  3. Home Assistant
  4. Error using Home Assistant with a serial gateway
21 Posts 3 Posters 10.4k Views 2 Watching
  • B Offline
    B Offline
    BastienVH
    I've been taking a look at Home Assistant lately, but encountered some problems setting it up.
    The first time I installed HA (0.10), I could connect my serial gateway and my temp sensor was recognized and added to the display on top of the web page.
    My install seems to have been corrupted though.
    When I wanted to test it out some more this week (with versions 0.10, 0.11.0 and 0.11.1) I can't get mysensors to work.
    HA can connect to the gateway, as seen here:
    INFO:mysensors.mysensors:/dev/ttyUSB2 is open...
    INFO:mysensors.mysensors:Connected to /dev/ttyUSB2
    But a little further on, I receive this error in the console:
    Exception in thread Thread-7:
      File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
        self.run()
      File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 312, in run
        response = self.handle_queue()
      File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 222, in handle_queue
        reply = func(*args, **kwargs)
      File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 105, in logic
        msg = Message(data)
      File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 397, in __init__
        self.decode(data)
      File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 417, in decode
        self.sub_type) = [int(f) for f in data]
    ValueError: need more than 0 values to unpack
    Has anyone else encountered this or have any idea how to solve this issue?
    Thanks in advance!
    • B BastienVH
          self.run()
          msg = Message(data)
          self.decode(data)
      Thanks in advance!
      martinhjelmareM Offline
      martinhjelmare
      @BastienVH
      Hi!
      Yes, I encounter it every now and then. I think it's some sort of out of sync comm creating a problem. Try restarting home assistant. If that doesn't solve it, disconnect/reconnect the USB for the serial gateway and restart home assistant. That always solves it for me.
      I'm looking into a software workaround to avoid the error.
      Edit:
      I only see this error at start of home assistant. Once it's solved after the restart I've never seen during operation.
      • B Offline
        B Offline
        BastienVH
        wrote on last edited by BastienVH
        Hi Martin,
        @martinhjelmare
        I've been trying the last couple of days to get it working, but to no avail...
        I stell get errors like
        ValueError: need more than 1 value to unpack
        The number can change though.
        I've tried your suggestions, updated and rebooted the pi but still no luck.
        Uninstalled and reinstalled home assistant but that also didn't help.
        Any other things I could try?
        • delsD Offline
          delsD Offline
          dels
          @BastienVH said:
          Hi Martin,
          @martinhjelmare
          I have been getting the same thing... it worked on one occasion where it was able to load, but I didnt know the sensors had to "present" themselves at that time... so I made some research, restarted HA, rebooted the pi, disconnected the serial gw... I have been trying at least 25 times since and now I am always getting this:
          16-01-23 14:32:29 homeassistant.bootstrap: Error during setup of component mysensors
            File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 98, in _setup_component
              if not component.setup(hass, config):
            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 124, in setup
              port, persistence, persistence_file, version)
            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 90, in setup_gateway
              protocol_version=version)
            File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 261, in __init__
              persistence_file, protocol_version)
            File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 33, in __init__
              self._load_sensors()
            File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 153, in _load_sensors
              self._perform_file_action(self.persistence_file, 'load')
            File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 167, in _perform_file_action
              fn(filename)
            File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 136, in _load_json
              self.sensors = json.load(f, cls=MySensorsJSONDecoder)
            File "/usr/lib/python3.4/json/__init__.py", line 268, in load
              parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
            File "/usr/lib/python3.4/json/__init__.py", line 331, in loads
              return cls(**kw).decode(s)
            File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
              obj, end = self.raw_decode(s, idx=_w(s, 0).end())
            File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
              raise ValueError(errmsg("Expecting value", s, err.value)) from None
          ValueError: Expecting value: line 1 column 1 (char 0)
          Any help appreciated :)
          dels
          delsD 1 Reply Last reply
          • delsD dels
            @BastienVH said:
            Hi Martin,
            @martinhjelmare
                fn(filename)
            dels
            delsD Offline
            delsD Offline
            dels
            @dels said:
            @BastienVH said:
            Hi Martin,
            @martinhjelmare
                fn(filename)
            dels
            Well... I feel stupid. I had completely forgotten that I had a Domoticz installed back a few weeks back when I first started searching for the right controller and it restarted when I rebooted the server... when I saw it was loaded, I shut it down and disabled it... then restarted home-assistant, which loaded mysensors perfectly and discovered the PIR sensor as soon as I reconnected it (after the mysensors component was loaded in HA). My guess is it loaded before HA and had dibs on the serial port or something...
