  3. Home Assistant
  4. Error using Home Assistant with a serial gateway
21 Posts 3 Posters 11.0k Views 2 Watching
  • B BastienVH
    Hi Martin,
    @martinhjelmare
    I've been trying the last couple of days to get it working, but to no avail...
    I stell get errors like
    ValueError: need more than 1 value to unpack
    The number can change though.
    I've tried your suggestions, updated and rebooted the pi but still no luck.
    Uninstalled and reinstalled home assistant but that also didn't help.
    Any other things I could try?
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @BastienVH
    What version of pyserial do you have installed?
    For me version 2.5 has been the least buggy. Version 2.7 has a bug which was solved in version 3, but other bugs have emerged. I'm hoping they will be fixed soon.
    pip3 install pyserial==2.5
    Repeat this if you upgrade home assistant.
    Do you also only see the error on startup, or have you every successfully started up home assistant and loaded mysensors without errors, and later while running had this error?
    I'd like to try and make a workaround in the pymysensors api, but as I haven't really nailed down the bottom cause, all information will help me.
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Btw, I'm also working on a mysensors ethernet gateway for home assistant, but there is still some work and testing to be done.
      If you already have an ethernet module and like mqtt and don't mind having to do some configuring for every sensor/switch, mqtt is supported by home assistant in general. @Mihai has written a couple of guides both here and in the home assistant forum, for that.
      Soon I'm hoping you will have the option of choosing between all three gateway types when using home assistant, but of course we should try and make the serial connection more reliable.
      B 1 Reply Last reply
        B
        B
        BastienVH
        @martinhjelmare
        I was running pyserial 2.6, but have now installed version 2.5.
        I get the error, the moment I restart a sensor to have it included in HA.
        When I press the reset button on my sensor, the error shows up almost instantly in the terminal.
        So I guess that means that HA can connect to the serial gateway and receive messages, but just doesn't deal with it properly...
        Also: I had some trouble uninstalling the pyserial version and after some messing around, I now get this in my 'pip freeze'
        pyserial-py3k==2.5
        No mention of a 'normal' pyserial.
        Thanks for the help you've already provided!
        • B BastienVH
          @martinhjelmare
          pyserial-py3k==2.5
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @BastienVH
          Regarding py3k, that was a bug solved in 2.7:
          "[Bug pyserial:130] setup.py should not append py3k to package name"
          in https://github.com/pyserial/pyserial/blob/master/CHANGES.rst
          But that shouldn't affect the performance of 2.5, I think.
          If I understand correct, you do:
          hass
          wait for and get:
          n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
          Then you reset your sensor node, and get the error?
          Edit:
          In my experience, I don't think I get the gateway started confirmation before I get the error. You should make sure that the gateway is ready before you do the restart of the sensor node. I think the problem might be that the gateway tries to talk to homeassistant before homeassistant is ready, and only part of the message gets "translated".
            @BastienVH
            hass
            wait for and get:
            Edit:
            B
            B
            BastienVH
            @martinhjelmare
            I never got the "n:0 c:0 ...." message, only "Connected to /dev/MSgw".
            I found out there was an instance of FHEM running and occuping the GW.
            I stopped that and now it does give the "gateway started" message.
            Now the error occurs indeed before the gateway started message.
            Now I get the following after trying to let a node with DHT send its data to the gateway:
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 10-10-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
            INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 10-10-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.3
            INFO:homeassistant.components.mysensors:update sensor_update: node 10
            INFO:homeassistant.components.sensor.mysensors:Motion Sensor 10.1: value_type 16, value = 0
            Exception in thread Thread-15:
              File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
                self.run()
              File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 312, in run
                response = self.handle_queue()
              File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 222, in handle_queue
                reply = func(*args, **kwargs)
              File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 108, in logic
                self._handle_presentation(msg)
              File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 51, in _handle_presentation
                self.alert(msg.node_id)
              File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 175, in alert
                self.event_callback("sensor_update", nid)
              File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 226, in node_update
                callback(self, node_id)
              File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 149, in mysensors_callback
                entity.update_ha_state(True)
              File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 108, in update_ha_state
                self.unit_of_measurement is not None:
              File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/mysensors.py", line 137, in unit_of_measurement
                self.value_type == self.gateway.const.SetReq.V_PERCENTAGE or \
              File "/usr/lib/python3.4/enum.py", line 255, in __getattr__
                raise AttributeError(name) from None
            AttributeError: V_PERCENTAGE
            Is there a list with which kinds of sensors are supported in HA?
            Is motion/pir supported?
            • B BastienVH
              @martinhjelmare
                  self.run()
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @BastienVH
              Basically all pure sensors are supported. Not all actuator types, though.
              You can look at the source code for specifics. I want to add more documentation, but it's not done currently.
              Your log seems to concern a motion sensor, but you said DHT?
