
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  Those warnings are no reason for concern. Everything works like before.
                                  ferpandoF 1 Reply Last reply
                                    ferpandoF
                                    ferpandoF
                                    ferpando
                                    @Anticimex
                                    Ok, but is there a way to remove them?
                                    I can confirm it compiles and uploads correctly.
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      Should just be a matter of editing platform.txt I suppose. I have not worked with those aspects. The release only change signing related parts. Those warnings are probably relating to IDE and versions of board support packages.
                                        @korttoma
                                        1.5.3 in codebender compiles now.
                                        They're only compatible with arduino IDE 1.0.5 currently. Which means they don't define ARDUINO_ARCH_AVR which MySensors relies on.
                                        Patched the codebender library (manually defining this) as a workaround until they update their things.
                                        • korttomaK
                                          korttomaK
                                          korttoma
                                          @hek how do I Patch my copy of 1.5.3 or where can I download the Patched version? Seems like it is stil 1.4 that is used on codebender unless you upload your own version.
                                          • Tomas