            I hope it helps someone else!
            • delsD dels
              @dels said:
              @BastienVH said:
              Hi Martin,
              @martinhjelmare
                  fn(filename)
              dels
              martinhjelmare
              @dels
              Nice catch! Yes, the serial port is exclusive. Only one device/user at a time per port per end, is allowed.
              • B BastienVH
                Hi Martin,
                @martinhjelmare
                martinhjelmare
                @BastienVH
                What version of pyserial do you have installed?
                For me version 2.5 has been the least buggy. Version 2.7 has a bug which was solved in version 3, but other bugs have emerged. I'm hoping they will be fixed soon.
                pip3 install pyserial==2.5
                Repeat this if you upgrade home assistant.
                Do you also only see the error on startup, or have you every successfully started up home assistant and loaded mysensors without errors, and later while running had this error?
                I'd like to try and make a workaround in the pymysensors api, but as I haven't really nailed down the bottom cause, all information will help me.
                • martinhjelmareM Offline
                  martinhjelmare
                  Btw, I'm also working on a mysensors ethernet gateway for home assistant, but there is still some work and testing to be done.
                  If you already have an ethernet module and like mqtt and don't mind having to do some configuring for every sensor/switch, mqtt is supported by home assistant in general. @Mihai has written a couple of guides both here and in the home assistant forum, for that.
                  Soon I'm hoping you will have the option of choosing between all three gateway types when using home assistant, but of course we should try and make the serial connection more reliable.
                  B 1 Reply Last reply
                    B Offline
                    B Offline
                    BastienVH
                    @martinhjelmare
                    I was running pyserial 2.6, but have now installed version 2.5.
                    I get the error, the moment I restart a sensor to have it included in HA.
                    When I press the reset button on my sensor, the error shows up almost instantly in the terminal.
                    So I guess that means that HA can connect to the serial gateway and receive messages, but just doesn't deal with it properly...
                    Also: I had some trouble uninstalling the pyserial version and after some messing around, I now get this in my 'pip freeze'
                    pyserial-py3k==2.5
                    No mention of a 'normal' pyserial.
                    Thanks for the help you've already provided!
                    • B BastienVH
                      @martinhjelmare
                      pyserial-py3k==2.5
                      martinhjelmare
                      @BastienVH
                      Regarding py3k, that was a bug solved in 2.7:
                      "[Bug pyserial:130] setup.py should not append py3k to package name"
                      in https://github.com/pyserial/pyserial/blob/master/CHANGES.rst
                      But that shouldn't affect the performance of 2.5, I think.
                      If I understand correct, you do:
                      hass
                      wait for and get:
                      n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                      Then you reset your sensor node, and get the error?
                      Edit:
                      In my experience, I don't think I get the gateway started confirmation before I get the error. You should make sure that the gateway is ready before you do the restart of the sensor node. I think the problem might be that the gateway tries to talk to homeassistant before homeassistant is ready, and only part of the message gets "translated".
                        @BastienVH
                        hass
                        wait for and get:
                        Edit:
                        B Offline
                        B Offline
                        BastienVH
                        @martinhjelmare
                        I never got the "n:0 c:0 ...." message, only "Connected to /dev/MSgw".
                        I found out there was an instance of FHEM running and occuping the GW.
                        I stopped that and now it does give the "gateway started" message.
                        Now the error occurs indeed before the gateway started message.