              You need to post the sensor sketch and all of the log from gateway started confirmation, to give me more background.
                @BastienVH
                B
                B
                BastienVH
                @martinhjelmare
                Yeah, I was also trying to get my motion sketch working, so that log message may have been something left over from that.
                This is everything in my terminal
                INFO:mysensors.mysensors:/dev/MSgw is open...
                INFO:mysensors.mysensors:Connected to /dev/MSgw
                INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
                INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 192.168.1.1
                INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 192.168.1.70
                INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.1.70:1972/DeviceDescription.xml
                Exception in thread Thread-6:
                    self.run()
                I hope you can find something there...
                • B BastienVH
                  @martinhjelmare
                      self.run()
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                    [[topic:post-is-deleted]]
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @BastienVH
                    I don't see a line in the log for presentation of the child sensor, or sketch name, or sketch version, but there already seem to be info loaded, sketch name and version and value type, looking at the line before the stack trace.
                    Is persistence disabled? Do you present the sensor in the sketch? Can you link to or post your sketch?
                    I think the problem might be that you're reusing an old node id with a different sensor type that's already been loaded via persistence.
                    I don't think I support these dynamics at the moment. I'll have to look more closely in the code, but if you can link your sketch, that will help me confirm this.
                    Solution would be to clear the persistence file.
                      @BastienVH
                      B
                      B
                      BastienVH
                      @martinhjelmare
                      Sorry, I was away from the computer for a little while.
                      I did reuse an old node id, that could have been the problem.
                      Assigned a new node ID and this is where I stand now:
                      Firts up: the node sketch:
                       * Version 1.0 - Henrik EKblad
                       * This sketch provides an example how to implement a humidity/temperature
                       * sensor using DHT11/DHT-22
                      #define DIGITAL_INPUT_MOTION 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                      #define INTERRUPT DIGITAL_INPUT_MOTION-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                      #define CHILD_ID_HUM 0
                      #define CHILD_ID_TEMP 1
                      #define CHILD_ID_MOT 2
                      unsigned long SLEEP_TIME = 15000; // Sleep time between reads (in milliseconds)
                      DHT dht;
                      float lastTemp;
                      float lastHum;
                      boolean metric = true;
                      MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
                      int node_id = 20;
                      boolean lastTripped = false ;
                        gw.begin(NULL, node_id);
                        gw.sendSketchInfo("Humidity and motion", "1.0");
                        pinMode(DIGITAL_INPUT_MOTION, INPUT);      // sets the motion sensor digital pin as input
                        gw.present(CHILD_ID_MOT, S_MOTION);
                        /* int wake;
                        wake = gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                         if (wake == 1) {
                           Serial.println("wake by motion");
                           Serial.println("reading motion");
                           motion();
                         else {
                           Serial.println("wake by timer");
                           motion();
                           Serial.println("reading temp/hum");
                           humTemp();
                        motion();
                        Serial.println("read temp / hum");
                        humTemp();
                        Serial.println("going to sleep now.");
                        gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME); //sleep a bit
                      void motion() {
                        // Read digital motion value
                        boolean tripped = digitalRead(DIGITAL_INPUT_MOTION);
                        Serial.println(tripped);
                        if (lastTripped != tripped) {
                          gw.send(msgMot.set(tripped ? "1" : "0")); // Send tripped value to gw
                          lastTripped = tripped;
                      void humTemp() {
                        gw.wait(dht.getMinimumSamplingPeriod());
                        if (isnan(temperature)) {
                          lastTemp = temperature;
                          if (!metric) {
                          Serial.print("T: ");
                        if (isnan(humidity)) {
                          lastHum = humidity;
                          Serial.print("H: ");
                          Serial.println(humidity);
                      Now, my HA config:
                      homeassistant:
                        # Name of the location where Home Assistant is running
                        # Location required to calculate the time the sun rises and sets
                        latitude: xxxxxxxx
                        longitude: xxxxxxxxxxxxxx
                        # C for Celcius, F for Fahrenheit
                        temperature_unit: C
                        # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
                        time_zone: Europe/Brussels
                      # View all events in a logbook
                      logbook:
                      # Checks for available updates
                      updater:
                      # Discover some devices automatically
                      discovery:
                      # Track the sun
                      sun:
                      # Allows you to issue voice commands from the frontend
                      conversation:
                      # Enables support for tracking state changes over time.
                      history:
                      # Enables the frontend
                      frontend:
                      # Show links to resources in log and frontend
                      introduction:
                      mysensors:
                        gateways:
                          - port: '/dev/MSgw'
                        debug: true
                        persistence: false
                      and the output when starting hass:
                      Config directory: /home/pi/.homeassistant
                      WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
                      INFO:homeassistant.bootstrap:Home Assistant core initialized
                      INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
                      INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
                      INFO:homeassistant.loader:Loaded http from homeassistant.components.http
                      INFO:homeassistant.loader:Loaded history from homeassistant.components.history
                      INFO:homeassistant.loader:Loaded introduction from homeassistant.components.introduction
                      INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
                      INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
                      INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
                      INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
                      INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
                      INFO:homeassistant.loader:Loaded api from homeassistant.components.api
                      INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
                      INFO:homeassistant.components.introduction:
                              Hello, and welcome to Home Assistant!