                        Now I get the following after trying to let a node with DHT send its data to the gateway:
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 10-10-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
                        INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 10-10-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.3
                        INFO:homeassistant.components.mysensors:update sensor_update: node 10
                        INFO:homeassistant.components.sensor.mysensors:Motion Sensor 10.1: value_type 16, value = 0
                        Exception in thread Thread-15:
                            self.run()
                          File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 108, in logic
                            self._handle_presentation(msg)
                          File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 51, in _handle_presentation
                            self.alert(msg.node_id)
                          File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 175, in alert
                            self.event_callback("sensor_update", nid)
                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 226, in node_update
                            callback(self, node_id)
                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 149, in mysensors_callback
                            entity.update_ha_state(True)
                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 108, in update_ha_state
                            self.unit_of_measurement is not None:
                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/mysensors.py", line 137, in unit_of_measurement
                            self.value_type == self.gateway.const.SetReq.V_PERCENTAGE or \
                          File "/usr/lib/python3.4/enum.py", line 255, in __getattr__
                            raise AttributeError(name) from None
                        AttributeError: V_PERCENTAGE
                        Is there a list with which kinds of sensors are supported in HA?
                        Is motion/pir supported?
                        • B BastienVH
                          @martinhjelmare
                              self.run()
                          martinhjelmare
                          @BastienVH
                          Basically all pure sensors are supported. Not all actuator types, though.
                          You can look at the source code for specifics. I want to add more documentation, but it's not done currently.
                          Your log seems to concern a motion sensor, but you said DHT?
                          You need to post the sensor sketch and all of the log from gateway started confirmation, to give me more background.
                            @BastienVH
                            B Offline
                            B Offline
                            BastienVH
                            @martinhjelmare
                            Yeah, I was also trying to get my motion sketch working, so that log message may have been something left over from that.
                            This is everything in my terminal
                            INFO:mysensors.mysensors:/dev/MSgw is open...
                            INFO:mysensors.mysensors:Connected to /dev/MSgw
                            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                            INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 192.168.1.1
                            INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 192.168.1.70
                            INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.1.70:1972/DeviceDescription.xml
                            Exception in thread Thread-6:
                                self.run()
                            I hope you can find something there...
                            • B BastienVH
                              @martinhjelmare
                                  self.run()
                              martinhjelmare
                                martinhjelmare
                                @BastienVH
                                I don't see a line in the log for presentation of the child sensor, or sketch name, or sketch version, but there already seem to be info loaded, sketch name and version and value type, looking at the line before the stack trace.
                                Is persistence disabled? Do you present the sensor in the sketch? Can you link to or post your sketch?
                                I think the problem might be that you're reusing an old node id with a different sensor type that's already been loaded via persistence.
                                I don't think I support these dynamics at the moment. I'll have to look more closely in the code, but if you can link your sketch, that will help me confirm this.
                                Solution would be to clear the persistence file.
                                  @BastienVH
                                  B Offline
                                  B Offline
                                  BastienVH
                                  @martinhjelmare
                                  Sorry, I was away from the computer for a little while.
                                  I did reuse an old node id, that could have been the problem.
                                  Assigned a new node ID and this is where I stand now:
                                  Firts up: the node sketch:
                                   * Version 1.0 - Henrik EKblad
                                   * This sketch provides an example how to implement a humidity/temperature
                                   * sensor using DHT11/DHT-22
                                  #define DIGITAL_INPUT_MOTION 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                                  #define INTERRUPT DIGITAL_INPUT_MOTION-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                                  #define CHILD_ID_HUM 0
                                  #define CHILD_ID_TEMP 1
                                  #define CHILD_ID_MOT 2
                                  unsigned long SLEEP_TIME = 15000; // Sleep time between reads (in milliseconds)
                                  DHT dht;
                                  float lastTemp;
                                  float lastHum;
                                  boolean metric = true;
                                  MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
                                  int node_id = 20;
                                  boolean lastTripped = false ;
                                    gw.begin(NULL, node_id);
                                    gw.sendSketchInfo("Humidity and motion", "1.0");
                                    pinMode(DIGITAL_INPUT_MOTION, INPUT);      // sets the motion sensor digital pin as input
                                    gw.present(CHILD_ID_MOT, S_MOTION);
                                    /* int wake;
                                    wake = gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                                     if (wake == 1) {
                                       Serial.println("wake by motion");
                                       Serial.println("reading motion");
                                       motion();
                                     else {
                                       Serial.println("wake by timer");
                                       motion();
                                       Serial.println("reading temp/hum");
                                       humTemp();
                                    motion();
                                    Serial.println("read temp / hum");
                                    humTemp();
                                    Serial.println("going to sleep now.");
                                    gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME); //sleep a bit
                                  void motion() {
                                    // Read digital motion value
                                    boolean tripped = digitalRead(DIGITAL_INPUT_MOTION);
                                    Serial.println(tripped);
                                    if (lastTripped != tripped) {
                                      gw.send(msgMot.set(tripped ? "1" : "0")); // Send tripped value to gw
                                      lastTripped = tripped;
                                  void humTemp() {
                                    gw.wait(dht.getMinimumSamplingPeriod());
                                    if (isnan(temperature)) {
                                      lastTemp = temperature;
                                      if (!metric) {
                                      Serial.print("T: ");
                                    if (isnan(humidity)) {
                                      lastHum = humidity;
                                      Serial.print("H: ");
                                      Serial.println(humidity);
                                  Now, my HA config:
                                  homeassistant:
                                    # Name of the location where Home Assistant is running
                                    # Location required to calculate the time the sun rises and sets
                                    latitude: xxxxxxxx
                                    longitude: xxxxxxxxxxxxxx
                                    # C for Celcius, F for Fahrenheit
                                    temperature_unit: C
                                    # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
                                    time_zone: Europe/Brussels
                                  # View all events in a logbook
                                  logbook:
                                  # Checks for available updates
                                  updater:
                                  # Discover some devices automatically
                                  discovery:
                                  # Track the sun
                                  sun:
                                  # Allows you to issue voice commands from the frontend
                                  conversation:
                                  # Enables support for tracking state changes over time.
                                  history:
                                  # Enables the frontend
                                  frontend:
                                  # Show links to resources in log and frontend
                                  introduction:
                                  mysensors:
                                    gateways:
                                      - port: '/dev/MSgw'
                                    debug: true
                                    persistence: false
                                  and the output when starting hass:
                                  Config directory: /home/pi/.homeassistant
                                  WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                                  INFO:homeassistant.bootstrap:Home Assistant core initialized
                                  INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                                  INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                                  INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                                  INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                                  INFO:homeassistant.loader:Loaded introduction from homeassistant.components.introduction
                                  INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                                  INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                                  INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                                  INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                                  INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                                  INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                                  INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                                  INFO:homeassistant.components.introduction:
                                          Hello, and welcome to Home Assistant!
                                          We'll hope that we can make all your dreams come true.
                                          Here are some resources to get started:
                                           - Configuring Home Assistant:
                                             https://home-assistant.io/getting-started/configuration/
                                           - Available components:
                                             https://home-assistant.io/components/
                                           - Troubleshooting your configuration:
                                             https://home-assistant.io/getting-started/troubleshooting-configuration/
                                           - Getting help:
                                             https://home-assistant.io/help/
                                          This message is generated by the introduction component. You can
                                          disable it in configuration.yaml.