                              We'll hope that we can make all your dreams come true.
                              Here are some resources to get started:
                               - Configuring Home Assistant:
                                 https://home-assistant.io/getting-started/configuration/
                               - Available components:
                                 https://home-assistant.io/components/
                               - Troubleshooting your configuration:
                                 https://home-assistant.io/getting-started/troubleshooting-configuration/
                               - Getting help:
                                 https://home-assistant.io/help/
                              This message is generated by the introduction component. You can
                              disable it in configuration.yaml.
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=introduction>
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
                      INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
                      /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
                        warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
                      INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=mysensors.sensors>
                      INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
                      INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
                      INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=mysensors.switches>
                      INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
                      INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.1 @ 20:51:46 24-01-2016>, entity_id=sun.sun>
                      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
                      INFO:homeassistant.core:Starting Home Assistant (16 threads)
                      INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
                      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
                      INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
                      INFO:homeassistant.core:Timer:starting
                      INFO:mysensors.mysensors:Trying to connect to /dev/MSgw
                      INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                      INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
                      INFO:netdisco.service:Scanning
                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=1,t=1,pt=7,l=5,sg=0:54.0
                      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=1,t=1,pt=7,l=5,sg=0:53.0
                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.21 @ 20:51:46 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.1 @ 20:51:46 24-01-2016>>
                      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.36 @ 20:51:46 24-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=below_horizon; next_setting=16:19:22 25-01-2016, friendly_name=Sun, next_rising=07:29:47 25-01-2016, elevation=-33.21 @ 20:51:46 24-01-2016>>
                      INFO:homeassistant.components.http:"GET /states HTTP/1.1" 200 -
                      INFO:homeassistant.components.http:"GET /static/frontend-1003c31441ec44b3db84b49980f736a7.html HTTP/1.1" 200 -
                      INFO:homeassistant.components.http:"GET /static/favicon-192x192.png HTTP/1.1" 200 -
                      INFO:homeassistant.components.http:"GET /static/favicon.ico HTTP/1.1" 200 -
                      I don't get errors anymore, but nothing shows up in the web interface.
                      I think the messages aren't being interpreted?
                      delsD 1 Reply Last reply
                      • B BastienVH
                        @martinhjelmare
                        DHT dht;
                        float lastTemp;
                        float lastHum;
                        int node_id = 20;
                          /* int wake;
                           if (wake == 1) {
                             motion();
                           else {
                             motion();
                             humTemp();
                          motion();
                          humTemp();
                        void motion() {
                        void humTemp() {
                            if (!metric) {
                            lastHum = humidity;
                        Now, my HA config:
                        homeassistant:
                          latitude: xxxxxxxx
                          temperature_unit: C
                        logbook:
                        updater:
                        discovery:
                        # Track the sun
                        sun:
                        conversation:
                        history:
                        frontend:
                        introduction:
                        mysensors:
                          gateways:
                            - port: '/dev/MSgw'
                          debug: true
                          persistence: false
                                 - Getting help:
                        delsD
                        delsD
                        dels
                        @BastienVH said:
                        @martinhjelmare
                        DHT dht;
                        float lastTemp;
                        float lastHum;
                        int node_id = 20;
                          /* int wake;
                           if (wake == 1) {
                             motion();
                           else {
                             motion();
                             humTemp();
                          motion();
                          humTemp();
                        void motion() {
                        void humTemp() {
                            if (!metric) {
                            lastHum = humidity;
                        Now, my HA config:
                        homeassistant:
                          latitude: xxxxxxxx
                          temperature_unit: C
                        logbook:
                        updater:
                        discovery:
                        # Track the sun
                        sun:
                        conversation:
                        history:
                        frontend:
                        introduction:
                        mysensors:
                          gateways:
                            - port: '/dev/MSgw'
                          debug: true
                          persistence: false
                                 - Getting help:
                        You have to reboot your individual sensors so HA can see their Presentation message. Your output seems to be good for the gateway itself, but the gateway is not an actual "item" in HA, when it detects the sensors though, you should see their status.