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=introduction>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                                  INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                                  /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
                                    warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                                  INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=mysensors.sensors>
                                  INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                                  INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                                  INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=mysensors.switches>
                                  INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                                  INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.1 @ 20:51:46 24-01-2016>, entity_id=sun.sun>
                                  INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                                  INFO:homeassistant.core:Starting Home Assistant (16 threads)
                                  INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                                  INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                                  INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                                  INFO:homeassistant.core:Timer:starting
                                  INFO:mysensors.mysensors:Trying to connect to /dev/MSgw
                                  INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                                  INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
                                  INFO:netdisco.service:Scanning
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=1,t=1,pt=7,l=5,sg=0:54.0
                                  INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=1,t=1,pt=7,l=5,sg=0:53.0
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.21 @ 20:51:46 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.1 @ 20:51:46 24-01-2016>>
                                  INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.36 @ 20:51:46 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.21 @ 20:51:46 24-01-2016>>
                                  INFO:homeassistant.components.http:"GET /states HTTP/1.1" 200 -
                                  INFO:homeassistant.components.http:"GET /static/frontend-1003c31441ec44b3db84b49980f736a7.html HTTP/1.1" 200 -
                                  INFO:homeassistant.components.http:"GET /static/favicon-192x192.png HTTP/1.1" 200 -
                                  INFO:homeassistant.components.http:"GET /static/favicon.ico HTTP/1.1" 200 -
                                  I don't get errors anymore, but nothing shows up in the web interface.
                                  I think the messages aren't being interpreted?
                                  • B BastienVH
                                    @martinhjelmare
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                    int node_id = 20;
                                      /* int wake;
                                       if (wake == 1) {
                                         motion();
                                       else {
                                         motion();
                                         humTemp();
                                      motion();
                                      humTemp();
                                    void motion() {
                                    void humTemp() {
                                        if (!metric) {
                                        lastHum = humidity;
                                    Now, my HA config:
                                    homeassistant:
                                      latitude: xxxxxxxx
                                      temperature_unit: C
                                    logbook:
                                    updater:
                                    discovery:
                                    # Track the sun
                                    sun:
                                    conversation:
                                    history:
                                    frontend:
                                    introduction:
                                    mysensors:
                                      gateways:
                                        - port: '/dev/MSgw'
                                      debug: true
                                      persistence: false
                                             - Getting help:
                                    delsD Offline
                                    delsD Offline
                                    dels
                                    @BastienVH said:
                                    @martinhjelmare
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                    int node_id = 20;
                                      /* int wake;
                                       if (wake == 1) {
                                         motion();
                                       else {
                                         motion();
                                         humTemp();
                                      motion();
                                      humTemp();
                                    void motion() {
                                    void humTemp() {
                                        if (!metric) {
                                        lastHum = humidity;
                                    Now, my HA config:
                                    homeassistant:
                                      latitude: xxxxxxxx
                                      temperature_unit: C
                                    logbook:
                                    updater:
                                    discovery:
                                    # Track the sun
                                    sun:
                                    conversation:
                                    history:
                                    frontend:
                                    introduction:
                                    mysensors:
                                      gateways:
                                        - port: '/dev/MSgw'
                                      debug: true
                                      persistence: false
                                             - Getting help:
                                    You have to reboot your individual sensors so HA can see their Presentation message. Your output seems to be good for the gateway itself, but the gateway is not an actual "item" in HA, when it detects the sensors though, you should see their status.
                                    • delsD dels
                                      @BastienVH said:
                                      @martinhjelmare
                                      DHT dht;
                                      float lastTemp;
                                      float lastHum;
                                      int node_id = 20;
                                        /* int wake;
                                         if (wake == 1) {
                                           motion();
                                         else {
                                           motion();
                                           humTemp();
                                        motion();
                                        humTemp();
                                      void motion() {
                                      void humTemp() {
                                          if (!metric) {
                                          lastHum = humidity;
                                      Now, my HA config:
                                      homeassistant:
                                        latitude: xxxxxxxx
                                        temperature_unit: C
                                      logbook:
                                      updater:
                                      discovery:
                                      # Track the sun
                                      sun:
                                      conversation:
                                      history:
                                      frontend:
                                      introduction:
                                      mysensors:
                                        gateways:
                                          - port: '/dev/MSgw'
                                        debug: true
                                        persistence: false
                                               - Getting help:
                                      B Offline
                                      B Offline
                                      BastienVH
                                      It seems I did in fact forget to reboot my node when trying to include it in HA. (long day messing around with code...)
                                      Here is a console log from today in which I start up HA and reboot my node.