                        • delsD dels
                          @BastienVH said:
                          @martinhjelmare
                          DHT dht;
                          float lastTemp;
                          float lastHum;
                          int node_id = 20;
                            /* int wake;
                             if (wake == 1) {
                               motion();
                             else {
                               motion();
                               humTemp();
                            motion();
                            humTemp();
                          void motion() {
                          void humTemp() {
                              if (!metric) {
                              lastHum = humidity;
                          Now, my HA config:
                          homeassistant:
                            latitude: xxxxxxxx
                            temperature_unit: C
                          logbook:
                          updater:
                          discovery:
                          # Track the sun
                          sun:
                          conversation:
                          history:
                          frontend:
                          introduction:
                          mysensors:
                            gateways:
                              - port: '/dev/MSgw'
                            debug: true
                            persistence: false
                                   - Getting help:
                          B
                          B
                          BastienVH
                          It seems I did in fact forget to reboot my node when trying to include it in HA. (long day messing around with code...)
                          Here is a console log from today in which I start up HA and reboot my node.
                          HA receives the messages, but the node never shows up in the web interface:
                          pi@raspberrypi ~ $ hass
                                   - Getting help:
                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sun.sun, new_state=<state sun.sun=above_horizon; next_rising=07:28:30 26-01-2016, friendly_name=Sun, next_setting=16:19:22 25-01-2016, elevation=1.59 @ 08:45:51 25-01-2016>>
                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, discovered=>
                          INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, discovered=>
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.3
                          INFO:homeassistant.components.mysensors:update sensor_update: node 20
                          INFO:homeassistant.components.mysensors:No sketch_name: node 20
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-20-20 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=11,pt=0,l=19,sg=0:Humidity and mo
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=2,c=0,t=1,pt=0,l=0,sg=0:
                          INFO:homeassistant.components.http:"GET /api/logbook/2016-1-25 HTTP/1.1" 200 -
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=0,c=1,t=1,pt=7,l=5,sg=0:51.0
                          INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 20-20-0 s=2,c=1,t=16,pt=0,l=1,sg=0:1
                          INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sun.sun, new_state=<state sun.sun=above_horizon; next_rising=07:28:30 26-01-2016, friendly_name=Sun, next_setting=16:19:22 25-01-2016, elevation=1.67 @ 08:45:51 25-01-2016>, old_state=<state sun.sun=above_horizon; next_rising=07:28:30 26-01-2016, friendly_name=Sun, next_setting=16:19:22 25-01-2016, elevation=1.59 @ 08:45:51 25-01-2016>>
                          ^CINFO:homeassistant.core:Stopping
                          INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
                          INFO:mysensors.mysensors:Disconnecting from /dev/MSgw
                          INFO:mysensors.mysensors:Stopping thread
                          INFO:homeassistant.components.recorder:Closing database
                          This is the line when I start my node:
                          Your thoughts?
                          martinhjelmareM 2 Replies Last reply
                          • B BastienVH
                                     - Getting help:
                            Your thoughts?
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @BastienVH
                            I can't see anything wrong in the log. You present properly and end by sending a value per sensor. The only thing is, there's no adding of the entity device in the log. Home assistant should report that in the log, when that happens: "adding new devices...".
                            This is an internal message of type 15: I_REQUEST_SIGNING.
                            This is a presentation message for node 20 of type 17: S_ARDUINO_NODE.
                            First line is an internal message from node 20 to controller as request of type 6: I_CONFIG.
                            The second line is an internal message from controller to node as response of type 6: I_CONFIG, payload:M for metric.
                            This is an internal message of type 11: I_SKETCH_NAME.
                            This is an internal message of type 12: I_SKETCH_VERSION.
                            This is a presentation message for sensor 0 of type 7: S_HUM.
                            Then you have presentation messages for sensor 1 of type 6 and for sensor 2 of type 1.
                            See the API to figure those out:
                            https://www.mysensors.org/download/serial_api_15
                            The last three messages are reporting sensor values:
                            This is a set message for sensor 1 of type 0: V_TEMP, payload: 22.0.
                            The other two are set messages for sensor 0 of type 1 and sensor 2 of type 16.
                            Maybe you can try everything again. Did you disable persistence? I think it's good to have it disabled, until you know everything is working, then you can activate persistence and do the presentation a final time. Remember to delete the persistence file if you have an old one, first though.
                            Edit:
                            There's a bug in home assistant version 0.11.1, which makes it impossible to load devices on the fly. A workaround is to enable persistence, present the sensors and send a value per sensor and then restart home assistant. After the restart the sensors should show up in the gui.
                            • B BastienVH
                                       - Getting help:
                              Your thoughts?
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @BastienVH
                              We've been troubleshooting this in the other thread, and there seems to be a problem in the code somewhere. See this post for a workaround:
                              http://forum.mysensors.org/topic/2831/home-assistant-v-0-11-1-with-switch-support/45
                              Edit:
                              The bug is found, and there will be a fix.
                                @BastienVH
                                Edit:
                                B
                                B
                                BastienVH
                                @martinhjelmare
                                Thanks for the heads up!
                                After following the steps there, I get my node up and running.
                                Thanks for the help!