                                      HA receives the messages, but the node never shows up in the web interface:
                                      pi@raspberrypi ~ $ hass
                                               - Getting help:
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sun.sun, new_state=<state sun.sun=above_horizon; next_rising=07:28:30 26-01-2016, friendly_name=Sun, next_setting=16:19:22 25-01-2016, elevation=1.59 @ 08:45:51 25-01-2016>>
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, discovered=>
                                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, discovered=>
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.3
                                      INFO:homeassistant.components.mysensors:update sensor_update: node 20
                                      INFO:homeassistant.components.mysensors:No sketch_name: node 20
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-20-20 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=11,pt=0,l=19,sg=0:Humidity and mo
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=2,c=0,t=1,pt=0,l=0,sg=0:
                                      INFO:homeassistant.components.http:"GET /api/logbook/2016-1-25 HTTP/1.1" 200 -
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=1,t=1,pt=7,l=5,sg=0:51.0
                                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=2,c=1,t=16,pt=0,l=1,sg=0:1
                                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sun.sun, new_state=<state sun.sun=above_horizon; next_rising=07:28:30 26-01-2016, friendly_name=Sun, next_setting=16:19:22 25-01-2016, elevation=1.67 @ 08:45:51 25-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=07:28:30 26-01-2016, friendly_name=Sun, next_setting=16:19:22 25-01-2016, elevation=1.59 @ 08:45:51 25-01-2016>>
                                      ^CINFO:homeassistant.core:Stopping
                                      INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
                                      INFO:mysensors.mysensors:Disconnecting from /dev/MSgw
                                      INFO:mysensors.mysensors:Stopping thread
                                      INFO:homeassistant.components.recorder:Closing database
                                      This is the line when I start my node:
                                      Your thoughts?
                                      martinhjelmareM 2 Replies Last reply
                                      • B BastienVH
                                                 - Getting help:
                                        Your thoughts?
                                        martinhjelmare
                                        @BastienVH
                                        I can't see anything wrong in the log. You present properly and end by sending a value per sensor. The only thing is, there's no adding of the entity device in the log. Home assistant should report that in the log, when that happens: "adding new devices...".
                                        This is an internal message of type 15: I_REQUEST_SIGNING.
                                        This is a presentation message for node 20 of type 17: S_ARDUINO_NODE.
                                        First line is an internal message from node 20 to controller as request of type 6: I_CONFIG.
                                        The second line is an internal message from controller to node as response of type 6: I_CONFIG, payload:M for metric.
                                        This is an internal message of type 11: I_SKETCH_NAME.
                                        This is an internal message of type 12: I_SKETCH_VERSION.
                                        This is a presentation message for sensor 0 of type 7: S_HUM.
                                        Then you have presentation messages for sensor 1 of type 6 and for sensor 2 of type 1.
                                        See the API to figure those out:
                                        https://www.mysensors.org/download/serial_api_15
                                        The last three messages are reporting sensor values:
                                        This is a set message for sensor 1 of type 0: V_TEMP, payload: 22.0.
                                        The other two are set messages for sensor 0 of type 1 and sensor 2 of type 16.
                                        Maybe you can try everything again. Did you disable persistence? I think it's good to have it disabled, until you know everything is working, then you can activate persistence and do the presentation a final time. Remember to delete the persistence file if you have an old one, first though.
                                        Edit:
                                        There's a bug in home assistant version 0.11.1, which makes it impossible to load devices on the fly. A workaround is to enable persistence, present the sensors and send a value per sensor and then restart home assistant. After the restart the sensors should show up in the gui.
                                        • B BastienVH
                                                   - Getting help:
                                          Your thoughts?
                                          martinhjelmare
                                          @BastienVH
                                          We've been troubleshooting this in the other thread, and there seems to be a problem in the code somewhere. See this post for a workaround:
                                          http://forum.mysensors.org/topic/2831/home-assistant-v-0-11-1-with-switch-support/45
                                          Edit:
                                          The bug is found, and there will be a fix.
                                          11.9k
                                          113.3k
